POV-Ray : Newsgroups : povray.binaries.images : Port Whatmough MyMaglev system - camera inconsistency problem Server Time
31 Jul 2024 20:20:09 EDT (-0400)
  Port Whatmough MyMaglev system - camera inconsistency problem (Message 1 to 2 of 2)
Subject: Port Whatmough MyMaglev system - camera inconsistency problem
Date: 30 May 2009 04:52:57
Message: <4a20f3e9@news.povray.org>
High!
Advancing with MyMaglev... but just as I approached the completion of
the demonstration track constant-speed animation, a strange effect
appeared: from one frame to the next, the grey sky sphere suddenly
showed a kind of banding, also the perspective of the rails changed
significantly, which both never occurred before - but I didn't change
neither the y position of the camera nor the y direction of the look_at
vector!
The problem occurred at the "border" between two rail segments: a
So what is the difference between:
// frame 2270
#declare loc=<4.3933982822, 0.2, -44.8223306237>+15*<sin(radians(45)),
0, cos(radians(45))>+<-0.1646497652-(clock-2196)*0.2, 0,
0.1646497652+(clock-2196)*0.2>*1/(sqrt(2));
#declare ldir=vrotate(<0, 0, 1>, y*315);
and
// frame 2271
#declare loc = <4.3933982822, 0.2, -44.8223306237>+15*<sin(radians(45)),
0, cos(radians(45))>+<-15, 0, 15>*1/(sqrt(2))+15*<sin(radians(45)), 0,
cos(radians(45))>+15*<sin(radians(225.6289157763+(clock-2271)*0.763943726)),
0, cos(radians(225.6289157763+(clock-2271)*0.763943726))>;
#declare ldir = vrotate(<0, 0, 1>,
y*(315.6289157763+(clock-2271)*0.763943726));
See you in Khyberspace!
Yadgar
Download 'cabinrailway2270.png' (23 KB) Download 'cabinrailway2271.png' (25 KB)
Preview of image 'cabinrailway2270.png'
Preview of image 'cabinrailway2271.png'
Subject: Re: Port Whatmough MyMaglev system - camera inconsistency problem (solved)
Date: 30 May 2009 06:16:22
Message: <4a210776$1@news.povray.org>
> vector!
I found the reason for the change in the view: I left out "angle 40" in
default FOV with PoV-Ray 3.6!
Yadgar
