POV-Ray : Newsgroups : povray.binaries.images : Ripple Tank Sim Server Time
29 Nov 2026 03:42:54 EST (-0500)
  Ripple Tank Sim (Message 1 to 16 of 16)
Subject: Ripple Tank Sim
Date: 11 Aug 2009 03:44:34
Message: <4a812162@news.povray.org>
a ripple tank simulation, computed with POV-Ray 3.7.0.beta.33; original
size of render: 300x100 pixels (this is a scaled-up 100x100 excerpt);
frame 6000 of 9999, total computation time for the whole sequence 30
minutes on a Core i7 (7 threads).
Green area indicates wave generator shape; red areas indicate barriers.
(An optimized C program could probably do the whole smash in a matter of
seconds - even a naive attempt does it in about a minute - but that's
not the point :P)
As an interesting side note, although performing bulk mathematical
simulation, the SDL script doesn't use a single function (except for
auxiliary purposes), not a single array, no file #write or #read, and
only a single control statement (an #if, for special treatment of the
very first frame). Virtually all it does is render frame after frame of
the animation.
Download 'wavetank.jpg' (63 KB)
Preview of image 'wavetank.jpg'
Subject: Re: Ripple Tank Sim
Date: 11 Aug 2009 10:45:03
Message: <4a8183ef$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4a812162@news.povray.org...
> not the point :P)
> the animation.
This is VERY interesting as we all - sooner or later - need HF's for water
reflecting/refracting from obstacles. I know I did for my TC-RTC
contribution, but I let it be for the time being.
Date: 11 Aug 2009 12:20:00
Message: <web.4a8199b9f3b84fbd958421d50@news.povray.org>
> not the point :P)
It's likely, but they both slow down quickly since, for an n x n grid, the time
increases at a rate of O(n^3).  I'm running a version right now that's 6th
order in space and time, and it takes about four hours or so for about 10000
frames at 1000x1000 resolution.
> the animation.
Wait a minute--no #while?  No arrays?  Are you using textures or what?  Sounds
like great material for an obfuscated POV contest, but maybe it's really
straightforward.  Let me guess...  Read the last two frames as a texture.  Move
the last frame up, down, left, and right by one pixel.  Add together and
subtract the last frame to get a laplacian.  Then do a simple explicit
iteration in time to get the next frame as a texture.  Render.  Repeat.  (?)
 - Ricky
Just thinking out loud...  er, silently...
Wave equation:
d^2p/dt^2 = c^2 del^2 p
Discretize the time derivative:
(p_n+1 - 2*p_n + p_n-1)/dt^2 = c^2 del^2 p
Rearrange:
p_n+1 = 2*p_n - p_n-1 + (c*dt)^2 del^2 p
Discretize the laplacian:
p_n+1 = 2*p_n - p_n-1 + (c*dt/dx)^2 (p_i+1,j + p_i-1,j + p_i,j+1 + p_i,j-1 -
4*p_i,j)
So to get the next frame, read the last two as a texture.  Add twice the last
frame minus the second-to-last frame.  Then add (c*dt/dx)^2 multiplied by the
sum of the last frame shifted in every direction by a pixel minus 4 times the
last frame.
Render?
Date: 11 Aug 2009 14:53:22
Message: <4a81be22$1@news.povray.org>
It's funny you should come up with this, since yesterday I was thinking
about how to do this very thing. We have no persistent variables, but
using images would work.
This reminds me. It would be really sweet if we could have POV output an
image with an exact name during an animation, such as "water.png"
instead of "water001.png". This would make iterative image production a
much neater process. As it is now, whenever I have an iterative imaging
setup I end up with a ton of images in the directory.
Good job! I think I'll stick to C programming for this effect though.
It's easy enough to produce a barrier and generator mask using POV, and
then take it into C to run the sim :/
Sam
Date: 11 Aug 2009 15:40:10
Message: <4a81c91a@news.povray.org>
stbenge wrote:
> We have no persistent variables, but using images would work.
I guess a person could #write to a file and generate persistent
variables that way...
Date: 11 Aug 2009 15:45:10
Message: <4a81ca46$1@news.povray.org>
I guess the O(n^3) applies not to an increased "tank" size, but an
increased resolution (which then also requires an increased resolution
of time I guess), right?
> straightforward.
Indeed. The algorithm should also be perfectly suited for a cellular
automaton (ah well, in a way that water-tank-alike thing *is* a cellular
automaton, if only with a very high number of states...). There's only a
slight bit of obfuscation in it because...
- The math isn't as obvious when you do it with textures
- So far I've used a more naive approach than what you propose,
explicitly keeping track of both pressure and velocity (2 dimensions)
separately (yet side-by-side in the same frame - hence the 3:1 aspect
ratio), not realizing that the velocity can be inferred from the
difference between previous frames (then again, can it? after all, the
difference is an overlay of velocity influences in two dimensions...
except of course if you process only a single dimension per step). This
of course uses some weird hacks to properly superimpose the various
dimensions.
> last frame.
> Render?
Something along these lines, yes. Except that I'm not that deep into
"official" math to know what a "laplacian" is - I just derived the
iteration approach from basics (and I should also note that it's not an
exact simulation of water waves - rather an idealized medium, in which
waves propagate by straightforward interaction of some scalar
"potential" field and a 2d-vector "flux" field (or however you want to
call it), without any other effects to mess up things (except a small
damping factor I introduced, to prevent quantization noise from building
up). And, as I mentioned, so far I explicitly store the "flux" field
instead of referring to older frames. (My first approach actually
computed each component separately, using a three-frame cycle for
potential, X-flux and Y-flux, but it was darn ugly to watch ;-) I also
figured (correctly) that using a combined-frame approach might speed up
things, especially since parsing time was a significant factor.)
I was wondering indeed whether there would be ways to streamline the
algorithm. I also wonder whether doing multiple iteration steps per
frame (by overlaying more copies of the last two frames) might speed up
things, as parsing (and probably image loading and saving) still eats a
good deal of the time, and there's possibly other significant overhead
involved. After all, we're talking about ~40 fps.
Ah, one last note: I guess OpenEXR should be recommended for this
application of POV-Ray.
Date: 11 Aug 2009 16:00:32
Message: <4a81cde0$1@news.povray.org>
I mainly did it because the C(/++) program I had written earlier only
produced ASCII art output, and it did quite well for starters, but I got
tired of its limitations, and was too lazy to integrate support for
proper image reading and writing ;-)
And, of course, misusing POV-Ray in this manner was an interesting
challenge to do ;-)
Next on the agenda: Game of life. Should be a piece of cake if done
properly: Read in last frame, apply a color map according to birth/death
rules, overlay with 8 tuned-down displaced copies to add birth/death
hints for the next step - render.
Date: 11 Aug 2009 16:31:51
Message: <4a81d537$1@news.povray.org>
You positively don't want to do that with a ripple tank sim :P
Date: 11 Aug 2009 18:05:01
Message: <web.4a81ead7f3b84fbd805d39df0@news.povray.org>
clipka <ano### [at] anonymousorg> wrote:=
Exactly.  It's the CFL (Courant-Friedrichs-Lewy) condition, and it basically
just says that information can't travel more than one grid cell per step.  This
means that if you double the resolution, you also have to cut the time step in
half to preserve stability.  So if you double the resolution, you have a factor
of four, and halving the time step makes 8.
> dimensions.
Sorry for all the math.  I just popped my head in and saw something I couldn't
resist responding to.
Mathematically, you can rewrite the wave equation as two first order PDE's:
d^2p/dt^2 = d^2p/dx^2 + d^2p/dy^2 = del^2 p
becomes
dp/dt = div( v )
dv/dt = grad( p )
This is equivalent since differentiating the first, dp/dt, gives
d^2p/dt^2 = d/dt div(v) = div( dv/dt ) = div( grad(p) ) = del^2 p
Then, as you've done, you just store three quantities (i.e. pressure and 2 x
velocity) and compute them separately.  They're mathematically equivalent, but
computationally different.  For my approach, you need two previous frames but
only one quantity.  For your approach you need one previous frame, but three
quantities.
Sorry for the lingo; it's just the sum of second derivatives (curvature) in all
the different dimensions.  If the overall curvature is downward, it accelerates
downward, and vice versa.
 - Ricky
Date: 11 Aug 2009 19:55:00
Message: <web.4a8203d5f3b84fbd805d39df0@news.povray.org>
> the animation.
Sometimes you have to do things the fun way.  That got me thinking.  It's not
POV-Ray, but here's what I came up with.  It should compile on any kind of x11
system.  It's about as short as I could get it with a gui and an interesting
setup.  Not written for clarity (although it's really pretty straightforward).
 - Ricky
Compile with: 'cc main.c -O3 -L/usr/X11R6/lib -lX11'
Run with: ./a.out
#include <X11/Xlib.h>
#include <math.h>
int main(){int i,j,y=200,p,v;float*a,*b,
*c,*t,f[6*y*y];Display*d=XOpenDisplay(0)
;Window w=RootWindow(d,0);GC g=XCreateGC
(d,w,0,0);w=XCreateSimpleWindow(d,w,0,0,
y*2,y,0,0,0);XMapWindow(d,w);a=f;b=f+2*y
*y;c=f+y*y*4;for(i=0;i<y*y*6;f[i++]=0){}
for(;;++*f){for(i=1;i<y*2-1;i++)for(j=1;
j<y-1;j++){if((fabs(i-y)>1)|(fabs(fabs(j
-y/2)-y/10)<8)){p=i*y+j;p[a]=(b[p-1]+b[p
+1]+b[p-y]+b[p+y])/2-p[c];v=fmin(fmax(a[
p]*500+127,0),255);XSetForeground(d,g,v|
v<<8|v<<16|v<<24);XDrawPoint(d,w,g,i,j);
}}a[y*(1+y)/2]=sin(*f*.4);t=c,c=b,b=a,a=
t;}return 0;}
Date: 12 Aug 2009 05:34:18
Message: <4a828c9a$1@news.povray.org>
> challenge to do ;-)
I'm all for misusing programs and languages in this way. Heck, I'd go as
far as to say that the more unique ways you can find to accomplish a
singular goal, the better! "Unique ways" being the key of course ;)
> rules  overlay with 8 tuned-down displaced copies to add birth/death
  Ah, with the #if statement right near the apex of that calculation?
And with an average pattern instead of a function? Any way, I'd like to
see it :)
Date: 12 Aug 2009 14:25:18
Message: <4a83090e$1@news.povray.org>
Yeah, I'm in for such stuff, too.
>> birth/death rules  overlay with 8 tuned-down displaced copies to add
>> birth/death
>  Ah, with the #if statement right near the apex of that calculation? And
> with an average pattern instead of a function? Any way, I'd like to see
> it :)
What #if statement? The code won't need any #if :-) (the color map will
serve as a kind of #switch statement).
Date: 12 Aug 2009 16:55:45
Message: <4a832c51$1@news.povray.org>
>> to see it :)
Oh, I guess I was surmising based on your previous statements...
Date: 18 Aug 2009 05:22:45
Message: <4a8a72e5$1@news.povray.org>
> tired of its limitations, and was too lazy to integrate support for proper
> challenge to do ;-)
> rules, overlay with 8 tuned-down displaced copies to add birth/death hints
What you are doing here is actually very similar to how you write such
things for the GPU.  I wrote a wave simulator for the GPU a while back and
it works almost identically, never thought of the GoL on a GPU, should be
easy to implement.
Date: 18 Aug 2009 12:07:28
Message: <4a8ad1c0$1@news.povray.org>
clipka wrote:
> ...., and was too lazy to integrate support for
I'm sure you already know this but ascii PPM images are the way forward
here - a nice easy human readable/writable HDRI image format.
Obviously I admire your abuse of PovRay.
Date: 18 Aug 2009 12:49:39
Message: <4a8adba3$1@news.povray.org>
scott schrieb:
> never thought of the GoL on a GPU, should be easy to implement.
I bet. If it can be done in POV-Ray with textures only...
Here's the full POV-Ray SDL code for a GoL sim starting with a random
pattern - the only non-linearity in control flow is the #if to care for
first-frame initialization.
The world is toroidal, though this can be chaned by enabling the "once"
keyword in the definition of PgNext.
As an interesting side note, the sim does /not/ store the end result of
each generation, but interim results: The status of the cell itself,
combined with a count of the surrounding live cells. This allows easy
use of a color_map for the conditionals.
(The code could be made shorter by using macros, but I reckon this would
be counter-productive for parsing speed.)
// +W100 +H100 +KFI1 +KFF9999 +FE
#version 3.6;
global_settings {
   assumed_gamma 1.0
   ambient_light 1.0
   max_trace_level 15
   orthographic
   location <0,0,100>
   look_at  <0,0,0>
   right   -1*x
   up       1*y
default {
   finish { ambient 1.0 diffuse 0.0 }
#local FrameDigits  = int(log(final_frame)) + 1;
#local NumLayers    = 9;
#local Delta        = 1/max(image_width,image_height);
#local NeighborFactor   = 0.05;
#local CellFactor       = 0.50;
#local EPSILON          = 1e-6;
#if (frame_number = 1)
   #local PgNext = pigment { bozo color_map { [ 0.499 rgb 0 ] [ 0.501
rgb 1 ] } scale Delta }
#else
     image_pattern { concat("Life", str(frame_number-1,-FrameDigits,0))
/*once*/ }
     color_map {
       // dead cell
       [ 0*CellFactor + 2.5*NeighborFactor -EPSILON  rgb 0 ]
       [ 0*CellFactor + 2.5*NeighborFactor +EPSILON  rgb 1 ]
       [ 0*CellFactor + 3.5*NeighborFactor -EPSILON  rgb 1 ]
       [ 0*CellFactor + 3.5*NeighborFactor +EPSILON  rgb 0 ]
       // live cell
       [ 1*CellFactor + 1.5*NeighborFactor -EPSILON  rgb 0 ]
       [ 1*CellFactor + 1.5*NeighborFactor +EPSILON  rgb 1 ]
       [ 1*CellFactor + 3.5*NeighborFactor -EPSILON  rgb 1 ]
       [ 1*CellFactor + 3.5*NeighborFactor +EPSILON  rgb 0 ]
     translate -<0.5,0.5,0>
#local Tx1 = texture { pigment { PgNext translate <-1,-1, 0>*Delta }
finish { ambient NumLayers * NeighborFactor } }
#local Tx2 = texture { pigment { PgNext translate <-1, 0, 0>*Delta }
#local Tx3 = texture { pigment { PgNext translate <-1, 1, 0>*Delta }
#local Tx4 = texture { pigment { PgNext translate < 0,-1, 0>*Delta }
#local Tx5 = texture { pigment { PgNext translate < 0, 0, 0>*Delta }
finish { ambient NumLayers * CellFactor } }
#local Tx6 = texture { pigment { PgNext translate < 0, 1, 0>*Delta }
#local Tx7 = texture { pigment { PgNext translate < 1,-1, 0>*Delta }
#local Tx8 = texture { pigment { PgNext translate < 1, 0, 0>*Delta }
#local Tx9 = texture { pigment { PgNext translate < 1, 1, 0>*Delta }
#local TxOutput = texture {
   average
   texture_map {
     [1 Tx1 ]
     [1 Tx2 ]
     [1 Tx3 ]
     [1 Tx4 ]
     [1 Tx5 ]
     [1 Tx6 ]
     [1 Tx7 ]
     [1 Tx8 ]
     [1 Tx9 ]
box { <-1.5, -0.5, 0.0>, <1.5, 0.5, 0.0> texture { TxOutput } }
