POV-Ray : Newsgroups : povray.binaries.images : Proximity pattern, experimental builtin Server Time
29 Nov 2026 00:52:39 EST (-0500)
  Proximity pattern, experimental builtin (Message 1 to 9 of 9)
Subject: Proximity pattern, experimental builtin
Date: 24 Jul 2011 06:25:56
Message: <4e2bf334@news.povray.org>
Based on the sample scene of DF3 Proximity Macro 0.9
(radiosity=true)
Parser Time
  Parse Time:       0 hours  0 minutes  0 seconds (0.002 seconds)
              using 1 thread(s) with 0.002 CPU-seconds total
  Bounding Time:    0 hours  0 minutes  0 seconds (0.000 seconds)
              using 1 thread(s) with 0.000 CPU-seconds total
Render Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Antialiasing.........On  (Method 1, Threshold 0.100, Depth 3, Jitter 1.00,
 Gamma 2.50)
==== [Rendering...] ========================================================
Render Statistics
Image Resolution 1025 x 1025
Pixels:          1171569   Samples:         1952865   Smpls/Pxl: 1.67
Rays:           15268941   Saved:           3499267   Max Level: 10/200
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                            6314506         1291506     20.45
Fractal                       13468771         7148980     53.08
Plane                         13041069         7906708     60.63
Sphere                          234859          138332     58.90
Bounding Box                 129474454        49881145     38.53
Shadow Ray Tests:           1271395   Succeeded:                     0
Reflected Rays:             9068827
Radiosity samples calculated:            47974 (0.40 %)
  discarded due to low quality:           3688
  retained for re-use:                   44286
Radiosity samples reused:             12040620
Radiosity sample rays shot:            3075680
Radiosity octree nodes:                   4139
Radiosity octree samples/node:           11.59
Radiosity blocks examined:         13979582508
Radiosity blocks passed test 0:    13979582508 (100.00 %)
Radiosity blocks passed test 1:     4395736697 (31.44 %)
Radiosity blocks passed test 2:     3201568901 (22.90 %)
Radiosity blocks passed test 3:      455746080 (3.26 %)
Radiosity blocks passed test 4:      224958056 (1.61 %)
Radiosity blocks passed test 5:      216499681 (1.55 %)
Radiosity blocks rejected:         13763082827 (98.45 %)
Radiosity Depth 0 calculated:            28918 (0.42 %)
Radiosity Depth 0 reused:              6776209
Radiosity Depth 0 rays shot:           2313440
Radiosity (final) calculated:             7315 (0.08 %)
Radiosity (final) reused:              9004020
Radiosity (final) rays shot:            584320
  Pass     Depth 0    Depth 1           Total
  1            239       3275            3514
  2            634       3859            4493
  3           1947       4642            6589
  4           5513       3847            9360
  5+         13292       3411           16703
  Final       7293         22            7315
  Total      28918      19056           47974
  Weight     0.227      0.095
Render Time:
  Photon Time:      No photons
  Radiosity Time:   0 hours  0 minutes 45 seconds (45.715 seconds)
              using 12 thread(s) with 519.848 CPU-seconds total
  Trace Time:       0 hours  2 minutes  7 seconds (127.362 seconds)
              using 12 thread(s) with 1455.857 CPU-seconds total
POV-Ray finished
Download 'proximity_test.jpg' (167 KB)
Preview of image 'proximity_test.jpg'
Subject: Re: Proximity pattern, experimental builtin
Date: 24 Jul 2011 07:22:24
Message: <4e2c0070$1@news.povray.org>
nice ... i like the right mid-ground one
Date: 25 Jul 2011 08:20:39
Message: <4e2d5f97$1@news.povray.org>
Could you explain what's happening here, because I can't see what's so
special about the image.
Date: 25 Jul 2011 10:45:07
Message: <4e2d8173$1@news.povray.org>
Le 25/07/2011 14:20, Warp nous fit lire :
Just that no DF3 file was used.
#macro zorglub(bron,vect,rad)
object {
        test_object
		proximity { test_object } radius rad
		texture_map {
#if( bron = true )
			[ 0.45 shiny_brass ]
			[ 0.55 dull_brass ]
			[ 0.65 dull_brass ]
			[ 0.7 corroded_brass]
#else
			[ 0.0 pigment { rgb <0,169,224>/255 } ]
			[ 0.2 pigment { rgb <50,52,144>/255 } ]
			[ 0.4 pigment { rgb <234,22,136>/255 } ]
			[ 0.6 pigment { rgb <235,46,46>/255 } ]
			[ 0.8 pigment { rgb <253,233,45>/255 } ]
			[ 1.0 pigment { rgb <0,158,84>/255 } ]
	translate vect
zorglub(true,0,20)
zorglub(false,200*x+600*z,20)
zorglub(true,-200*x+600*z,1)
zorglub(false,100*x+1100*z,1)
zorglub(false,-100*x+1100*z,10)
Date: 25 Jul 2011 19:14:39
Message: <4e2df8df$1@news.povray.org>
Nice! How would it look with a black/white color_map and ambient 1?
Date: 26 Jul 2011 03:58:18
Message: <4e2e739a@news.povray.org>
Le 26/07/2011 01:14, Christian Froeschlin nous fit lire :
Removing radiosity, single light source instead (irrelevant but for the
shadow on floor), diffuse 0 ambient 1
texture_map {
[ clock  pigment { rgb 0 } finish { ambient 1.0 diffuse 0.0 } ]
[ 1.0-clock  pigment { rgb 1 }  finish { ambient 1.0 diffuse 0.0 }]
 povray Fro.pov +KI0 +KF0.4 +KFI1 +KFF3 +FJ
The value 0 & 1 of the map are very seldom reached, so reducing the
range is also interesting.
Download 'fro1.jpg' (92 KB) Download 'fro2.jpg' (104 KB) Download 'fro3.jpg' (121 KB)
Preview of image 'fro1.jpg'
Preview of image 'fro2.jpg'
Preview of image 'fro3.jpg'
Date: 26 Jul 2011 04:00:52
Message: <4e2e7434$1@news.povray.org>
Le 26/07/2011 09:58, Le_Forgeron nous fit lire :
> texture_map {
The original object has a size of 60. The 3 objects were using proximity
with a radius of 1, 10 and 20. (from left to right)
Date: 30 Jul 2011 20:50:05
Message: <4e34a6bd@news.povray.org>
Very good. Looking forward to playing with this ;)
Date: 31 Jul 2011 02:57:47
Message: <4e34fceb$1@news.povray.org>
It looks like your technique is going to be much simpler to use than the
Proximity Macro which, by the way, was already a major and important
achievement gladly acknowledged, thanks to Edouard Poor.
