Hello everyone,
Here is a cellular automata simulation I created in POV. It's a very
common version that you see everywhere, but I thought it would look nice
as a shell. I wasn't striving for realism, though to figure out a way to
make an actual shell would be nice :)
The CA sim is a long strip. An array was used to store two levels of
cell history. The spheres comprising the shell hold the entire history
of the sim.
Questions and comments are welcome, as always~
Sam
Download 'lbtest7_19.jpg' (131 KB)
Preview of image 'lbtest7_19.jpg'
"stbenge" <^@hotmail.com> wrote in message news:49d00e5a@news.povray.org...
> Hello everyone,
> of the sim.
> Sam
Thats pretty hardcore man!
That would make a nice v3.7 sample scene...imo...
ian
Friggin' jawdropping awesome as usual. I also enjoy the soft lighting very much
in this one.
I won't even ask the mindblowing details even though it's probably just a couple
of meta-recursive functions in the hyperquadric domain. It's sunday.
Just wow.
Do I understand correctly that the shell shape itself
is not related to the CA simulation, i.e. no 3D growth?
Thanks Ian!
> in this one.
It's actually not that bad.
Christian Froeschlin wrote:
> Just wow.
Right Christian. The shell's shape is independent from the CA sim. I
could have displaced the spheres according to the CA data, but that
would have involved compensating for the holes caused by the
displacement. Details would have been lost.
My, that's purdie!
Tried this as a blob?
Is that "pretty hardcore, man!", or "pretty, hardcore man!"? ;)
Well, true enough either way...
> My, that's purdie!
Thanks.
Sure, I thought about it. I don't like to think of what the render time
would be though. I might give it a shot, for another object perhaps.
[speechless]
Beautiful.
I've wondered before about ways to realistically texture mollusc shells, and
this appears to be it! It might not even be too far from how it actually
happens in reality.
I too would be interested to see a blob version.
Bill
Oooh.
Beautiful both the image and the concept.
Paolo
>stbenge on date 30/03/2009 02:11 wrote:
> Hello everyone,
> of the sim.
> Sam
> > My, that's purdie!
> Thanks.
Actually, I recently replaced several thousands of randomly placed spheres in
some scene with blobs, not for "blobification" but just for speedup. Seems like
the internal bounding of blobs is significantly more effective than the standard
boxing approach.
But that may also differ depending on other circumstances; for instance, those
spheres were scattered quite sparsely about, so the main load was not to
compute intersection points, but to verify that no intersection points had to
be computed in the first place.
Wolfram, move over. Very pretty.
There's no CD like OCD, there's no CD I knoooow!
stbenge wrote:
I remember a time when I actually understood what you were doing.
You always seem to arrive at these things so casually. Like you back
into the discovery while doing something else.
Intriguing in the possibilities hinted at. Could 'Cellular Automata' be
implemented as a POV procedural pattern?
Could the building blocks be actual building blocks, like bricks or
something?
-Jim
Thomas de Groot wrote:
> [speechless]
> Thomas
> Beautiful.
> happens in reality.
I sometimes wonder how certain shells have come to have such patterns on
them. There is one CA sim based on Pascal's triangle which produces
Sierpinki-esqu patterns, and I have seen something strikingly similar on
a real shell. How does it happen?
It might just happen :)
Paolo Gibellini wrote:
> Oooh.
> Paolo
Thank you Paolo!
Darren New wrote:
> Wolfram, move over.
I know you must be kidding.
> Very pretty.
Jim Charter wrote:
It's as easy as Pascal's triangle, and only gets better from there.
Sometimes that is the case. This time I had made the discoveries some
time ago, but never put them together to produce an image like this one.
I know it can, because I managed to do it. Attached is an example of the
pattern so far. This is just one of many possibilities. This particular
image exhibits the pattern's ability to exceed POV's 256 entry limit for
the color_map function. I can exceed that number vertically, but not
horizontally, for to do so might eat too much memory. I can make really
long strips with this, a total of 255*128 cells. This one, stretched
out, would be only four times its current height. Rendering the full
length version caused my computer to start swapping the hard drive
earlier today.
> something?
Yes. To make it "physical" you could use inside() tests to check space
for previously placed cells. By doing this you could break free of the
usual grid restraints.
Sam
Download 'capattern0_31.jpg' (154 KB)
Preview of image 'capattern0_31.jpg'
I don't think I've seen anything like this in p.b.i--it's so different and
beautiful that it seems like a 'new direction' for POV-Ray. This has "Hall of
Fame" written all over it. I can't begin to imagine how you accomplished such a
work of art; it's sublime, and transcends technique.
KW
> KW
ANKOS - A New Kind Of Shell :)
stbenge wrote:
> How does it happen?
Probably something like a CA, only implemented in biological chemistry.
Well, is it any surprise that organisms comprised of cells exhibit some
"cellular automaton" behavior? ;)
"Paul Fuller" <pgf### [at] optusnet com au> a écrit dans le message de news:
49d1f499$1@news.povray.org...
>> and
>> "Hall of
>> such a
>> KW
YAANA - Yet Again A New Acronym ;)
Marc
To quote from
http://www.sciencedaily.com/releases/2006/11/061126121128.htm
Biology reveals that the shape and colour patterns on the shell of the
mollusc mirror the localised expression of specific genes in the
mantle, a layer of skin situated just below the shell.
For rendering shells in POV you could look at http://www.shelly.de/
I have not tried this program though.
The isosurface tutorial has some renderings
http://www.econym.demon.co.uk/isotut/shells.htm
I am sure i saw an article some time ago that gave equations enabled
you to draw the patterns of actual shell colourings but cannot
remember where that was.
John
A case for the AAAAA - American Association Against Acronym Abuse...
>>> and
>>> "Hall of
>>> such a
>>> KW
> Marc
Well I didn't coin it - just adapted it from Mr Wolfram and his CA opus
"A New Kind Of Science".
Paul
clipka nous illumina en ce 2009-04-01 05:11 -->
It's AAAAAAA - American Association Against Acronims Abuse And Ambiguity.
Sometimes my love of the arcane combines with my askew humor to make me
unintelligible!!
Thank you for the kind words, KW
