POV-Ray : Newsgroups : povray.binaries.images : Stony ground with ant (218K) Server Time
29 Nov 2026 02:18:42 EST (-0500)
  Stony ground with ant (218K) (Message 1 to 25 of 25)
Subject: Stony ground with ant (218K)
Date: 5 May 2010 03:58:16
Message: <4be12518@news.povray.org>
Ok, the last one with the ant...
Jaime Vives Piqueres
http://www.ignorancia.org
Download 'hormiga-suelo.jpg' (219 KB)
Preview of image 'hormiga-suelo.jpg'
Subject: Re: Stony ground with ant (218K)
Date: 5 May 2010 05:15:01
Message: <web.4be136936e393ef021619a220@news.povray.org>
Oh wow - that is stunningly real! Amazing job!
I spent about 5 minutes looking at it to see if there was anything that gave it
away as a render, and the only thing I could come up with was the green sprouts
coming through the sand look a little plasticy - are you using 3.7 or Megapov?
If it's 3.7, I reckon some SSLT on those will complete the illusion completely.
Cheers,
Edouard.
Date: 5 May 2010 08:10:01
Message: <web.4be15f866e393ef0ae92d9930@news.povray.org>
I think the sand or dirt could use a bit more color variation among the
'grains', but those chaotic pebbles are quite amazing, *so* real. I tried
something similar in the past, but never even came close to what you've done.
Kudos!
Ken
Date: 6 May 2010 05:07:33
Message: <4be286d5@news.povray.org>
   Thanks!
> gave it away as a render, and the only thing I could come up with was the
> green sprouts coming through the sand look a little plasticy - are you
> using 3.7 or Megapov? If it's 3.7, I reckon some SSLT on those will
   I'm using the beta for this one, so here it is with SSLT on the sprouts.
I've just plagiarized the demo scene, changing the colors and the mm per
unit until it looked (somewhat) right. But this, and 7 more samples on the
focal blur, increased the render time from 6 to 11 hours...
   BTW, this scene renders much faster than expected with the beta, judging
by the speed of both 3.6 and MegaPOV with it. Almost 6 times faster! ...but
before trying it with the beta, I was already puzzled by how slow it was
with MegaPOV and 3.6, so perhaps it was just a bug that got fixed.
Download 'hormiga-suelo.jpg' (220 KB)
Date: 6 May 2010 05:22:55
Message: <4be28a6f@news.povray.org>
> 'grains'
   It *HAS* a very wide variation in grain colors, but the focal blur makes
it almost disappear... and if I make the grain bigger to avoid this, it
doesn't look like grains anymore. :(
> but those chaotic pebbles are quite amazing, *so* real. I tried something
   Me too, tried it before but never got it right... I think it's due to the
fact that I was always using a single while loop to place the pebbles, but
this time used 3 loops, with increasing random sizes and decreasing number
of pebbles. Also, the pebbles are not totally random in their placement, as
I used a pigment function (granite) to determine if a pebble should be
placed or not. And BTW, it is just a single mesh pebble made with
Wings3d... :)
Date: 6 May 2010 05:30:56
Message: <4be28c50$1@news.povray.org>
Am 06.05.2010 11:27, schrieb Jaime Vives Piqueres:
>> 'grains'
See <http://www.tc-rtc.co.uk/imagenewdisplay/stills/index207.html> for
some other approach at sand.
Date: 6 May 2010 06:52:34
Message: <4be29f72@news.povray.org>
>>> the 'grains'
>> makes it almost disappear... and if I make the grain bigger to avoid
>> this, it doesn't look like grains anymore. :(
   Ah, yes... that's the best POV-Ray sand to date! In fact, I did remember
about it at first, when I was using MegaPOV, but it was extremely slow to
render with 100,000 spheres. And later I forgot to try it again with the
beta... well, that will be the first job for the AMD Phenom II X4 that I
just purchased. :)
Date: 6 May 2010 07:30:01
Message: <web.4be2a8046e393ef034d207310@news.povray.org>
Very cool. I like the degree of realism here.
Date: 6 May 2010 08:00:01
Message: <web.4be2af156e393ef0ae92d9930@news.povray.org>
> placed or not.
Very clever!  It seems to eliminate the 'clumping together' that usually occurs
when using a 'random' distribution. Using eval_pigment, I suppose? Must remember
this trick!
Ken
Date: 6 May 2010 09:49:18
Message: <4be2c8de$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> schreef in bericht
news:4be28a6f@news.povray.org...
> the
> as
> Wings3d... :)
Additionally, what you can use to good effect, is the prob() function.
Excellent image (as always).... I am finishing a desert scene which I shall
show here soon. Much cruder textures however than your finely realistic ones
Date: 6 May 2010 11:30:00
Message: <web.4be2e0746e393ef0773c9a3e0@news.povray.org>
> Wings3d... :)
randomized proceduralized placement, randomized proceduralized mesh-based
geometry, randomized proceduralized imagemap-based texturing (not necessarily in
this one)... you're such a random procedural magician! :D
Subject: Re: Stony ground with ant II (267K)
Date: 9 May 2010 11:42:12
Message: <4be6d7d4@news.povray.org>
   Ok, after a painful move to the new AMD Phenom II x4, that took two days
to complete, finally got the chance to try it out. I added 350,000 spheres
and it still rendered in 4h! :)
Download 'hormiga-suelo-02.jpg' (267 KB)
Preview of image 'hormiga-suelo-02.jpg'
Date: 10 May 2010 03:19:19
Message: <4be7b377$1@news.povray.org>
news:4be6d7d4@news.povray.org...
Yes! This is the real world! :-)
Date: 10 May 2010 03:26:35
Message: <4be7b52b$1@news.povray.org>
Just thinking: With the DoF, you may get away with a lesser number of
spheres, or are they all concentrated in the sharp zone?
Date: 10 May 2010 03:58:17
Message: <4be7bc99$1@news.povray.org>
> occurs when using a 'random' distribution. Using eval_pigment, I suppose?
> Must remember this trick!
   No, just using the pigment function on a #if statement against the stone
   #if (f_distrib(stone_location.x,0,stone_location.z).gray<=.5)
   where stone_location was generated randomly over the height_field.
Date: 10 May 2010 04:13:36
Message: <4be7c030@news.povray.org>
   prob()??? ...I've never heard of that function. In fact, the only thing I
can find is prod(), which was also unknown to me, and can't see how would
use it here.
> shall show here soon. Much cruder textures however than your finely
> realistic ones
   I cheated greatly there... ;) there is only one texture for the stones,
which is a "procedularized" picture of a pebbles bed. I scaled it really
big, and translated it randomly for each pebble, making the finish also
random for each one.
Date: 10 May 2010 04:16:40
Message: <4be7c0e8@news.povray.org>
> necessarily in this one)... you're such a random procedural magician! :D
   I love rand()!!! I use it even for things as bizarre as finding the camera
placement! ;)
Date: 10 May 2010 04:22:20
Message: <4be7c23c$1@news.povray.org>
   No, I'm not that sharp: they are scattered evenly. And there is a real
difference in realism even on the blurred zones. Oh, and 3.7 managed to
parse all the scene in 29 seconds, so why bother? :)
Date: 10 May 2010 04:53:06
Message: <4be7c972$1@news.povray.org>
Am 09.05.2010 17:41, schrieb Jaime Vives Piqueres:
Looking /really/ good now!
Yes, a neat QuadCore is fun with POV-Ray ;-)
Date: 10 May 2010 10:33:38
Message: <4be81942$1@news.povray.org>
news:4be7c030@news.povray.org...
> I
> use it here.
It is not described in the docs it seems... You can find the probability
macro as the first one in rand.inc. I use it quite often to select between
different plants for instance, or any selection of objects.
>> realistic ones
Great technique! I shall remember that.
Date: 10 May 2010 11:12:16
Message: <4be82250$1@news.povray.org>
ha ... new one on me as well! since you've used it, perhaps you could
come up with a sentence or two and i'll add it to the wiki docs
i'll watch this thread or you can put it over here:
http://wiki.povray.org/content/Documentation_Talk:Reference_Section_7.3
jim
Date: 11 May 2010 04:28:55
Message: <4be91547@news.povray.org>
"Jim Holsenback" <jho### [at] povrayorg> schreef in bericht
news:4be82250$1@news.povray.org...
Well, you could maybe use something like this:
Prob(P, RS)
The probability macro returns true or false. P is the probability of
returning true (value between 0 and 1) RS is a random number stream.
Example code:
//start code
//If you want a 40% chance of red objects amongst blue ones
#local ObjProb = Prob(0.4, r);
object {
  #if (ObjProb)
    RedObj
  #else
    BlueObj
//end code
Date: 11 May 2010 05:13:49
Message: <4be91fcd$1@news.povray.org>
haha ... I think WE ALL deserve a RTFM on this one ;-)
It was already there:
http://wiki.povray.org/content/Documentation:Reference_Section_7.3#Discrete_Distributions
In the unix docs it's in section:
3.7.11.2.3 Discrete Distributions
Jim
Date: 11 May 2010 10:39:49
Message: <4be96c35$1@news.povray.org>
news:4be91fcd$1@news.povray.org...
The thing is that in the unix docs, it does not appear in the Index....  so,
I assumed...
Date: 11 May 2010 11:07:26
Message: <4be972ae$1@news.povray.org>
it was missing this tag needed for it to appear in the index listing:
<!--<indexentry primary "Prob">--->
Jim
