POV-Ray : Newsgroups : povray.binaries.images : A speed enhancement for blurred reflections (144KB PNG) Server Time
16 Oct 2026 21:37:27 EDT (-0400)
  A speed enhancement for blurred reflections (144KB PNG) (Message 1 to 18 of 18)
Subject: A speed enhancement for blurred reflections (144KB PNG)
Date: 22 Jan 2011 16:59:30
Message: <4d3b5342@news.povray.org>
A while ago somebody came up with a novel idea for rendering blurred
reflections in POV-Ray. It used an averaged texture_map where each entry
was reflective and had a jittered surface normal. Unfortunately the
setup rendered very slowly when multiple inter-reflecting surfaces were
present.
A speed enhancement can be used to cut the render time down
significantly, with an arguably acceptable loss of accuracy. Under this
setup, two instances of the same object are used. One copy is visible,
uses blurred reflection, and has a no_reflection modifier applied to it.
The other copy uses non-blurred reflection, but with a no_image modifier
applied.
The image to the left uses a standard technique for creating blurred
reflections. The object has a very small bumps normal. The scene uses
focal blur with 1000 blur_samples and 0 variance. It took 3 minutes, 14
seconds to render.
The image to the right uses the averaged texture_map technique with the
aforementioned speed enhancement. The texture uses 256 averaged samples.
It took only 34 seconds to render with medium AA settings.
They were both rendered on three cores and without any light_sources.
I didn't make a full render of the original averaged texture_map
technique (it's way too slow), but the results would be comparable to
using the focal blur method, though with different artifacts.
Here's the basic setup:
#declare Obj =
union{
  box{-1,1 scale<10,1,10> translate -y*5}
  sphere{0,4}
#declare Texture_Metallic =
texture{
  finish{
   reflection .9
#declare Texture_Blurred_Metallic =
texture{
  average
  texture_map{
   #declare R=seed(1001);
   #declare V=0;
   #while(V<256)
    [1
     Texture_Metallic
     normal{
      bumps .2
      scale 4
      translate<rand(R),rand(R),rand(R)>*100
    #declare V=V+1;
object{Obj
  texture{ Texture_Blurred_Metallic }
  no_reflection
object{Obj
  texture{Texture_Metallic}
  no_image
This would probably be most useful for things like dull painted
surfaces, wooden floors, plastic, etc.
~Sam
Download 'rblur.png' (141 KB)
Preview of image 'rblur.png'
Subject: Re: A speed enhancement for blurred reflections (144KB PNG)
Date: 22 Jan 2011 17:19:04
Message: <4d3b57d8$1@news.povray.org>
Neat. It's similar to max_trace_level for area lights
in MegaPOV. Maybe a general mechanism for reduced quality
settings in reflections would be nice for future versions.
Date: 22 Jan 2011 20:44:09
Message: <4d3b87e9@news.povray.org>
Especially if said future version natively supported blurred
reflection/refraction. I wouldn't mind a loss of accuracy for such a
feature (at least it would still be raytraced :) ).
Date: 23 Jan 2011 07:52:10
Message: <4d3c247a$1@news.povray.org>
Am 22.01.2011 22:58, schrieb stbenge:
> applied.
I'd suggest a minor modification to this approach: For the no_image
version, do use the same normals pertubation as for the no_reflection
version, except that only a single layer is used.
The downside of your approach is of course that it won't work well with
a mix of both blurred and non-blurred surfaces in the same scene, e.g. a
dull brass figure in front of a mirror.
Date: 23 Jan 2011 11:55:00
Message: <web.4d3c5c5ece9e302b1df6284f0@news.povray.org>
> applied.
That's a great idea and it works like a charm, but...
http://news.povray.org/povray.binaries.images/message/%3C4baab97a%241%40news.povray.org%3E/#%3C4baab97a%241%40news.povr
ay.org%3E
-Just shows you guys are both very sharp!
Dave Blandston
Date: 23 Jan 2011 13:00:01
Message: <web.4d3c6c77ce9e302b1cd033bf0@news.povray.org>
 > applied.
Would there be a corresponding technique for speeding up blurred refractions?
Date: 23 Jan 2011 14:53:51
Message: <4d3c874f$1@news.povray.org>
> ay.org%3E
> Regards,
> Dave Blandston
That figures! I do remember that thread, but I can't remember if had
read through all of it or not... Ideas often get lodged into my
subconsciousness, surfacing now and again giving me the impression that
they are original thoughts. At any rate, it's a good speed enhancement
that needed more exposure ;)
~Sam
Date: 23 Jan 2011 15:03:05
Message: <4d3c8979@news.povray.org>
One layer, as in two total averaged copies of the texture?
The main problem is that the object possessing the blurred reflection
interacts with itself too much. Reflection groups would be the way to
go, but they would probably be difficult to set up (if they existed).
~Sam
Date: 23 Jan 2011 15:07:57
Message: <4d3c8a9d@news.povray.org>
>   >  applied.
There would, if POV had a "no_refraction" modifier. The best (and
fastest) method for blurred refractions that I can think of is to bake
all your scene's textures to meshes (and/or use Rune's illusion.inc),
add a small surface normal to the refractive material and use high focal
blur settings.
~Sam
Date: 23 Jan 2011 17:42:27
Message: <4d3caed3$1@news.povray.org>
Even then a scene might not benefit much, as a second
blurred refraction object would need to be positioned
such that it appears in the first blurred refraction
for this technique to help. Refraction tends to be
less annoyingly recursive than reflection ;)
BTW I just tried: if the refraction leads to total
internal reflection the no_reflection modifier will
take effect.
Date: 24 Jan 2011 03:23:57
Message: <4d3d371d@news.povray.org>
>> refractions?
If you want no refraction, why don't you just turn the transmit & filter
to 0.0 (of the deepest texture in case of layered texture) ?
It seems so simple, I must have missed something.
Date: 24 Jan 2011 05:37:08
Message: <4d3d5654$1@news.povray.org>
Am 24.01.2011 09:23, schrieb Le_Forgeron:
> If you want no refraction, why don't you just turn the transmit&  filter
You have indeed ;-)
Date: 24 Jan 2011 06:30:01
Message: <web.4d3d618dce9e302b207c1e20@news.povray.org>
I posted that idea back in 2006. Anyone beat me to it? :)
http://news.povray.org/povray.binaries.images/message/%3Cweb.45509993b8175aee696633280%40news.povray.org%3E
Regards Roman
vr
> ay.org%3E
> Regards,
> Dave Blandston
Date: 24 Jan 2011 11:00:00
Message: <web.4d3da1d2ce9e302b1df6284f0@news.povray.org>
> At any rate, it's a good speed enhancement that needed more exposure ;)
There's a blurred reflection entry in the wiki thing describing how to use the
averaged normals, maybe that entry could be enhanced a little to describe the
speed enhancement trick as well. It's a really good tip!
http://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips
Dave Blandston
Date: 24 Jan 2011 13:15:33
Message: <4d3dc1c5@news.povray.org>
> take effect.
It's good to know, though not something I would rely on ;)
Date: 24 Jan 2011 13:23:16
Message: <4d3dc394@news.povray.org>
This is beginning to look like the "stacked planes" scenerio all over
again :D
Date: 24 Jan 2011 13:24:24
Message: <4d3dc3d8@news.povray.org>
Hmm, I forgot all about the Wiki...
Date: 24 Jan 2011 15:16:09
Message: <4d3dde09@news.povray.org>
clipka wrote:
> You have indeed ;-)
Actually I fell into the same trap when first reading
the original post, my mind completely flowed over trying to
understand why anyone would go to the trouble of averaging
256 reflective textures just to tell the object it would
be "not reflecting" after all ;)
