POV-Ray : Newsgroups : povray.binaries.images : Brass Lamp Server Time
22 Nov 2026 16:44:06 EST (-0500)
  Brass Lamp (Message 1 to 26 of 26)
Subject: Brass Lamp
Date: 21 Sep 2009 07:58:58
Message: <4ab76a82@news.povray.org>
This is the brass lamp that I'd been working on for a while. I finally
solved the problems with the lamp globe.
Came up with the normal on the globe after working through Warps slope map
tutorial!
Jim
Download 'BrassLamp.png' (808 KB)
Preview of image 'BrassLamp.png'
Subject: Re: Brass Lamp
Date: 21 Sep 2009 08:11:04
Message: <4ab76d58@news.povray.org>
Impressive! I guess the normal work on the globe really makes it.
BTW, what's that grey flask on the right? What would anyone build a
vessel like that for? (Needs some more beveling work around its resting
surface and where the box meets the cylinder, btw... the table could
also need some.)
Date: 21 Sep 2009 08:49:00
Message: <4ab7763c@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4ab76d58@news.povray.org...
> BTW, what's that grey flask on the right? What would anyone build a vessel
> like that for?
My guess would be that it's a traditional solution to the thick gloopy
liquid problem, before squeezy bottles and upside-down ketchup bottles were
invented, so you don't have to wait while it makes its way all the way from
the bottom to the spout each time you want some?
Anywhere close?
Chris B.
Date: 21 Sep 2009 09:17:57
Message: <4ab77d05@news.povray.org>
Yes it does! The problem (you and discussed) with the globe was even though
I could see through the lath object, it was rendering the volume of the
object until I figured out how to close the spline.
> like that for? (Needs some more beveling work around its resting surface
> and where the box meets the cylinder, btw... the table could also need
> some.)
The grey object on the right is a bed warmer .... fill it with hot water and
it goes between the sheets (down by your toes), and yes perhaps a little
more work is needed! It's a union of lathe object and a rounded box. Any
ideas how to smooth the transition from base to lathe object?
The table could probably use a little more normal work, but the edges ...
well I have this table in the shop, pretty crude primitive construction. The
methods of the period (c1840) never broke the edges like you're suggesting.
Not round legs either ... basic straight egdes and tapered ... pegged
together, NO NAILS!!!
Thanks!
Jim
Date: 21 Sep 2009 09:19:48
Message: <4ab77d74@news.povray.org>
> were invented, so you don't have to wait while it makes its way all the
> way from the bottom to the spout each time you want some?
> Anywhere close?
> Regards,
> Chris B.
Way off (ha-ha) ... it's a bed warmer!
Jim
Date: 21 Sep 2009 09:47:52
Message: <pm0fb5tktbb0e3rbt22h12921hlap3udh5@4ax.com>
On Mon, 21 Sep 2009 10:17:56 -0300, "Jim Holsenback" <jho### [at] povrayorg>
I would describe it as an old fashioned or stone "hot water" bottle.
I'm not sure that I can describe it in English but I will try,
Add a cylinder that is tangential to the lathe object and the base and has a
radius that suits your model (This is easier when you use a modeller and you can
see where things touch. :P). Add a box where one face goes through the tangents
of the cylinder and lathe object at the top and the cylinder and base. Turn that
into a CSG difference (you may need to add extra boxes to clean it up) with the
cylinder subtracted from the box. You should now have an object that is a
"filler".
I've not tried it but it is the way I do these things.
Regards
Date: 21 Sep 2009 09:54:55
Message: <4ab785af$1@news.povray.org>
"Jim Holsenback" <jho### [at] povrayorg> wrote in message
news:4ab77d74@news.povray.org...
>> Anywhere close?
>> Regards,
>> Chris B.
> Jim
Doh!!
Date: 21 Sep 2009 10:36:07
Message: <4ab78f57$1@news.povray.org>
Yes: Hard math :-P
I'll need a macro for linking rectangular blocks to cylinders, too, but
so far I haven't figured out the details yet. ATM I could only give you
an example of how to round off the edges on a linear polygon with
circular arcs, but although it's presumably a closely related problem,
it's not exactly the same.
Even without deliberate rounding, beveling or even sanding, boards will
/never/ have perfectly sharp edges - not to mention some deal of
involutary beveling by wear.
(That's why on my steam locomotive I'm actually beveling - or more
precisely, rounding off - /everyhing/ at least a tiny bit, even if it is
supposed to be machined steel instead of cast iron.)
Date: 21 Sep 2009 11:32:37
Message: <4ab79c95@news.povray.org>
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:pm0fb5tktbb0e3rbt22h12921hlap3udh5@4ax.com...
> a
> you can
> tangents
> Turn that
> with the
> "filler".
Ok ... (clipka's and yours) inputs have started some ideas. I'll sit down
with a sheet of graph paper (this computer doesn't have POV) while I'm
watching the shop.
Cheers!
Date: 21 Sep 2009 11:36:42
Message: <4ab79d8a@news.povray.org>
news:4ab78f57$1@news.povray.org...
I took a look and YES I do see what you mean ... most excellent!
Date: 21 Sep 2009 15:35:01
Message: <web.4ab7d4adadad6a7ab65741ba0@news.povray.org>
Looks terrific & brings to mind an oil lamp my family used when the
electric would go out. We'd play cards by the light - flame looks just right to
me.
Bill
> tutorial!
> Jim
Date: 22 Sep 2009 00:01:58
Message: <4ab84c36$1@news.povray.org>
That's a great image. It's so crisp that I keep looking for artifacts, but I
can't find any. The lighting, the colors, and the shapes are all very
appealing.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 22 Sep 2009 04:02:48
Message: <4ab884a8@news.povray.org>
Excellent work, Jim. The only thing I find a bit perturbing is the big
yellowish shadow on the wall as it does not relate to something visible or
even recognizable in the scene. Maybe that needs some thought.
Date: 22 Sep 2009 04:25:01
Message: <web.4ab88924adad6a7aad917e280@news.povray.org>
> tutorial!
> Jim
The brass lamp seems really a brass lamp... very relistic!
(...and I like the "grainy effect" of the wall.)
Date: 22 Sep 2009 06:47:47
Message: <4ab8ab53@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:4ab884a8@news.povray.org...
Hmmm .... the lamp flame?
Date: 22 Sep 2009 06:49:07
Message: <4ab8aba3$1@news.povray.org>
"Carlo C." <nomail@nomail> wrote in message
news:web.4ab88924adad6a7aad917e280@news.povray.org...
thanks ...
a scaled small agate normal
Date: 22 Sep 2009 06:57:34
Message: <4ab8ad9e$1@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote in message
news:4ab84c36$1@news.povray.org...
> I can't find any. The lighting, the colors, and the shapes are all very
> appealing.
thanks! almost seven hours (not counting rad run) on my poor old single core
machine ... +am2 +a0.1 +r2
Date: 22 Sep 2009 10:45:58
Message: <4ab8e326$1@news.povray.org>
The lamp is awesome!
Perhaps the edges of the table are too sharp compared to the object on
his surface.
Nice work!
Paolo
> tutorial!
> Jim
Date: 22 Sep 2009 11:41:42
Message: <4ab8f036@news.povray.org>
I like how you dared to put the lamp somewhere else than at the very
center of the image. The main object at the very center of the image is
almost always a very poor choice of composition (although there are some
exceptions). Being slightly on the side gives a much stronger artistic
feeling to the image.
Date: 23 Sep 2009 04:56:12
Message: <4ab9e2ac@news.povray.org>
"Jim Holsenback" <jho### [at] povrayorg> schreef in bericht
news:4ab8ab53@news.povray.org...
>> or even recognizable in the scene. Maybe that needs some thought.
That big shadow carving out a triangle on the back wall is not made by the
lamp flame I guess? or is it? I cannot relate it to something and it is what
troubles me :-)
Date: 23 Sep 2009 06:55:22
Message: <4ab9fe9a$1@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> a écrit dans le
message de news: 4ab9e2ac@news.povray.org...
> what troubles me :-)
I see it as a shadow from a more luminous and remote lamp to something as a
stair and its post.
I like it because it gives us a hint of the scene behind the camera :-)
Marc
Date: 24 Sep 2009 03:24:40
Message: <4abb1eb8@news.povray.org>
"m_a_r_c" <jac### [at] wanadoofr> schreef in bericht
news:4ab9fe9a$1@news.povray.org...
> a stair and its post.
That is what I thought too... but there is something in the geometry or in
the relative position of this shadow that I find disturbing... I am unable
to be much clearer I am afraid.
On the other hand, it nicely frames the lamp.
Date: 24 Sep 2009 04:59:55
Message: <4abb350b@news.povray.org>
news:4ab9e2ac@news.povray.org...
> Thomas
There is a big window and you are seeing the shadow of the framework of that
window (half moon shape in center with panels forming a larger half moon).
Having the light from the lamp as the only light source was a problem. The
wideness of the base just under the lamp globe made a zone of darkness and I
needed an outside light source to get the lamp base looking like I wanted.
Jim
Date: 24 Sep 2009 05:13:53
Message: <4abb3851$1@news.povray.org>
news:4ab8f036@news.povray.org...
Thanks .... used a subtle trick I discovered by mistake! Basically the
camera orbits the table located at origin, depending how much "zoom" you use
a very small rotation of the camera around the origin works nicely. In this
case just 5 degrees.
Jim
Date: 24 Sep 2009 05:19:00
Message: <4abb3984@news.povray.org>
"Paolo Gibellini" <p.g### [at] gmailcom> wrote in message
news:4ab8e326$1@news.povray.org...
> Perhaps the edges of the table are too sharp compared to the object on his
> surface.
> Nice work!
> Paolo
Ha-ha ... I've already started work on the table. I've made a "tool" (box
differened by a cylinder) that I'm using to trim some of the edges. The lamp
DID turn out nice .... Thanks
Date: 25 Sep 2009 04:25:09
Message: <4abc7e65$1@news.povray.org>
news:4abb350b@news.povray.org...
> that window (half moon shape in center with panels forming a larger half
> moon). Having the light from the lamp as the only light source was a
> problem. The wideness of the base just under the lamp globe made a zone of
> darkness and I needed an outside light source to get the lamp base looking
> like I wanted.
Yes, I thought it was something like that. Maybe it is the alignment of the
window's shadow with the table which should be shifted a tiny bit in order
to break its symmetry. It is rather subtle what I have in mind and would
need a bit of experimentation. Also the wall would be great with fine lines
or cracks here and there, and/or some irregularities... Oh well, I should
stop now ;-)
To be sure, this is a great scene anyway, Jim, especially the lamp, but also
the feeling/touch of the objects.
