POV-Ray : Newsgroups : povray.binaries.images : I need a faster computer. Server Time
29 Nov 2026 02:46:52 EST (-0500)
  I need a faster computer. (Message 1 to 13 of 13)
Subject: I need a faster computer.
Date: 1 Feb 2010 18:10:57
Message: <4b675f81@news.povray.org>
Scene contains 6 frame level objects; 0 infinite.
Statistics for triforce.pov, Resolution 640 x 480
Pixels:          312000   Samples:          312000   Smpls/Pxl: 1.00
Rays:          20049467   Saved:            579731   Max Level: 10/10
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                         7642950539      5029906249     65.81
CSG Intersection            1606762390       586731732     36.52
Bounding Box                4711634819      3005395253     63.79
Light Buffer                8364355053      5795374111     69.29
Vista Buffer                   1202459          901250     74.95
Calls to Noise:                  0   Calls to DNoise:             10
Media Intervals:          24236446   Media Samples:        690560487 (28.49)
Shadow Ray Tests:       1197618743   Succeeded:            575085574
Reflected Rays:           10840576   Total Internal:         5663492
Refracted Rays:            6429680
Transmitted Rays:          2408330
Number of photons shot:          58881
Surface photons stored:         563400
Media photons stored:         25211616
Priority queue insert:    159359134552
Priority queue remove:     93253179332
Gather function called:        3608877
Smallest Alloc:                 25 bytes   Largest:           327704
Peak memory used:        516015973 bytes
Time For Parse:    0 hours  0 minutes   1.0 seconds (1 seconds)
Time For Photon:   0 hours  2 minutes  28.0 seconds (148 seconds)
Time For Trace:   88 hours 45 minutes  32.0 seconds (319526 seconds)
     Total Time:   88 hours 47 minutes  55.0 seconds (319675 seconds)
CPU time used: kernel 208.67 seconds, user 272669.25 seconds, total
272877.92 seconds
Render averaged 1.13 PPS over 307200 pixels
An i7 ought to do this in 3.5 hours, not 3.5 days.  I'm not even using
antialiasing or very high media/photon settings!
Tim Cook
http://empyrean.freesitespace.net
Download 'triforce.png' (298 KB)
Preview of image 'triforce.png'
Subject: Re: I need a faster computer.
Date: 1 Feb 2010 20:10:01
Message: <web.4b677b40400e2fe6412fad2f0@news.povray.org>
weird indeed!
Date: 1 Feb 2010 22:01:42
Message: <4b679596$1@news.povray.org>
> 272877.92 seconds
> Tim Cook
May be worth looking at your media. Do you have intervals set to
anything larger than 1? Bring back to 1 and adjust samples as needed.
intervals 10 samples 5 is much slower than samples 100 intervals 1.
How many dispersion_samples?
It don't looks like a memory isue, unless you have a ridiculously low
amount in your computer, as you use less than 500 Mb.
Date: 1 Feb 2010 23:52:11
Message: <4b67af7b$1@news.povray.org>
Yeah the media's one thing I need to fix and save back to the library...
Really, the thing that's making it slow is the refractive objects.  I
could slap no_image on them and get the nice media/photon effects in a
few minutes.  Turn off the media and photons and have the tetrahedra on
and it takes a few days.
Is there any way to speed that up?  How do commercial renderers compare
speedwise for refractives?  What do they do differently?
Tim Cook
Date: 2 Feb 2010 03:40:09
Message: <4b67e4e9@news.povray.org>
"Tim Cook" <z99### [at] gmailcom> a écrit dans le message de news:
4b67af7b$1@news.povray.org...
> could slap no_image on them and get the nice media/photon effects in a few
> minutes.  Turn off the media and photons and have the tetrahedra on and it
> takes a few days.
The keyword that comes in mind is adc_bailout... did you try setting it
higher?
Marc
Date: 2 Feb 2010 16:32:32
Message: <4b6899f0$1@news.povray.org>
> Tim Cook
Then, what is your max_trace_level and adc_bailout?
Often, adc_bailout 0.01 is good enough.
Your main problem looks to be many total internal reflections. With
dispersion, you can get total internal reflection for blue, but not for
red. This leads to partial doubling of the rays, blue is reflected but
cyan to red goes through with some added reflection, and the spawning of
still more dispersion rays.
What's the value for dispersion_sample? A somewhat smaller value could
be enough.
One other thing that you can try, rotate the tetrahedra a small bit. It
could be all that's needed to prevent extremely long internal paths.
Some comercials products seems to have quicker bailouts. Other may skip
on the dispersion, or fake it even more than POV-Ray does, or only apply
it for the first or last refractive surface encountered before hiting an
opaque surface. Some don't even support dispersion.
Date: 2 Feb 2010 23:46:02
Message: <4b68ff8a$1@news.povray.org>
Was at default, trying small render with 4 and 0.02 now...
> be enough.
Was 40, trying 20.
Reducing resolution to 400x300...
Fiddling a few other photon settings...
Tim Cook
Date: 2 Feb 2010 23:50:47
Message: <4b6900a7@news.povray.org>
Oh wow.  Just a bit faster (just under a minute)...needs work to get
closer to previous result, but have a starting point.
Tim Cook
Date: 3 Feb 2010 00:50:07
Message: <web.4b690e00400e2fe6412fad2f0@news.povray.org>
from 88 hours to 1 minute is a long way. :)
radiosity and photon blocks also have their own adc_bailout, keep that in mind.
BTW, you surely is really making use of all those threads and cores with 3.7,
right?
Date: 3 Feb 2010 04:16:18
Message: <4b693ee2$1@news.povray.org>
> right?
I'm still crawling along with 3.5, because I use Moray and it doesn't
work with newer.  Here's hoping the team decides to fix it first after
final 3.7 release before waiting for POV 4.
Tim Cook
Date: 3 Feb 2010 07:40:00
Message: <web.4b696e22400e2fe6412fad2f0@news.povray.org>
> > right?
too bad!  In any case, it's a simple scene.  Can't Moray just export the pov
scene and you render that with 3.7?  With your i7, that alone should mean you'd
render it 8x faster at minimum.
Date: 3 Feb 2010 08:59:00
Message: <4b698124$1@news.povray.org>
Alas, I don't have an i7 yet.  That by itself should drop my render
times from 3.5 days to about 3 hours...  T_T
Tim Cook
Date: 3 Feb 2010 15:35:00
Message: <web.4b69dd96400e2fe6412fad2f0@news.povray.org>
oh, I misread it then.  But no, not likely it'd do that without migrating to
multiprocessing 3.7 either.
