POV-Ray : Newsgroups : povray.binaries.images : interesting shape: CA, DF3, isosurface (284k jpg) Server Time
29 Nov 2026 04:06:59 EST (-0500)
  interesting shape: CA, DF3, isosurface (284k jpg) (Message 1 to 20 of 20)
Subject: interesting shape: CA, DF3, isosurface (284k jpg)
Date: 4 Jun 2009 20:25:45
Message: <4a286609@news.povray.org>
Hello Everyone,
Here is the result of a 256x256-cell, 2D cellular automata sim played
out in 128 frames and copied into a df3 file. It was then rendered in
POV-Ray 3.7 using an isosurface, a box containing absorbing media, and a
single area_light. A little bit of glare was added for a touch of extra
luminance.
Thanks goes out to Warp. Last year he posted an example of how to write
df3 files in C++. I was able to adapt his code to mine and run with it.
Thanks!
Q's & C's, welcome as always~
Sam
Download 'cadf3b.jpg' (284 KB)
Preview of image 'cadf3b.jpg'
Subject: Re: interesting shape: CA, DF3, isosurface (284k jpg)
Date: 4 Jun 2009 21:15:07
Message: <4a28719b$1@news.povray.org>
A very awesome visualization. Very cool. I bet if you got a glider gun, you
could see the leaning towers. :-)
Speaking of which, I just posted "MakeDF3" to p.b.utilities. It's a
stand-alone Windows program (with portable Tcl source) that will read a file
of x,y,z,v tuples and generate an appropriate binary DF3 file. Just in case
you're working in BASIC or something and don't have convenient binary
output. ;-)
   There's no CD like OCD, there's no CD I knoooow!
Date: 5 Jun 2009 00:20:02
Message: <4a289cf2@news.povray.org>
> you could see the leaning towers. :-)
Thanks! Yeah, I should rediscover one of the large gliders I came
across. Pretty long period, might be interesting.
Sounds like a nifty app. Do you know anything about writing higher bits
to a df3 file? Will 16 or 32 bits make for a smoother function in POV? I
tried to implement higher bit values based on what the POV docs said
about it, but didn't see any difference. I'm probably doing it wrong :)
Sam
Date: 5 Jun 2009 01:23:36
Message: <4a28abd8@news.povray.org>
stbenge wrote:
>> gun, you could see the leaning towers. :-)
Actually, I'd like to see the file into which you injected your DF3. That
is, the surrounding lighting and statements and such.
I don't know. I wrote the code at the request of someone else.
Date: 5 Jun 2009 03:33:23
Message: <4a28ca43$1@news.povray.org>
Interesting, it does look a bit like organic growth of
some coral or sponge.
Note that you can write binary files since beta 32, so if
you ever port your automata to SDL you can write DF3 too ;)
Date: 5 Jun 2009 03:35:00
Message: <web.4a28c9f181b26676dd25f0b0@news.povray.org>
Remarkable. In the best possible sense :-)
Date: 5 Jun 2009 03:56:48
Message: <4a28cfc0@news.povray.org>
Corals! Excellent!
Date: 5 Jun 2009 11:30:27
Message: <4a293a13@news.povray.org>
I'll keep that in mind if I ever feel like doing things the slow way ;)
But that's good to know, actually. Thanks :)
Sam
Date: 5 Jun 2009 11:31:13
Message: <4a293a41@news.povray.org>
Thanks!
Sam
Date: 5 Jun 2009 11:32:36
Message: <4a293a94$1@news.povray.org>
Thomas de Groot wrote:
> Corals! Excellent!
That was one of my first impressions too. I removed the texture which
made it resemble a human brain. I didn't want to make anybody sick ;)
Sam
Date: 5 Jun 2009 11:58:49
Message: <4a2940b9@news.povray.org>
> That is, the surrounding lighting and statements and such.
Okay, here it is. I can also post the df3 file if you are interested. I
have the max_gradient for the isosurface set at 80, even though POV
suggested 2037.859:
CAdf3B.pov
June 2009
Samuel Benge
#default{finish{ambient 0}}
camera{
  location <-0.1735,10.3,-13>
  look_at<0,.5,0>
  angle 20/1.75
#declare air = <.1 .2 .5>;
#declare lres = 3;
#declare lpos = <.5,.5,1>;
light_source{
  lpos*100000,1.75
  area_light x*80000,z*80000,lres,lres
  adaptive 2 jitter
background{rgb <92,30,1>/1024}
#declare densityFile = "brainB.df3";
#declare DF3B=
pigment{
  pigment_pattern{planar scale 2 translate -y}
  pigment_map{
   [0 rgb 0]
   [.05
    density_file df3 densityFile
    interpolate 1
    translate -1/2
    rotate x*90+y*90
    scale 2*<1,-1,1>
#declare DF3=
function{
  pigment{
   pigment_pattern{DF3B}
   color_map{
    [0 rgb 0]
    [.25 rgb 1]
isosurface{
  function{
   -DF3(x,y,z).grey+.5
  accuracy .001
  max_gradient 80
  contained_by{box{-1,1}}
  pigment{
   bumps scale<100,.1,100>
   frequency 20
   translate y*.25
   color_map{
    [0 rgb<.8,.8,1>]
    [.25 rgb 1]
    [.5 rgb<.8,.7,1>]
    [1 rgb<1,.8,.7>]
  finish{brilliance 0}
  translate -y/8
  scale<2,1,2>
  double_illuminate
  no_shadow
box{-1.01,1.01
  pigment{rgbt 1}
  interior{
   media{
    absorption 70*air
    density{
     color_map{
      [.1 rgb 0]
      [.125 rgb 1]
  translate -y/8
  scale<2,1,2>
  hollow
Date: 5 Jun 2009 12:31:36
Message: <4a294868$1@news.povray.org>
Thank you!  I wanted to play with different CAs, not fiddle with the POV ray
itself. :-)
Actually, I have a CA that generates a nice 3D cave structure kind of thing
(sorta). Originally built for an automated dungeon-crawl type game. I've put
off building an actual scene because the blobs never seemed to come out
right. I never thought to try a DF3 instead. I'll give this a go (in my
copious spare time ;-).
Date: 5 Jun 2009 14:04:04
Message: <4a295e14$1@news.povray.org>
> ray itself. :-)
No problem! I know how you feel. I should feel bad about not learning
vector.h and how to write df3s with it, but I don't :)
> thing (sorta). Originally built for an automated dungeon-crawl type
> game. I've put off building an actual scene because the blobs never
> seemed to come out right. I never thought to try a DF3 instead. I'll
> give this a go (in my copious spare time ;-).
I would like to see it when you have something to show. I'm always
interested in those types of things!
Sam
Date: 8 Jun 2009 04:30:56
Message: <4a2ccc40@news.povray.org>
Really intriguing!
Paolo
Date: 8 Jun 2009 14:14:39
Message: <4a2d550f$1@news.povray.org>
Paolo Gibellini escribió:
> Really intriguing!
   Now that I think of it, apart from the technical wonders and the highly
artistic look, there is always "the intriguing touch" in Sam images.
   Great Work on this one, BTW...
Jaime
Date: 8 Jun 2009 15:22:12
Message: <4a2d64e4@news.povray.org>
Paolo Gibellini wrote:
> Really intriguing!
> Paolo
Thank you.
Sam
Date: 8 Jun 2009 15:23:33
Message: <4a2d6535$1@news.povray.org>
>> Really intriguing!
Thanks, it was just a test. I figured I should post *something* :)
Sam
Date: 9 Jun 2009 02:59:33
Message: <4a2e0855$1@news.povray.org>
"stbenge" <" <-"@hotmail.com> schreef in bericht
news:4a2d6535$1@news.povray.org...
Somehow, your tests are always more than just a test.
Date: 9 Jun 2009 11:21:41
Message: <4a2e7e05$1@news.povray.org>
   Test scenes are almost whole genre in visual arts, and some people are
very good at it, including Samuel. Making a non-boring test scene is really
an art...
Jaime
Date: 10 Jun 2009 03:50:34
Message: <4a2f65ca@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> schreef in bericht
news:4a2e7e05$1@news.povray.org...
> really
> an art...
I fully agree.
