Subject: The Ringworld revisited (day and night)
Date: 13 Jun 2010 07:58:10
Message: <4c14c7d2@news.povray.org>
Following up on the thread "spinner" space colony, and taking up againthe
work of 2005, here are two views of Larry Niven's Ringworld, scale 1:1,
during day and during night. Like Niven tells that, during the day, the
"Arch of Heaven" is much less visible than during the night. This is indeed
confirmed by my visit there ;-)
The ground surface is featureless because of the huge scale. A local
landscape should be superposed on it. That will be the next todo.
Download 'Ringworld_1_1_2010_03_night.jpg' (83 KB)
Download 'Ringworld_1_1_2010_03_day.jpg' (20 KB)
Preview of image 'Ringworld_1_1_2010_03_night.jpg'
Preview of image 'Ringworld_1_1_2010_03_day.jpg'
Go for it :-)
Best Regards,
Looking good. I've been playing with my version too, I'll post when I have
something decent!
> something decent!
Please do. :-D
Best Regards,
Spin ? ;-)
> Thomas
"Lightbeam" <st.### [at] free fr> schreef in bericht
news:4c16755b$1@news.povray.org...
> Spin ? ;-)
Yeah... I am not much of an animator, but making the Shadow Squares spin
gives an interesting effect over the Ring, including the penumbra.
Something I had not really realized before is that the lighting of the
landscape is extremely flat due to the Sun being at the vertical of the
landscape. This does not make for very breathtaking vistas I am afraid...
The landscape is described as having the same variation as the surface of any
planet - indeed, the maps of the other worlds from known space are all there,
Mars being a plateau raised by some km to simulate the thin atmosphere. The most
interesting lighting conditions will probably be evening/night-time - the
brightest archlight should be cast from the few next/previous days to
spinward/antispinward.
To be honest, the best way of doing this is probably to pick your position
across the ring width, render a spherical camera view with nothing on the ring
floor, then just use it on a sky sphere/light probe for the landscape scene of
your choice. Not as satisfying, unfortunately... :(
"Bill Pragnell" <bil### [at] hotmail com> schreef in bericht
news:web.4c17392c325a7df36dd25f0b0@news.povray.org...
> any
> there,
> The most
The landscapes are not an issue indeed, it is the full daylight lighting
which is *uninteresting* in itself. Shadows from trees should become
important items for giving more contrast to the relief.
You are right, interesting effects should be obtained from twilight periods.
This is something to investigate further I think.
> ring
> scene of
This is indeed an idea to follow up. I forgot for the moment the possibility
of a HDRI light probe and shall try that out, although - as you say - this
is somewhat less satisfying.
On 6/15/2010 4:02 AM, Thomas de Groot wrote:
> "Lightbeam"<st.### [at] free fr> schreef in bericht
>> Spin ? ;-)
> Thomas
I know you're trying to stay true to the book, but you could replace the
shadow "squares" with a lattice of some sort that progressively blocks
more or less light in a gradual manner.
http://isometricland.com
Subject: Re: The Ringworld revisited (day and night)
Date: 16 Jun 2010 03:18:17
Message: <4c187ab9@news.povray.org>
"SharkD" <pos### [at] gmail com> schreef in bericht
news:4c18359b$1@news.povray.org...
No, that is not the problem, and in fact the area_light sun already takes
care of the penumbrae cast by the shadow squares like you can see on the
images. The point is that the sun is always at the vertical to the ring
surface, like if you were in the tropics on Earth, and permanently at noon.
This results in very little shadow effects on the landscape, and is why by
the way, photography at noon is not recommended in general. So *real*
shadows will be cast by overhangs, artificial objects, and clouds.
On 6/16/2010 3:18 AM, Thomas de Groot wrote:
> "SharkD"<pos### [at] gmail com> schreef in bericht
> Thomas
Yes, I'm having the same problem with my spinner colony. Maybe you could
add some sort of lens surrounding the sun that makes it appear as if it
changes position?
> changes position?
Your habitat has windows on the endcaps, doesn't it? What about a view with the
axial sun-tube switched off, but sunlight coming into the cylinder from outside?
With decent radiosity settings this might look very interesting.
Or both. Not sure yet if I want the colony in a solar or planetary orbit
though.
> though.
Or at a Lagrange point, LOL!
> though.
You'd want a solar or gas-giant orbit if possible - photovoltaic power
from a close solar orbit, or put out conductor spines to sweep the gas-giants
magnetosphere for inductive power. I vote gas-giant, the view's better and you
don't need to worry about solar weather or heat disposal.
</geekery>
> </geekery>
What are "conductor spines", and what might they look like?
> > </geekery>
Just a description, not any particular technical term. The idea is to hang long
wires out radially from your rotating habitat such that they sweep through the
planet's magnetic field and induce electrical currents that can be used as a
power source, just like a really big dynamo.
Date: 18 Jun 2010 04:34:44
Message: <4c1b2fa4@news.povray.org>
After some tweaking of the Ringworld and playing with landscape generation,
here is a first test.
1) I wrote the whole Ringworld basics, including Sun and Shadow Squares into
a macro to make it easy to add in any scene.
2) An interesting experiment is to make the area_light of the Sun a tiny bit
larger than the Shadow Squares. It results a bit like the corona
illuminating diffusely the night skies along the ring. THis is not the case
in the present image.
3) For the landscape I made use of John VanSickle's height_field patchwork
macro. It is a bit difficult to control, especially in the areas nearest the
camera (see image) but it results in interesting landscapes.
4) The dark shape to the right is not an artefact but the Rim Wall.
5) I am testing ways of making local clouds but not with anything really
useful till now.
Download 'Ringworld 2010.jpg' (90 KB)
Preview of image 'Ringworld 2010.jpg'
Looks nice! I really need to set aside some time to play with this - another
ringworld-off, methinks.
Don't forget that the rim wall in the book was described as a continuous,
impossibly high mountain range, not a literal wall - although I realise this
will be much harder to model...!
Bill
Date: 18 Jun 2010 05:10:49
Message: <4c1b3819@news.povray.org>
news:web.4c1b3226325a7df36dd25f0b0@news.povray.org...
> another
...This is a rapid test with some clouds and their effects on the landscape.
> this
Yes, that is more difficult, but I think that can be overcome by a local
range locally superposed over/against the basic wall, which is a 1000 miles
high in this image. I have to think about that issue...
Download 'Ringworld 2010.jpg' (73 KB)
The Day/Night banding is good. Are the mountains not a bit high or is
that a mountainous part of the landscape?
Best Regards,
"Stephen" <mca### [at] aolDOT com> schreef in bericht
news:4c1b5526$1@news.povray.org...
> The Day/Night banding is good. Are the mountains not a bit high or is that
Yes, the banding is "better" because no light is leaking around the Shadow
Squares. As soon as some leaking occurs, there is some diffuse lighting of
the night areas, which may lead to interesting effects. Quite inadvertently
I came across that phenomenon.
The "mountains" are fairly high although scale is difficult to judge here. I
shall add simple trees to give an idea.
> Bill
Are you sure? I thought it was just a flat wall.
news:4c1cf039$1@news.povray.org...
I should look this up of course, but I seem to remember indeed that the Rim
Wall was carved into mountain shapes. In the later books, spill mountains
were added too for the necessary feeding of rivers.
> Thomas
Must have missed that bit, thanks!
Date: 20 Jun 2010 19:23:08
Message: <4c1ea2dc$1@news.povray.org>
I think the rim itself was just a wall, non-withstanding that the
terrain was mostly shaped such that it was blocked of by mountains
(although the rim wall is much higher than the mountains).
Here's a nice viewpoint from the rim:
http://www.dennisantinori.com/RingworldRPG/14109.html
Allegedly 1600 km high? About 5 times the ISS orbital height ;)
Date: 21 Jun 2010 03:56:46
Message: <4c1f1b3e@news.povray.org>
"Christian Froeschlin" <chr### [at] chrfr de> schreef in bericht
news:4c1ea2dc$1@news.povray.org...
As I said, I should look this up. I think the inner wall face is
sculpted/hidden behind mountain shapes. The transport system functions
behind that fake landscape.
In this image, the width of the wall seems much too narrow! And yes, it is
1600 km high indeed.
Date: 21 Jun 2010 04:53:48
Message: <4c1f289c@news.povray.org>
Here is a view that I start to find acceptable. 50000 trees were planted.
Rendered in 14 minutes.
macros and techniques used from: John VanSickle, Zeger Knaepen, Bill
Pragnell, Kirk Andrews. My thanks, gentlemen! And Larry Niven for the
concept of course! :-)
Download 'Ringworld 2010_05b.jpg' (88 KB)
Preview of image 'Ringworld 2010_05b.jpg'
Very nice. I love the way the wall looms over the regular foreground mountains.
Maybe a sheer wall is more dramatic than spill mountains. I anticipate future
iterations!
> iterations!
Is that the side wall? It looks a bit strange to me, hidden behind the
mountains. If you could see it continuing just slightly above the
mountain it might be more recognisable.
To which god does one pray to, to move mountains? ;-)
Best Regards,
I believe the locals name one Louis Wu. :)
Date: 21 Jun 2010 08:19:08
Message: <4c1f58bc$1@news.povray.org>
High!
Impressive! Is the "local landscape" a simple heightfield or an isosurface?
See you in Khyberspace!
Yadgar
Now playing. Santa Fe (Deuter)
LOL.
I've got Ringworld as a talking book. I must listen to it when driving
to and from work.
Best Regards,
"Jörg 'Yadgar' Bleimann" <yaz### [at] gmx de> schreef in bericht
news:4c1f58bc$1@news.povray.org...
> isosurface?
Thank you indeed!
The local landscape is a patchwork macro of height_fields, thanks to John
Van Sickle.
news:web.4c1f2ed6325a7df36dd25f0b0@news.povray.org...
> mountains.
> future
> iterations!
Thanks Bill!
The Rim Wall being so high, it "naturally" tends to loom even from far away.
We are standing here about 99% across the ring (calculated from the center).
So the Ring Wall still is about 5000 miles from the camera!
I wonder if it would really be visible so well, due to atmospheric haze and
such? I think that Larry Niven has not really considered the question... On
the other hand, the top of the wall is virtually out of the atmosphere, and
we may be able to see better a long way up than a long way away...
Date: 21 Jun 2010 10:15:35
Message: <4c1f7407@news.povray.org>
news:4c1f4c83$1@news.povray.org...
> mountains. If you could see it continuing just slightly above the mountain
The Rim Wall looms over the "local" landscape,, which is seen under an angle
of 80 degrees to the Ringworld.
As Bill said: Louis Wu is the proper god. I wouldn't trust Nessus. ;-)
Well, the smart money would be on Nessus, but the locals never met him properly.
Date: 21 Jun 2010 10:59:19
Message: <4c1f7e47@news.povray.org>
...and a possible (mid)night view would be like this one. Render time is 35
minutes, mainly due to the water.
Download 'Ringworld 2010_05c.jpg' (61 KB)
Preview of image 'Ringworld 2010_05c.jpg'
news:web.4c1f7974325a7df36dd25f0b0@news.povray.org...
> properly.
Yes, he is the hidden one, if not the hindmost... ;-)
Now that really is nice... a bit of light bloom and more opaque clouds would
make it almost perfect.
One thing has just struck me - I don't think the top of the wall would be
properly visible, especially at night. Since the top sticks out of the
atmosphere by some 800-900 miles, it should probably be obscured by the sky in
the same way as the arch, only showing up where in full sunlight. I don't know
how to make that look believable :\
On 21/06/2010 3:15 PM, Thomas de Groot wrote:
> "Stephen"<mca### [at] aolDOT com> schreef in bericht
Yes but in your image it looks, to me, as if a part of the landscape is
veering off to the right at an angle to the ring. I know it is just a
matter of perspective an optical illusion really.
I must re-read the series again, soon.
Best Regards,
Indeed. ALtho one must wonder why.
Eiffel - The language that lets you specify exactly
that the code does what you think it does, even if
it doesn't do what you wanted.
Fans should be aware there's a whole new series out, covering what Nessus
was doing the whole time he wasn't obvious. Basically, Known Space as told
from the puppeteer's point of view. Very, very fun.
> Nessus was doing the whole time he wasn't obvious. Basically, Known
> Space as told from the puppeteer's point of view. Very, very fun.
I didn't know. What is it called?
Best Regards,
IIRC, there's also a book that goes into the technical details behind
the Ringworld series based on conversations by fans over the years on
various newsgroups (not sure which ones though).
The book mentions how the bottom (or outside edge) of the ring is shaped
like a cake mold due to the sculpting of the mountains, but nothing
about the side walls.
He talks about it in the introduction to Book 4.
I was hoping I wouldn't have to dig it up... ;-)
The volume I have is called "Juggler of Worlds" by Niven and Edward Lerner.
The intro/etc implies there's an entire series, but I haven't tracked it
down yet. Maybe "Fleet of Worlds" according to the cover notes?
Wikipedia says "Fleet of Worlds", "Juggler of Worlds" and "Destroyer of Worlds".
I shall have to hunt these down, they sound interesting.
(I only read "Ringworld's Children" quite recently - it was much better than
Throne, I thought it had the same sort of feel as Engineers).
That's a plus I've not read "Ringworld's Children", yet.
Best Regards,
