POV-Ray : Newsgroups : povray.binaries.images : hf_tools.inc Server Time
11 Oct 2026 23:25:32 EDT (-0400)
  hf_tools.inc (Message 1 to 26 of 26)
Subject: hf_tools.inc
Date: 15 Dec 2009 01:46:52
Message: <4b2730dc@news.povray.org>
Hello,
Here are some example shots from hf_tools.inc, which I just dropped at
p.b.scene-files.
The top two images show the edge pattern at work. The edge pigment in
the upper-left image was rendered at less than one third quality; it
does get better than that :) The upper-right image is using a
pre-rendered edge map at full quality. The edge radius is adjustable.
The bottom left image shows the superellisoidal pigment encasing a
height field. It lets you make smooth transitions from height field to
plane, while keeping more detail at the corners (as opposed to using,
say a spherical pigment).
The bottom right image shows how an angle map can be used to transform
textures according to the different angles of a height field.
Just a few features. Maybe they will prove useful...
Sam
P.S. The upper-right image shows some strange behavior at the height
field's edges. POV-Ray is handling image maps incorrectly, I think.
Download 'hf_tools.jpg' (156 KB)
Preview of image 'hf_tools.jpg'
Subject: Re: hf_tools.inc
Date: 15 Dec 2009 02:43:30
Message: <4b273e22@news.povray.org>
   I'm without words... really. :O
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 15 Dec 2009 03:16:45
Message: <4b2745ed$1@news.povray.org>
"stbenge" <UN### [at] hotmailcom> schreef in bericht
news:4b2730dc@news.povray.org...
Well, that is easy for us to cut off in a difference or intersection.... :-)
This is really incredible. I need to experiment with this now!
You rule, Sam! You rule!
Date: 15 Dec 2009 07:12:54
Message: <4b277d46@news.povray.org>
High!
stbenge wrote:
> Hello,
> p.b.scene-files.
Awesome! When I saw the upper right and lower left image, I instantly
thought "Afghanistan!"... yes, this tool would be great for rugged
desert landscapes on DM +19 279 e XI (or Ghurghusht, how it is called by
its colonists). For real Afghanistan, I better rely on actual elevation
data... but perhaps there might be a way to enrich them with small-scale
erosion details!
See you in Khyberspace!
Yadgar
Date: 15 Dec 2009 10:28:05
Message: <4b27ab05$1@news.povray.org>
Two words:  A Mazing!  ;-)
On 2009-12-15 01:45, stbenge wrote:
> Hello,
> p.b.scene-files.
> Sam
Date: 15 Dec 2009 12:20:00
Message: <4b27c540@news.povray.org>
Holy grab!
Date: 15 Dec 2009 12:21:49
Message: <4b27c5ad$1@news.povray.org>
WOW!
That top left one looks like a polycrystalline surface under high
magnification, it already looks useful!
Date: 15 Dec 2009 13:46:00
Message: <4b27d968$1@news.povray.org>
Jörg 'Yadgar' Bleimann wrote:
> High!
Not yet! Maybe my second cup of coffee will do the trick ;)
> erosion details!
I hope you know that this file _does_not_ produce erosion... That height
map is an example I included from World Machine :/
Date: 15 Dec 2009 13:46:33
Message: <4b27d989$1@news.povray.org>
That's the best way to be, at least until you learn the tool's
limitations ;D
Date: 15 Dec 2009 13:53:12
Message: <4b27db18$1@news.povray.org>
Yeah, but it's an annoying way to go about it. You can always use the
boxed pigment to cut off the edges while building you HF.
After reading Yadgar's reply, I started to worry that everybody thinks
this file can produce erosion... it cannot... It only does what I said
it does, plus some near-useless red/green functions that I'm not
particularly proud of :/
Date: 15 Dec 2009 13:57:51
Message: <4b27dc2f$1@news.povray.org>
Thanks... Hmm, your comment is making me think about height field mazes.
It might just be possible with arrays and a variation of Tek's Cells
pattern...
Date: 15 Dec 2009 14:00:39
Message: <4b27dcd7$1@news.povray.org>
nemesis wrote:
> Holy grab!
Clear the streets, the Caped Crusader is passing through ;)
Date: 15 Dec 2009 14:03:25
Message: <4b27dd7d$1@news.povray.org>
> WOW!
I hope so :)
Date: 15 Dec 2009 16:51:51
Message: <4b2804f7$1@news.povray.org>
Le 2009-12-15 01:45, stbenge a écrit :
> Hello,
> p.b.scene-files.
> Sam
It looks like it can be prety usefull. I'll play with that one.
Date: 15 Dec 2009 19:22:19
Message: <4b28283b@news.povray.org>
Did you use the "once" keyword? Otherwise the image_map will repeat and
the value at 1.0 will be identical to the value at 0.0 by definition.
Date: 15 Dec 2009 20:56:41
Message: <4b283e59@news.povray.org>
Yes, I tried that. I also tried using repeat warps with the flip
command, in the hope that mirrored edges would eliminate the problem. In
theory, it should work, but it doesn't.
I really need to make a small functioning example to provide along with
a bug report.
Date: 15 Dec 2009 20:57:31
Message: <4b283e8b@news.povray.org>
The edge map is probably the most useful feature :)
Date: 16 Dec 2009 03:20:32
Message: <4b289850$1@news.povray.org>
news:4b283e59@news.povray.org...
> I really need to make a small functioning example to provide along with a
> bug report.
I may be talking nonsense here, but those same features are often also
created by WM or GeoControl. I don't remember them from Leveller, but it has
been a while since I last used that app. Do you think they have the same
origin? Are they the same kind of bug?
In GeoControl I can correct manually with a brush, but in hf's from WM I
just cut off a thin slice around from it by using an intersection in POV.
Not very elegant as a solution but it works.
Date: 16 Dec 2009 06:20:00
Message: <web.4b28c11df654043d65f302820@news.povray.org>
Where was this years ago??!!  You've created some real magic here. It must be
the coffee--drink lots more, so you can come up with more cool ideas!
I'm really looking forward to trying this out (and looking over your code, to
glean some ideas from 'the Master.')
Ken
Date: 16 Dec 2009 13:14:52
Message: <4b29239c@news.povray.org>
stbenge escreveu:
>> High!
bwahaha.  Always wanted to do some fun with that... :D
a game sig: http://tinyurl.com/d3rxz9
Date: 16 Dec 2009 14:15:20
Message: <4b2931c8@news.povray.org>
>> bug report.
I doubt they are the same bug.
Check this out:
height_field{
  png"mountains.png"
It works just fine, always has.
Compare it to this:
height_field{
  function 513, 513{
   pigment{
    image_map{
     png"mountains.png"
     interpolate 2 once
This is when edge artifacts show up. The dimensions are correct. The
problem happens regardless of image_map attributes such as interpolation
and repetition.
I would say it's a height_field issue, but I know it's not. I have
encountered this same problem when using image_maps at other times, like
for my luminous bloom code.
Whatever works :)
Date: 16 Dec 2009 14:17:29
Message: <4b293249@news.povray.org>
Drink more coffee? Okay :)
Whatever you do, have fun!
Date: 17 Dec 2009 03:17:52
Message: <4b29e930$1@news.povray.org>
news:4b2931c8@news.povray.org...
> Check this out:
> height_field{
>  png"mountains.png"
> Compare it to this:
> height_field{
>  function 513, 513{
>   pigment{
>    image_map{
>     png"mountains.png"
>     interpolate 2 once
> and repetition.
Ah, right. I see your point. One way or another I have never noticed this
difference. Strange indeed. Thanks for drawing my attention to it.
Date: 17 Dec 2009 10:40:01
Message: <web.4b2a4f8ff654043d65f302820@news.povray.org>
> Check this out:
> height_field{
>   png"mountains.png"
> Compare it to this:
> height_field{
>   function 513, 513{
>    pigment{
>     image_map{
>      png"mountains.png"
>      interpolate 2 once
Yeah, there are some strange goings-on in HFs made from functions.  I think I've
noticed the edge artifacts you mentioned.  But there's also the odd fact that
the applied pattern (or image_map) ends up being flipped upside down(?) like a
mirror-image, AND that the 'origin point' of the pattern/image is out of place.
The usual origin that we all know and love is at <0,0,0>; with a HF function,
the 'origin' is mysteriously at <0,0,1>, and the applied pattern/image
scales out from there. I've come up with simple workarounds to these particular
situations--but, along with the edge artifacts, it's apparent that HF functions
are not working correctly. I suppose, though, that re-engineering the
problematic code (whatever it is!) would cause lots of backward-compatibility
problems with previously-made scenes.
Ken
Date: 18 Dec 2009 06:10:01
Message: <web.4b2b61d2f654043d65f302820@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote:
> ...But there's also the odd fact that
> place...
BY 'image_map,' what I meant to say was "an image_map used as [or used as part
of] the HF function"--not an image_map *texture* applied to the HF afterward
(which is applied as it should be.) Sorry if that confused anyone.
Ken
Date: 18 Dec 2009 14:35:09
Message: <4b2bd96d@news.povray.org>
>> place...
It didn't confuse me, Kenneth :) It's an annoying problem, but easy
enough to work around. It probably should be fixed, but you're right
when saying that by doing so, many older scenes will be broken.
