POV-Ray : Newsgroups : povray.binaries.images : Rocky Desert Server Time
16 Oct 2026 23:57:43 EDT (-0400)
  Rocky Desert (Message 1 to 19 of 19)
Subject: Rocky Desert
Date: 1 Oct 2010 14:25:08
Message: <4ca62784@news.povray.org>
Following my usual pattern, I put aside everything else and followed the
impulse to create this scene. Thankfully it was easy and quick to transform
parts of prior scenes into this one.
The snake is a mesh model found on archive3d.net.
Rendered with radiosity, focal blur and aa in about 30 min.
Jaime Vives Piqueres
http://www.ignorancia.org
Download 'rocky-desert-05.jpg' (116 KB)
Preview of image 'rocky-desert-05.jpg'
Subject: Re: Rocky Desert
Date: 1 Oct 2010 14:29:31
Message: <4ca6288b@news.povray.org>
Am 01.10.2010 20:25, schrieb Jaime Vives Piqueres:
Nice one! I like the layer of dusty air in the distance.
Focal blur is a bit to strong though, I think.
Date: 1 Oct 2010 20:55:10
Message: <4ca682ee@news.povray.org>
>> transform
I don't think that the focal blur is to strong. It's just the very fore
ground that is notably blurry, the rest (most of the scene) appears in
focus.
My only complain is that the rocks seems to be somewhat to glossy, but
it may only be an effect of a harsh lighting.
Date: 2 Oct 2010 03:01:20
Message: <4ca6d8c0$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> schreef in bericht
news:4ca62784@news.povray.org...
> transform
As usual, good work, Jaime. Especially the rocks look very convincing. I am
a little bit less enthousiastic about the ground surface though, which looks
too smooth and shiny to me, showing its image map origin :-)  But I am sure
you are able to do something about that!
Date: 2 Oct 2010 20:55:01
Message: <web.4ca7d3462ba0250fe32b58850@news.povray.org>
Usually when that happens to me, I never end up posting anything \:
It's a good scene, but the light balance doesn't seem to follow the sun much.
Textured fog might help with something like this, but POV doesn't support it. I
wrote some code a while back to add this kind of functionality, you might want
to check it out. It's over at p.t.scene-files. Perhaps you can glean something
from it.
http://news.povray.org/povray.text.scene-files/thread/%3Cweb.4ca7d0bf43dc9b86e32b58850%40news.povray.org%3E/
Sam
Date: 3 Oct 2010 02:57:47
Message: <4ca8296b$1@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> schreef in bericht
news:web.4ca7d3462ba0250fe32b58850@news.povray.org...
> much.
> it. I
> want
> something
> from it.
WOW!
You are amazing, Sam...
Date: 3 Oct 2010 13:25:01
Message: <web.4ca8bbbf2ba0250f7f7f41ca0@news.povray.org>
> WOW!
It's too bad that it doesn't always work well with radiosity. I was hoping that
with the new distinction between ambient and emission finish attributes, I could
keep the texture from illuminating itself... Maybe someday POV will support
sky_sphere-based fog. It would probably be a very easy thing to implement. If
only my connection wasn't so slow, I could download all the necessary tools to
compile POV myself...
Sam
Date: 4 Oct 2010 15:05:59
Message: <4caa2597$1@news.povray.org>
El 03/10/10 08:57, Thomas de Groot escribió:
> WOW!
   I'm missing some more "O"s there... ;)
Date: 4 Oct 2010 15:06:18
Message: <4caa25aa@news.povray.org>
    That's a shame... I usually enjoy your unique images.
> much. Textured fog might help with something like this, but POV doesn't
> support it. I wrote some code a while back to add this kind of
> functionality, you might want to check it out. It's over at
> p.t.scene-files. Perhaps you can glean something from it.
    Thanks, that works wonderfully on this case, and was easy to add due to
the way the scene was constructed. Indeed, your code is a very good
demonstration of the idea, and allows to quickly grasp the concept and to
see how useful it is for outdoor scenes. I second the feature request, of
course...
Download 'rocky-desert-08-sbtf.jpg' (237 KB)
Preview of image 'rocky-desert-08-sbtf.jpg'
Date: 4 Oct 2010 15:09:25
Message: <4caa2665$1@news.povray.org>
   Yes, thanks... I was trying to follow your latest advice on focal blur,
but screwed it. Now I think I got it right (see my last post).
Date: 4 Oct 2010 15:10:44
Message: <4caa26b4@news.povray.org>
El 02/10/10 02:55, Alain escribió:
> My only complain is that the rocks seems to be somewhat to glossy, but it
   No, I was over-using the specular there... now I raised it by half the
amount. Thanks...
Date: 4 Oct 2010 15:13:01
Message: <4caa273d$1@news.povray.org>
> am a little bit less enthousiastic about the ground surface though, which
> looks too smooth and shiny to me, showing its image map origin :-)  But I
> am sure you are able to do something about that!
   You're right about the ground... I abused the specular, and also used a
too simple normal on the ground height_field. On the last shot I tried to
correct both, thanks!
Date: 4 Oct 2010 16:18:50
Message: <4caa36aa$1@news.povray.org>
> course...
Woooow! So much beter :)
Date: 5 Oct 2010 02:51:49
Message: <4caacb05$1@news.povray.org>
Woooooooooowww.........!
Really good!
Date: 5 Oct 2010 09:44:55
Message: <4cab2bd7$1@news.povray.org>
As usual, another top-notch rendering. You're truly a master at POV!
~Mike
Date: 5 Oct 2010 14:10:01
Message: <web.4cab66242ba0250ff9f6e13c0@news.povray.org>
> course...
That looks much better! It's an awesome scene :) Did you try out the ground fog
version I posted? It doesn't look nearly as good, but I wanted to provide the
option for it anyway.
Media would be the ideal choice in any case, but it's still pretty slow even
with multiple cores.
In other scenarios, casting glare from the sun would also help balance the
light. A sphere with a polar or spherical pigment pointing at the sun works. And
there's that clear tube with a specular or phong finish connecting between the
sun and camera. It seems to work pretty well, and even reacts when something
occludes the light.
And then there are clouds. The same technique of using a polar pigment located
at the camera position--and pointed at a light_source--can help "stacked planes"
clouds look more realistic.
Sam
P.S. Are coral snakes desert creatures? I heard this saying regarding the
distinction between coral and king snakes: "Red touching yellow, kill a fellow.
Red touching black, friend to Jack."
Date: 6 Oct 2010 04:35:00
Message: <web.4cac339b2ba0250f196b08580@news.povray.org>
> course...
Looks beautiful. (I really like desert scenes--they can incorporate lots of
random-looking detail that help 'sell' the image; and you've done a really nice
job with that.) The depth-of-field looks better in this one too. But I miss the
tiny circling birds. :-(  Or maybe they're just washed out in the sun glare.
Methinks the scene could use a bit more ambient lighting in the shadows now (or
brighter radiosity) since the sky now has some atmospheric glow. Seems that it
should fill in the shadows more.
Ken
Date: 1 Nov 2010 17:52:09
Message: <4ccf3689$1@news.povray.org>
I like the scene!
Any chance of all or some of the scene code being posted somewhere?
I would love to use the desert/rocks to help create a Lego Stars Wars
Clone Wars desert battle scene similar to the image found here:
http://alj029.blogspot.com/2010/03/almost-there.html
I already have Lego 3D models of the Imperial Dropship and the
stormtroopers (see link below for picture of the dropship)
http://shop.lego.com/ByTheme/Product.aspx?p=7667&cn=520&d=322
Bye for now
Reuben
reu### [at] pearsecouk
http://www.pearse.co.uk/lego
Date: 2 Nov 2010 10:27:16
Message: <4cd01fc4$1@news.povray.org>
El Mon, 01 Nov 2010 21:52:19 +0000, Reuben Pearse escribió:
> I like the scene!
  Thanks!
  Yes, there are chances... but who knows when? :)
  Seriously, I should finish this scene, clean and publish the code, and
answer some pending posts on this thread... I'm almost finished with the
thing that was eating all my little free time, so perhaps I can do it
soon.
  Anyhow I can send you the code "as it is" now, if you really need it...
