POV-Ray : Newsgroups : povray.binaries.images : My longest render but I'm unhappy Server Time
29 Nov 2026 03:27:12 EST (-0500)
  My longest render but I'm unhappy (Message 1 to 14 of 14)
Subject: My longest render but I'm unhappy
Date: 11 Sep 2009 04:26:36
Message: <4aaa09bc@news.povray.org>
Hallo!
The render of the image I had to propose for IRTC testing session is
ended yesterday (I have posted a version without water).
My home hardware is a little obsolete and after a month render was at
30%, so I've asked help to a friend with a more efficient machine, which
completed the work in less than two weeks (ok, I need to upgrade my
hardware).
I'm not happy of the final image because it is shady and the golden
pieces composing the IRTC word doesn't shines as in my intention.
Sources in p.b.i.
Have a nice day,
Paolo
Download 'irtc_200906_1280_aa.jpg' (176 KB)
Preview of image 'irtc_200906_1280_aa.jpg'
Subject: Re: My longest render but I'm unhappy
Date: 11 Sep 2009 09:40:00
Message: <web.4aaa52f5489ef02881c811d20@news.povray.org>
Paolo Gibellini <p.g### [at] gmailcom> wrote:
> Hallo!
> hardware).
> Sources in p.b.i.
> Have a nice day,
> Paolo
I haven't tried to run the scene yet, but some thoughts from reading the file:
When doing water, I prefer to let the water interior do all the work:
rgbt 1.0 (completely clear)
diffuse 0.0 (if it's clear it won't do anything anyways)
use only fresnel reflection at full: reflection{0 1 fresnel on} with ior set to
1.33 (for water)
for the water colour and light fading you can use either
light fading read docs for full usage:
fade_distance (play with value that works)
fade_power (I prefer to use 1000 which kicks in the exponential function)
fade_colour (use this to control the colour of the water)
or you can use media which will give better results, but be slower.
Use absorption media with or without scattering
Here is the water I use for my BathTubs:
(http://news.povray.org/povray.binaries.images/thread/%3Cweb.494744dd800e72a4c67b294d0%40news.povray.org%3E/?ttop=30059
8&toff=50&mtop=294124)
#declare WCol=rgb <0.51373, 0.70588, 0.70588>;// Water colour, based on coastal
water
#local FD=-25/ln(0.58);  //Fade distance, alter the first number for the
distance, the odd ln(0.58) is from experimenting to emulate exponential as best
as I can.
#declare MWater=
  material{
    texture{
      pigment{rgbt 1}
      finish{conserve_energy  diffuse 0.0  ambient 0  reflection{0 1 fresnel on
metallic 0}}
    interior{
      ior 1.33
      media{
        absorption rgb 1-WCol
        density{rgb 1/FD}
-tgq
Date: 11 Sep 2009 09:45:00
Message: <web.4aaa5383489ef02881c811d20@news.povray.org>
> Hallo!
> hardware).
> Sources in p.b.i.
> Have a nice day,
> Paolo
Oh, in addition to my previous post: I also prefer to not use specular,
highlights, but keep it to reflection only and provide a background to reflect.
 While the colour and depth of water is defined by the interior colouring and
fading, the surface is best defined by what it reflects, even if it is just a
cloudy sky.
-tgq
Date: 11 Sep 2009 10:50:01
Message: <web.4aaa62a0489ef02881c811d20@news.povray.org>
I ran the file (without rad or photons) and noted a couple more items:
The light_source:
 light_source{<0,2,2> color rgb <1, 1, 1>}
is located inside the water and causes problems with the light_fading.  Raise it
up out above the water level.  Then increase your fade_distance in the water.  I
got the following to work nicely (other than the water may be too blue, needs
more greeniness):
#declare t_water = texture {
    pigment{rgbt 1}
    normal {
        ripples 0.25   // 0.75
        frequency 0.1
        translate <-10,0,10>
    finish {
 diffuse 0.0
 ambient 0.0
        reflection {0, 1 fresnel}
        conserve_energy
#declare i_water =interior {
    ior 1.33
    fade_distance 3
    fade_power 1000
    fade_color rgb <0.217,0.552,0.877>
#declare m_acqua =material {
    texture {t_water}
    interior {i_water}
You are also using an isosurface for your water.  While this works and gives a
nice smooth ripply surface, isosurfaces are real time killers.  The water
surface can be acheived just as well with a heightfield which will speed it up
considerably.  I tweaked and the following is somewhat equivalent to your
isosurface:
Note that isosurfaces take their function from the X-Y plane, but are created on
the X-Z plane hence the swapping of Z and Y in the function
Also note that heightfields are created 1x1x1 so the function got scaled down by
adding the *35 and then the heightfield gets scaled up after.
The 600,600 is the resolution of the heightfield and can be increased/decreased
to change quality and speed:
#local FWATER = function{1-(1-sin(x*35*2*pi))*0.01-f_noise3d(x*35,y*35,0)*0.1}
#declare water=
intersection{
  height_field{function 600,600 {pattern{function{FWATER(x,y,z)}}} smooth}
  box{0 1}
  hollow
  scale <35,4,35>
  translate <-10,-3,-10>
I may have a few more suggestions to come yet.
-tgq
Date: 11 Sep 2009 11:05:00
Message: <web.4aaa66ef489ef02881c811d20@news.povray.org>
OK, a couple final observations:
If you do want to use the iso rather than a heightfield, I noticed that your
isosurface is clipped too high and intersects with the floor, this will get
noticeable when the light fading is working properly.  Change your contained_by
box (This is likely also increasing your render time unecessarily)
   contained_by {box {<-10,-3,-10>, < 25, 1, 25>}}
If you are not happy with the way the lightfading is working switch to media,
with scattering only it doesn't add much render time: (be sure to add "hollow"
to your isosurface or heightfield object for it to work)
#declare WCol=rgb <0.217,0.552,0.877>;
#local FD=3;
    ior 1.33
      media{
        density{rgb -ln(0.58)/FD}
I did some very quick time comparisons for you:
1) Original iso with fading: 56s
2) Corrected iso (as above) with fading: 40s  (big increase! doesn't have to
calculate back intersections anymore
3) Corrected iso with media: 42s (only slight increase)
4) HF (600x600) with fading: 28s  (another big decrease!)
5) HF (600x600) with media: 30s  (again, only slight increase)
Also note that changin the resoltuion of the HF only increases parse time (and
memory usage) not render time.
Hope this has all been of some help to you.
-tgq
Date: 11 Sep 2009 14:25:10
Message: <4aaa9606@news.povray.org>
Paolo Gibellini wrote:
> Hallo!
> hardware).
> Sources in p.b.i.
> Have a nice day,
> Paolo
It looks quite nice imo
Date: 11 Sep 2009 18:00:23
Message: <4aaac877$1@news.povray.org>
> #local FD=3;
>     ior 1.33
>       media{
> -tgq
Trevor, thank you sincerely for all your work: you probably spent a lot
of time!
Now I'm beginning to test your suggestion in a more simple scene. I will
post the results.
Thank you again,
Paolo
Date: 11 Sep 2009 18:01:12
Message: <4aaac8a8$1@news.povray.org>
>> Hallo!
>> which completed the work in less than two weeks (ok, I need to upgrade
>> my hardware).
>> Sources in p.b.i.
>> Have a nice day,
>> Paolo
Thank you, Jim!
I will try now Trevor's suggestions.
Paolo
Date: 12 Sep 2009 20:43:01
Message: <4aac4015@news.povray.org>
Paolo Gibellini a écrit :
> Hallo!
> hardware).
> Sources in p.b.i.
> Have a nice day,
> Paolo
Did you use photons? This is a case where "caustics" can avantageously
be used.
Date: 13 Sep 2009 03:11:29
Message: <4aac9b21$1@news.povray.org>
It makes me unhappy, too.   ;-)
Date: 13 Sep 2009 03:25:00
Message: <web.4aac9d08489ef0282182165e0@news.povray.org>
> Hallo!
> hardware).
We all know what it is like to have slow CPUs. All hardware is slow in the face
of some render jobs. My brother's Tandy CC3 was actually able to compute the
Mandelbrot in 16 hours.
I'm always trying to find ways to speed up my renders. The results are not
always accurate :(
> Sources in p.b.i.
Ideas always shine most brightly in the mind :)
Sam
Date: 15 Sep 2009 07:49:44
Message: <4aaf7f58@news.povray.org>
> be used.
> Alain
Yes, the scene arises from caustics in water test.
Now I'm working on Trevor's suggestions.
Paolo
Date: 15 Sep 2009 07:50:58
Message: <4aaf7fa2$1@news.povray.org>
A trouble shared is a trouble halved,
Paolo
Date: 15 Sep 2009 07:51:52
Message: <4aaf7fd8$1@news.povray.org>
> Sam
I agree...
Paolo
