POV-Ray : Newsgroups : povray.binaries.images : Lights on the Water Server Time
29 Nov 2026 02:18:41 EST (-0500)
  Lights on the Water (Message 1 to 14 of 14)
Subject: Lights on the Water
Date: 23 May 2010 17:37:44
Message: <4bf9a028@news.povray.org>
Ah, at last I found some time again to /toy around/ with POV-Ray rather
than hack its code!
This one was inspired by an overdose of stackernight.pov regression test
renders - plus a bit of Google and Wikipedia searching. The moon sneaked
its way into the picture as a harmless decoration at first, but then
started inflating its role before I could stop it.
About half a day of SDL coding, and roughly half an hour of rendering.
Download 'lanterns 2010-05-23 1510.png' (540 KB)
Preview of image 'lanterns 2010-05-23 1510.png'
Subject: Re: Lights on the Water
Date: 23 May 2010 18:05:43
Message: <4bf9a6b7@news.povray.org>
sslt or backside diffuse on the laterns?
I like it!
Date: 24 May 2010 00:05:01
Message: <web.4bf9f9fbcc6f80dcba3fb0f0@news.povray.org>
> I like it!
I like it too because it's so peaceful. Judging by the reflections on the water
it looks like the lanterns are hollow inside, so my guess is something other
than sslt. I'm also curious about the lighting method. It's very pleasant.
Dave Blandston
Date: 24 May 2010 03:28:25
Message: <4bfa2a99@news.povray.org>
Excellent indeed!
Isn't there a Japanese festival with lanterns put floatong on the water?
Date: 24 May 2010 04:19:31
Message: <4bfa3693@news.povray.org>
> than hack its code!
Harmonious and peaceful scene, I like it
Paolo
Date: 24 May 2010 10:34:28
Message: <4bfa8e74@news.povray.org>
"clipka" <ano### [at] anonymousorg> a écrit dans le message de news:
4bf9a028@news.povray.org...
> than hack its code!
Very quiet  and beautiful :)
No smoke? :p
And I won't ask you if you like fried chicken as well? :ppp
Date: 24 May 2010 12:00:40
Message: <4bfaa2a8$1@news.povray.org>
Am 24.05.2010 00:08, schrieb Jim Holsenback:
Backside diffuse. A box clipped_by another box to open top & bottom and
leave only the surface.
> I like it!
Thanks!
Date: 24 May 2010 12:07:39
Message: <4bfaa44b$1@news.povray.org>
Am 24.05.2010 06:00, schrieb Dave Blandston:
Some light from the direction of the moon (area_light with all the
standard bells & whistles, i.e. circular orient adaptive jitter), but
the main light sources are the candles (again area_lights); the
illumination of the water below the lanterns is achieved with a greenish
diffuse plane right below the transparent surface. Radiosity is used,
but maybe doesn't even play much of a role.
Date: 24 May 2010 12:13:47
Message: <4bfaa5bb$1@news.povray.org>
Am 24.05.2010 09:28, schrieb Thomas de Groot:
 From my researches, there are several such festivals in different parts
of the world, though many seem to be using open vessels, or just set the
candles afloat in the water. The most popular festival using lanterns
seems to be something in Hawaii (IIRC) - and indeed another annual event
in Japan, but I'd hesitate to call it a "festival": They're
commemorating the nuclear bomb attacks, if I gathered it right.
Date: 31 May 2010 04:31:34
Message: <4c0373e6$1@news.povray.org>
Not bad. In fact, quite a good idea!
My only thought is (without having it seen in reality so just guessing) that
the water surface close around each lamp should be illuminated by the lamp
light, even if only a little bit and in the color of the light's color.
Date: 31 May 2010 04:32:10
Message: <4c03740a@news.povray.org>
And the moon is too blue in the water, I believe.
Date: 31 May 2010 07:33:52
Message: <4c039ea0$1@news.povray.org>
Am 31.05.2010 10:31, schrieb Sven Littkowski:
Well, they do - as can be seen on the closer lamps. The direct
illumination from the candles inside is a good deal stronger though than
the indirect one from the colored lanterns, so there's not much of a
difference. And on the far-away water, specular reflection strongly
dominates, so we don't see the water being illuminated.
Date: 31 May 2010 07:40:30
Message: <4c03a02e$1@news.povray.org>
Am 31.05.2010 10:32, schrieb Sven Littkowski:
Yes, as far as realism goes, you're certainly right, as I deliberately
"tuned" the moon to get a stronger contrast with the lanterns' colors.
(Then again, in reality the observer's eyes would probably adapt a good
deal to the lanterns' colors, causing the impression of a rather blueish
moon.)
Another thing that's deliberately unrealistic is the moon's size - it's
about 5 times larger than it would be in reality.
Date: 1 Jun 2010 14:29:00
Message: <4c05516c$1@news.povray.org>
I have to confess I didn't actually recognize it as the moon
before reading your post. Apart from the size and the color,
this may also be because the view is so crisp and I've never
been to a place where the environment gets so dark (and
with full moonshine at that). Maybe add a bit of halo?
Nice image, though.
