I've been mostly working on the normal maps. There's a lot of textures here
that are influenced by the pattern of the sea, to create concentric waves
near the coast, cliffs on the shore, etc. Rendered without atmosphere to
save some time.
This view is much closer than anything I plan on using in a finished image,
but it's a nice way to tweak the texture details.
There's still a lot of work needed, but what do you think of it so far?
Tek
http://evilsuperbrain.com
Download 'planet_surface.jpg' (304 KB)
Preview of image 'planet_surface.jpg'
B-E-A-Utiful!
In the thumbnail it works almost perfect. In the high-res version the land
textures definitely ask for more work, but as you're not planning on doing such
close-ups anyway it should be fine.
"Tek" <tek### [at] evilsuperbrain com> wrote in message
news:4a6660c9@news.povray.org...
> here that are influenced by the pattern of the sea, to create concentric
> waves near the coast, cliffs on the shore, etc. Rendered without
> atmosphere to save some time.
> image, but it's a nice way to tweak the texture details.
> Tek
Un-beeeee-lievable!!
Looks incredible!
Well done!
Cheers Dre
Subject: Re: Planet texture WIP #3 - Coast
Date: 22 Jul 2009 02:46:27
Message: <4a66b5c3@news.povray.org>
Definitely, your brain is super and evil... ;)
Jaime
Good work, Tek!
The people on this planet obviously have a problem with sea-level rise :-)
all those roads disappearing into the sea...
What are those cracks on the landscape? Roads? They don't look like
very "natural" (so to speak) roads.
Unless this is an alien planet with an alien culture which designs
roads like that... :)
"Warp" <war### [at] tag povray org> wrote in message
news:4a66e78b@news.povray.org...
It's a futuristic world, where everyone drives amphibious cars!
Yeah... I'm gonna trim the roads back from the ocean edge I think. Though it
really is meant to be a futuristic planet so I'm not sure if they're roads
or hi-tech monorail or what.
Tek
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:4a66cd72@news.povray.org...
> Good work, Tek!
I hadn't thought of it like that :)
I plan on trimming the roads back from the coast a little, but haven't got
round to it yet.
Tek
> save some time.
Your textures are beleivable. The reliefs are correct.
You used a crackle pattern for your roads. I don't think that it's the
best one for that purpose.
Try to find a way to make the roads stop farther from the sea. Normaly,
you don't build a road on the beaches. You also have a bit of road that
don't connect to any other.
OK, it's a closeup, but those houses are very huge compared to the
natural features. Ether the planet is prety small, or it's inhabitents
are giants.
Yeah the road pattern needs some other influences, particularly to avoid the
sea.
You're right about the scale it's waaaaay off! The man-made things are huge
compared to the planet. Basically the view I plan to use is from space, and
I need the planet to look inhabited, so I'm going to keep tweaking the scale
in the final image.
Also it's a sci-fi future so maybe 58-lane freeways and 10,000 room tower
blocks are normal :)
Tek
"Alain" <aze### [at] qwerty org> wrote in message
news:4a67722c$1@news.povray.org...
> OK, it's a closeup, but those houses are very huge compared to the natural
> features. Ether the planet is prety small, or it's inhabitents are giants.
> Alain
Following some comments from my earlier posts I'm working on a pattern to
create more natural continents.
This one uses crackle with a spotted pattern on the edges to create either
peaks or troughs, with a nice turbulence to make it look more natural.
Now what I need to do is combine it with the other patterns :)
Tek
> here
> save some time.
> image,
> Tek
Download 'tectonic_test.jpg' (46 KB)
Preview of image 'tectonic_test.jpg'
Very good!
"We'd like you to back-port all the changes in 2.0
back to version 1.0."
"We've done that already. We call it 2.0."
> save some time.
At this distance from a planet, an object the size of an ordinary ocean
wave is not discernible; it would be far smaller than even one pixel in
the image here. Any of the waves you depict here would be the Mother of
all Tsunamis.
John
The scale is rather inconsistent at the moment, but the waves should be on a
similar scale to the buildings & roads.
After a bit of googling I found this image:
http://coastalchange.ucsd.edu/images/refraction2.jpg
That's the kind of thing I was going for.
If anything it's the random noisey waves in the deeper water that I need to
change, all the ocean pictures I can find show very regular patterns.
Tek
"John VanSickle" <evi### [at] hotmail com> wrote in message
news:4a67b846$1@news.povray.org...
> all Tsunamis.
> Regards,
> John
That starts looking a lot less like cheap fractals and more like the
real thing.
> save some time.
very nice looking, but I can't help but notice all of the huge landfills
all over the planet's surface ... Are the inhabitants extra trashy? ;)
~Mike
That's not trash those are sparsely distributed buildings. Though they don't
look like it so I might trim those ones or force it to only place them near
the roads.
Tek
"Mike Raiford" <"m[raiford]!at"@gmail.com> wrote in message
news:4a68bf9d$1@news.povray.org...
> ~Mike
I may be over-thinking this... here's a map of the temperatures on this
planet!
My theory is that rather than simply randomly placing different types of
terrain, if I can get nice patterns for temperature and rainfall that are
different but related to the continental pattern, then in theory I should
get a much more realistic looking planet.
I'm working on a rainfall map now :)
Tek
Download 'heat.jpg' (166 KB)
Preview of image 'heat.jpg'
> planet!
Wow, this is going to look nice when it's all done. Excellent job!
~Mike
> the roads.
I figured so, but I couldn't help myself... ;)
are the buildings randomly oriented?
~Mike
news:4a68c8d8@news.povray.org...
They're generated using crackle solid metric 1, so there's not really a
concept of orientation.
Tek
> sea.
> in the final image.
Or single buildings housing 10 000 000+ peoples who also work it that
same building...
This make me think of Azimov's Steel caves. Huge cities made of
interconnected buildings so huge that you no longer know that there is
something called "outside" ou what a "sky" is.
> planet!
I think that it's a very good idea.
It looks like it's a surface temperature, and it gets coldre at high
altitude.
Now, tou realy be complete, you also need a water and a high temperature
mao.
The vegetation will be more abundent east of the areas of high see
temperatures.
I thought of "tektonic" plates. :P
amazing as usual...
> temperatures.
Depends on the direction of rotation :P
> > temperatures.
Also on prevailing wind direction, I would think. Much oversimplified wind
directions on my west-to-east rotating planet, for example:
+90 Calm (polar high)
Northeast
+60 Calm (polar front)
Southwest
+30 Calm (subtropical high, "horse latitudes")
Northeast ("trade winds")
0 Calm (intertropical convergence zone, "doldrums")
Southeast
-30 Calm (subtropical high)
Northwest
-60 Calm (polar front)
Southeast
-90 Calm (polar high)
http://en.wikipedia.org/wiki/Atmospheric_circulation
http://en.wikipedia.org/wiki/File:Earthmap720x360_grid.jpg
Contrary to popular belief, flush toilets do *not* follow this plan:
http://www.ems.psu.edu/~fraser/Bad/BadCoriolis.html
Note that the prevailing wind directions *are* dependent on the direction of
rotation ;)
That's the spirit!
"clipka" <nomail@nomail> schreef in bericht
news:web.4a6c58ca515abde5877441c40@news.povray.org...
...and on the orientation of mountain ranges versus coasts and versus
rotation, creating rain shadows....
Date: 27 Jul 2009 15:15:11
Message: <4a6dfcbf@news.povray.org>
but that is rather a "closeup" with at most a few kilometers
field of view. Your image seems to have a curved horizon which
indicates a scale at least two magnitudes higher (although it's
a bit difficult to tell as only a short section is visible).
hmm... I hadn't thought about how rotation affects wind, I was just going to
use some turbulence for the wind, but I'll add some rotation to it.
I'd like to get the mountain ranges to cause rain, but I can't see a way to
get a smooth result without taking lots of samples, and I'm not going to do
that for what is, after all, just a pretty pattern :)
Tek
news:4a6d9119$1@news.povray.org...
> Thomas
"Christian Froeschlin" <chr### [at] chrfr de> wrote in message
news:4a6dfcbf@news.povray.org...
As I said, the scale is rather inconsistent. The waves, buildings, and roads
are on a scale that's roughly consistent with each other, but the planet's
radius is much too small by comparison.
Tek
Such a nice planet... now - please - don't add pollution in your textures!
Paolo
> save some time.
Starts to look great! Congratulations!
