POV-Ray : Newsgroups : povray.binaries.images : Strange attractors Server Time
11 Oct 2026 23:25:50 EDT (-0400)
  Strange attractors (Message 1 to 36 of 36)
Subject: Strange attractors
Date: 6 Dec 2009 17:38:57
Message: <4b1c3281@news.povray.org>
All that amazing mandelbulb stuff has inspired me to dig out a strange
attractor search/plot app I wrote a few years ago, and try to get some
decent plots into POV-Ray. Here's a few of the nicer ones I've found
over the last couple of weeks.
Bill
Download 'dancer.jpg' (90 KB) Download 'shuriken.jpg' (96 KB) Download 'scribble.jpg' (88 KB) Download 'topshell.jpg' (84 KB) Download 'loop.jpg' (81 KB) Download 'barbwire.jpg' (70 KB) Download 'ribbons.jpg' (81 KB) Download 'hook.jpg' (62 KB) Download 'spidery.jpg' (74 KB) Download 'crownothorns.jpg' (72 KB)
Preview of image 'dancer.jpg'
Preview of image 'shuriken.jpg'
Preview of image 'scribble.jpg'
Preview of image 'topshell.jpg'
Preview of image 'loop.jpg'
Preview of image 'barbwire.jpg'
Preview of image 'ribbons.jpg'
Preview of image 'hook.jpg'
Preview of image 'spidery.jpg'
Preview of image 'crownothorns.jpg'
Subject: Re: Strange attractors
Date: 6 Dec 2009 19:55:33
Message: <4b1c5285$1@news.povray.org>
"Bill Pragnell" <bil### [at] hotmailcom> wrote in message
news:4b1c3281@news.povray.org...
> Bill
AWESOME!!!!
Really, they are WOW images to me :)
I'd love to know some more about how you did this!
Cheers Dre
Date: 6 Dec 2009 21:35:01
Message: <web.4b1c6921e6b3a3e0f99d05c80@news.povray.org>
Lovely...Just lovely!
Date: 6 Dec 2009 22:07:58
Message: <4b1c718e$1@news.povray.org>
Now model a modern art gallery and put these on pedestals therein.
Tim Cook
http://empyrean.freesitespace.net
Date: 7 Dec 2009 03:15:17
Message: <4b1cb995$1@news.povray.org>
Neat! I take it these images are essentially an exorbitant
number of spheres around externally generated data points?
I wondered if it's a blob but I thought some transitions
didn't quite look like it, although it's hard to tell
with the small object size. If it's spheres it might
be worth to try a blob for faster rendering.
Date: 7 Dec 2009 03:28:06
Message: <4b1cbc96$1@news.povray.org>
Strange and attractive, Bill :)
Good work!
Date: 7 Dec 2009 04:10:01
Message: <web.4b1cc63ee6b3a3e06dd25f0b0@news.povray.org>
Thanks! It's just a shame they don't look as good at higher resolutions.
Most of the work is done externally, I'm really only using POV-Ray to plot a
dataset and do pretty lighting. I used some of the equations given on the
Chaoscope website (http://www.chaoscope.org/doc/attractors.htm), originally in a
Java app (the quickest way I knew to implement some sort of gui at the time).
Basically, if the orbit doesn't collapse or escape within a few hundred
iterations I plot it properly for inspection. Most of these turn out to be
mundane, but every now and again an 'interesting' one crops up. At this point I
save the equation coefficients in a data file.
Java is entirely unsuitable for iterating 1e8 points over a 30+ coefficient
dynamical system, so eventually I wrote a simple tool in C++ to do some proper
plotting from the saved coefficients, and (optionally) to write a text file full
of vectors suitable for reading from POV-Ray SDL.
Add some random lights using the data file as a seed, and away we go...
Date: 7 Dec 2009 04:15:00
Message: <web.4b1cc681e6b3a3e06dd25f0b0@news.povray.org>
Good idea! I could make some of them really big, put 2D plots in picture
frames... *gazes into middle distance*
Date: 7 Dec 2009 04:25:00
Message: <web.4b1cc8ece6b3a3e06dd25f0b0@news.povray.org>
Exactly right. :) (See my other post for my somewhat hacky workflow)
The data files vary in size from a few 100k for the thin spindly ones, up to
20MB+ for the more voluminous ones. Luckily even the vast ones are pretty quick
to produce from just the equation coefficient data. The slowest part appears to
be writing the data file!
I tried blobs, but they turn out to be many times slower for this case. These do
use radiosity and multiple area_lights, after all. With antialiasing off, they
render in a couple of minutes (parsing can be longer!). With AA on, an hour or
so.
Actually I quite like the expanded-polystyrene/gritty look that bare spheres
produce!
Date: 7 Dec 2009 11:18:33
Message: <4b1d2ad9$1@news.povray.org>
I Really love "barbwire"... How did you code these ?
> Bill
Date: 7 Dec 2009 16:35:01
Message: <web.4b1d7437e6b3a3e05a5ee9370@news.povray.org>
> Bill
Excellent really interesting shapes, I don't think I will even try to understand
how they were made and just accept I should have paid more attention at school.
It's a shame they don't look as good at high resolutions you could make some
fairly good abstract poster art.
Sean
Date: 7 Dec 2009 21:14:10
Message: <4b1db672$1@news.povray.org>
Beter yet:
Make them *for real!*
Date: 7 Dec 2009 21:17:26
Message: <4b1db736$1@news.povray.org>
> so.
> produce!
You could output as DF3 file and render as an isosurface. You also could
render those as media. It can be worth a try.
Date: 8 Dec 2009 04:15:01
Message: <web.4b1e17e7e6b3a3e06dd25f0b0@news.povray.org>
That was the first method I tried. However, the df3 is very wasteful since most
of the volume is empty. Furthermore, the df3s for these examples would be at
least 512MB each! During testing at ~100x100x100, I found that generating,
reading in and rendering a df3 was much slower than the method I'm currently
using for a volume 64x larger.
I'm using a 3d vector<bool> to store the volume during iteration, then only
write out the voxel coordinates that were hit. That way, memory usage and file
size is at a minimum and I throw away all the empty locations. Unfortunately, I
also throw away the cumulative information, but it's very quick to iterate so
I'll probably come back and do something with it in future.
Bill
Date: 8 Dec 2009 04:20:01
Message: <web.4b1e1987e6b3a3e06dd25f0b0@news.povray.org>
Yes, I like that one too - looks like the Sorting Hat from Harry Potter!
The equations can be found here:
Using different coefficients in these equations produces different attractors
(although most combinations don't produce an attractor - you need to 'search'
random combinations of coefficients to find interesting shapes). Each new point
is calculated from the previous point, and the attractor is built up point by
point. It's just a matter of storing those points and plotting them, either as a
2D projection, or in 3D.
I wrote a java app some time ago to search for and plot attractors, but I had to
rewrite the plotting in C++ (for speed) to get data files that I could then read
into POV-Ray.
Bill
Date: 8 Dec 2009 10:52:48
Message: <4b1e7650$1@news.povray.org>
Looks like a job for a 3D printer!   :-)
Here's one for only $5000:  http://www.desktopfactory.com/our_product/
> Beter yet:
> Alain
Date: 8 Dec 2009 13:36:00
Message: <4b1e9c90$1@news.povray.org>
>> Beter yet:
>> Alain
I've seen one made out from an old ploter converted with the laser from
an old fax machine. You can also reuse one from any old laser printer.
It could create stuning models out of ordinary sugar with a granyness of
about 0.5mm.
It can be home made for under $100 or about, and the functioning cost is
prety low.
Date: 8 Dec 2009 15:18:10
Message: <4b1eb482$1@news.povray.org>
I've seen demos of that as well.  In one instance, they "printed" a
chain made out of sugar, with the links already connected.
The raw materials are very cheap.  It's a fast-moving field of research
and development.  Very exciting stuff.  In another 10 years, we might
have machine to fabricate 3D objects out of all kinds of materials,
including food!
Imagine the possibilities:
Strange Attractor Crackers
Chocolate Mandelbulbs
Menger Sponge Cake
Cantor Cheese Logs
Moebius Strip Steaks
Solenoid Licorice
(see http://www.dgp.toronto.edu/~mjmcguff/codeGallery/*)
* Many years ago, I wrote code to generate Pickover's solenoids in POV-Ray.
>>>> picture
>>> Beter yet:
>>> Alain
> about 0.5mm.
> prety low.
> Alain
Date: 8 Dec 2009 15:20:32
Message: <4b1eb510$1@news.povray.org>
They didn't teach anything like that when I was in school, although I
still didn't pay enough attention.
My mind managed to completely block out all memories of differential
equations completely.  To this day I couldn't tell you the first thing
about them.  :-)
But thanks to POV-Ray, I'm very comfortable with trigonometry!
>> Bill
> Sean
Date: 8 Dec 2009 19:05:00
Message: <web.4b1ee97be6b3a3e077a8e84e0@news.povray.org>
> about them.  :-)
I'm sure I would have paid a lot more attention if they had used POV to try to
teach me (although I don't think it was around back then...). Still, my daughter
was the only pupil in her class that knew what a radius was as she had asked me
how I created pictures on the computer and I had shown her how to make a very
basic scene. I'm sure using something like POV would make the lessons much more
memorable.
Sean
Date: 8 Dec 2009 19:10:03
Message: <web.4b1eea9ae6b3a3e04726e92b0@news.povray.org>
> Bill
Wow, those are awesome Bill! I wrote a little app a couple of years back to plot
2d attractors but never came up with anything as cool as your 3d versions. The
renders are very artistically done - I love the lighting.
Seeing these made me go searching through my own stuff - here's one I did that's
a "morph" between two attractors. I loaded the data sets into SDL arrays and
used elements from each array as cylinder endpoints (with gradient pigments
along their arbitrary axes). Good times.
Rob
http://www.McGregorFineArt.com
Download 'attractormorph1.png' (2179 KB)
Preview of image 'attractormorph1.png'
Date: 8 Dec 2009 19:15:02
Message: <web.4b1eeb52e6b3a3e04726e92b0@news.povray.org>
And here's another one where I used the attractor data to generate a height
field and associated pigment.
Download 'attractor_hftest2.png' (1430 KB)
Preview of image 'attractor_hftest2.png'
Date: 9 Dec 2009 05:15:00
Message: <web.4b1f777be6b3a3e06dd25f0b0@news.povray.org>
Thanks!
Random colours and positions, seeded by the data file. Usually needs a bit of a
tweak to get a nice combo, but quite handy!
Looks interesting - it's a pity you can't quite make out the attractors'
shapes... good idea though. I might try an animation using my sphere technique,
if I turn off AA they only take a minute or so.
Bill
Date: 9 Dec 2009 06:00:00
Message: <web.4b1f82fde6b3a3e0f48316a30@news.povray.org>
Gobsmackingly goodlooking!
But I think you got the spidery one wrong:  looks more like a butterfly and a
very good looking one at that!
Povray abstracts at its best, ladies and gentleman! :D
Date: 9 Dec 2009 06:30:00
Message: <web.4b1f8943e6b3a3e06dd25f0b0@news.povray.org>
Hehe, naming was an issue, until I decided to call them the first noun that came
to mind when looking at the 2D plot. Some of them look utterly different in
3D... :)
There's plenty more. I'll put them all up on a web page at some point :)
Date: 9 Dec 2009 08:35:11
Message: <4b1fa78f$1@news.povray.org>
What a good idea to use that background. :D
Best Regards,
Date: 9 Dec 2009 08:40:01
Message: <web.4b1fa796e6b3a3e04726e92b0@news.povray.org>
Ah, excellent point - here are the source attractors for the morph.
-Rob
Download 'sourceattractors.png' (325 KB)
Preview of image 'sourceattractors.png'
Date: 9 Dec 2009 08:55:00
Message: <web.4b1fab7de6b3a3e04726e92b0@news.povray.org>
This morning I found this morph animation in a subfolder of my attractors
folder; I had completely forgotten about it! Originally rendered as an 1920x1080
(HD) AVI, I just squashed it down into this little MPEG-4 to post here.
-Rob
Download 'morph1.mp4.mpg' (92 KB)
Date: 9 Dec 2009 09:05:00
Message: <web.4b1fae64e6b3a3e06dd25f0b0@news.povray.org>
That's fascinating! I take it these two attractors use the same set of
equations? It looks like it - there appears to be a certain congruence between
some of the features (if that's the right phrase!).
I've got to try this!
Date: 9 Dec 2009 09:28:32
Message: <4b1fb410$1@news.povray.org>
I like them all.
A worthy tribute to chaos theory.
Paolo
> Bill
Date: 9 Dec 2009 11:23:28
Message: <4b1fcf00$1@news.povray.org>
My primary suggestion is to try making stereoscopic pairs. I found that to
be great fun when I was playing with such stuff. It really brings out the
complexity better.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 9 Dec 2009 14:10:00
Message: <web.4b1ff4dde6b3a3e086ff1d480@news.povray.org>
Well, my little app calculates Lyapunov exponents based on some random numbers,
looping over the function until I get lucky and the series doesn't tend toward
zero or infinity. Then it creates 100,000 or so particles and draws a preview in
the viewport. If I like what I see I can click a button that saves the data as a
POV include file (an array of vectors) along with the preview bitmap, or click a
"Try Another" button to start over. I saved off more than a hundred interesting
varieties over the couple of weeks that I was exploring these types of
attractors.
Something I found really exciting and fascinating was seeing a real-life
attractor a couple of months later, one I thought I recognized from my
experiments! It was early June, 2007, nearing sunset here on the east coast of
Florida and the space shuttle had launched about 15 miles from my home. Some
weird chaotic upper air currents were doing an attractor dance up there and the
smoke trail left by the shuttle showed the pattern. I grabbed my camera and took
a few shots for posterity. Here's the attractor saved by my app preview and the
similar real-life version:
Download 'shuttleattractorcloud.jpg' (92 KB)
Preview of image 'shuttleattractorcloud.jpg'
Date: 9 Dec 2009 14:55:01
Message: <web.4b1fffdce6b3a3e0773c9a3e0@news.povray.org>
Life imitates art. :)
glad you're quick on the camera!
Date: 10 Dec 2009 04:27:43
Message: <4b20bf0f$1@news.povray.org>
"Robert McGregor" <rob### [at] mcgregorfineartcom> schreef in bericht
news:web.4b1ff4dde6b3a3e086ff1d480@news.povray.org...
> coast of
> Some
> and the
> and took
> and the
Incredible! This is a fantastic experience.
Date: 12 Dec 2009 22:21:45
Message: <4b245dc9$1@news.povray.org>
>> about 0.5mm.
>> prety low.
The CupCake 3D printer kit is $750.
http://store.makerbot.com/cupcake-cnc.html
The RepRap Darwin runs about $400 in parts,
they're close to finalizing the Mendel model as well.
There's a nice photo of some printed objects on display
at Massey University on the front page.
http://reprap.org/bin/view/Main/WebHome
Date: 13 Dec 2009 01:09:53
Message: <4b248531$1@news.povray.org>
That looks great! I wonder if it's possible to render something similar
to the clouds/smoke, instead of just a lot of spheres...
