![](/i/fill.gif) |
Hi(gh)!
Still fiddling with the include files exhibition room at Port
Whatmough's PoV-Ray museum... I want to have the glass lid of the
exhibition table to include a text display which glows in its own light
(and is also glowing when used together with radiosity, so ambient 1 is
no option). I tried emissive media, but found out that it fades to
invisibility against a white background.
Simply increasing the red component gives weird results... attached here
are four attempts:
1. rgbft <1, 0, 0, 0.5, 0.5>, ambient 1
2. rgbft <10, 0, 0, 0.5, 0.5>, default ambient
3. rgbft <10, 0, 0, 0, 0.5> default ambient
4. rgbft <10, 0, 0, 0.5, 0> default ambient
What did I misunderstand?
See you in Khyberspace!
Yadgar
Download '20111219a_pwres.jpg' (51 KB)
Download '20120127a_pwres.jpg' (64 KB)
Download '20120127b_pwres.jpg' (51 KB)
Download '20120127c_pwres.jpg' (67 KB)
Preview of image '20111219a_pwres.jpg'
![20111219a_pwres.jpg](/povray.binaries.images/attachment/%3C4f2315be%40news.povray.org%3E/20111219a_pwres.jpg?preview=1)
Preview of image '20120127a_pwres.jpg'
![20120127a_pwres.jpg](/povray.binaries.images/attachment/%3C4f2315be%40news.povray.org%3E/20120127a_pwres.jpg?preview=1)
Preview of image '20120127b_pwres.jpg'
![20120127b_pwres.jpg](/povray.binaries.images/attachment/%3C4f2315be%40news.povray.org%3E/20120127b_pwres.jpg?preview=1)
Preview of image '20120127c_pwres.jpg'
![20120127c_pwres.jpg](/povray.binaries.images/attachment/%3C4f2315be%40news.povray.org%3E/20120127c_pwres.jpg?preview=1)
![](/i/fill.gif) |
![](/i/fill.gif) |
> no option).
Are you using POV-Ray 3.6 or 3.7?
If 3.6, then you can set #default { finish { ambient 0 } } in general, and set
ambient as high as you like in the finish{} of individual glowing objects.
If 3.7, have you tried finish { emission 1 }?
![](/i/fill.gif) |
![](/i/fill.gif) |
> ambient 1 is no option
if you mean ambient is set to 0 when rendering with 3.7 RC3:
-> emission 1 should work with radiosity
if you heard ambient should not be used in textures
when using radiosity in 3.6:
-> if the object is actually intended to be glowing, this is
perfectly fine, it emits light and radiosity will consider it
appropriately.
> I tried emissive media, but found out that it fades to invisibility
If your background is fully white it means it emits the maximum
amount of light that can be recognized by the eye or camera viewing
the scene. It will be impossible to see a glow in front of it. Any
text displayed before this background will be visible because it
is darker / absorbing. Considering this may help you to figure
out what end result you are actually aiming at.
I don't fully understand this either but if your filter
value times the color value exceeds 1.0 some weirdness is
to be expected (however, if this physically unrealistic
value is allowed, I'd have expected it to amplify red
light passing through it, which should never result in
a white background turning blueish).
![](/i/fill.gif) |
