POV-Ray : Newsgroups : povray.binaries.images : 'Accidental' isosurface Server Time
29 Nov 2026 03:11:00 EST (-0500)
  'Accidental' isosurface (Message 1 to 50 of 68)
Goto Latest 50 Messages Next 18 Messages >>>
Subject: 'Accidental' isosurface
Date: 16 Nov 2009 20:30:15
Message: <4b01fca7@news.povray.org>
After seeing the mandelbulb getting some press recently on slashdot, I
started to wonder how close I could get with povray.
I forgot to segment the parts of the isosurface into the x,y,z
components (added them instead), and this happened, at least it's fun
looking.
#local n = 8;
#local r = function{sqrt(pow(x,2)+pow(y,2)+pow(z,2))};
#local theta = function{atan2(sqrt(pow(x,2)+pow(y,2)),z)};
#local phi = function{atan2(y,x)};
isosurface{
   function {
pow(r(x,y,z),n)*(sin(theta(x,y,z)*n)*cos(phi(x,y,z)*n)+sin(theta(x,y,z)*n)*sin(phi(x,y,z)*n)+cos(theta(x,y,z)*n))
   threshold 0
   max_gradient 57
   contained_by {sphere{0,1}}
   texture{
     pigment{color rgb 0.8}
     finish{ambient 0 diffuse 1}
Download 'mandelball.jpg' (22 KB)
Preview of image 'mandelball.jpg'
Subject: Re: 'Accidental' isosurface
Date: 17 Nov 2009 17:05:40
Message: <4b031e34$1@news.povray.org>
That's cool.
I've been wondering the same thing, but I haven't made any effort to
find out if it's possible to do the Mandelbulb in POV.  I figure someone
who knows a lot more than me will figure it out first.
> looking.
> #local n = 8;
> isosurface{
> function {
> threshold 0
> max_gradient 57
> texture{
Date: 19 Nov 2009 07:51:56
Message: <4b053f6c$1@news.povray.org>
> I've been wondering the same thing, but I haven't made any effort to find
> out if it's possible to do the Mandelbulb in POV.  I figure someone who
I think it would be easiest (ie not take 400 years) if you made a program in
a faster language (eg C++) to write a df3 file, and then used POV to render
the df3 file as an isosurface.
Date: 19 Nov 2009 09:06:56
Message: <4b055100$1@news.povray.org>
>> someone who knows a lot more than me will figure it out first.
> program in a faster language (eg C++) to write a df3 file, and then used
> POV to render the df3 file as an isosurface.
Like this?
http://news.povray.org/povray.binaries.animations/thread/%3Cweb.4b02da71bde7fd6d299b4a940%40news.povray.org%3E/
That 256x256x256 df3 took a few minutes to generate on my machine, so
the proof of concept works.
I haven't optimized the code too far yet, it's still using the trig
functions, but it can be used for any value N. It's ready to render a
XxYxZ resolution mesh at any zoom, defined by passing min and max values
for each dimension. Unfortunately it's not multi-threaded yet either,
but as soon as I learn a bit more about how to write that, the structure
of the code will require very little modification to allow that.
Chris
Date: 19 Nov 2009 10:12:12
Message: <4b05604c@news.povray.org>
> Like this?
> That 256x256x256 df3 took a few minutes to generate on my machine, so the
Hehe I just did the same :-)  Mine was 1024x1024x1024 df3 file which took
about half an hour multithreaded under c#.net (I decided the speedup I could
get by easy multithreading in c# outweighed the speedup I could get with C++
over C#).  The render only took about 2 minutes, it's just an isosurface and
a few lights.
Yeh mine too, it looks like there should be a way to lose the trig even with
N=8, but it might get a bit scary...
> Unfortunately it's not multi-threaded yet either, but as soon as I learn a
> bit more about how to write that, the structure of the code will require
Yeh, I chose to do it under C# because it's very easy to do the
multithreading on there and I have no experience of doing multithreading on
normal C++.  I just wanted to get something working this afternoon to see
what it looked like.
The issue is that the isosurface is still made up of millions of little cube
shaped voxels, I think the only way to improve that is to write a
fractal-ray tracer too!  Or maybe patch POV...
Download 'mandelbulb.jpg' (112 KB)
Preview of image 'mandelbulb.jpg'
Date: 19 Nov 2009 10:58:33
Message: <4b056b29$1@news.povray.org>
scott wrote:
>> Like this?
> took about half an hour multithreaded under c#.net (I decided the
> speedup I could get by easy multithreading in c# outweighed the speedup
> I could get with C++ over C#).  The render only took about 2 minutes,
> it's just an isosurface and a few lights.
> with N=8, but it might get a bit scary...
>> learn a bit more about how to write that, the structure of the code
> on normal C++.  I just wanted to get something working this afternoon to
> see what it looked like.
> cube shaped voxels, I think the only way to improve that is to write a
Amazing!  I wish I was half as smart as all these programmers around
here.  I'd love to see a large and detailed render.
Date: 19 Nov 2009 14:08:06
Message: <4b059796$1@news.povray.org>
scott wrote:
>> Like this?
g
o
	Well, if your compiler supports OpenMP, the multithreading is as
simple as including omp.h and writing "#pragma omp parallel for
shared(a)" just before your outer loop (where "a" is the name of the
array in which you store your results)...
See: https://computing.llnl.gov/tutorials/openMP/
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
Date: 19 Nov 2009 20:29:15
Message: <4b05f0eb$1@news.povray.org>
... or use the "interpolate" keyword?
If you use tricubic interpolation, you may want to change your generator
program though, to output not values 0 and 255, but something like 64
and 192, as some versions of POV-Ray have bugs in the interpolation code
that may otherwise cause artifacts due to "overshoot".
Date: 20 Nov 2009 02:47:53
Message: <4b0649a9@news.povray.org>
It's already using interpolate 1 (interpolate 2 was very slow and I couldn't
see much difference from this zoom), but as all voxels are either 0 or 255
you still get a very rough look.
> program though, to output not values 0 and 255, but something like 64 and
> 192,
Yeh good idea, I could do something clever in the df3 generator to output a
varying value depending on how "close" the voxel is to the border.
Date: 20 Nov 2009 07:38:42
Message: <4b068dd2@news.povray.org>
> Amazing!  I wish I was half as smart as all these programmers around here.
Better?  There are still artifacts due to the discrete nature of the df3
file, but I'm working on it.
Generating a df3 file from code outside of POV is not very hard.  And I just
copied the formulas to generate the fractal from the websites referenced.
Download 'mandelbulb4.jpg' (490 KB)
Preview of image 'mandelbulb4.jpg'
Date: 20 Nov 2009 08:10:49
Message: <4b069559$1@news.povray.org>
That's an interesting effect though. Looks like knitwear or the like.
Date: 20 Nov 2009 18:05:01
Message: <web.4b07204bce81d185f99d05c80@news.povray.org>
I modified the (illegal, but still renders) recursive function formulation
posted by Warp and managed to get a straight SDL isosurface.  This is the result
of six iterations.  The render time isn't too terribly bad if you can find a
good combination of accuracy and max_gradient.  Due to the object's fractal
nature, the reported maximum gradient doesn't help, though.
Shutdown Warning: The maximum gradient found was 1019075328.000, but
 max_gradient of the isosurface was set to 2048.000. The isosurface may contain
 holes! Adjust max_gradient to get a proper rendering of the isosurface.
-David
Download 'mandelbulb8i6.015.png' (602 KB)
Preview of image 'mandelbulb8i6.015.png'
Date: 20 Nov 2009 18:10:24
Message: <4b0721e0$1@news.povray.org>
> -David
Nice!
Now figure out how to zoom in to get all the fun details... ;)
Chris
Date: 20 Nov 2009 21:10:01
Message: <web.4b074bd3ce81d185f99d05c80@news.povray.org>
CShake wrote:
> Nice!
Thanks!
Since it's a just an isosurface, all you have to do is move the camera closer
and adjust the accuracy and max_gradient proportional to the "zoom level".
This is still six iterations.
~David
Download 'mandelbulb8i6-closer.png' (346 KB)
Preview of image 'mandelbulb8i6-closer.png'
Date: 20 Nov 2009 23:10:02
Message: <web.4b076760ce81d185f99d05c80@news.povray.org>
Oh, and here is the same view with the isosurface function limited to eight
iterations.
I just found the function also works well, and is far, far quicker, as a media
density.
Good times.
~David
Download 'mandelbulb8i8-closer.png' (346 KB)
Preview of image 'mandelbulb8i8-closer.png'
Date: 21 Nov 2009 02:06:05
Message: <4b07915d@news.povray.org>
> iterations.
> density.
> Good times.
> ~David
Well, I'm seeing that the actual surface generation and rendering is
probably best left to people like you who seem to get good results, so I
figured I might as well go another direction with it.
Instead of going for the full 3d, as many of you are, I decided to make
a way to get 2d 'slices' of this beast that allow for nice smooth
coloring based on divergence rate, like most of the pictures for the
original Mandelblot, instead of only edge finding like everyone seems to
be doing with this so far. I wrote some code that will generate
grayscale images based on number of iterations according to various
parameters.
Here is one slice, generated with parameters mirroring povray:
center = <0.7275,0.272,0.5>
right = <0.001,0,0>
up = <0,0.001,0>
n = 8
max_iterations = 200
This image is NOT pov-created, but can be used for patterns and the
like. It was originally generated at 5000x5000 (.png) which took about a
minute, then downsized for uploading here.
C++ source available on request, the only dependencies are ImageMagick
for creating the image file itself, and a compiler supporting OpenMP.
Download 'mb_slice_demo.jpg' (270 KB)
Preview of image 'mb_slice_demo.jpg'
Date: 21 Nov 2009 11:10:01
Message: <web.4b080fc0ce81d185f4c648ed0@news.povray.org>
> a few lights.
Nice work, Scott. And others!
I have a slow old machine, with only 768MB of RAM, so my renders take a bit
longer, and my biggest so far is 800³, which you can see below.
I'm especially jealous of that special version of povray that can do custom
fractal functions. :) But I suppose it's probably slower than using a density
file. (I haven't played with them much before, and I'm frankly amazed at how
fast those things parse, even fairly huge ones.)
I *think* I figured a way to do this Mandelbulb function using standard SDL. We
don't need the ability to do arbitrarily deep iterations, since 6 or
7 are quite adequate. So we could unroll the iteration loop... into a veritable
rats' nest of functions, which would probably involve lots of duplicated
evaluations & be incredibly slow. :)
You can lose the trig functions by using the formulae of sin(2t) & cos(2t) in
terms of sin(t) & cos(t). We want the 8th power, so we just double the angle 3
times. My first explorations of the Mandelbulb used Python to generate the voxel
data, but I translated my code to C today, and it should compile with no
problems on any system (if it supports doubles :)).
To avoid clutter, I'll post my C source in a separate message in this thread.
Your renders look a fair bit smoother than mine. What accuracy are you using on
the isosurface, and what sort of max_gradient for that size grid? The one below
uses max_gradient 1072, accuracy 0.002.
The pigment on the attached image is just function{sqrt(x*x+z*z)*4.5}, with an
old favourite colour map I created many years ago when I was writing 2D
Mandelbrot programs on the Amiga.
Download 'mandelbulbg8sa90.jpg' (160 KB)
Preview of image 'mandelbulbg8sa90.jpg'
Date: 21 Nov 2009 11:20:00
Message: <web.4b08128dce81d185f4c648ed0@news.povray.org>
Simple "Mandelbulb" C source code.
Compile with
gcc -o Mandelbulb Mandelbulb.c -lm -O3
 * Mandelbulb
 * Written by PM 2Ring November 2009.
 * Converted from Python to C, 2009.11.21
From http://www.skytopia.com/project/fractal/mandelbulb.html
Similar to the original 2D Mandelbrot , the 3D formula is defined by:
z -> z^n + c
....but where 'z' and 'c' are hypercomplex ('triplex') numbers, representing
Cartesian x, y, and z coordinates. The exponentiation term is defined by:
{x,y,z}^n = r^n {sin(theta*n) * cos(phi*n), sin(theta*n) * sin(phi*n),
cos(theta*n)}
where
r = sqrt(x^2 + y^2 + z^2)
theta = atan2(sqrt(x^2+y^2), z)
phi = atan2(y, x)
n is the order of the 3D Mandelbulb. Use n=8 to find the exact object in this
article.
The addition term in z -> z^n + c is similar to standard complex addition,
and is simply defined by:
{x,y,z}+{a,b,c} = {x+a, y+b, z+c}
The rest of the algorithm is similar to the 2D Mandelbrot!
#include <math.h>
#include <stdio.h>
#include <time.h>
//Compute sin(8t) & cos(8t) given r*sin(t), r*cos(t) & r
void trig8(double *ps, double *pc, double r)
    //int i;
    double c = *pc, s = *ps, t;
    if (r > 0.0)
        s /= r;
        c /= r;
        //Iterate formulae for sin(2t) & cos(2t) 3 times
        //to get sin(8t) & cos(8t)
        //for (i=0; i<3; i++)
            t = 2.0*s*c; c = c*c - s*s; s = t;
        *ps = s;
        *pc = c;
//Determine if voxel (cx, cy, cz) is in the Mandelbulb
int Mandel3D(double cx, double cy, double cz, int iters)
    double x = cx, y = cy, z = cz, w, w2, r, r2, r8,
    sth8, cth8, sph8, cph8;
    int i;
    for (i=0; i<iters; i++)
        //Convert (x, y, z) coordinates to polar (r, th, ph)
        w2 = x*x + y*y;
        w = sqrt(w2);
        r2 = w2 + z*z;
        r = sqrt(r2);
        if (r >= 2.0)
            return 0;
        //Raise (r, th, ph) to the 8th power
        sth8 = w; cth8 = z; trig8(&sth8, &cth8, r);
        sph8 = y; cph8 = x; trig8(&sph8, &cph8, w);
        //(r, th, ph) <- c + (r, th, ph)^8
        r8 = r2 * r2 * r2 * r2;
        x = cx + r8 * sth8 * cph8;
        y = cy + r8 * sth8 * sph8;
        z = cz + r8 * cth8;
    return 1;
int Mandelbulb(double vx, double vy, double vz, double scale, int side, int
iters, char *fname)
    FILE *f;
    unsigned char *row;
    int i, j, k;
    time_t itime;
    double x, y, z;
    if(!(f = fopen(fname, "wb")))
        return 1;
    if(!(row = (unsigned char *) malloc(side)))
        return 1;
    //Write header: voxel grid dimensions in little endian
        unsigned char lo = side & 0xff, hi = side >> 8;
        fprintf(f, "%c%c%c%c%c%c", hi, lo, hi, lo, hi, lo);
    itime = time(NULL);
    for (k=0; k<side; k++)
        //Planes
        z = vz + scale * k;
        for (j=0; j<side; j++)
            //Rows
            y = vy + scale * j;
            for (i=0; i<side; i++)
                //Voxels
                row[i] = Mandel3D(vx + scale * i, y, z, iters) ? 255 : 0;
            fwrite(row, 1, side, f);
        if (k%10 == 0)
            int n = (int) difftime(time(NULL), itime);
            //fputc('.', stderr);
            fprintf(stderr, "\r %2d:%02d:%02d Plane %d of %d ",
                n/3600, (n/60)%60, n%60, k, side);
    free(row);
    fclose(f);
    return 0;
int main(int argc, char *argv[])
    int side, iters, rc;
    char *fname;
    double r, scale;
    side = argc > 1 ? atoi(argv[1]) : 100;
    fname = argc > 2 ? argv[2] : "Mandelbulb.df3";
    iters = argc > 3 ? atoi(argv[3]) : 7;
    r = 1.1;    //Mandelbulb Set "radius"
    //r = 1.05 * (1.0 + 2.0 / side);
    scale = 2.0*r / (side - 1);
    rc = Mandelbulb(-r, -r, -r, scale, side, iters, fname);
    fputc('\n', stderr);
    return rc;
Date: 21 Nov 2009 13:49:12
Message: <4b083628@news.povray.org>
  Why does it have to be an isosurface? If you created a mesh out of it,
it would probably render about a thousand times faster, in which case
you could start adding fancy texturing, lighting and other effects
without having to wait until the Sun dies.
Date: 21 Nov 2009 20:50:01
Message: <web.4b089876ce81d185f99d05c80@news.povray.org>
Wow!  That's gorgeous!  I can imagine some good uses for it.
To see about making an animated fly-through, I zoomed way in by using trace() to
place the camera on a surface a few iteration levels above the look_at point on
the iteration ten (10) surface here rendered.  Since I picked starting and
target points more-or-less at random, I have no idea where this surface is, and
there is only a single light source placed at the camera location.  I also
shrunk the contained_by (too much, it turned out) to avoid overheating the CPU
when the sun goes nova.
Are we having too much fun yet?
~David
  Trace Time:       1 hours 45 minutes 26 seconds (6326.522 seconds)
              using 8 thread(s) with 47526.303 CPU-seconds total
Download 'mb8i10_zoom_1.png' (220 KB)
Preview of image 'mb8i10_zoom_1.png'
Date: 21 Nov 2009 23:46:26
Message: <4b08c222@news.povray.org>
> ~David
Here's another one, grayscale generated in c++ in 5 minutes or so
(5000x5000), used as an image_pattern in povray with a color map
applied, rendered at 2500x2500 (15 seconds), then resized down for
upload (and to smooth a bit).
The hardest part is finding where to zoom in actually, there are a lot
of places with nothing, then others with lots of curved lines going the
same way.
Download 'mbslice_colored3.jpg' (281 KB)
Preview of image 'mbslice_colored3.jpg'
Date: 22 Nov 2009 00:18:17
Message: <4b08c999$1@news.povray.org>
I dare you to render this thing as glass.
Tim Cook
http://empyrean.freesitespace.net
Date: 22 Nov 2009 04:15:01
Message: <web.4b090044ce81d185f4c648ed0@news.povray.org>
Hi, Warp.
How do you turn a df3 density file into a mesh? Or do you mean convert the voxel
data into a mesh before feeding it to povray? Is there an easy way to do this? I
know how to turn a heightfield into a mesh, but not a solid 3D object like the
Mandelbulb, with its many internal holes.
Here is a monochrome GIF anim of XY plane cross sections through a 121³ voxel
Mandelbulb. (174410 bytes)
http://i2.photobucket.com/albums/y43/PM2Ring/Mandel3danim2a.gif
Here's my most recent render, a stereo pair using 500³ voxels.
Download 'mandelbulbg9rls90.jpg' (149 KB)
Preview of image 'mandelbulbg9rls90.jpg'
Date: 22 Nov 2009 11:15:01
Message: <web.4b096336ce81d1854861b0db0@news.povray.org>
So is this a function that you have defined within povray for the isosurface or
are you using a df3 file?
Instead of fiddling with user-definable functions within povray I added a new
function to povray's fnintern.cpp which allowed me to render mandelbulbs with
povray.
The patch:
http://softwareprocess.es/x/x/mandelbulb/fnintern.cpp.patch
How I call it:
http://softwareprocess.es/x/x/mandelbulb/mandelbulb.pov
And a description of how I got here:
http://softwareprocess.us/index.cgi/Mandelbulb
I really think the functional approach is superior to the voxel approach since
getting 1000x1000x1000 voxels is time consuming and space consuming.
But if you did define your own function in isosurface I'd love to see it.
abram
Download '1povaa.640480.png' (182 KB)
Preview of image '1povaa.640480.png'
Date: 22 Nov 2009 11:32:22
Message: <4b096796$1@news.povray.org>
> povray.
> The patch:
> How I call it:
> abram
Very nice!
I was hoping that someone would take that approach, I looked into the
source but didn't understand it quite well enough to make my own patch.
On that note, I wonder if it would be feasible to add some sort of
user-defined recursive function to the fractal class (z=z^n+c for this,
but replace that ^n part with whatever you want), much like
julia_fractal takes the function name as a parameter. It would make POV
into a very usable fractal generator, since the raytracing side of it is
so well defined already, and most of the other fractal tracers are
homebrew contraptions that are struggling to get good shading but have
the math down.
Date: 22 Nov 2009 13:16:14
Message: <4b097fee$1@news.povray.org>
  You don't turn a df3 density file into a mesh. You calculate a mesh
from the original fractal.
  (Granted, it's not a trivial task, requiring using something like the
marching triangles algorithm, but still beneficial in terms of rendering
speed.)
Date: 22 Nov 2009 13:53:32
Message: <4b0988ac$1@news.povray.org>
> povray.
Good stuff!
However, regarding the return value, note that the "threshold" parameter
in the isosurface statement is a /borderline/ value; with your
implementation, the default value will cause the isosurface to misbehave
in situations where "insideness" needs to be tested. This can easily be
fixed by using an isosurface threshold of e.g. -0.5, but I think it
would be more elegant to have the function return -1 and 1, respectively.
I'd also be curious whether rendering speed might be improved by
choosing different return values, that might give POV-Ray a hint how
close it might be to the surface. Anyone some experience with that?
Date: 22 Nov 2009 14:15:00
Message: <web.4b098d69ce81d185f99d05c80@news.povray.org>
It's a pair of functions, one to do the iterations, and another to return a
value suitable for making an isosurface.  The plan was to add additional
functions better suited to use as a pattern, media, etc.
> povray.
I agree, and thanks for making the patch available.  I may take a whack at
modifying it to use  PM 2Ring's trigless algorithm.
OK.  I've avoided posting it since it's an illegal recursive function and can
crash 3.7.  It seems to work only when there is just one recursive function
defined, and this recursive function does not call any other user-defined
function.  There are posts to this site showing how to unroll these type of
functions using macros to make everything legal, and I may try that, as well.
However, to make a good isosurface I found it necessary to modify the return
value so it is no longer strictly a step function returning a value proportional
to just the iteration number.  It seems this is needed so the isosurface's
surface normal can be calculated correctly, and it also speeds rendering and
works with lower max_gradient and larger accuracy values.  I probably don't have
the quite the right formulation yet, but what's below works pretty well.
~David Wagner
P.S. Attached are some Easter eggs courtesy of the Basic scene template.
// Persistence of Vision Ray Tracer Scene Description File
// File: mandelbulb.inc
// Vers: 3.6.1, 3.7
// Desc: Mandelbulb Functions
// Date: 11/18/09
// Auth: David Wagner
//Making the return value a float by adding how close to the radius of
convergence REALLY helps!
//Returns 0 to mb_imax+2?  Taking off 3 seems to work best.
//This new version seems to have interior surfaces, too.
#declare mb_fn_iterator_frac = function(mb_i,mb_imax, mb_in, x,y,z,
mb_ix,mb_iy,mb_iz) {
   select(mb_i > mb_imax | pow(mb_ix,2) + pow(mb_iy,2) + pow(mb_iz,2) >4, 0,
      mb_fn_iterator_frac(mb_i+1,mb_imax, mb_in, x,y,z,
         x + pow(pow(mb_ix,2) + pow(mb_iy,2) + pow(mb_iz,2) , mb_in/2)
             * sin( atan2( sqrt(pow(mb_ix,2) + pow(mb_iy,2)), mb_iz) * mb_in)
             * cos( atan2(mb_iy,mb_ix) * mb_in),
         y + pow(pow(mb_ix,2) + pow(mb_iy,2) + pow(mb_iz,2) , mb_in/2)
             * sin( atan2(mb_iy,mb_ix) * mb_in),
         z + pow(pow(mb_ix,2) + pow(mb_iy,2) + pow(mb_iz,2) , mb_in/2)
             * cos( atan2( sqrt(pow(mb_ix,2) + pow(mb_iy,2)), mb_iz) * mb_in)
      mb_i + 1/(pow(mb_ix,2) + pow(mb_iy,2) + pow(mb_iz,2) -3 )
      )//end select
#declare mb_fn_iso = function(x,y,z, mb_fn_n, mb_fn_iterations) {
   ( mb_fn_iterations - mb_fn_iterator_frac(0,mb_fn_iterations-1, mb_fn_n,
x,y,z, x,y,z) -0.5 )
   / mb_fn_iterations
  The iteration number is negated so the inside is defined correctly.
  Taking off 0.5 here may be a mistake now that the iteration is no longer an
integer...
    but it seems to work best for isosurfaces.
//Use the include file as follows:
#include "mandelbulb.inc"
#local mb_n=8;           // Mandelbulb Power
#local mb_iterations=6;
#local mb_zoom=2;        // Use higher values for tighter views.
isosurface {
  function { mb_fn_iso(y, x, z, mb_n, mb_iterations) }
  threshold 0.0
  contained_by { sphere { <0,0,0>, 1.2 } } //Power 8
  //For power 8
  accuracy     pow(2,-mb_iterations  )  /32 /mb_zoom
  max_gradient pow(2, mb_iterations/2)  *32 *mb_zoom
texture{pigment{color White}}
finish{ambient 0 diffuse 0.9 phong 0.1 specular 0.0}
Download 'mb_pattern_basic_set.png' (134 KB)
Preview of image 'mb_pattern_basic_set.png'
Date: 22 Nov 2009 16:30:02
Message: <web.4b09ac35ce81d185f99d05c80@news.povray.org>
Well, now here's an accidental isosurface at today's Astronomy Picture of the
Day.
http://antwrp.gsfc.nasa.gov/apod/ap091122.html
It kinda looks like someone hit a lower-power mandelbulb with a turbulence warp.
That inspired me to try mandelbulbs with fractional powers.  Attached is a power
2.3 mandelbulb, 20 iterations, rotated off-axis, and rendered as media.
Download 'mb2-3i20_media.png' (193 KB)
Preview of image 'mb2-3i20_media.png'
Date: 22 Nov 2009 22:46:09
Message: <4b0a0581$1@news.povray.org>
Tried that, too, with solids. Doesn't look too pretty though, as such
variants exhibit a distinctive discontinuity at one side. Apparently
you'd need more than 360 degrees in a circle to give them rotational
symmetry...
Date: 23 Nov 2009 03:25:22
Message: <4b0a46f2$1@news.povray.org>
But take a thousand times longer to code :-)
Date: 23 Nov 2009 11:07:53
Message: <4b0ab359$1@news.povray.org>
abram wrote:
> The patch:
Looking at it again, I can see a simple improvement that shouldn't cost
too much computing power and would make it much more usable for pigments
and media - returning smooth values based on rate of divergence.
No change needed on your if(cnt<=0){return -1.0;}, but what you can do
for the other condition is:
return (cnt+log(log(r)/log(2.0))/log(n))/(iterations);
In words: find the count you got down to, and add a fraction to it that
approximates how close it was to taking one less iteration, then
normalizing that so it will return a range from 0 to 1+, where 0 is when
you've reached nearly the max iterations, and 1+ when it takes only 1
iteration to diverge, and higher than that when it diverges really far
in the first step.
The actual formula for that fraction is log[base n](log[base
threshold](cnt)), where your threshold for the radius is 2.0.
This would let you get smoothly colored pigment patterns if you want to
do any rate of divergence coloring, which could be interesting. Of
course feel free to change the range of returned values, this is just an
idea for normalizing. To save very minor computational cost you can
pre-calculate the log(2.0), or even change your divergence radius to E.
Chris
Date: 24 Nov 2009 07:40:00
Message: <web.4b0bd319ce81d185f4c648ed0@news.povray.org>
> speed.)
Thanks, Warp.
I found the Marching Cubes C code (cunningly disguised as C++ code...) in p.b.u.
It
converts 8 bit df3 files ok, but of course the resulting mesh isn't quite as
accurate as a POV isosurface. The mesh renders much faster, but it does take
more memory & is much slower to render. So for some applications (eg a lot of
small renders for an animation) I prefer to use the isosurface.
Maybe I need to use the df3 file more efficiently. Currently, I'm only storing 1
bit per voxel: 0 if it's not in the Mandelbulb, 255 if it is. I'm wondering if
there's a better way.
Someone mentioned earlier about doing a glass Mandelbulb. I don't know if this
would work very well, since the surface is fractally bumpy. I've done a glassy
one of a 100³ grid (ior 1.5, no dispersion, photons, or radiosity) amd a shiny
metallic one, and they both look interesting, but a metallic one of a 500³ grid
doesn't look very shiny; as you can see below, it's more like a scrunched up
ball of foil.
Download 'mandelbulbi5s90.jpg' (160 KB)
Preview of image 'mandelbulbi5s90.jpg'
Date: 24 Nov 2009 11:46:13
Message: <4b0c0dd5$1@news.povray.org>
  There's a skull in that image.
Date: 24 Nov 2009 12:19:07
Message: <4b0c158b@news.povray.org>
>> speed.)
> Thanks, Warp.
> It
> ball of foil.
If you want to make it glass or metallic, you need to change a few
things for the DF3 way:
Outside value: 16
Inside value: 200
This is to get rid of the overshot artefacts you can get with the
interpolation. Interpolate 2 realy don't work well when you have sharp
jumps to zero and 255.
Use interpolate 2
Gives you a nice smooth, curvy, interpolation.
Date: 24 Nov 2009 15:23:52
Message: <4b0c40d8$1@news.povray.org>
> ball of foil.
Goodness!  Who let a mathematician into the Brillo factory?
Tim Cook
Date: 24 Nov 2009 16:35:01
Message: <web.4b0c505ece81d185f99d05c80@news.povray.org>
These things can look weirdly organic, especially when rendered in media.
Attached is "side" view of a power 2, iteration 20 image.
Oh, for those who don't watch the binaries.animations newsgroup, I posted an
animation of mandelbulb powers 1 through 100 rendered in media.
http://news.povray.org/povray.binaries.animations/message/%3Cweb.4b09e469315ec22ef99d05c80%40news.povray.org%3E/#%3Cweb
(Just remove the .dat extension and it should play on MS, Mac, and Linux
systems.)
Download 'mb2i20_media_1024.png' (428 KB)
Preview of image 'mb2i20_media_1024.png'
Date: 24 Nov 2009 17:10:01
Message: <web.4b0c5989ce81d185f99d05c80@news.povray.org>
> ball of foil.
I found the same thing.  However, lower iteration mandelbulbs show some promise,
especially if you just cut out part of it.  Attached are power 8, iteration 3
mandelbulbs in stock glass and chrome.  (I apologize I suck at glass.)
~David
Download 'mb8i3_glass_chrome.png' (769 KB)
Preview of image 'mb8i3_glass_chrome.png'
Date: 25 Nov 2009 16:48:12
Message: <4b0da61c@news.povray.org>
  AFAIK the Marching Triangles algorithm produces meshes of much higher
quality than Marching Cubes.
  Marching Cubes tends to produce randomly-sized triangles and very thin
triangles whose size is in no way related to the shape, and it doesn't
take into account the curvature of the surface being tesselated.
  Marching Triangles, on the other hand, produces nice about
evenly-sized triangles for surfaces with the same curvature, and does so
adaptively, ie. producing smaller triangles at high curvature places and
larger triangles at low curvature places. The end result (when eg.
rendered as a wireframe) tends to look a lot more pleasing.
Date: 27 Nov 2009 20:45:01
Message: <web.4b108022ce81d185f4c648ed0@news.povray.org>
> Outside value: 16
> Inside value: 200
> Use interpolate 2
Thanks for the suggestion, Alain. It does look better, but it needs a much
higher max_gradient. And I noticed some strange artifacts when rendering a
simple cubical frame with interpolate 2, even though all the outer voxels in my
cube df3 are supposed to be outside the surface.
FWIW, the metallic Mandelbulb I posted was done using a mesh produced by
Marching Cubes.
Date: 27 Nov 2009 20:50:00
Message: <web.4b1081b2ce81d185f4c648ed0@news.povray.org>
That sounds great, Warp. But after over an hour of searching for Marching
Triangles code, I haven't located anything yet, not even pseudocode. :( Do you
have any suggestions for where I should look? I have found some articles in PDF
format, but I haven't downloaded any of them to check if they contain source
code.
Date: 27 Nov 2009 20:59:11
Message: <op.u320412a7bxctx@bigfrog.bredbandsbolaget.se>
> Do you have any suggestions for where I should look? I have found some
> articles in PDF format, but I haven't downloaded any of them to check if
> they contain source code.
http://en.wikipedia.org/wiki/Marching_tetrahedrons
The Wikipedia article links to:
http://local.wasp.uwa.edu.au/~pbourke/geometry/polygonise/#tetra
FE
Date: 27 Nov 2009 21:15:31
Message: <4b1087c3$1@news.povray.org>
>> Outside value: 16
>> Inside value: 200
>> Use interpolate 2
> Marching Cubes.
If the values reach zero or the highest possible value (255 for 8 bits),
  you get overshots, and those results in warping around the resulting
values from your density_map. If you go to zero, you get areas that will
eroneously use the entry for 1 on the density map. If you go to 255, you
get areas that will use the values for zero, or close to zero.
That's why I told tou to restrict the range of values used.
Date: 27 Nov 2009 21:25:00
Message: <web.4b1089c8ce81d185f4c648ed0@news.povray.org>
Thanks, Fredrik, but I've already seen those links. Marching Tetrahedrons is a
slight improvenent on Marching Cubes, but Marching Triangles appears to be quite
a different algorithm, with adaptive triangle sizes.
Date: 27 Nov 2009 21:35:01
Message: <web.4b108b70ce81d185f4c648ed0@news.povray.org>
> >> Outside value: 16
> >> Inside value: 200
> That's why I told you to restrict the range of values used.
I understand, Alain, and I have restricted the values: my df3 test files only
use 16 & 200 (I used tr to translate my existing files). But I still get these
artifacts. I didn't bother saving an image, but I'll generate a new one, if
you'd like to see for yourself.
Date: 27 Nov 2009 21:59:25
Message: <op.u323xgyj7bxctx@bigfrog.bredbandsbolaget.se>
On Sat, 28 Nov 2009 03:24:08 +0100, PM 2Ring <nomail@nomail> wrote:
> Marching Tetrahedrons is a slight improvenent on Marching Cubes,
> but Marching Triangles appears to be quite a different algorithm,
Source code for that does seem to be scarce, but the original article (by
Hilton & Illingworth) has a pretty detailed stepwise description of the
algorithm. It should not be to difficult to work from that.
FE
Date: 28 Nov 2009 07:04:40
Message: <4b1111d8@news.povray.org>
You can find some code in this thread:
http://news.povray.org/povray.binaries.scene-files/thread/%3C47be20ab%40news.povray.org%3E/
Subject: "Isosurface Approximation macros rewrite"
Date: 22 Feb 2008 01:08:59
Tor Olav
http://subcube.com
Date: 28 Nov 2009 13:10:00
Message: <web.4b116755ce81d185f4c648ed0@news.povray.org>
Thanks, Tor Olav. I'll have a look at it when I wake up. :)
Date: 29 Nov 2009 07:17:51
Message: <4b12666f@news.povray.org>
I see from your answer to Fredrik that it is not Marching Tetrahedrons you're after,
so what I linked to is probably not relevant for you.
Tor Olav
http://subcube.com
Date: 29 Nov 2009 23:15:01
Message: <web.4b134639ce81d185f4c648ed0@news.povray.org>
> Tor Olav
> http://subcube.com
That's OK. Once I had a look at the code, I realized it wasn't Marching
Triangles, but decided to try it out anyway. The meshes it produces do look
better than Marching Cubes, but of course it is very slow on large data sets,
being in POV SDL rather than C. Especially with recursion depth of 3 or more.
FWIW, in one of my tests I got an error message from POV saying that a normal
vector can't be <0,0,0>.
