POV-Ray : Newsgroups : povray.binaries.images : Why you may want gamma-correction Server Time
17 Oct 2026 05:16:26 EDT (-0400)
  Why you may want gamma-correction (Message 1 to 21 of 21)
Subject: Why you may want gamma-correction
Date: 4 Nov 2009 21:53:17
Message: <4af23e1d@news.povray.org>
I guess you'll agree there's something wrong with the reflection on the
left side...
Although artificially constructed, this scene may serve to showcase how
raytracing computations can go wrong when ignoring gamma issues.
Left side was rendered with POV-Ray 3.6 with default settings (i.e.
without any gamma handling), right side was rendered with POV-Ray 3.7
defaults (i.e. full-fledged gamma handling); the only difference between
the scenes is in the brightness of the truly-grey squares, to roughly
preserve the percieved contrast to the black-and-white-striped squares
as seen on the unreflected plane (just as you would have to overhaul a
legacy scene if you want to render it with full gamma handling).
Download 'gammachecker_comparison.png' (103 KB)
Preview of image 'gammachecker_comparison.png'
Subject: Why is gamma-correction applied in povray, anyway?
Date: 5 Nov 2009 04:34:30
Message: <4af29c26$1@news.povray.org>
Why is gamma-correction correction applied to images in povray, anyway? And
in 3.7 by default?
As I understand it, gamma correction is correction that has to be applied to
make pictures look like they "should" - to correct luminance.
However, in order to get the appearance right, you have to gamma-correct
your monitor and printer, too. So, if we apply gamma-correction in povray,
we still need additional correction on printer and monitor. So why have a
correction in povray in the first place, if it is not really neccessary. We
still need to correct gamma later. Besides, what does look "right" is a very
subjective matter - it even changes with age.
Is the "raw" povray output correct (in the sense of: does the output follow
the laws of physics), or isn't it?
Does it >have< to be corrected?
Or, better put, is the left or right side of your image "correct"?
Subject: Re: Why you may want gamma-correction
Date: 5 Nov 2009 09:48:00
Message: <4af2e5a0$1@news.povray.org>
> left side...
Nice one ;-)
Subject: Re: Why is gamma-correction applied in povray, anyway?
Date: 5 Nov 2009 10:20:03
Message: <4af2ed23$1@news.povray.org>
> your monitor
All monitors (all consumer ones at least) apply a gamma function to the
incoming data before displaying it.  This is fixed, you cannot change this,
it's just how they work (this was how CRTs worked, LCDs just copied them so
everything looks the same as before).
This is the whole point of why you *must* "gamma correct" data before
sending it to the monitor (that just means applying the inverse of the
monitor gamma function, so it cancels out).
So, no, you don't need to "gamma correct" your monitor - that makes no sense
at all.
I have no idea what printers do, but I imagine the consumer printer drivers
try to match the print output closely to what is shown on a typical display,
so you probably should send them a gamma corrected image too.
BTW, all images you see on the web and photos from digital cameras etc are
already gamma corrected, so they just get sent straight to the monitor.  If
you goal is to make the output from POV look like a photo (ie
photorealistic) then you must therefore gamma correct before writing to the
file.
Date: 5 Nov 2009 10:28:52
Message: <4af2ef34@news.povray.org>
> in 3.7 by default?
Yes.
No, what looks "right" can be quantified quite well: For instance, a
50%-intensity-grey should look exactly the same (when you squint your
eyes a bit, or otherwise "physically blur" what your display shows) as a
pattern of alternating black (0%) and white (100%) stripes.
Sort of, yes. There are some features in it that don't /exactly/ follow
physics, but even those are designed to come as close as possible in the
/linear/ world.
Yes.
The 2.2 gamma curve is much closer to the dynamics of human perception
than linear color space; e.g. the difference between a 10%-intensity
grey and an 11%-intensity grey is percieved as far greater than between
a 90%-intensity grey and a 91%-intensity grey. Thus, for efficient
storage of image data, it makes sense to "compress" brighter colors and
instead "expand" darker colors, to make the most out of the bit depth.
This is called "gamma encoding".
For gamma-encoded images, a color depth of 8 bits per pixel is just
about enough to avoid visible color banding. With linear encoding on the
other hand, a color depth depth of 12 bits per pixel or more would be
needed to avoid banding artifacts in dark areas, while for brighter
regions some 6 bits per pixel would suffice.
Obviously, this is not very efficient, and since high-performace RAM
suitable for graphics card frame buffers used to be very expensive (and
still is to some extent), while a few additional lines of software code
are cheap, graphics hardware almost invariably used gamma encoding for
the frame buffers. Not to mention that it also fit so well with the
inherent gamma of CRTs, allowing both the graphics adaptor and CRT
display electronics to be pretty simple.
Therefore, even today, output devices are /not/ calibrated to achieve
/linear/ behavior, but to achieve some /standard/ gamma (typically 2.2
on PC systems, though the sRGB output curve is becoming more frequent),
which is then made known to (or silently assumed by) the image
processing software running on the system. Most operating systems have
either an official or at least a de-facto standard for the gamma
encoding to be used for data submitted to the display subsystem.
Of course, the same storage efficiency applying to graphics hardware is
of benefit for image file formats as well; for this reason, and because
image viewing software has a much easier job if all it needs to do is
shove the image file data into the display frame buffer, gamma encoding
(double featuring as pre-correction, and often exclusively interpreted
as such) has been the de-facto standard for virtually all 8-bit image
file formats out in the wild, and is explicitly recommended for the most
common formats nowadays.
Therefore, if POV-Ray would /not/ perform gamma pre-correction for the
preview display, it would go against operating system conventions; and
if it would /not/ perform gamma encoding / pre-correction for the output
file, it would go against de-facto and recommended standards of the
respective file format.
Note that for some file formats, POV-Ray does /not/ apply gamma
correction, namely Radiance HDR and OpenEXR, as both formats are defined
to encode linear light intensity data (which they can do efficiently
because they use floating-point-like data formats).
As you can see (or /should/ see, unless your display an/or your image
viewing software is /totally/ screwed up), the left side shows a
checkered plane, but the reflection on the sphere does not. Can this
possibly be correct?
The right side may or may not look /perfectly/ correct, depending on
whether your display is perfectly calibrated or not, but if it is
/anywhere/ close to sanity, it /will/ look "much more correct" than the
left side (that's a physical fact, not just an assumption about your
personal visual perception).
The only thing that could mess up this "experiment" would be a system
that ignores both color profile information and gAMA chunk present in
the image file, /and/ instead of exhibiting just some typical random
display gamma would happen to use linear color space. *Very* unlikely,
unless the person in charge of the system has no clue about color
management but thinks he/she does.
That, or you may be unable to squint your eyes; in that case, some
peculiarities about your visual perception might kick in and spoil it
all, but even that seems rather unlikely to me. As soon as you somehow
physically blur the image projected by the display (which is what
squinting your eyes does), the experiment /will/ work on every system
that is able to display PNG files at least /roughly/ right.
Date: 5 Nov 2009 13:20:23
Message: <4af31767$1@news.povray.org>
Thank you for the explanation - it surely beats wikipedia.
> viewing software is /totally/ screwed up), the left side shows a checkered
> plane, but the reflection on the sphere does not. Can this possibly be
> correct?
I was referring to luminance, not to the reflection in the sphere. The
brightness of the sky is very different, too. I meant: what is more correct
(related to the sky) - luminence on the left or right?
Of course reflection on the left makes more sense than on the right. Is this
a gamma-related problem or is this an error in povray?
I am having lots of problems with gamma correction on my system. At least
there are a lot of iffy things.
Contrary to what has been posted here, my video card's driver seems to do
some gamma correction (Nvidea). At least I can do a some gamma correcting in
the setup. However, it is a lot of voodoo: I don't know for sure what is
corrected and when. I really don't see any difference.
Now, I am using Corel quite a lot. Corel has a lot of colour correcting,
too. I downloaded the proper colour-management system files for my monitor
and my printer, respectively, but the printed result did not look much like
the screen. The PDF-file I sent to my printer (I mean the real one, the guy
who doesn't bother printing anything below 1000 copies ;-) did look like
neither my printout, nor the screen.
So I did trash all colour-correcting. All set to "ignore" - from video card
driver to Corel to printer profile and printer driver. And behold: now I get
on my printer what I see on my TFT and the guys at the printing press
produce something that comes close enough to what I want.
So I am a bit distrustful of colour correction, especially when it is stored
as a kind of optional parameter in the image-file, like in PNG. Depending on
the respective viewer / editor, gamma correction in PNG is either ignored or
applied. If it is applied, one only can hope it is applied correctly. This
really is a problem. Do you know which browsers support PNG
gamma-correction?
Date: 5 Nov 2009 13:34:42
Message: <4af31ac2$1@news.povray.org>
"scott" <sco### [at] scottcom> schrieb im Newsbeitrag
news:4af2ed23$1@news.povray.org...
> sense at all.
Maybe. As I already posted in reply to clipka, my video card driver (Nvidia)
allows to do gamma correcting. And Adobe has some additonal gamma
correcting, too. And the graphics program of your choice wants to manage
monitor color, too.
Then there is colour temperature, which can be set on most monitors. How
does this relate to gamma?
Date: 5 Nov 2009 17:35:19
Message: <4af35327@news.povray.org>
Maybe in some very subtle way, but I'd expect it to be dwarfed by the
impact on color hues. Which in turn is an issue that would require
full-fledged color management to address - which POV-Ray isn't ready for
yet :-)
Getting gamma straight is a start. Getting color management right will
be one step further.
Date: 5 Nov 2009 17:45:01
Message: <web.4af354fa6aedb0e878641e0c0@news.povray.org>
> at all.
I have this gamma control dialog box on my system.  I don't know whether it
applies gamma correction to the output signal, or controls the LCD itself,
though I suspect the former.
I've never seen one of these on a CRT based system, but that might well be an
artifact of history.
Download 'gamma_control.png' (206 KB)
Preview of image 'gamma_control.png'
Date: 5 Nov 2009 18:11:58
Message: <4af35bbe$1@news.povray.org>
That depends on how you prefer to interpret the color values in the
scene file.
I'd say both are wrong in this respect, because the original scene
author tried to achieve what can be seen on the left, but due to not
paying attention to gamma issues he ended up with parameters that result
in the image on the right when the computations are done properly.
Whoops - are you mixing up left & right here?
It actually is a gamma-related problem, which in this case manifests
itself at the antialiasing step.
You could, with some legitimacy, also call this a design error in the
old POV-Ray versions (in this case 3.6 used with default parameters). It
is /not/ possible to produce the effect seen on the left-hand side with
POV-Ray 3.7, unless deliberately forcing it to enter 3.6-compatibility mode.
... which doesn't seem to be too uncommon, unfortunately.
Yes, I guess I know that tool. I used it, too, to calibrate my display.
This should actually "patch" some lookup table in the graphics hardware,
which maps 8-bit framebuffer values to values supplied to the ADC (to
generate the analog signal for the VGA interface) or transmitted on the
DVI interface.
I guess there's some caveat here: The monitor vendor doesn't know what
graphics card you are using, and how you set your display gamma.
I guess you just have to know exactly what you're doing in order to
benefit from color management. I for one don't, so I stick to plain old
gamma correction for now.
> gamma-correction?
You can try yourself: Just render a POV-Ray scene to PNG using the 3.7
beta, once with File_Gamma=2.2 and once with File_Gamma=1.0.
Any software displaying both files identically (except maybe for a bit
of color banding in the File_Gamma=1.0 version) is doing proper gamma
handling.
Internet Explorer 8 does it right. The IC image viewer does, too, and
Windows Explorer's image preview likewise.
Photoshop 6.0 does it wrong (but I guess current versions do a better
job), and so does Microsoft Paint.
Date: 5 Nov 2009 18:20:21
Message: <4af35db5$1@news.povray.org>
Yes, that looks just like one of the tools provided by graphics card
vendors to adjust the output signal of the graphics card.
If it is what it looks like, it essentially tampers with a look-up table
in the graphics card that maps framebuffer values to more precise values
sent to either the LCD via DVI connector or the DAC generating the VGA
signal.
My Nvidia graphics card also came with a tool that would help you set up
that curve properly.
Date: 5 Nov 2009 19:45:00
Message: <web.4af36cbf6aedb0e8cbc3e8670@news.povray.org>
The settings in your card driver are there to correct differences between
monitors, but unfortunately, they have no way to tell what your monitor is
actually doing, so the settings are only as good as your ability to tell if your
monitor is properly balanced.  This in turn is influenced by a lot of things,
including the lighting where your monitor is.  But if you send an image to your
printer and the colors are completely different than onscreen, then its a good
bet your colors aren't balanced.
Check out http://www.normankoren.com/
He has some stuff on how monitors produce color and how your settings actually
work, along with some tools to help you calibrate them correctly.  In a
nutshell, he says your brightness sets the white level, contrast sets the black
level and then you use the gamma setting of your card to adjust the colors in
between.
Can't say anything about the science behind it, but I can say that after
following his advice my prints not only look more like onscreen, but I no longer
see the extreme differences in colors I used to see when viewing pictures on
different monitors. (A big issue in POV when creating textures... if you've ever
rendered a scene on another box only to find that your 'perfect' texture on box
A looks absolutely horrible on box B...)
Date: 6 Nov 2009 02:48:06
Message: <4af3d4b6@news.povray.org>
> (Nvidia) allows to do gamma correcting.
You should try to set that to unity as a starting point, otherwise your OS
GUI and any web browsing will be messed up and not as they intended it to be
viewed.  I guess it's more there to tweak your monitor by a very small
amount if it doesn't quite exactly match the standard sRGB gamma (a lot of
monitors nowadays have an "sRGB" setting which I assume is at least close to
the standard), obviously no consumer monitor is perfect unless manually
calibrated.
In theory not at all, but in practise it probably does a bit just due to the
way its implemented in some monitors.  Colour temperature defines what the
white point should be, for accuracy you should set this to the D65 standard
(daylight 6500K) which is the sRGB standard.  Obviously if you tell your
monitor to use 6500K it might not exactly use it due to manufacturing
tolerances (or there might not even be a scale on your monitor, just "warm"
to "cool"), that's why there are tools to calibrate your monitor.
Date: 6 Nov 2009 02:55:51
Message: <4af3d687$1@news.povray.org>
> in the setup. However, it is a lot of voodoo: I don't know for sure what
> is corrected and when. I really don't see any difference.
Without access to a luminance meter, just show an image like this:
http://web.mit.edu/jmorzins/www/gamma/adilger/gamma.png
Squint your eyes to blur it a bit, and then where the plane grey area (under
the numbers) matches the black/white lines (should be in the 1.6-2.4 range),
you can read off the gamma value.
You can tweak your settings in the nVidia control panel until you achieve a
gamma of 2.2 with that image.
Date: 6 Nov 2009 03:54:07
Message: <4af3e42f$1@news.povray.org>
>> this a gamma-related problem or is this an error in povray?
Oups! Well - back to painting "L" and "R" on my hands ;-)
Sorry about this.
Date: 6 Nov 2009 17:07:53
Message: <4af49e39$1@news.povray.org>
> left side...
Actually, no, I have no idea what you're talking about.
Great opening line for a thread though.
Mike
Date: 6 Nov 2009 17:11:48
Message: <4af49f24$1@news.povray.org>
> left side...
Instead of arguing about it on this newsgroup, why don't one of you guys
write a wiki article so we can just go along step by step, starting from
the beginning?
Mike
Date: 6 Nov 2009 17:43:03
Message: <4af4a677$1@news.povray.org>
> the beginning?
Guess what: I'm presently on it. The left-side shot was designed to be
an illustration for that.
Date: 6 Nov 2009 17:47:31
Message: <4af4a783$1@news.povray.org>
>> left side...
Do you see a checkered plane on the left side?
If you don't (even if you squint your eyes or take some steps back),
then your system really screws up PNG files.
If you do, then wouldn't you expect to see that checkered plane in the
reflection as well?
Date: 6 Nov 2009 18:34:24
Message: <4af4b280$1@news.povray.org>
On 11/6/2009 5:43 PM, clipka wrote:
>> guys write a wiki article so we can just go along step by step,
>> starting from the beginning?
Awesome!
Mike
Date: 7 Nov 2009 21:50:01
Message: <web.4af631b96aedb0e880a55a690@news.povray.org>
FWIW, my experience matches yours to the dot: The more "color management" is
going on, the rattier and less predictable the result becomes. Which is why I
keep asking folks who write software for a switch that goes "turn off / ignore /
keep your hands off all this"...
