POV-Ray : Newsgroups : povray.binaries.images : Hope for Pathological Radiosity Cases Server Time
29 Nov 2026 02:02:40 EST (-0500)
  Hope for Pathological Radiosity Cases (Message 1 to 12 of 12)
Subject: Hope for Pathological Radiosity Cases
Date: 21 Aug 2010 20:23:27
Message: <4c706dff@news.povray.org>
I don't want to brag, but I think this is a breakthrough for radiosity:
The attached images show a purely radiosity-lit scene, using
pathologically small light emitters (three tiny spheres).
Image #1 shows the familiar splotchy output even at the maximum sample
ray count of 1600 and a nearest_count of 10, after a render time of 1
minute 45 seconds on my Core i7 machine.
Image #2 shows how this can be improved (not surprisingly) by using a
count of 6400 instead, after having replaced the built-in sample
sequence with a 160,000-element halton sequence, of which a subset of
6400 was picked for each sample in a round-robin fashion. Splotches are
almost gone, but there's a caveat: Render time increased to 7 minutes 20
seconds.
Image #3 however shows even better quality with a rendering time of just
2 minutes 18 seconds. On the same machine. With virtually identical
settings. So what's the deal here?
The basic idea is pretty simple: Trace fewer radiosity sample rays if
they only hit non-important objects :-)
Of course we can't know in advance whether we will hit important or
non-important objects; however, we /can/ decide to perform full
computations only on a subset of rays hitting non-important objects
(applying a factor to compensate for the discarded rays), so that at
least we need to perform fewer texture computations - not to mention
secondary rays for reflections or shadow computations.
For image #3, 12,800 rays were shot per sample, but I guess only roughly
2-5% of them (i.e. about 256 - 640) were continued beyond the ray-object
intersection tests.
Hey, I like this!
Download 'rad_count_test_37a_1600__1m45s.png' (177 KB) Download 'rad_count_test_38plus_6400of160000__7m20s.png' (177 KB) Download 'rad_count_test_38plus_12800of160000_weighted__2m18s.png' (170 KB)
Preview of image 'rad_count_test_37a_1600__1m45s.png'
Preview of image 'rad_count_test_38plus_6400of160000__7m20s.png'
Preview of image 'rad_count_test_38plus_12800of160000_weighted__2m18s.png'
Subject: Re: Hope for Pathological Radiosity Cases
Date: 21 Aug 2010 20:40:01
Message: <web.4c70711e84b746c8bf013bd00@news.povray.org>
> Hey, I like this!
Go on, brag. You've got the right :) This looks like a wonderful breakthrough
indeed.
Sam
Date: 21 Aug 2010 20:45:01
Message: <web.4c70723c84b746c8bf013bd00@news.povray.org>
Wait a minute, in the third image there is less reflected light on the plane
under the red sphere, and to a lesser degree, under the green sphere. Is it
supposed to be that way?
Date: 21 Aug 2010 20:58:22
Message: <4c70762e$1@news.povray.org>
Am 22.08.2010 02:42, schrieb Samuel Benge:
I'm not quite sure - I might still have one or two flaws in the code. I
guess I'll check with MCPov for comparison.
Date: 22 Aug 2010 03:08:13
Message: <4c70ccdd@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4c706dff@news.povray.org...
Good work! Congrats!
Date: 22 Aug 2010 07:52:56
Message: <4c710f98$1@news.povray.org>
Looks good ... I've not had too much luck with purely radiosity lit
scenes in the past, so bragging rights are indeed yours!
> seconds.
Be sure to keep us //all// up to date with your progress and I'll make
sure to integrate your findings into the documentation.
> Hey, I like this!
Concur!
Date: 22 Aug 2010 08:15:01
Message: <web.4c7113d784b746c81d5b3dfa0@news.povray.org>
is that the so called importance sampling? :)
yeah, pretty neat, but I noticed the same as Sam too...
Nice to see radiosity still improving.
Date: 22 Aug 2010 08:23:13
Message: <4C7116C0.2040702@gmail.com>
I am not sure it is not an artefact of our brain. In the second image
there are 'lines' of slight contrast just like in the first one, where
they are horrible. It might be that we misinterpret those lines as if
they are reflections of the floor although they are mere artefacts.
Date: 22 Aug 2010 13:22:25
Message: <4c715cd1$1@news.povray.org>
> seconds.
> intersection tests.
> Hey, I like this!
Very good! Congratulation, you are welcome to brag about your work :)
The 3rd image seems the best to me. In the others, the area under the
large spheres, especialy the red one, look to bright.
Date: 22 Aug 2010 18:06:38
Message: <4c719f6e$1@news.povray.org>
Sounds great!
How do you decide if an object is non-important?
Would this also help for scenes where light falls
through a narrow opening (door, blinds, ...)?
Date: 22 Aug 2010 18:38:11
Message: <4c71a6d3@news.povray.org>
Am 23.08.2010 00:09, schrieb Christian Froeschlin:
> Sounds great!
I don't - the user does. At least that's how I've currently implemented
it; e.g.:
   sphere {
     radiosity { importance 0.2 }
Should be possible, by placing a fully transparent object there with
high importance.
Note however that this in turn means a glass windows will be sampled
with the window pane's importance, unless the pane is marked as
"no_radiosity" to fully hide it from sampling.
I might still come up with an even smarter idea. I guess the approach
still leaves quite some room for further improvement.
Date: 23 Aug 2010 21:25:01
Message: <web.4c731eb084b746c834d207310@news.povray.org>
Oh I don't know, I think the real test for radiosity is in how it handles "dark
corners".
