Some soap bubbles, rendered with a complete re-design of the iridescence
feature.
Download 'test.png' (335 KB)
Preview of image 'test.png'
... and two pearls.
Download 'test.png' (139 KB)
A bearing ball with a thin coat of I-have-no-idea-what.
Download 'test.png' (187 KB)
> feature.
Oh! Very nice! Will this fix make it into 3.7?
> feature.
Excellent! A little treat for Jim's shells... ;-)
Am 01.12.2011 07:39, schrieb waggy:
>> feature.
I think so. It will break scenes relying on the crappy(*) existing
iridescence, so it's better to introduce it with the transition from 3.6
to 3.7, rather than 3.7.0 to 3.7.1 or something.
(*For starters, the existing implementation doesn't respect a light
source's color, or even brightness for that matter.)
Am 01.12.2011 04:23, schrieb clipka:
> .... and two pearls.
now with blurred reflection.
Download 'test.png' (201 KB)
Am 01.12.2011 09:23, schrieb Thomas de Groot:
>> feature.
Yup.
> feature.
Outstanding ... I'll keep an eye on revision control. I'm anxious to get
it a test drive. Since, it would seem, that my sea shell attempt at
using iridescence is what inspired you to dig into this, I have a
question about the aoi pattern that was mentioned as an alternative ...
you wouldn't expect it (aoi) to respond to other pattern modifiers
correct, as it doesn't appear to. However when I read the doc passage,
"It gives a value proportional to the angle between the ray and the
surface" it makes me think that's correct behavior. If this is true
enough, perhaps I should make a slight addition to that passage to clarify.
Jim
>> feature.
> Thomas
don't you just love good news first thing in the morning!
Am 01.12.2011 14:37, schrieb Jim Holsenback:
>> feature.
> it a test drive.
You are clear for take-off.
The description in the docs is correct. The mechanism is actually pretty
similar to the slope pattern, except that the reference direction is not
a constant "up" direction, but the direction of the light ray to the
observer.
As the surface normal is only well-defined at the object's surface, you
can't do stuff such as scaling, translating or rotating the pattern, or
perturbing it (as that is essentially a non-uniform translation of the
pattern).
You can perturb the surface normal though, which affects the aoi pattern.
clipka escreveu:
awesome!
how about some slight SSS, now? ;)
a game sig: http://tinyurl.com/d3rxz9
Am 01.12.2011 16:50, schrieb nemesis:
Unfortunately, SSLT doesn't play nice with iridescence yet.
>>> feature.
I don't think that it will realy break those scenes.
Yes! They will render diferently, but the new result probably won't be
bad. In fact, I won't be surpirsed if the result using your corrected
code gets beter.
