POV-Ray : Newsgroups : povray.binaries.images : Problem with mesh2 building - memory crash! Server Time
29 Nov 2026 02:34:41 EST (-0500)
  Problem with mesh2 building - memory crash! (Message 1 to 4 of 4)
Subject: Problem with mesh2 building - memory crash!
Date: 25 Apr 2010 10:51:58
Message: <4bd4570e@news.povray.org>
High!
Today I tried to build a mesh2 from the 24-bit heightfield I recently
generated from my original Ghurghusht isosurface (attached here)...
after completing the eval_pigment() scan of the heightfield, POV-Ray
crashed with an error message: "corrupted double-linked list" and a long
list of addresses...
Here is the relevant code:
#declare T_Ghurghusht=
texture
   pigment { color rgb <0.98, 0.85, 0.45> }
   finish { ambient 0.05 diffuse 1 brilliance 0.98 }
#if (tcm=0)
   #declare Ghurghusht =
     isosurface
       function { Terrain_Function(x, y, z) }
       contained_by { sphere { 0, 1 } }
       max_gradient 5
       accuracy 0.0001
       double_illuminate
       texture { T_Ghurghusht }
       scale 5178
#else
   #declare hf=
   pigment
     image_map
       png "tiles/ghurghusht360_n05_040.png"
   #declare sl=5124.6666;
   #declare rng=31.5519+6.2452;
   #declare ll=sl-6.2452;
   #declare long=40;
   #declare lat=5;
   mesh2
     vertex_vectors
       1440000 // 1200 * 1200
       #declare a=0;
       #while (a<1200)
	#declare b=0;
	#while (b<1200)
	  #declare rd=eval_pigment(hf, <1/2400+b/1200, 2399/2400-a/1200, 0>).red;
	  #declare gr=eval_pigment(hf, <1/2400+b/1200, 2399/2400-a/1200,
0>).green/256;
	  #declare bl=eval_pigment(hf, <1/2400+b/1200, 2399/2400-a/1200,
0>).blue/65536;
(ll+(rd+gr+bl)*rng)*<sin(radians(-long-(10/3)*(1/2400+b/1200)))*cos(radians(lat-(10/3)*(1/2400+a/1200))),
sin(radians(lat-(10/3)*(1/2400+a/1200))),
cos(radians(-long-(10/3)*(1/2400+b/1200)))*cos(radians(lat-(10/3)*(1/2400+a/1200)))>
	  #declare b=b+1;
	#warning concat("Assigning vectors for line ", str(a, 4, 0))
	#declare a=a+1;
     face_indices
       2875202 // 1199 * 1199 * 2
       #declare a = 0;
       #while (a < 1199)
	#declare b = 0;
	#while (b < 1199)
	  <1200*a + b, 1200*a + b+1, 1200*(a+1) + b>,
	  <1200*a + b+1, 1200*(a+1) + b+1, 1200*(a+1) + b>
	  #if(b<(l-2))
	  #declare b = b+1;
	#warning concat("Parsing lines ", str(a, 4, 0), " and ", str(a+1, 4,
0),".")
	#declare a = a+1;
// end of code
Why?
See you in Khyberspace!
Yadgar
Now playing: I've Seen All Good People (Yes)
Download 'ghurghusht360_n05_040.png' (3431 KB)
Preview of image 'ghurghusht360_n05_040.png'
Subject: Re: Problem with mesh2 building - memory crash!
Date: 25 Apr 2010 15:00:41
Message: <4bd49159$1@news.povray.org>
Le 2010-04-25 10:47, Jörg 'Yadgar' Bleimann a écrit :
> High!
Personaly, I'd use that image directly as a hight_field.
Date: 25 Apr 2010 16:27:37
Message: <4bd4a5b9$1@news.povray.org>
High!
Is POV-Ray nowadays able to use 24-bit heightfields? I never heard of
that...
But even if it would be possible, it will probably be of no use to me,
as my terrain relief should follow the curvature of the planet's surface!
Yadgar
Date: 26 Apr 2010 22:29:36
Message: <4bd64c10@news.povray.org>
You should do an optimization of the mesh before using in POV-Ray. This
will also let you bend the mesh to do curvature, since you're getting a
mesh as a result whose vertices you can move.
Ray
