POV-Ray : Newsgroups : povray.binaries.images : "Spinner" space colony (2) Server Time
17 Oct 2026 01:57:38 EDT (-0400)
  "Spinner" space colony (2) (Message 1 to 50 of 65)
Goto Latest 50 Messages Next 15 Messages >>>
Subject: "Spinner" space colony (2)
Date: 4 Jun 2010 17:04:14
Message: <4c096a4e$1@news.povray.org>
I moved the rendering to here:
http://isometricland.com/gearhead/ghpanotour_spinner_test.php
Right now (not in the above image yet) I'm experimenting with radiosity
and a bit of atmospheric haze. What would good values be for scattering
media? I'm assuming the density should be greater toward the edges of
the cylinder, but by how much? Should the density increase linearly or
exponentially?
Thanks!
Subject: Re: "Spinner" space colony (2)
Date: 4 Jun 2010 21:05:52
Message: <4c09a2f0$1@news.povray.org>
> exponentially?
> Thanks!
For the density. It would remain almost constent near the axis of
rotation, then increase somewhat faster as you get nearer to the outer
surface. I'd go for proportional to the square of the radius. At least,
it looks reasonable to me. Use a cylindrical pattern:
density{cylindrical poly_wave 0.5 density_map{[0 1][1,0.3]}}
Your cloudy "sky" looks out of place here. A large transparent area,
while good to get some natural light, is a great structural weakness,
not to mention that that area is lost from the ocupancy potential of the
station. If it's just a decoration for the inabitants, it's even worst.
Also, as the illumination seems to come from that bright axial beam, it
should be constant everywhere.
If you want your buildings to taper toward the top, I suggest using
prisms instead of simple boxes. But, unless a building is particularly
broad, there is no real reason that they should'nt have a constant width.
Date: 4 Jun 2010 21:52:33
Message: <4c09ade1$1@news.povray.org>
> Alain
Thanks for the comments. Do I need to scale the density file to the
scale of my scene?
The "sky" is also meant to place the opposite side in shade in order to
produce "night". I've tried other methods like placing a sleeve around
the lamp, but due to radiosity the opposite side is then never fully in
the dark. I.e. the "bright" side casts reflected light onto the supposed
"dark" side.
As for loss of occupancy, you're assuming people want to live in zero G.
Only the areas near the surface have suitable "gravity".
The "sky" does look ugly though.
Date: 7 Jun 2010 14:22:20
Message: <4c0d38dc@news.povray.org>
>> Alain
> scale of my scene?
> "dark" side.
Yes, you need to scale the cylindrical pattern to the radius of the scene.
For the "night", in an environment such as that station, there is never
one, and it's quite realistic that there should be no dark side.
If they want a "night", they should do it by turning off the central
glowing beam, or dim it down. There is absolutely no reason to have
areas dark while other are brightly illuminated, it's the same hour and
time of the day everywhere. Have you seen Babylon 5? It's a very good
example of a spining cylindrical space station.
For the loss of ocupancy, I mean loss of living surface due to the "sky"
area, not going all the way up to the axis.
Date: 7 Jun 2010 16:58:15
Message: <4c0d5d67$1@news.povray.org>
Good idea.
I uploaded a new render (same URL). I'm still having problems with the
scene looking "artificial", or like a miniature model. I can't quite put
my finger on it.
Date: 9 Jun 2010 14:32:53
Message: <4c0fde55@news.povray.org>
Still looks washed out... :(
Download 'gh_scene_spinner_cubemap_h.png' (444 KB)
Preview of image 'gh_scene_spinner_cubemap_h.png'
Date: 9 Jun 2010 14:39:13
Message: <4c0fdfd1$1@news.povray.org>
> Good idea.
> my finger on it.
All those cars and the streets don't help. I'd expect a comunal
transport system, part on grount, part suspended, to accomodate the
cityzens transportation.
I still have a dificulty with your clouds and "blue sky". If there are
some clouds, they would tend to gather into a cylinder around the center
beam, but never touching it.
Any blueish area due to the athmospheric scattering would be in the
direction of the central beam relative to the observer. Now, it's about
120° from where it should be.
The location IS artificial by definition. You may add some light fog, it
may help to give a sense of scale.
You may try puting the camera on the roof of a building or at street level.
Date: 9 Jun 2010 19:56:38
Message: <4c102a36@news.povray.org>
I adjusted all the pigments to compensate for assumed_gamma. The scene
is no longer as washed-out and bright.
Another problem I haven't fixed yet are the streets. For some reason
they show up as black when they instead should be gray. I don't know
why. I thought I fixed all coincident/overlapping surfaces.
Download 'gh_scene_spinner_cubemap_i.png' (406 KB)
Preview of image 'gh_scene_spinner_cubemap_i.png'
Date: 10 Jun 2010 03:28:29
Message: <4c10941d$1@news.povray.org>
Better indeed.
From looking at the buildings, I feel that the cylinder should have a much
larger radius. People will get claustrophobic here, with the impression that
the buildings are falling on their heads. :-)
I think that the sense of scale would be improved with a better balance
between cylinder dimensions and building dimensions. I suggest a larger
cylinder and (much more) scaled-down buildings/living space. Add some
atmospheric media or a subtle fog for suggesting distance and you will get a
much more believable scene.
Date: 10 Jun 2010 04:21:10
Message: <4c10a076@news.povray.org>
On 10/06/2010 8:28 AM, Thomas de Groot wrote:
> Better indeed.
I agree.
I suggest a larger
If Mike does that then it may be realistic but it will be boring to look
at. IMO realistic space scenes show one feature while hiding most others
due to differences in scale. Do you remember the posts from a few years
back (2005) of Larry Niven’s (or it could have been Bill’s) Ringworld?
Having said that the ground could be s bit further away ;-)
Best Regards,
Date: 10 Jun 2010 12:34:11
Message: <4c111403$1@news.povray.org>
This one is ok, if a little dark. The previous one was not washed out,
at least on my screen. In fact, it was much more contrasted.
I see a major problem: the ground should curves along the cylinder, now,
it's faceted.
Again, I maintain that planet's ground city like streets and the
presence of cars is just plain wrong in that kind of environment.
You use boxes for the buildings, it may be beter to use prisms; at least
for the taler ones, over 5 stories high, and have those buildings taper
as they go up. Low buildings, 1 to 4 stories, can probably do with
simple boxes.
Date: 10 Jun 2010 15:10:40
Message: <4c1138b0$1@news.povray.org>
Am 10.06.2010 18:34, schrieb Alain:
I disagree. (Well, then again I don't know your screen ;-))
Date: 10 Jun 2010 20:20:35
Message: <4c118153@news.povray.org>
Made the buildings larger, the roads narrower.
Download 'gh_scene_spinner_cubemap_k.png' (439 KB)
Preview of image 'gh_scene_spinner_cubemap_k.png'
Date: 11 Jun 2010 03:32:27
Message: <4c11e68b$1@news.povray.org>
"Stephen" <mca### [at] aolDOTcom> schreef in bericht
news:4c10a076@news.povray.org...
Yes indeed. Bill, and myself, did some exploration that way back then; and
there was some scenes based on Arthur Clarke's Rama iirc, some years ago
too. It is not easy, fairly impossible, to show all, so a shrewd choice of
viewpoint and scene cutout to suggest - more than to show - the vast
dimensions of such artificial structures is needed.
Date: 11 Jun 2010 03:40:58
Message: <4c11e88a$1@news.povray.org>
"SharkD" <pos### [at] gmailcom> schreef in bericht
news:4c118153@news.povray.org...
Hmmm.... yes and no. The sense of scale is starting to come nicely but the
ground should be curved around the cylinder and not faceted, with the
buildings abruptly at an angle above the pedwalks, and the park as a
completely flat area in front of us. I think cars would have difficulty in
maneuvering across the obvious angles in the roads while driving
cross-cylinder. :-)
It would do as a cartoonesk scene I guess but not as the more realistic one
here.
Date: 11 Jun 2010 08:25:05
Message: <4c122b21$1@news.povray.org>
On 11/06/2010 8:32 AM, Thomas de Groot wrote:
> "Stephen"<mca### [at] aolDOTcom>  schreef in bericht
I think that, that is the reason I gave up realistic modelling of scenes
like that. (Claims bonus for using “that” three times in one sentence ;-) )
I now prefer to model what I see in my mind’s eye.
Best Regards,
Date: 11 Jun 2010 08:45:02
Message: <web.4c122ef6f3c715fa6dd25f0b0@news.povray.org>
Ah, but I think Mike's approach with the interactive VR is exactly the way to do
a space habitat. I think the way the perspective distorts the edge of the frame
while panning gives the viewer an instinct for the fov that can be very tricky
for non-rectilinear geometries. I'm going to try this with my ringworld - and
I'll also dig out the O'Neill habitat that I started constructing some years
ago. (As an aside, this had a simple uniform fog inside it, and it worked very
well as a depth cue!)
Bill
Date: 11 Jun 2010 09:25:37
Message: <4c123951@news.povray.org>
> a space habitat.
I agree with you. I think this is an interesting experiment. It makes me
wonder what a game engine would make of it.
I’m not too sure about the distortion when you look straight down. It
would make you seasick driving down those roads.
I look forward to seeing it.
Best Regards,
Date: 11 Jun 2010 09:40:01
Message: <web.4c123c62f3c715fa6dd25f0b0@news.povray.org>
That reminds me - ever play any of the Halo games? There's a pretty good
rendition of a ringworld, and beautiful to look at. I kept getting shot up cos I
was too busy ogling the scenery :-)
Date: 11 Jun 2010 10:32:42
Message: <4c12490a$1@news.povray.org>
No, the last game I played was Doom II, Doom III was too dark for me to
see anything. I’m not very good at games.
I’ll see if I can pick up a copy and try God mode.
Best Regards,
Date: 11 Jun 2010 11:04:26
Message: <4c12507a@news.povray.org>
news:web.4c122ef6f3c715fa6dd25f0b0@news.povray.org...
> to do
> frame
> tricky
> and
> years
> very
Would be nice to do a Ringworld again. We have progressed over the last five
years, or so I hope :-)
I don't remember well now, was that epsilon issue fixed/corrected in version
3.7 or not? At the time we had a rapid patch of 3.6 I seem to remember...
Date: 11 Jun 2010 11:20:00
Message: <web.4c1252bff3c715fa6dd25f0b0@news.povray.org>
Haven't touched mine for a while. Perhaps its time to haul it out again :)
I think the smaller epsilon was to be included in 3.7. This was a few years ago
now so I guess it's in there... either have a peek at the source or try to
render something vast!
Date: 11 Jun 2010 12:55:18
Message: <4c126a76@news.povray.org>
>> shot up cos I
Doom III was way BAD. They totaly sacrified playability to athmosphere :(
Even in the living abitats and working areas, where a good lighting is
vital, you had great dificulty seeing things. Another bad thing: it
overrode your gamma/contrast/brightness settings and did not restore
those on exit.
Date: 11 Jun 2010 13:23:13
Message: <4c127101@news.povray.org>
I realy like your new end cap. I also like that you now have more
vegetation space.
But:
Why is the ground faceted and not smoothly curving?
Still to many road vehicles. The ONLY vehicles should be utility and
public transportation, and positively NO personal ones.
On a space station, any space station, even an imensly huge one,
resources are inherently scarce. Living space, parks space, working
space, cargo space, air, water, raw and rafined materials, energy,
everything is counted and counts. Personal cars are a waste of
resources, and thus frowned uppon.
Juging by the dimentions of the buildings and other indices, I could
relatively easily walk from one end to the other to get to work and back
home. I could even walk back home for my lunch... After all, it looks
like the overall length is less than about 2Km, or about a 10 to 20
minutes walk. In such a case, taking a car would take about the same
amount of time... and using a bike would reduce the time needed to 5
minutes or less. (I need about 20 minutes to walk about 3Km. Most
peoples have a walking speed ranging from 5 to 7Km/h)
Date: 11 Jun 2010 18:18:24
Message: <4c12b630$1@news.povray.org>
> those on exit.
You won’t get an argument from me on that view. ;-)
Best Regards,
Date: 12 Jun 2010 03:01:48
Message: <4c1330dc$1@news.povray.org>
news:web.4c1252bff3c715fa6dd25f0b0@news.povray.org...
> years ago
Yes, that is what I thought too. I'll do something vast... :-)
Date: 12 Jun 2010 03:15:15
Message: <4c133403@news.povray.org>
Two new renders. One from last night showing the atmosphere and rounded
portal to outside. And one from just a few minutes ago showing the
curved (as well as some new) buildings.
Download 'gh_scene_spinner_cubemap_l.png' (831 KB) Download 'gh_scene_buildingstrip_curve_c.png' (186 KB)
Preview of image 'gh_scene_spinner_cubemap_l.png'
Preview of image 'gh_scene_buildingstrip_curve_c.png'
Date: 12 Jun 2010 03:30:44
Message: <4c1337a4$1@news.povray.org>
Looking better :-D
Best Regards,
Date: 12 Jun 2010 04:48:17
Message: <4c1349d1@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> schreef in bericht
news:4c1330dc$1@news.povray.org...
Just to test, a quick-and-dirty scene from the past, rapidly adapted to 3.7,
without any atmospheric effects at all, and viewed from close to the
Ringworld floor.
No epsilon artefacts indeed. Maybe time to produce something better now...
:-)  Time allowing, I intend to take up the project again.
Download 'ringworld_1_1_2010.jpg' (45 KB)
Preview of image 'ringworld_1_1_2010.jpg'
Date: 12 Jun 2010 06:58:43
Message: <4c136863$1@news.povray.org>
On 12/06/2010 9:48 AM, Thomas de Groot wrote:
> "Thomas de Groot"<tDOTdegroot@interDOTnlANOTHERDOTnet>  schreef in bericht
> Ringworld floor.
Ooo! Nicer :-)
Best Regards,
Date: 12 Jun 2010 10:55:29
Message: <4c139fe1@news.povray.org>
news:4c136863$1@news.povray.org...
> Ooo! Nicer :-)
<grin>
...or on a heavily polluted surface. This is about the lowest possible
camera position without epsilon artefacts in 3.7 (as I modelled from the
original dimensions, about 0.05 miles from the surface; how many feet are
that??).   ;-)
Just playing around for now. The more serious work will come later...
Download 'ringworld_1_1_2010_2.jpg' (27 KB)
Preview of image 'ringworld_1_1_2010_2.jpg'
Date: 12 Jun 2010 14:21:38
Message: <4c13d032@news.povray.org>
>> Ooo! Nicer :-)
> <grin>
> that??).   ;-)
> Thomas
0.05 miles, that just around 110feet.
Date: 13 Jun 2010 03:09:47
Message: <4c14843b@news.povray.org>
"Alain" <aze### [at] qwertyorg> schreef in bericht
news:4c13d032@news.povray.org...
Ah! Not bad at all! Now, working on a superposed local landscape becomes
extremely easy. However, far away textures and skies need more attention
obviously.
Date: 13 Jun 2010 03:43:32
Message: <4c148c24$1@news.povray.org>
>> Ooo! Nicer :-)
> <grin>
> ....or on a heavily polluted surface. This is about the lowest possible
> that??).   ;-)
I like the banding from the clouds :-)
Best Regards,
Date: 13 Jun 2010 05:49:00
Message: <4c14a98c$1@news.povray.org>
> Looking better :-D
Render times just shot through the roof though! My test scene is a lot
simpler, but it's taking about an hour to render now instead of a few
seconds. I can't imagine how long the full scene is going to take to
render...
Date: 13 Jun 2010 05:58:55
Message: <4c14abdf$1@news.povray.org>
>> Looking better :-D
> render...
It looks like it might be worth it. :-D
Best Regards,
Date: 13 Jun 2010 06:20:53
Message: <4c14b105$1@news.povray.org>
Well, the last time I rendered the full scene it took all night. That
was before the recent changes. :(
Date: 13 Jun 2010 08:02:57
Message: <4c14c8f1@news.povray.org>
news:4c148c24$1@news.povray.org...
The banding (on the Ringwold) is not from the clouds however, but from the
Shadow Squares... :-)
Date: 13 Jun 2010 08:05:36
Message: <4c14c990$1@news.povray.org>
news:4c14b105$1@news.povray.org...
> Well, the last time I rendered the full scene it took all night. That was
Most of my scenes, in the end, take more than 24 hours to render with 2
cores, more tipically about 72 hours...  :-)
Date: 13 Jun 2010 10:29:26
Message: <4c14eb46$1@news.povray.org>
Even so looks good.
Best Regards,
Date: 13 Jun 2010 10:30:48
Message: <4c14eb98@news.povray.org>
Quality is not cheap ;-)
Best Regards,
Date: 14 Jun 2010 02:11:43
Message: <4c15c81f$1@news.povray.org>
How good is the radiosity pretrace as an estimator of how long a scene
will take to render? Right now it takes about 10 seconds to render a
pixel, even with a reduced texture quality.
Date: 14 Jun 2010 02:18:28
Message: <4c15c9b4@news.povray.org>
Another render showing another new building type and a variety of other
objects.
Download 'gh_scene_buildingstrip_curve_d.png' (322 KB)
Preview of image 'gh_scene_buildingstrip_curve_d.png'
Date: 14 Jun 2010 03:20:51
Message: <4c15d853$1@news.povray.org>
news:4c15c9b4@news.povray.org...
> objects.
This is looking really good!
Date: 14 Jun 2010 08:07:23
Message: <4c161b7b$1@news.povray.org>
Not for me to answer as I seldom use radiosity. 10 seconds a pixel, WOW!
Best Regards,
Date: 14 Jun 2010 08:35:33
Message: <4c162215$1@news.povray.org>
Am 14.06.2010 08:11, schrieb SharkD:
It's usually not a good estimator, because there are various factors
involved:
The Good News:
- Unless radiosity pretrace settings are poor, the pretrace will take a
significantly higher ratio of radiosity samples per pixel (with each
sample requiring tens, hundreds, or even up to 1600 more rays to be
shot, albeit with a few simplifications).
- Using low_error_factor significantly increases the "cost" of sample
lookup (i.e. looking up samples that have already been taken nearby)
during pretrace, while leaving the "cost" during main render unchanged.
The Bad News:
- As the pretrace progresses, the total number of samples keeps
increasing (of course), which also increases the overhead of checking
which samples are suitable for re-use; thus, sample re-use is
comparatively more "expensive" during the main render than during the
first pretrace steps.
- Some features are disabled during pretrace, most notably antialiasing
and focal blur, so these added "costs" don't show during pretrace.
So, all in all, pretrace may or may not be slower or faster than main
render - it depends.
A smaller-sized render is probably a much better indicator of the main
render performance.
Date: 14 Jun 2010 16:23:35
Message: <4c168fc7$1@news.povray.org>
On 6/14/2010 3:20 AM, Thomas de Groot wrote:
> "SharkD"<pos### [at] gmailcom>  schreef in bericht
>> objects.
> Thomas
Yeah, clipka's advice on compensating for gamma really helped a bunch!
Date: 14 Jun 2010 18:12:51
Message: <4c16a963$1@news.povray.org>
What kinds of things might be the causes of all the slowdown? I've
turned off all media and reflection and it is still abysmally slow.
One major revision I've made to Chris Colefax's CityGen include file is
that each building is now called by a macro and generated individually
at runtime. Whereas originally a single copy (more or less) of a
building was stored in an array and replicated/duplicated when needed.
The other difference of course is that buildings now have greater
complexity. They make use of more CSG operations and feature a greater
number of storeys.
Date: 14 Jun 2010 19:03:34
Message: <4c16b546$1@news.povray.org>
> number of storeys.
You have a "concave" geometry composed of many objects made out of
coaxyal cylinders slices. This can very easily lead to bounding problems
where most objects bounding boxes overlap each other, and are
excessively large.
Try manualy bounding the individual buildings. Try to see if you can use
some mesh.
Use simple boxes or prisms for narrow buildings and some of the farder
ones. Some/most broad buildings probably can do with only a texture that
curves instead of the actual floors.
Except for the closest buildings, don't model individual floors. A flat
topped conical building can be a simple truncated cone. The flat base
beed hiden under the ground. If needed, remove a small cylindrical part
from it's top.
Only model the interior of a building IF you look from it's inside or
take a closeup look into it. Use conditional statements, possibly based
on insideness test or bounding box test to toggle the insides as needed.
Date: 14 Jun 2010 19:31:17
Message: <4c16bbc5$1@news.povray.org>
>> number of storeys.
> excessively large.
> some mesh.
> from it's top.
> Alain
Here's the macro I use to generate the concave cylinder sections:
#macro cyl_box(in_star, in_stop)
	#local in_star_height	= city_radius - in_star.y;
	#local in_stop_height	= city_radius - in_stop.y;
	#local in_star_z_angle	= in_star.x/city_circum * 360;
	#local in_stop_z_angle	= in_stop.x/city_circum * 360;
	difference
		cylinder {<0,0,in_star.z-0>, <0,0,in_stop.z+0>, in_star_height}
		cylinder {<0,0,in_star.z-1>, <0,0,in_stop.z+1>, in_stop_height}
		plane {+x, 0 rotate z * in_star_z_angle}
		plane {-x, 0 rotate z * in_stop_z_angle}
		bounded_by {cylinder {<0,0,in_star.z-0>, <0,0,in_stop.z+0>,
in_star_height}}
Can I use an object produced by this macro as a bounding object? Would
it be better to use a mesh instead? Does bounding work on unions and
merges as well as differences and intersections?
