Subject: POVSolar/POVEarth: still problem with adjusting the day/night gradient
Date: 18 May 2012 19:10:02
Message: <4fb6d6ca@news.povray.org>
Hi(gh)!
Meanwhile, I almost got the boundary between day and night Earth texture
right (by rotating the gradient of the texture_map using vrotate) - but
still a portion of the night texture shows up on the opposite side of
the night hemisphere (see second attached image below).
Here is my code for the time being:
#declare sc=1; // scaling factor, should be 13347, i. e. 1 POV unit
equals 13,347 kilometres
#declare T_Earth_Night =
texture
pigment
image_map
png "solarsys/ev5826_land_ocean_ice_lights_8192.png"
map_type 1
interpolate 2
finish
ambient 0.5
diffuse 0
#declare T_Earth_Day =
texture
pigment
image_map
png "solarsys/ev11612_land_ocean_ice_8192_POV.png"
map_type 1
interpolate 2
finish { F_Standard_Planetary_Surface }
#macro SetAxis(dec, ras) // declination, right ascension (in degrees!)
of planet's celestial north pole relative to Earth's celestial north pole
rotate <bodies[3][4]-(90-dec), 0, 0>
rotate <0, 90-ras, 0>
union
sphere // Earth, surface
0, 1
texture
#declare grd=vrotate(z, -<bodies[3][4], 0, 0>);
gradient vrotate(grd, <0, orb_ang, 0>)
texture_map
[0.45 T_Earth_Day translate z*1 scale 0.5]
[0.45 T_Earth_Night translate z*1 scale 0.5]
scale 2
translate <0, 0, -1>
scale <bodies[3][1], bodies[3][3], bodies[3][2]>/sc
sphere // Earth, clouds
0, 1
texture
pigment
image_map
png "solarsys/cloud_combined_8192a_alpha.png"
map_type 1
interpolate 2
scale <bodies[3][1]+5, bodies[3][3]+4.983270985, bodies[3][2]+5>/sc
rotate -y*clock
SetAxis(bodies[3][10], bodies[3][11]) // 90, 90
translate Pos_Earth/sc
// end of code
Earth's position on its orbit (for the time being I use circular orbits)
is 0°, i. e. "north" of the Sun. The camera position in the first image
is 270° ("west" of Earth), in the second one 180° ("south" of Earth).
How do I get rid of the repetition of the gradient pattern?
See you in Khyberspace!
Yadgar
Download '2012-05-19 earth, take 78 - view from 45,000 kms.png' (124 KB)
Download '2012-05-19 earth, take 80 - view from 45,000 kms.png- view from 45,000 kms.png' (173 KB)
Preview of image '2012-05-19 earth, take 78 - view from 45,000 kms.png'
Preview of image '2012-05-19 earth, take 80 - view from 45,000 kms.png- view from 45,000 kms.png'
The problem is here:
> texture
> texture_map
> scale 2
You've got a gradient pointing in the direction of that vrotate vector, which
you scale by 2, then translate by -1 on the *z* axis. You want to translate it
in the same direction as the gradient.
If you want to be lazy you can remove that translate and just do "phase 0.5",
which will shift the gradient in the way you want. But personally I'd do it like
this:
pigment_pattern { // isolate transforms from the day/night maps
gradient z
scale 2 translate -z // offset to middle of gradient
rotate <-bodies[3][4], orb_ang, 0> // x rotation is applied before y
texture_map {
[0.45 T_Earth_Day]
[0.45 T_Earth_Night]
Subject: Re: POVSolar/POVEarth: still problem with adjusting the day/night gradient
Date: 22 May 2012 10:27:38
Message: <4fbba25a@news.povray.org>
Hi(gh)!
> texture {
> gradient z
> rotate<-bodies[3][4], orb_ang, 0> // x rotation is applied before y
> texture_map {
> [0.45 T_Earth_Day]
It did not work as expected - the repeated portion of the night side on
the daylight hemisphere disappeared, but, on the other hand, the
texture_map is no longer tilted according to Earth's axial tilt! See
below what I've got instead...
Yadgar
Download '2012-05-22 earth, take 82 - view from 45,000 kms.png- view from 45,000 kms.png' (119 KB)
Preview of image '2012-05-22 earth, take 82 - view from 45,000 kms.png- view from 45,000 kms.png'
Subject: Re: POVSolar/POVEarth: still problem with adjusting the day/nightgradient
Date: 22 May 2012 10:50:58
Message: <4fbba7d2@news.povray.org>
...and if I leave out the transformations inside the texture_map
brackets, it gets even worse (see attached images)!
Download '2012-05-22 earth, take 83 - view from 45,000 kms.png- view from 45,000 kms.png' (118 KB)
Download '2012-05-22 earth, take 84 - view from 45,000 kms.png- view from 45,000 kms.png' (167 KB)
Preview of image '2012-05-22 earth, take 83 - view from 45,000 kms.png- view from 45,000 kms.png'
Preview of image '2012-05-22 earth, take 84 - view from 45,000 kms.png- view from 45,000 kms.png'
Can you show me the code for that?
There's probably still a transform that needn't be there or something.
Date: 22 May 2012 12:26:29
Message: <4fbbbe35@news.povray.org>
O.k., here it is!
Download 'us-ascii' (99 KB)
> O.k., here it is!
The gradient isn't wrapped in pigment_pattern{}, so the rotation and scale
that's applied to the gradient is also applied to the textures in the
texture_map.
If you just copy the code from my earlier post it should work.
Date: 23 May 2012 09:19:43
Message: <4fbce3ef@news.povray.org>
> texture_map.
Not just copying, but also inserting the transformations you suggested
in your posting of May 21... oh, and I also found out that the rotation
around the y axis has to be applied *before* the compensation for the
axial tilt to make the day/night boundary following the illumination
correctly!
Here is my current code and some scenes I rendered:
union
0, 1
texture
pigment_pattern
gradient z
// transform gradient without affecting patterns in the texture_map
rotate <0, orb_ang, 0>
rotate <-bodies[3][4], 0, 0> // x rotation is applied before y
texture_map
[0.45 T_Earth_Day]
[0.48 T_Earth_Night]
0, 1
texture
pigment
image_map
map_type 1
interpolate 2
rotate -y*clock
// end of code
Yadgar
Download '2012-05-23 earth, take 86 - morning earth from 45,000 kms.png' (123 KB)
Download '2012-05-23 earth, take 92 - evening earth from 45,000 kms.png' (125 KB)
Download '2012-05-23 earth, take 111 - moscow from 4,000 kms, evening view.png' (570 KB)
Download '2012-05-23 earth, take 128 - north pole from 20,000 kms, daylight view.png' (410 KB)
Preview of image '2012-05-23 earth, take 86 - morning earth from 45,000 kms.png'
Preview of image '2012-05-23 earth, take 92 - evening earth from 45,000 kms.png'
Preview of image '2012-05-23 earth, take 111 - moscow from 4,000 kms, evening view.png'
Preview of image '2012-05-23 earth, take 128 - north pole from 20,000 kms, daylight view.png'
