POV-Ray : Newsgroups : povray.binaries.images : Transparant shadow? Server Time
17 Oct 2026 05:16:25 EDT (-0400)
  Transparant shadow? (Message 1 to 21 of 21)
Subject: Transparant shadow?
Date: 11 Nov 2009 10:23:22
Message: <4afad6ea@news.povray.org>
OK. I should know this, but somehow I am baffled now.
- png image_map (on a mesh2)
- uv_mapped
- with alpha channel (for serrated borders)
- floating above a table
---> casts *straight* shadows!
Rendered in 3.7 beta 34.
I forget something, but what?
Thanks for your help!!!
All the best,
Download 'TT.jpg' (95 KB)
Preview of image 'TT.jpg'
Subject: Re: Transparant shadow?
Date: 11 Nov 2009 11:32:39
Message: <4afae727$1@news.povray.org>
> - uv_mapped
How appropriate “The Fool reversed” LOL
If no one answers before tonight I’ll have a go.
Best Regards,
Date: 11 Nov 2009 12:45:07
Message: <4afaf823$1@news.povray.org>
A bug I'd say.
Date: 11 Nov 2009 12:47:33
Message: <4afaf8b5@news.povray.org>
> A bug I'd say.
(That is, yes, I can confirm this behavior, and no, it's not how it
should work...)
Date: 11 Nov 2009 12:54:07
Message: <4afafa3f$1@news.povray.org>
>> A bug I'd say.
> should work...)
... and no, much to my surprise POV-Ray 3.6.2 ain't doin' it right either.
How come it has taken so long for this one to surface? You'd think it
was some trivial everyday case. And how the **** come I've done renders
with ample such partially-transparent objects casting /proper/ shadows?
Date: 11 Nov 2009 13:09:31
Message: <4afafddb$1@news.povray.org>
El 11/11/09 18:53, clipka escribió:
> either.
> How come it has taken so long for this one to surface? You'd think it was
> some trivial everyday case. And how the **** come I've done renders with
   I don't know... but this happened sometimes to me with certain PNG files,
and not with others. For example, all the trasnparent PNG files I export
from Chief Architect seem to behave this way, but the ones from TORCS I used
on my last post here and other scenes, work perfectly... except if I use
filtering media or fog, of course.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 11 Nov 2009 13:40:54
Message: <4afb0536$1@news.povray.org>
>> either.
> used
I guess I got it.
The following construct works properly:
     texture { uv_mapping pigment { image_map { ... } }
This one doesn't:
     texture { pigment { uv_mapping image_map { ... } }
Note the placement of the uv_mapping statement.
I'll file an error report if nobody has done yet.
Date: 11 Nov 2009 14:06:29
Message: <4afb0b35@news.povray.org>
Since it is a bug why not use a transparency map in the meantime?
Best Regards,
Download 'card01.jpg' (76 KB)
Preview of image 'card01.jpg'
Date: 11 Nov 2009 14:18:07
Message: <4afb0def@news.povray.org>
El 11/11/09 19:40, clipka escribió:
> I guess I got it.
> This one doesn't:
   Didn't test it, but looking at my own scenes now, I can confirm this
finding: the ones I exported from Chief Architect where exported with
Poseray, which puts the uv_mapping inside the pigment, indeed... you're
fast, man!
Date: 11 Nov 2009 14:46:47
Message: <4afb14a7@news.povray.org>
> fast, man!
Yeah, I guess I am - as a matter of fact, I even finished a fix some
minutes ago, ready to be submitted to the codebase.
Wasn't such a big deal actually. Throwing out the dozen lines of code
that handled the case that's working already, in favor of five lines of
code someplace else to handle both cases in one go did the job.
Date: 11 Nov 2009 16:01:16
Message: <4afb261c@news.povray.org>
clipka escreveu:
>>> either.
>>> was
>> files,
>> I used
> I guess I got it.
> This one doesn't:
That's not a bug, that's a feature! ;)
yes, I've met it before and yes, I thought it was a feature... :P
a game sig: http://tinyurl.com/d3rxz9
Date: 11 Nov 2009 17:13:59
Message: <4afb3727@news.povray.org>
Not bloody likely.
Date: 12 Nov 2009 04:19:06
Message: <4afbd30a$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> schreef in bericht
news:4afb0def@news.povray.org...
> fast, man!
Note that the latest version of Poseray puts the uv-mapping code *wrongly*.
Older versions did put it in the *right* place. I guess that is why I had
not noticed this really before.
Date: 12 Nov 2009 04:25:33
Message: <4afbd48d$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4afb0536$1@news.povray.org...
> I guess I got it.
> This one doesn't:
Yes, this works correctly, Christoph. Thanks!
I shall post a also a comment in povray.tools.poser for the difference in
Poseray.
Date: 12 Nov 2009 04:44:43
Message: <4afbd90b@news.povray.org>
"Stephen" <mca### [at] aolDOTcom> schreef in bericht
news:4afb0b35@news.povray.org...
LOL indeed!!
It was because I did not use a transparency map that I discovered the
problem, but also that Poseray had changed the place of the uv_mapping code
in the latest version which led ultimately to the discovery.
Date: 12 Nov 2009 07:31:09
Message: <4afc000d$1@news.povray.org>
> LOL indeed!!
Well it gave me something to do last night :)
Best Regards,
Date: 12 Nov 2009 07:39:37
Message: <4afc0209@news.povray.org>
news:4afc000d$1@news.povray.org...
Excellent! As they say here "Ledigheid is des duivels oorkussen" which my
dictionary translates as "Idleness is the parent of vice" or "The devil
always finds work for idle hands", but somehow I prefer the literal
translation "idleness is the devil's pillow". :-)
Date: 12 Nov 2009 08:37:32
Message: <4afc0f9c$1@news.povray.org>
Hijacking thread somewhat, and not sure if it's the latest version of
Poseray or not, but it exports Poser objects incorrectly (it might be a
setting I have ticked) and requires editing of the .inc file to
work...namely:
section
//This encapsulates the material into the mesh so that Moray can use the
original materials
#declare Victoria_4_hip_hip_2_hip__2_SkinHip_=...
(and so forth)
followed by:
//Model assembly from the meshes
#declare Victoria_4_hip_=
union {
object{Victoria_4_hip_hip_2_hip__2_SkinHip_uv_mapping}
object{Victoria_4_hip_rThigh_2_rThigh__2_SkinHip_uv_mapping}
object{Victoria_4_hip_rThigh_2_rThigh__3_SkinLeg_uv_mapping}
object{Victoria_4_hip_lThigh_2_lThigh__2_SkinHip_uv_mapping}
object{Victoria_4_hip_lThigh_2_lThigh__3_SkinLeg_uv_mapping}
split_union off
the problem is the fact that it does not declare any objects that end
with "_uv_mapping", making POV stall.  you have to manually remove the
"_uv_mapping" from each item in this part.  it doesn't take very long,
but it is a nuisance that shouldn't be necessary.
Tim Cook
http://empyrean.freesitespace.net
Date: 12 Nov 2009 08:44:59
Message: <4afc115b$1@news.povray.org>
Great! I must learn how to pronounce that for when our Dutch colleagues
complain that I am working them too hard, :)
Best Regards,
Date: 12 Nov 2009 10:58:50
Message: <4afc30ba$1@news.povray.org>
[snip]
> Tim Cook
Not being funny Tim but FlyerX is good at responding to emails and this
is getting quite a long thread. He might miss what you wrote. Or you
could start a new thread.
Best Regards,
Date: 12 Nov 2009 11:10:37
Message: <4afc337d$1@news.povray.org>
"Tim Cook" <z99### [at] gmailcom> schreef in bericht
news:4afc0f9c$1@news.povray.org...
> work...namely:
> section
> original materials
> (and so forth)
> followed by:
> union {
> split_union off
> the problem is the fact that it does not declare any objects that end with
> "_uv_mapping" from each item in this part.  it doesn't take very long, but
This is indeed to go to the povray.tools.poser newsgroup.
What version of Poseray are you using? I do not get this output with pure
Poser figures, but Victoria is Daz|Studio, so maybe Poseray incorrectly
writes from there?
