On 24/02/2011 9:30 AM, Bill Pragnell wrote:
>> I had the same problem with Lucy, using MeshLab. Somehow I could not get it
>> > converted.
> What seemed to be the issue? I also converted Lucy (I think with Meshlab +
> Poseray) a couple of years ago and had no problems. I did lower the triangle
> count a bit, since the file size was vast and I knew most of it would be
> sub-pixel in the scene I was making...
MeshLab fails with an error message saying that the application has
requested the Runtime to terminate in an unusual way.
PoseRay might do it. But slowly, slowly!
After about 10 minutes loading the PLY file the % completed bar is at
about 2%.
Regards
"Stephen" <mcavoys_at@aoldotcom> schreef in bericht
news:4d663e0f@news.povray.org...
> about 2%.
Same for me.
>> > about 2%.
> Same for me.
I gave up after 21 hours and about 20% ~ 25% done
Regards
> >> > about 2%.
> > Same for me.
I'll try again next time I'm in front of it... failing that, I might still have
the converted .inc file, if it's still useful?
That would be great, Bill.
Regards
"Bill Pragnell" <bil### [at] hotmail com> schreef in bericht
news:web.4d677237d81bd80d6dd25f0b0@news.povray.org...
> have
Yes, Bill, that would be fine indeed.
http://www.infradead.org/~wmp/lucy.inc.zip
It's about 60mb. One mesh2, #declared as 'lucy'. Enjoy!
news:web.4d6ade48d81bd80da7b682960@news.povray.org...
Thank you indeed, Bill!
Thanks Bill, quick to download too. :-D
Regards
> >> > converted.
> about 2%.
I thought I'd give this a go - I grabbed the PLY file of Lucy and wrote a few
lines of Smalltalk to convert into a mesh2 file - took about 30 minutes. Flat
polygons, but, as Bill said, they're probably going to be sub-pixel anyway.
But. But... The resulting file (with 5 decimal places of accuracy) is 1.2GB in
size, and when I tried to render it on my 4GB MacBook Pro, POV took about 3.8GB
of Virtual Memory, which nowhere near fitted into the 2.3GB of free RAM I had
after the OS and file buffers took their slices. I left it trying to parse the
file for about 50 minutes then just gave up.
I might give it a go on an AWS EC2 cloud instance - it's US$0.68 per hour for a
8 CPU/7G RAM/64 Bit machine. But I've still got to get a 1.2GB file onto it!
I'm *not* going to give anyone the file, but you welcome to take the code and
run it yourself in Pharo 1.2 (a Smalltalk development environment). You *will*
need a 6GB, 8GB or greater machine to use the mesh2 though!
Cheers,
Edouard.
What might be of help, if you can do it, is to simplify the model. Using
a trial version of 3DS Max I reduced the vertex count to 20% of the
original (28 Meg, 9 Meg zipped)
Regards
Download 'lucy20_01b_1.jpg' (156 KB)
Preview of image 'lucy20_01b_1.jpg'
sweet ... excellent material!
Thanks but it is the bog standard marble. It is backlit and that makes a
difference. :-)
I think I'll try Lucy with the material map I used for the Buddha.
Regards
> difference. :-)
And here it is. I've created another simplified mesh using 10% of the
vertexes (14 Meg zipped to 5 Meg). It messes up my big idea of
mm_per_unit though.
I don't mind sharing it even though 3DS Max says the mesh is a rats nest.
Regards
Download 'lucy10_01_.jpg' (191 KB)
Preview of image 'lucy10_01_.jpg'
> mm_per_unit though.
Here's my little attempt. Rendered in 10mins, without aa though. One thing I've
noticed is that I get a large number of bright single-pixel artifacts unless I
use large sample counts (using 1000,100 here), even when also using aa. Is there
any way to avoid this, or is it just the nature of the beast?
Bill
Download 'sublucy.jpg' (36 KB)
Preview of image 'sublucy.jpg'
Am 01.03.2011 13:05, schrieb Stephen:
Very beautiful texture!
Nice but use aa it makes a difference. My samples are only 100, 50. Back
lighting makes a difference as well.
I used mm_per_unit = 1.105 for the first one and 28.6 for the green one.
It took well over an hour.
Your image looks more like marble what settings did you you use?
Regards
Thanks but as I said to Jim it is the marble from the paper.
I like the jade one posted later better.
I'm going to run some more test renders overnight.
Regards
I lied, I've just noticed that they are 500, 250
Regards
But does it? I thought aa was wasted on otherwise supersampled features like
area lights, focal blur, media etc? The edges of lucy's self-shadows are lovely,
it's just the floor shadow and her horizon that show aliasing. I'll do some aa
tests tonight.
Excellent, I was shooting for a very translucent marble.
mm_per_unit = 80 (the model is about 1 unit high)
samples 1000, 100 (only way I could get rid of bright point artifacts)
subsurface { 5*colour, 0.5*(1-colour) } (IIRC!)
Bill
> tests tonight.
I did a test without aa and there are more artefacts in the non-aa
rendering.
So your model is about 80 mm (3 inches) why pick that value?
This is something I'm having difficulty getting my head around. :-(
Regards
> rendering.
I see what you mean. The artifacts were definitely lessened by aa, but they were
lessened much more by increasing the sampling :)
Well, I was basically just tweaking until it looked good. I don't really
understand what the subsurface:mm_per_unit ratio means, although the
scattering:absorption ratio of the subsurface values seems more intuitive (not
dissimilar to media).
I think the mm_per_unit value kind of makes sense - most everyday experience
with translucent stone objects is small statues/knick-knacks. For larger items
(metres and larger), I would expect the translucency to be much more subtle, or
even invisible, due to the greater path lengths.
I think word-of-god elucidation is required :)
>> rendering.
OK, that saves me some experimenting.
I agree that the subsurface values seems more intuitive.
I think that I'll wait until RC4, where the syntax will change, before
playing any more.
Regards
> mm_per_unit = 80
Using your setting of mm_per_unit 80 and subsurface {samples 500, 100 }
I think that this one turns out nice. It took five and a half hours to
render but I was only using 4 threads. (I’m getting to be an old feartie
after my laptop overheated)
Regards
Download 'lucy10_01c_.jpg' (183 KB)
Preview of image 'lucy10_01c_.jpg'
>> mm_per_unit = 80
I thought you were gonna wait for RC4
Now go have a cup of tea and let the ole laptop cool down for a bit ;-)
> Now go have a cup of tea and let the ole laptop cool down for a bit;-)
LOL
It was already rendering when I wrote that.
A cup of tea sounds good though.
Regards
> >> > converted.
> about 2%.
> Regards
> Stephen
Wow, I'm having deja vu; I converted Lucy with MeshLab and rendered a few SSLT
versions right after the feature first appeared about a year and half ago:
http://news.povray.org/web.4a9f2cce63e55f164726e92b0@news.povray.org
And uploaded the inc file to my web site, the link is here:
http://news.povray.org/web.4aa18ba663e55f164726e92b0@news.povray.org
I'm going to have to try that dragon now though...
Cheers,
Rob
www.McGregorFineArt.com
> LOL
You could boil the water on your cpu heatsink ;-)
OK what am I doing wrong? I've used mesh objects before so I'm not
blazing any new territory here. I see the parse (tokens) of the object
then the render ... get an empty scene except my ground plane and light
source (zoomed way back looked u/d ... scaled too) don't see nuttin' ...
I should be able to (after including the Lucy file I downloaded from
your site and do:
object { Lucy_Statue pigment {rgb 1}}
btw stats just show 2 objects (plane and light_source)
shucks ... I wanted to play too ;-)
On 02/03/2011 8:18 PM, Bill Pragnell wrote:
> You could boil the water on your cpu heatsink;-)
I could burn the heal of my hands on my laptop. (No kidding)
Regards
> shucks ... I wanted to play too;-)
Try
object { Lucy pigment {rgb 1}}
Or
scale <0.010000,0.010000,0.010000>
rotate <-90.000000,0.000000,0.000000>
translate <0.000000,6.000000,0.000000>
There is an offset and she's on her back (too much ambrosia IMO)
Then join the fun :-)
Regards
Am 02.03.2011 12:59, schrieb Bill Pragnell:
>> rendering.
I'd expect AA - instead of increasing samples - to give a benefit
nonetheless, as it avoids increasing the number of samples shot in areas
where everything is smooth as a baby's behind.
(I personally favor focal blur over AA though, as I think the
confidence/variance approach is superior the AA's mechanism.)
The "mm_per_unit" ratio specifies - not surprisingly - how many mm are
in a POV-Ray unit.
This is required because the subsurface coefficients are specified in
[average scattering/absorption events] "per mm", rather than "per
POV-Ray unit", in order to faciliate creating re-usable material
libraries. Otherwise what would like marble in one scene might look like
soap in another, depending on the scene's dimensions.
If you feel like multiplying "mm_per_unit" by some value just to make
your material look right, instead divide the coefficients by that value.
Yup, that's exactly the point of it.
> Try
> Or
thanks uncle steve ... didn't need the rotate, however still odd stats
behavior /without/ scale ... sheesh tried scale 0.1 when I didn't get
any joy moved the cam WAY back and still nuttin' ... long day (yawn)
Ray->Shape Intersection Tests Succeeded Percentage
then /with/ scale
Mesh 260598 109403 41.98
Bounding Box 31313889 8252368 26.35
Shadow Ray Tests: 50670 Succeeded: 21223
Shadow Cache Hits: 21221
I was a bit more scientific about it yesterday, and it seems aa is more helpful
than I thought - I had some reflection in the texture before that was confusing
the issue.
Agreed!
> in a POV-Ray unit.
Sorry, I wasn't clear enough, I meant the ratio of "mm_per_unit" to the
magnitude of the subsurface values. But your other comments make it much clearer
what's going on, I hadn't realised the subsurface coefficients were mm-1.
(should have read the reference paper!)
Right.
Thanks for the clarification. :)
> behavior/without/ scale ... sheesh tried scale 0.1 when I didn't get
> then/with/ scale
Wimp! ;-)
Mesh 7855178046 4549713063 57.92
Bounding Box 1118966758944 315950707952 28.24
Shadow Ray Tests: 7404170367 Succeeded: 4072760477
Shadow Cache Hits: 129165794
Trace Time: 6 hours 47 minutes 10 seconds (24430.593 seconds)
using 6 thread(s) with 141346.808 CPU-seconds total
I've uploaded to povray.binaries.misc a cut down version of the mesh, if
that is any help.
I can now see the advantage of using a modeller that has an OpenGl display.
Regards
> Right.
> Thanks for the clarification.:)
Me too. :-)
Regards
> Agreed!
I've not used focal blur much. What settings would be a good starting point?
Regards
>> Agreed!
> point?
My personal recipe:
Confidence .9
Variance 1/64
Samples to taste, for quicker renders, 10 does the job. For final
renders I'll go as high as 1000.
Why 1/64 on variance? Well, pixel-to-pixel it's very hard to see the
difference between a value that's 4 levels different than the next
(Though 3.7's gamma may change that in shadow or highlight areas) If you
must, go for the default variance. It slows a little bit, but not much.
As for confidence? Dunno. .9 is just sort of an arbitrary value.
Either than or start with the defaults, They're good enough (except
samples) occasionally I'll push confidence to 3 nines or even 4 nines,
if I think I'm going to get anything out of it.
> that is any help.
cool .. thanks my brother from another mother
>> that is any help.
LOL
Whatever you're smoking, I want some. :-D
Regards
On 03/03/2011 1:44 PM, Mike Raiford wrote:
> My personal recipe:
> Confidence .9
> Variance 1/64
Thanks I'm running a render on my old dual core laptop. with the default
values and samples 10 and aperture 0.400.
It is rendering at 8 pps 2 hours into it an 17% done.
I'll try variance = 1/64 next.
Regards
>>> that is any help.
> LOL
it's called insomnia ... and I think I'll scream if we don't get some
sunshine soon (sick of winter and gray days)
On 03/03/2011 2:48 PM, Jim Holsenback wrote:
>> LOL
>> > Whatever you're smoking, I want some.:-D
I sympathise my wife has that problem. I on the other hand sleep the
sleep of the just.
It’s not fair, is it? :-P
I would have thought that long nights and short days would meen that you
sleep longer.
Regards
> your site and do:
Jim, she's ~929 units tall; try this with my version of the mesh to make her ~5
units tall:
location <0, 0, -15>
look_at <0, 0, 0>
angle 60
light_source{ <-300, 300, -300> rgb 1 }
#include "shapes.inc"
#include "Lucy_POV_geom.inc"
#declare Lucy_Statue = object {
Center_Object(Lucy_Statue, x+y+z)
scale 1/929*5
rotate y*180
object { Lucy_Statue pigment { rgb 1 } }
Cheers,
Rob
> that is any help.
Ok ... here's my version rendered with RC4. I've settled for a more
subtle effect
Download 'work.png' (318 KB)
Preview of image 'work.png'
>> that is any help.
> subtle effect
RC4! Drool.
Nice image have you tried using a back light?
Regards
> subtle effect
Wait... Did I miss something? is RC4 out already?
>> subtle effect
I think that Jim gets first dabs 'cause he writes the documentation.
Regards
>>> that is any help.
>>> display.
>> subtle effect
> RC4! Drool.
not until now I hadn't ... ran a low samples example (light source and
hdr flipped y*180) ... interesting effect, however looks like I'll need
a whole different tune (reminds me of tuning IF stages in
transmitter/receivers) ... maybe it's telling me that my settings
weren't so hot to begin with. The translucency effect is more
pronounced, almost to the point of practically being able to see through
the material. I can see that I have more experimenting ahead ... this
stuff is fun and frustrating at the same time ;-)
ha-ha ... and yikes this thread sure has generated a lot of bandwidth
(i'm posting 55th message to this thread)
Surprisingly, I find that full-spectrum light bulbs really do help.
"How did he die?" "He got shot in the hand."
"That was fatal?"
"He was holding a live grenade at the time."
