POV-Ray : Newsgroups : povray.binaries.images : Hour Glass WIP Server Time
22 Nov 2026 16:06:22 EST (-0500)
  Hour Glass WIP (Message 1 to 7 of 7)
Subject: Hour Glass WIP
Date: 21 Feb 2010 16:06:17
Message: <4b81a049@news.povray.org>
Thanks Alain and Darren of suggestions.
Thought I'd share what I have so far. I'm getting some artifacts with the
glass container, and the upright connectors (lathe objects), perhaps my
Bishop skills need further development. I DO have sturm on  but don't know
where they (artifacts) are coming from ... perhaps viewing angle, or
lighting angle
Jim
Download 'HourGlass.png' (600 KB)
Preview of image 'HourGlass.png'
Subject: Re: Hour Glass WIP
Date: 22 Feb 2010 07:52:17
Message: <4b827e01$1@news.povray.org>
> lighting angle
I’ve noticed that even with the sturm flag set, I often get artefacts in
line with the horizon. I wonder if changing the orientation of the scene
would help. I can’t remember many problems with Moray which uses Z = up.
That is pretty expensive marble you’re using with the grain running from
one block through to another. You can add a degree of randomness (if you
are using B3D’s Object Array) by adding a small degree of Rot Axis Offset.
Nice modelling BTW. Is the shape of the hourglass from RL?
Best Regards,
Date: 22 Feb 2010 12:14:37
Message: <4b82bb7d@news.povray.org>
"Stephen" <mca### [at] aolDOTcom> wrote in message
news:4b827e01$1@news.povray.org...
thanks for the tip ... I'll give that a try!
ha-ha ... yes the texture was just a quick and dirty effort for now,
I have a little random routine that I had not cloned from another scene yet!
yes ... it WAS in the shop last year and didn't sell. I liked it so it's on
my desk now ;-)
I'm having a good time with Bishop and I like it. Modelling in general is
hard and it takes a lot of patience. I've also had to get in the habit of
saving more often especially when I finally get something looking like I
want.
Jim
Date: 22 Feb 2010 15:20:05
Message: <4b82e6f5$1@news.povray.org>
It didn’t work for me. :(
I’ve been meaning to spec a variant to the object array that adds a
random variation to the objects, for a while. Also a tab to translate
the texture would be useful.
> my desk now ;-)
The glass seams less “teardrop” shaped than I’ve seen before. Very
attractive, though.
I’m glad that you like it. I’ve spent a long time, along with your
countryman StephenS, guiding its development. Wait until you try the
animation features ;)
> want.
Hint: When you save a scene the last save is renamed as MyScene.bak, so
you can revert by renaming the extension to .bsp. Also, I like the Undo
Multiple feature.
Best Regards,
Date: 23 Feb 2010 13:03:56
Message: <4b84188c@news.povray.org>
news:4b82e6f5$1@news.povray.org...
I had camera y and look_at y the same. A couple of degrees of x rotation
made most of the artefacts go away, the rest appear to be ripples in the
lathe shape itself. I imagine a few more strategic points probably wouldn't
hurt!
Jim
Date: 23 Feb 2010 13:54:53
Message: <4b84247d@news.povray.org>
Actually Thomas deG once recommended that you should roll the camera a
bit, for artistic effect.
> hurt!
That sometimes helps as well ;-)
Best Regards,
Date: 24 Feb 2010 03:17:42
Message: <4b84e0a6@news.povray.org>
"Stephen" <mca### [at] aolDOTcom> schreef in bericht
news:4b84247d@news.povray.org...
hehe! Indeed...  :) just a couple of degrees.
It more or less simulate the fact that nobody is holding a camera perfectly
level. And it adds an extra, unconscious, tension to the image that is
difficul to trace back to its origin if you are unaware of the trick.
