POV-Ray : Newsgroups : povray.binaries.images : SSLT Dragon Server Time
11 Oct 2026 14:34:13 EDT (-0400)
  SSLT Dragon (Message 1 to 50 of 105)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: SSLT Dragon
Date: 22 Feb 2011 14:50:49
Message: <4d641399@news.povray.org>
With a bit of a back light.
I think I'll wait until the next RC before continuing.
Regards
Download 'dragon_01_c4b_.jpg' (73 KB)
Preview of image 'dragon_01_c4b_.jpg'
Subject: Re: SSLT Dragon
Date: 22 Feb 2011 17:05:02
Message: <4d64330e@news.povray.org>
cool subject choice ... i forget the artist but a dragon image was what
brought me to povray. hey where you been coming up with the cool test
objects ... bishop?
Date: 22 Feb 2011 17:41:21
Message: <4d643b91@news.povray.org>
Thanks :-D
> objects ... bishop?
No, I do the scene setting, CSG and rendering from B3D. The mesh models
I generally make in Poser. This dragon is from "The Stanford 3D Scanning
Repository". I downloaded Lucy but could not get it converted to a
format I could use.
Regards
Date: 24 Feb 2011 03:05:37
Message: <4d661151$1@news.povray.org>
"Stephen" <mcavoys_at@aoldotcom> schreef in bericht
news:4d643b91@news.povray.org...
> No, I do the scene setting, CSG and rendering from B3D. The mesh models I
> Repository". I downloaded Lucy but could not get it converted to a format
> I could use.
I had the same problem with Lucy, using MeshLab. Somehow I could not get it
converted.
Date: 24 Feb 2011 04:35:01
Message: <web.4d662519d81bd80d6dd25f0b0@news.povray.org>
> > I could use.
> converted.
What seemed to be the issue? I also converted Lucy (I think with Meshlab +
Poseray) a couple of years ago and had no problems. I did lower the triangle
count a bit, since the file size was vast and I knew most of it would be
sub-pixel in the scene I was making...
Date: 24 Feb 2011 06:16:31
Message: <4d663e0f@news.povray.org>
>> >  converted.
MeshLab fails with an error message saying that the application has
requested the Runtime to terminate in an unusual way.
PoseRay might do it. But slowly, slowly!
After about 10 minutes loading the PLY file the % completed bar is at
about 2%.
Regards
Date: 25 Feb 2011 03:07:13
Message: <4d676331$1@news.povray.org>
news:4d663e0f@news.povray.org...
> about 2%.
Same for me.
Date: 25 Feb 2011 03:59:09
Message: <4d676f5d$1@news.povray.org>
>> >  about 2%.
> Same for me.
I gave up after 21 hours and about 20% ~ 25% done
Regards
Date: 25 Feb 2011 04:15:00
Message: <web.4d677237d81bd80d6dd25f0b0@news.povray.org>
> >> >  about 2%.
> > Same for me.
I'll try again next time I'm in front of it... failing that, I might still have
the converted .inc file, if it's still useful?
Date: 25 Feb 2011 04:25:33
Message: <4d67758d$1@news.povray.org>
That would be great, Bill.
Regards
Date: 27 Feb 2011 03:18:16
Message: <4d6a08c8@news.povray.org>
news:web.4d677237d81bd80d6dd25f0b0@news.povray.org...
> have
Yes, Bill, that would be fine indeed.
Date: 27 Feb 2011 18:30:00
Message: <web.4d6ade48d81bd80da7b682960@news.povray.org>
http://www.infradead.org/~wmp/lucy.inc.zip
It's about 60mb. One mesh2, #declared as 'lucy'. Enjoy!
Date: 28 Feb 2011 03:17:23
Message: <4d6b5a13@news.povray.org>
news:web.4d6ade48d81bd80da7b682960@news.povray.org...
Thank you indeed, Bill!
Date: 28 Feb 2011 04:05:31
Message: <4d6b655b@news.povray.org>
Thanks Bill, quick to download too. :-D
Regards
Date: 1 Mar 2011 05:00:01
Message: <web.4d6cc33fd81bd80dc4633eb90@news.povray.org>
> >> >  converted.
> about 2%.
I thought I'd give this a go - I grabbed the PLY file of Lucy and wrote a few
lines of Smalltalk to convert into a mesh2 file - took about 30 minutes. Flat
polygons, but, as Bill said, they're probably going to be sub-pixel anyway.
But. But... The resulting file (with 5 decimal places of accuracy) is 1.2GB in
size, and when I tried to render it on my 4GB MacBook Pro, POV took about 3.8GB
of Virtual Memory, which nowhere near fitted into the 2.3GB of free RAM I had
after the OS and file buffers took their slices. I left it trying to parse the
file for about 50 minutes then just gave up.
I might give it a go on an AWS EC2 cloud instance - it's US$0.68 per hour for a
8 CPU/7G RAM/64 Bit machine. But I've still got to get a 1.2GB file onto it!
I'm *not* going to give anyone the file, but you welcome to take the code and
run it yourself in Pharo 1.2 (a Smalltalk development environment). You *will*
need a 6GB, 8GB or greater machine to use the mesh2 though!
Cheers,
Edouard.
Date: 1 Mar 2011 07:05:34
Message: <4d6ce10e@news.povray.org>
What might be of help, if you can do it, is to simplify the model. Using
a trial version of 3DS Max I reduced the vertex count to 20% of the
original (28 Meg, 9 Meg zipped)
Regards
Download 'lucy20_01b_1.jpg' (156 KB)
Preview of image 'lucy20_01b_1.jpg'
Date: 1 Mar 2011 08:59:30
Message: <4d6cfbc2$1@news.povray.org>
sweet ... excellent material!
Date: 1 Mar 2011 11:53:53
Message: <4d6d24a1$1@news.povray.org>
Thanks but it is the bog standard marble. It is backlit and that makes a
difference. :-)
I think I'll try Lucy with the material map I used for the Buddha.
Regards
Date: 1 Mar 2011 18:37:32
Message: <4d6d833c@news.povray.org>
> difference. :-)
And here it is. I've created another simplified mesh using 10% of the
vertexes (14 Meg zipped to 5 Meg). It messes up my big idea of
mm_per_unit though.
I don't mind sharing it even though 3DS Max says the mesh is a rats nest.
Regards
Download 'lucy10_01_.jpg' (191 KB)
Preview of image 'lucy10_01_.jpg'
Date: 1 Mar 2011 19:00:01
Message: <web.4d6d8811d81bd80da7b682960@news.povray.org>
> mm_per_unit though.
Here's my little attempt. Rendered in 10mins, without aa though. One thing I've
noticed is that I get a large number of bright single-pixel artifacts unless I
use large sample counts (using 1000,100 here), even when also using aa. Is there
any way to avoid this, or is it just the nature of the beast?
Bill
Download 'sublucy.jpg' (36 KB)
Preview of image 'sublucy.jpg'
Date: 1 Mar 2011 19:09:25
Message: <4d6d8ab5$1@news.povray.org>
Am 01.03.2011 13:05, schrieb Stephen:
Very beautiful texture!
Date: 1 Mar 2011 19:14:51
Message: <4d6d8bfb$1@news.povray.org>
Nice but use aa it makes a difference. My samples are only 100, 50. Back
lighting makes a difference as well.
I used mm_per_unit = 1.105 for the first one and 28.6 for the green one.
It took well over an hour.
Your image looks more like marble what settings did you you use?
Regards
Date: 1 Mar 2011 19:18:25
Message: <4d6d8cd1@news.povray.org>
Thanks but as I said to Jim it is the marble from the paper.
I like the jade one posted later better.
I'm going to run some more test renders overnight.
Regards
Date: 1 Mar 2011 19:28:08
Message: <4d6d8f18@news.povray.org>
I lied, I've just noticed that they are 500, 250
Regards
Date: 2 Mar 2011 04:20:01
Message: <web.4d6e0b8ad81bd80d6dd25f0b0@news.povray.org>
But does it? I thought aa was wasted on otherwise supersampled features like
area lights, focal blur, media etc? The edges of lucy's self-shadows are lovely,
it's just the floor shadow and her horizon that show aliasing. I'll do some aa
tests tonight.
Excellent, I was shooting for a very translucent marble.
mm_per_unit = 80 (the model is about 1 unit high)
samples 1000, 100 (only way I could get rid of bright point artifacts)
subsurface { 5*colour, 0.5*(1-colour) } (IIRC!)
Bill
Date: 2 Mar 2011 06:16:50
Message: <4d6e2722$1@news.povray.org>
> tests tonight.
I did a test without aa and there are more artefacts in the non-aa
rendering.
So your model is about 80 mm (3 inches) why pick that value?
This is something I'm having difficulty getting my head around. :-(
Regards
Date: 2 Mar 2011 07:00:00
Message: <web.4d6e3131d81bd80d6dd25f0b0@news.povray.org>
> rendering.
I see what you mean. The artifacts were definitely lessened by aa, but they were
lessened much more by increasing the sampling :)
Well, I was basically just tweaking until it looked good. I don't really
understand what the subsurface:mm_per_unit ratio means, although the
scattering:absorption ratio of the subsurface values seems more intuitive (not
dissimilar to media).
I think the mm_per_unit value kind of makes sense - most everyday experience
with translucent stone objects is small statues/knick-knacks. For larger items
(metres and larger), I would expect the translucency to be much more subtle, or
even invisible, due to the greater path lengths.
I think word-of-god elucidation is required :)
Date: 2 Mar 2011 08:22:37
Message: <4d6e449d$1@news.povray.org>
>> rendering.
OK, that saves me some experimenting.
I agree that the subsurface values seems more intuitive.
I think that I'll wait until RC4, where the syntax will change, before
playing any more.
Regards
Date: 2 Mar 2011 12:40:29
Message: <4d6e810d@news.povray.org>
> mm_per_unit = 80
Using your setting of mm_per_unit  80 and subsurface {samples 500, 100 }
I think that this one turns out nice. It took five and a half hours to
render but I was only using 4 threads. (I’m getting to be an old feartie
after my laptop overheated)
Regards
Download 'lucy10_01c_.jpg' (183 KB)
Preview of image 'lucy10_01c_.jpg'
Date: 2 Mar 2011 12:50:07
Message: <4d6e834f$1@news.povray.org>
>> mm_per_unit = 80
I thought you were gonna wait for RC4
Now go have a cup of tea and let the ole laptop cool down for a bit ;-)
Date: 2 Mar 2011 12:51:57
Message: <4d6e83bd@news.povray.org>
> Now go have a cup of tea and let the ole laptop cool down for a bit;-)
LOL
It was already rendering when I wrote that.
A cup of tea sounds good though.
Regards
Date: 2 Mar 2011 14:40:01
Message: <web.4d6e9cddd81bd80d86ff1d480@news.povray.org>
> >> >  converted.
> about 2%.
> Regards
>      Stephen
Wow, I'm having deja vu; I converted Lucy with MeshLab and rendered a few SSLT
versions right after the feature first appeared about a year and half ago:
http://news.povray.org/web.4a9f2cce63e55f164726e92b0@news.povray.org
And uploaded the inc file to my web site, the link is here:
http://news.povray.org/web.4aa18ba663e55f164726e92b0@news.povray.org
I'm going to have to try that dragon now though...
Cheers,
Rob
www.McGregorFineArt.com
Date: 2 Mar 2011 15:20:00
Message: <web.4d6ea60ad81bd80da7b682960@news.povray.org>
> LOL
You could boil the water on your cpu heatsink ;-)
Date: 2 Mar 2011 16:19:35
Message: <4d6eb467$1@news.povray.org>
OK what am I doing wrong? I've used mesh objects before so I'm not
blazing any new territory here. I see the parse (tokens) of the object
then the render ... get an empty scene except my ground plane and light
source (zoomed way back looked u/d ... scaled too) don't see nuttin' ...
I should be able to (after including the Lucy file I downloaded from
your site and do:
object { Lucy_Statue pigment {rgb 1}}
btw stats just show 2 objects (plane and light_source)
shucks ... I wanted to play too ;-)
Date: 2 Mar 2011 17:16:12
Message: <4d6ec1ac$1@news.povray.org>
On 02/03/2011 8:18 PM, Bill Pragnell wrote:
> You could boil the water on your cpu heatsink;-)
I could burn the heal of my hands on my laptop. (No kidding)
Regards
Date: 2 Mar 2011 17:28:59
Message: <4d6ec4ab$1@news.povray.org>
> shucks ... I wanted to play too;-)
Try
object { Lucy pigment {rgb 1}}
Or
  scale     <0.010000,0.010000,0.010000>
  rotate    <-90.000000,0.000000,0.000000>
  translate <0.000000,6.000000,0.000000>
There is an offset and she's on her back (too much ambrosia IMO)
Then join the fun :-)
Regards
Date: 2 Mar 2011 19:47:18
Message: <4d6ee516$1@news.povray.org>
Am 02.03.2011 12:59, schrieb Bill Pragnell:
>> rendering.
I'd expect AA - instead of increasing samples - to give a benefit
nonetheless, as it avoids increasing the number of samples shot in areas
where everything is smooth as a baby's behind.
(I personally favor focal blur over AA though, as I think the
confidence/variance approach is superior the AA's mechanism.)
The "mm_per_unit" ratio specifies - not surprisingly - how many mm are
in a POV-Ray unit.
This is required because the subsurface coefficients are specified in
[average scattering/absorption events] "per mm", rather than "per
POV-Ray unit", in order to faciliate creating re-usable material
libraries. Otherwise what would like marble in one scene might look like
soap in another, depending on the scene's dimensions.
If you feel like multiplying "mm_per_unit" by some value just to make
your material look right, instead divide the coefficients by that value.
Yup, that's exactly the point of it.
Date: 2 Mar 2011 19:52:30
Message: <4d6ee64e$1@news.povray.org>
> Try
> Or
thanks uncle steve ... didn't need the rotate, however still odd stats
behavior /without/ scale ... sheesh tried scale 0.1 when I didn't get
any joy moved the cam WAY back and still nuttin' ... long day (yawn)
Ray->Shape Intersection          Tests       Succeeded  Percentage
then /with/ scale
Mesh                            260598          109403     41.98
Bounding Box                  31313889         8252368     26.35
Shadow Ray Tests:             50670   Succeeded:                 21223
Shadow Cache Hits:            21221
Date: 3 Mar 2011 04:30:01
Message: <web.4d6f5eccd81bd80d6dd25f0b0@news.povray.org>
I was a bit more scientific about it yesterday, and it seems aa is more helpful
than I thought - I had some reflection in the texture before that was confusing
the issue.
Agreed!
> in a POV-Ray unit.
Sorry, I wasn't clear enough, I meant the ratio of "mm_per_unit" to the
magnitude of the subsurface values. But your other comments make it much clearer
what's going on, I hadn't realised the subsurface coefficients were mm-1.
(should have read the reference paper!)
Right.
Thanks for the clarification. :)
Date: 3 Mar 2011 05:03:57
Message: <4d6f678d$1@news.povray.org>
> behavior/without/  scale ... sheesh tried scale 0.1 when I didn't get
> then/with/  scale
Wimp! ;-)
Mesh                        7855178046      4549713063     57.92
Bounding Box             1118966758944    315950707952     28.24
Shadow Ray Tests:        7404170367   Succeeded:            4072760477
Shadow Cache Hits:        129165794
   Trace Time:       6 hours 47 minutes 10 seconds (24430.593 seconds)
               using 6 thread(s) with 141346.808 CPU-seconds total
I've uploaded to povray.binaries.misc a cut down version of the mesh, if
that is any help.
I can now see the advantage of using a modeller that has an OpenGl display.
Regards
Date: 3 Mar 2011 05:06:51
Message: <4d6f683b$1@news.povray.org>
> Right.
> Thanks for the clarification.:)
Me too. :-)
Regards
Date: 3 Mar 2011 06:09:49
Message: <4d6f76fd@news.povray.org>
> Agreed!
I've not used focal blur much. What settings would be a good starting point?
Regards
Date: 3 Mar 2011 08:45:35
Message: <4d6f9b7f$1@news.povray.org>
>> Agreed!
> point?
My personal recipe:
Confidence .9
Variance 1/64
Samples to taste, for quicker renders, 10 does the job. For final
renders I'll go as high as 1000.
Why 1/64 on variance? Well, pixel-to-pixel it's very hard to see the
difference between a value that's 4 levels different than the next
(Though 3.7's gamma may change that in shadow or highlight areas) If you
must, go for the default variance. It slows a little bit, but not much.
As for confidence? Dunno. .9 is just sort of an arbitrary value.
Either than or start with the defaults, They're good enough (except
samples) occasionally I'll push confidence to 3 nines or even 4 nines,
if I think I'm going to get anything out of it.
Date: 3 Mar 2011 08:50:00
Message: <4d6f9c88$1@news.povray.org>
> that is any help.
cool .. thanks my brother from another mother
Date: 3 Mar 2011 08:59:30
Message: <4d6f9ec2@news.povray.org>
>> that is any help.
LOL
Whatever you're smoking, I want some. :-D
Regards
Date: 3 Mar 2011 09:07:01
Message: <4d6fa085$1@news.povray.org>
On 03/03/2011 1:44 PM, Mike Raiford wrote:
> My personal recipe:
> Confidence .9
> Variance 1/64
Thanks I'm running a render on my old dual core laptop. with the default
values and samples 10 and aperture 0.400.
It is rendering at 8 pps 2 hours into it an 17% done.
I'll try variance = 1/64 next.
Regards
Date: 3 Mar 2011 09:48:13
Message: <4d6faa2d$1@news.povray.org>
>>> that is any help.
> LOL
it's called insomnia ... and I think I'll scream if we don't get some
sunshine soon (sick of winter and gray days)
Date: 3 Mar 2011 10:40:48
Message: <4d6fb680$1@news.povray.org>
On 03/03/2011 2:48 PM, Jim Holsenback wrote:
>> LOL
>> >  Whatever you're smoking, I want some.:-D
I sympathise my wife has that problem. I on the other hand sleep the
sleep of the just.
It’s not fair, is it? :-P
I would have thought that long nights and short days would meen that you
sleep longer.
Regards
Date: 3 Mar 2011 11:00:01
Message: <web.4d6fba03d81bd80d86ff1d480@news.povray.org>
> your site and do:
Jim, she's ~929 units tall; try this with my version of the mesh to make her ~5
units tall:
   location <0, 0, -15>
   look_at  <0, 0, 0>
   right    x*image_width/image_height
   angle    60
light_source{ <-300, 300, -300> rgb 1 }
#include "shapes.inc"
#include "Lucy_POV_geom.inc"
#declare Lucy_Statue = object {
   Center_Object(Lucy_Statue, x+y+z)
   scale 1/929*5
   rotate y*180
object { Lucy_Statue pigment { rgb 1 } }
Cheers,
Rob
Date: 3 Mar 2011 13:00:47
Message: <4d6fd74f@news.povray.org>
> that is any help.
Ok ... here's my version rendered with RC4. I've settled for a more
subtle effect
Download 'work.png' (318 KB)
Preview of image 'work.png'
