I’ve not posted anything for a while and I think this turned out OK for
an exercise.
I’ve been playing with trace() in Bishop3D. (It is not a feature but a
technique developed by StephenS) It was just a test for placing objects
on a mesh but I decided to make it into a scene in its own right.
Regards
Download 'stseb02n2_.jpg' (117 KB)
Preview of image 'stseb02n2_.jpg'
I may have been the first to post an example in the Bishop3d forum, but it's
your use of min/max_extent that made it useful ;-)
Stephen S
"Stephen" <mcavoys_at@aoldotcom> schreef in bericht
news:4d489f28@news.povray.org...
> an exercise.
I like that! The scene has that typical icon feeling. Maybe you should try a
vertical image ratio; and lean Sebastian against the tree perhaps?
> an exercise.
nice job with the character ... now all you need is slings to go with
those arrows ;-)
> those arrows ;-)
What outrageous fortune! I would rather take arms against a sea of
troubles. ;-)
Thanks, the model was just thrown together in about 20 minutes as a
target. For once I knew when to stop.
Regards
Thanks Thomas,
Your suggestion has merit. I think I got lucky with the pose and stopped
before it got over complicated. He should, by rights be tied to the
tree. So there is the usual problem of getting the tree into Poser to
pose him against. And the halo is a kludge too.
Arrg! I just checked to see if I could import the PovTree inc into Poser
and noticed that I've deleted all the later versions of St. Seb.
Drat and my back up does not include them. Heigh Ho! I'll have to
recreate it if I want to make another version.
Drat!
Regards
news:4d499290$1@news.povray.org...
> Thanks Thomas,
> before it got over complicated. He should, by rights be tied to the tree.
> So there is the usual problem of getting the tree into Poser to pose him
As for the tree (PovTree you say?) that is easy. Export the tree in PovTree
as a mesh, load into Poseray and export as .obj; then import into Poser.
Putting ropes around Sebastian is another - interesting - problem... ;-)
> Drat and my back up does not include them. Heigh Ho! I'll have to recreate
> Drat!
Well, that's a pity. How did you do that feat?
On 03/02/2011 8:02 AM, Thomas de Groot wrote:
> "Stephen"<mcavoys_at@aoldotcom> schreef in bericht
>> Thanks Thomas,
Yes, it was easy. But I could not use the technique I had used for the
halo as his arms and the tree are too close to the head. I’ve used a
torus in this version and a light group to make sure that there is no
shadow falling on it. It just doesn’t work right. :-(
>> Arrg!...
Carelessness really.
One of Bishop3D’s faults is the way it handles meshes. It imports the
complete mesh and exports it as SDL, each time it renders a scene.
Instead of using a UDO and referencing it in the Pov script. So for this
scene, the Bishop3D file is 12 Megs with a 12 Meg BAK file and a 22 Meg
Pov file. That is for each version I have saved. It soon adds up. I
accidently deleted the final version in the clean-up. On the plus side I
recovered 10 Gigs and it was only a test anyway.
Regards
Download 'stseb02_02b_.jpg' (53 KB)
Preview of image 'stseb02_02b_.jpg'
