POV-Ray : Newsgroups : povray.binaries.images : Lucy in the Sky (no diamonds) Server Time
11 Oct 2026 08:39:22 EDT (-0400)
  Lucy in the Sky (no diamonds) (Message 1 to 23 of 23)
Subject: Lucy in the Sky (no diamonds)
Date: 5 Mar 2012 18:26:49
Message: <4f554bb9@news.povray.org>
Another Lucy render. SSLT, focal blur, radiosity, and an illuminated
torch. Render time ~50 minutes.
Download 'stanford_lucy 2012-03-06 0023.png' (732 KB)
Preview of image 'stanford_lucy 2012-03-06 0023.png'
Subject: Re: Lucy in the Sky (no diamonds)
Date: 5 Mar 2012 18:38:11
Message: <4f554e63$1@news.povray.org>
Am 06.03.2012 00:26, schrieb clipka:
Just for comparison: Same scene, just with the SSLT turned off. ~7 minutes.
Date: 5 Mar 2012 18:50:45
Message: <4f555155@news.povray.org>
Am 06.03.2012 00:38, schrieb clipka:
... and I /did/ intend to attach the render output.
Download 'stanford_lucy 2012-03-06 0035.png' (601 KB)
Preview of image 'stanford_lucy 2012-03-06 0035.png'
Date: 6 Mar 2012 02:58:41
Message: <4f55c3b1$1@news.povray.org>
Well that showed me. ;-)
What settings did you use?
Regards
Date: 6 Mar 2012 11:45:22
Message: <4f563f22$1@news.povray.org>
Am 06.03.2012 08:58, schrieb Stephen:
That was my initial intention... until I found out that she's a real
beauty indeed, and worth spending some time with her on my own accord :-)
#declare MtMarble = material {
       marble
       warp { turbulence 1.0 }
       color_map {
         [0.0 color rgb <0.5,0.7,0.5>]
         [1.0 color rgb <0.5,1.0,0.5>]
     finish {
       diffuse albedo 0.7
       subsurface { translucency <0.5,0.2,0.2> }
       reflection { 0.2 fresnel }
       specular albedo 0.2 roughness 0.01
       conserve_energy
     scale 10 / MM_PER_UNIT
   interior { ior 1.5 }
(with Lucy being about 1.5 units in height, and MM_PER_UNIT being set to
100, so that she's roughly 150 mm)
Date: 6 Mar 2012 11:55:31
Message: <4f564183@news.povray.org>
Just spent a night with her. Oh boy, what a lady - it was totally worth
the 8 hours!
Download 'stanford_lucy 2012-03-06 1024.png' (409 KB)
Preview of image 'stanford_lucy 2012-03-06 1024.png'
Date: 6 Mar 2012 12:16:44
Message: <4f56467c$1@news.povray.org>
I like this one better than the (however beautiful) icy one.
Paolo
Date: 6 Mar 2012 13:20:17
Message: <4f565561$1@news.povray.org>
cool!
although she doesn't seem completely thawed yet ;)
Is the bright pixel noise in dark areas an SSLT artefact?
Date: 6 Mar 2012 14:01:49
Message: <4f565f1d$1@news.povray.org>
Am 06.03.2012 19:19, schrieb Christian Froeschlin:
Yup. I'm already running another render with higher-quality settings
(and desktop-size resolution).
Date: 6 Mar 2012 19:45:00
Message: <web.4f56aeaba0bb4ec894d713cc0@news.povray.org>
Fantastic!
www.McGregorFineArt.com
Date: 7 Mar 2012 02:51:58
Message: <4f57139e$1@news.povray.org>
> the 8 hours!
Very impressive! I shall have to use SSLT one day for sure ;-)
Date: 7 Mar 2012 06:09:56
Message: <4f574204$1@news.povray.org>
Good it worked. ;-)
She is worth spending time with.
This is the bit that I don't understand.
Why did you pick these values? I don't understand why you made the red
value larger than the others.
Thanks
Regards
Date: 7 Mar 2012 06:39:01
Message: <4f5748d5@news.povray.org>
Am 07.03.2012 12:09, schrieb Stephen:
As for the general scale of the translucency parameter, I toyed around
with it until I found a setting that seemed to convey the right sense of
scale and material to me. It was just a matter of "this looks to solid"
vs. "this looks too waxy".
As for the red component, I decided that I wanted thin portions of the
material to have a somewhat reddish tint, despite of the overall
greenish appearance. To achieve this, red light needs to travel further
inside the material than other colors.
Date: 7 Mar 2012 12:17:00
Message: <4f57980c$1@news.povray.org>
Thanks, again.
So it seems that James Holsenback was telling the truth. It is a case of
suck it and see.
Regards
Date: 7 Mar 2012 14:20:13
Message: <4f57b4ed$1@news.povray.org>
On 03/07/2012 12:16 PM, Stephen wrote:
> It is a case of suck it and see.
LOL ... yes there is a treat in the center if you suck long enough ;-)
Date: 7 Mar 2012 14:36:58
Message: <4f57b8da$1@news.povray.org>
Hmm! Sherbet. :-D
I found my problem, well one of them anyway. ;-)
With RC3 I was using a texture map material and each texture had its own
subsurface {}. That does not work well with RC4.
Regards
Date: 7 Mar 2012 17:24:04
Message: <4f57e004@news.povray.org>
Am 06.03.2012 20:01, schrieb clipka:
And here she is. Originally rendered at 3840x2400 pixels. Render time
was less than 7 hours.
Don't expect to get the same quality at the same speed with official 3.7
though: I needed to code a totally new anti-aliasing mode for this, and
it won't make it into the release. It'll make a good base for a
stochastic rendering spin-off of POV-Ray 3.7 though, so stay tuned.
Download 'stanford_lucy 2012-03-07 2235 1920x1200.png' (490 KB)
Preview of image 'stanford_lucy 2012-03-07 2235 1920x1200.png'
Date: 7 Mar 2012 17:40:21
Message: <4f57e3d5$1@news.povray.org>
Am 07.03.2012 23:23, schrieb clipka:
A close-up of the original. As you can see there is still some pixel
noise, but the noise level is much more uniform across the whole image,
making it far less distracting.
Date: 7 Mar 2012 17:41:35
Message: <4f57e41f@news.povray.org>
Am 07.03.2012 23:40, schrieb clipka:
... forgot the attachment again.
Download 'stanford_lucy 2012-03-07 2235 detail.png' (1310 KB)
Preview of image 'stanford_lucy 2012-03-07 2235 detail.png'
Date: 7 Mar 2012 17:42:12
Message: <4f57e444$1@news.povray.org>
On 07/03/2012 10:23 PM, clipka wrote:
> And here she is.
The lighting makes it.
Regards
Date: 7 Mar 2012 18:37:14
Message: <4f57f12a@news.povray.org>
Guess what - I managed to get hold of a tin miniature of her!
Unfortunately, the autofocus doesn't seem to play well with the macro lens.
Download 'stanford_lucy 2012-03-08 0034.png' (1610 KB)
Preview of image 'stanford_lucy 2012-03-08 0034.png'
Date: 7 Mar 2012 18:56:15
Message: <4f57f59f$1@news.povray.org>
Le 08/03/2012 00:36, clipka nous fit lire :
Yummy... but you're given away by the 3.7... (hint, no exif, and png has
more to says about what you did at 23:34:30Z on the 7th march)
Date: 7 Mar 2012 19:44:26
Message: <4f5800ea$1@news.povray.org>
Am 07.03.2012 23:42, schrieb Stephen:
>> And here she is.
Ain't that right?
I /love/ toying around with light & shadow.
