POV-Ray : Newsgroups : povray.binaries.images : POV 3.7 metals.inc; post your textures here Server Time
29 Nov 2026 04:17:00 EST (-0500)
  POV 3.7 metals.inc; post your textures here (Message 1 to 50 of 82)
Goto Latest 50 Messages Next 32 Messages >>>
Subject: POV 3.7 metals.inc; post your textures here
Date: 28 Mar 2009 22:06:15
Message: <49ced797@news.povray.org>
To all users:
Please post your metal textures here.
Once this inc file is done I will move to waters.inc, stones.inc, woods.inc,
etc.. so you can go ahead and post those textures too if you want. Remember:
radiosity compatibility. ;-)
ian
Subject: Re: POV 3.7 metals.inc; post your textures here
Date: 29 Mar 2009 05:20:20
Message: <49cf3d54@news.povray.org>
Here are six metal textures. Nothing really special. Just thought they might
be of interest.
Download 'textures_test_metals.jpg' (69 KB) Download 'textures_test_metals.inc.txt' (8 KB) Download 'textures_test_metals.pov.txt' (2 KB)
Preview of image 'textures_test_metals.jpg'
Date: 29 Mar 2009 09:10:01
Message: <web.49cf72ef4ee6dd4eea392f10@news.povray.org>
> be of interest.
The rusty steel looks great. The other ones in the front row I'm not sure about.
The three in the back look rather non-metallic to me - but then again, they
might all be oxidized - in that case I guess they're ok.
Date: 29 Mar 2009 09:35:37
Message: <49cf7929@news.povray.org>
"clipka" <nomail@nomail> schreef in bericht
news:web.49cf72ef4ee6dd4eea392f10@news.povray.org...
> about.
> they
The two in front you mention are fantasy metals, just for fun; the two
greenish ones are bronzes with an oxydized/patina layer. Back left, is a
rusty iron.
They may not be exactly RL, but I am not sure that metals.inc should only
contain RL stuff. However, I leave selection to the community.
Date: 29 Mar 2009 12:20:01
Message: <web.49cf9ea34ee6dd4e1dfafa300@news.povray.org>
"[GDS|Entropy]" <gds-entropy    AT    hotmail   DOT  com> wrote:
> To all users:
> ian
A rusty iron-texture
---[Snip]---------------
//*PMRawBegin
#include "textures.inc"
//*PMRawEnd
global_settings {
   adc_bailout 0.0039216
   assumed_gamma 1.5
   max_trace_level 256
   noise_generator 2
sky_sphere {
      color rgb <0.054902, 0.219608, 0.4>
cylinder {
   <0, 3, 0>, <0, -3, 0>, 2
         spherical
         turbulence <1, 1, 1>
         omega 1
         lambda 6
         color_map {
            [ 0.1 color rgb <0.478431, 0.513725, 0.462745>
      normal {
         boxed
         30
         omega 1
         lambda 6
         frequency 15
      finish {
         ambient rgb <0, 0, 0>
         diffuse 0.3
         specular 0.6
         conserve_energy
         reflection {
            rgb <0.1, 0.1, 0.1>
            metallic 1
      scale 15
   scale 1
   rotate <0, 0, 0>
   translate <1.6, 0, 5.53333>
sphere {
   <0, 0, 0>, 2
      uv_mapping
         spherical
         omega 1
         lambda 6
         color_map {
      normal {
         boxed
         30
         omega 1
         lambda 6
         frequency 15
      finish {
         diffuse 0.3
         specular 0.6
         conserve_energy
         reflection {
            rgb <0.1, 0.1, 0.1>
            metallic 1
      scale 7.5
   scale 1
   rotate <0, 0, 0>
   translate <2.13333, 0, -3.13333>
torus {
   3, 1
         spherical
         omega 1
         lambda 6
         color_map {
      normal {
         boxed
         30
         omega 1
         lambda 6
         frequency 15
      finish {
         diffuse 0.3
         specular 0.6
         conserve_energy
         reflection {
            rgb <0.1, 0.1, 0.1>
            metallic 1
      scale 7.5
   scale 1
   rotate <90, -45, 0>
   translate <-3.73333, 0, 3.5>
light_source {
   //*PMName Key-Light
   <7, 5, -10>, rgb <1, 1, 1>
   area_light <6, 0, 0>, <0, 6, 0>, 9, 9
   adaptive 2
   jitter
   circular
   orient
light_source {
   //*PMName Fill-Light
   <-7, 5, -10>, rgb <0.5, 0.5, 0.5>
   shadowless
   media_interaction off
   perspective
   location <-0.3, 4, -9>
   sky <0, 1, 0>
   direction <0, 0, 1>
   right <1.3333, 0, 0>
   up <0, 1, 0>
   look_at <0, 0, 0>
---[Snap]------------
Download 'rostiges eisen(2).png' (405 KB)
Preview of image 'rostiges eisen(2).png'
Date: 29 Mar 2009 13:28:02
Message: <49cfafa2@news.povray.org>
Metallic spaceship-hull panels
.. or greebles-in-a-texture if you like :)
--- START CODE ---
#declare MetalPanels=
  average
  pigment_map {
   [1
   cells
   pigment_map {
    [0
     cells
     color_map {
      [0 rgb .6]
      [1 rgb 1]
     scale 1.5
    [.4
     cells
     color_map {
      [0 rgb .8]
      [1 rgb 1]
     translate <.25,.5,.2>
   [1
   cells
   color_map {
    [0 rgb .8]
    [1 rgb 1]
   translate <.25,1.5,.2>
   scale 2
   translate <2.25,1.5,3.5>
  scale .25
 normal {
  average
  normal_map {
   [1
   cells
   normal_map {
    [0
     cells
     bump_size 1
     scale 1.5
    [.4
     cells
     bump_size .8
   scale 1
   [1
   cells
   normal_map {
    [0
     cells
     bump_size 1
     scale .5
    [.4
     cells
     bump_size .8
   scale .25
   [1
   cells
   bump_size .5
   scale 2
 finish {ambient 0 diffuse 1 brilliance 4 specular 1 roughness .01 metallic}
#declare PanelScars=
  crackle form <1,0,0>
  color_map {
   [0 rgbt <.1,.01,0,.5>]
   [.2 rgbt <.1,.01,0,1>]
  scale .5
  turbulence .2
  lambda 3
  scale 4
 normal {
  dents .1
 finish {
  diffuse .5 ambient 0
#declare PanelDirt=
  granite
  color_map {
   [0 rgb .2*<.8,.75,.7> transmit .99]
   [1 rgb .1*<.8,.75,.7> transmit .8]
 finish {ambient 0 diffuse .5}
#declare PanelDirt2=
  granite
  color_map {
   [1 rgb .1*<.8,.75,.7> transmit .6]
//Test-scene:
#local Area_Lights=off;
#local Skylights=60;
#local Seed=seed(123);
 location <2,2,2>*2
 look_at 0
//some fancy lighting
light_source {
 <-500,500,500>*50
 rgb <1.5,1.3,1.1>
 #if (Area_Lights)
 area_light
 x*5000,y*5000
 4,4
 circular
 orient
#local MI=Skylights;
#local I=0;
#while (I<MI)
 #local LL=vrotate(vrotate(x,z*360*rand(Seed)),y*180*rand(Seed));
 #local LH=pow(LL.y,2);
 #local LX=pow(1+LL.x/2,1);
 #local LL=LL*5000;
 light_source {
  LL
  rgb <.4,.5,.9>*2.5/MI
  #if (Area_Lights)
  area_light
  x*5000,y*5000
  4,4
  adaptive 2 jitter circular orient
 #local I=I+1;
sphere {
 0,1
 uv_mapping
 texture {MetalPanels translate 1 scale .25}
 texture {PanelScars scale <.125,.125,.5>}
 texture {PanelDirt scale <.5,.25,1>}
 texture {PanelDirt2 scale <.25,.125,.7>}
torus {
 1.5,.5
 uv_mapping
union {
 cylinder {-x*4,x*4,.35}
 cylinder {-z*4,z*4,.35}
 texture {PanelDirt scale <.5,.25,.5>}
 texture {PanelDirt2 scale <.7,.125,.7>}
sphere {
 0,1
 pigment {bumps
  color_map {
   [.25 rgb <.7,.8,.9>]
   [.7 rgb 1]
  poly_wave 2
  scale <1,.25,1>*5
  warp {turbulence .5 lambda 3}
  scale .5/5
 finish {ambient 1 diffuse 0}
 scale 100
 no_shadow
 no_image
plane {y,-2
  granite
  color_map {
   [0 rgb <.5,.4,.3>]
   [1 rgb <.6,.5,.4>]
 no_image
 no_shadow
--- END CODE ---
cu!
Download 'metalpanels.jpg' (40 KB)
Preview of image 'metalpanels.jpg'
Date: 29 Mar 2009 13:30:00
Message: <web.49cfaffb4ee6dd4eea392f10@news.povray.org>
Looks more like old oil than rust to me - but great effect in any case!
Date: 29 Mar 2009 14:07:22
Message: <49cfb8da$1@news.povray.org>
  That one could be quite useful to many, I'm sure.
Date: 29 Mar 2009 16:30:00
Message: <web.49cfda3f4ee6dd4eea392f10@news.povray.org>
Definitely so.
Date: 29 Mar 2009 18:15:00
Message: <web.49cff2824ee6dd4e5aa5eee10@news.povray.org>
> To all users:
> ian
Here's another rusty one ...
#declare radiosity_on = true;
#declare globalreflection =1;
#if (radiosity_on)
// radiosity (global illumination) settings
global_settings {
  radiosity {
    pretrace_start 0.08           // start pretrace at this size
    pretrace_end   0.04           // end pretrace at this size
    count 35                      // higher -> higher quality (1..1600) [35]
    nearest_count 5               // higher -> higher quality (1..10) [5]
    error_bound 1.8               // higher -> smoother, less accurate [1.8]
    recursion_limit 3             // how much interreflections are calculated
(1..5+) [3]
    low_error_factor .5           // reduce error_bound during last pretrace
step
    gray_threshold 0.0            // increase for weakening colors (0..1) [0]
    minimum_reuse 0.015           // reuse of old radiosity samples [0.015]
    brightness 1                  // brightness of radiosity effects (0..1) [1]
    adc_bailout 0.01/2
    //normal on                   // take surface normals into account [off]
    //media on                    // take media into account [off]
    //save_file "file_name"       // save radiosity data
    //load_file "file_name"       // load saved radiosity data
    //always_sample off           // turn sampling in final trace off [on]
    //max_sample 1.0              // maximum brightness of samples
  assumed_gamma 1.0
#else
global_settings {
  assumed_gamma 1.0
#declare base = texture {
  pigment { color rgb <0.91, 0.95, 0.91>*0.5}
  normal {
     wrinkles
      normal_map {
        [ 0.0 granite 0.00 scale 0.001]
        [ 0.2 granite 0.0 ]
        [ 0.28 wrinkles 0.05 turbulence 0.5 scale 0.005]
        [ 0.38 wrinkles 0.05 turbulence 0.5 scale 0.005]
        [ 0.4 granite 0.0 ]
        [ 0.62 granite 0.05 turbulence 0.5 scale 0.005]
        [ 0.9 granite 0.0 ]
        [ 1.0 granite 0.00 scale 0.001]
  turbulence 0.05
  scale 300
    #if (radiosity_on)
      finish {
        ambient 0.0
        brilliance 2
        diffuse 0.3
        metallic
        specular 0.80
        roughness 1/2000
        reflection 0.9*globalreflection
    #else
      finish {
        ambient 0.01
        brilliance 2
        diffuse 0.3
        metallic
        specular 0.80
        roughness 1/2000
#declare tex1 = texture {
  pigment { granite
    color_map {
      [ 0 color rgb <0.7, 0.4, 0.2> ]
      [ 1 color rgb <0.6, 0.2, 0.05> ]
    } turbulence 0.2 scale 0.5
  normal { bumps 0.2
  turbulence 0.05
  scale 0.5
    #if (radiosity_on)
      finish {
        ambient 0.0
        brilliance 2
        diffuse 0.3
        metallic
        specular 0.20
        roughness 1/20
        reflection 0.1*globalreflection
    #else
      finish {
        ambient 0.01
        brilliance 2
        diffuse 0.3
        metallic
        specular 0.20
        roughness 1/20
#declare tex2 = texture {
  wrinkles
  texture_map {
     [0  base]
     [0.5 tex1 ]
  } scale 0.2 turbulence 0.5
#declare final= texture {
  wrinkles
  texture_map {
     [0  base]
     [0.1 base]
     [0.1 tex2 scale 0.005]
     [0.11 tex2 scale 0.005]
     [0.12 base]
     [0.5 base]
     [0.7 tex2 scale 0.05]
Download 'metaltex.png' (216 KB)
Preview of image 'metaltex.png'
Date: 29 Mar 2009 18:46:25
Message: <49cffa41@news.povray.org>
galvanized steel, might need some work though
#declare GalvanizedSteel=
material {
  pigment {crackle solid scale .1
   color_map {
    [0 rgb .5]
    [1 rgb .9]
  normal {granite -.03}
  finish {ambient 0 diffuse 1 brilliance 3 specular 1 roughness .01 metallic
reflection {0,.125 fresnel on metallic 1}}
 interior {ior 30}
cu!
Download 'galvanized steel.jpg' (43 KB)
Preview of image 'galvanized steel.jpg'
Date: 29 Mar 2009 19:52:29
Message: <49d009bd$1@news.povray.org>
Great work everyone!!
Keep it up!
ian
Date: 30 Mar 2009 02:34:17
Message: <49d067e9$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schreef in bericht
news:49cfb8da$1@news.povray.org...
Absolutely.
Date: 30 Mar 2009 02:34:48
Message: <49d06808@news.povray.org>
I like your textures.
Date: 30 Mar 2009 21:46:06
Message: <49d175de@news.povray.org>
> be of interest.
> Thomas
Rust on chrome looks great, so does middle back, makes me think of lead?
or something about wet batteries?
Date: 31 Mar 2009 04:42:43
Message: <49d1d783$1@news.povray.org>
That is an excellent one!
Date: 31 Mar 2009 05:01:34
Message: <49d1dbee$1@news.povray.org>
"Jim Charter" <jrc### [at] msncom> schreef in bericht
news:49d175de@news.povray.org...
Middle back and right back are my combination, with some adaptations, of two
separate textures, one by Meothuru, the other by jivvy (originally in Moray
format).
Note: code files are attached in the message with the image.
Date: 31 Mar 2009 05:04:04
Message: <49d1dc84$1@news.povray.org>
This is great for far away; greebles for close up. Well done!
By the way, how is your update of the greebles macro coming along? (just
curious...)
Date: 31 Mar 2009 05:25:00
Message: <web.49d1e0484ee6dd4ef50167bc0@news.povray.org>
> To all users:
> ian
Sorry to be so brain-challenged, but: radiosity compatibility? I've seen that
term mentioned several times lately, and have no clue what it means re:
textures.  I must have missed something somewhere. Please explain?
KW
Date: 31 Mar 2009 05:35:00
Message: <web.49d1e3a74ee6dd4ef50167bc0@news.povray.org>
Unique and useful. Definitely a keeper.
KW
Date: 31 Mar 2009 05:40:01
Message: <web.49d1e4a14ee6dd4e6dd25f0b0@news.povray.org>
Very nice...
But how on EARTH did I not know about the 'solid' crackle pattern until now?
*smacks forehead* Obviously I'm not idly reading the docs during enough coffee
breaks!
Date: 31 Mar 2009 05:40:35
Message: <49d1e513@news.povray.org>
> Keep it up!
Here's a few I had stored away. Some are perty generic though.
#declare tex_gray_metal = texture {
   pigment{color <0.3,0.3,0.35>}
   finish {
      ambient 0.50
      brilliance 2
      diffuse 0.4
      metallic
      specular 0.50
      roughness 5/60
      reflection 0.1
#declare tex_black_metal = texture {
   pigment{Gray05}
   normal{facets coords 1 scale 0.1}
   finish {
      ambient 0.10
      brilliance 2
      diffuse 0.4
      metallic
      specular 0.50
      roughness 5/60
      reflection 0.1
   scale 0.5
#declare tex_cast_metal = texture {
   pigment {color <0.1,0.1,0>}
   normal {
      bumps
      scale <0.002,0.002,0.005>*2
   finish {
      specular 0.5
      roughness 0.15
#declare chrome = texture{
  pigment{ color rgb <1,1,0.941176> }
  finish{
     ambient 0
     diffuse 0.4
     specular 0.9
     roughness 0.06
     reflection 0.4
     metallic
#declare chrome2 = texture {
   pigment { color <1,1,0.941176> }
   finish {
      ambient 0
      diffuse 0.4
      specular 0.9
      roughness 0.06
      reflection 0.2
      metallic
#declare brushed = texture {
  pigment { color <1,1,0.968627> }
  normal {
     wrinkles 0.3
     scale 0.05
  finish {
     ambient 0
     diffuse 0.25
     specular 0.9
     roughness 0.1
     reflection 0.2
     metallic
     brilliance 0.9
     conserve_energy
#declare steel = texture {
  pigment { color rgb <1,1,0.941176> }
  finish {
     ambient 0
     diffuse .3
     specular .9
     roughness .1
     reflection .3
     metallic
  normal { wrinkles .1 scale 1 }
#declare brass = texture {
  pigment { color rgb <0.549019,0.333333,0.2> }
  normal {
     wrinkles 0.1
     scale 1
  finish {
     ambient 0
     diffuse 0.2
     specular 0.5
     roughness 0.02
     reflection 0.6
     metallic
Download 'my_metals.jpg' (178 KB)
Preview of image 'my_metals.jpg'
Date: 31 Mar 2009 06:11:08
Message: <49d1ec3c$1@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:49d1dc84$1@news.povray.org...
> curious...)
not so good :(
I was working on it this weekend.  It works, but it's extremely slow.  As
in: 25 minutes parsing time for 1 very simple greebled patch.  An entire
spaceship made with those greebled patches would take a couple of hours.
Not very useful, is it :(
I'm not sure yet how to make it faster.
oh well, I'll find a way :)
cu!
Date: 31 Mar 2009 07:07:37
Message: <49d1f979@news.povray.org>
My own textures aren't comparable to these incredible examples, but I
have some other suggestions:
LightBeam's "Pyramolles" metallic material:
http://news.povray.org/povray.binaries.images/thread/%3C41aa4cb1@news.povray.org%3E/?ttop=231772&toff=1650
Jaime Vives Piqueres's t_custom_paint:
http://news.povray.org/41d83ed3@news.povray.org
Michael Raiford's copper texture:
http://news.povray.org/41e52fcd$1@news.povray.org
Ross's texture:
http://news.povray.org/povray.general/thread/%3C42c5bb9d%40news.povray.org%3E/
Helge H's texture:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4403bbf171d7750e1c6902970@news.povray.org%3E/?ttop=284288&toff=1550
Paolo
 >[GDS|Entropy]  on date 29/03/2009 04:06 wrote:
> To all users:
> ian
Date: 31 Mar 2009 07:35:00
Message: <web.49d1ff864ee6dd4e6dd25f0b0@news.povray.org>
These textures are all great, but they all seem to fill very specific needs.
What might be nice is to also offer a set of 'bog-standard' ;-) polished,
diffuse or otherwise finished metals which just consist of a well-chosen
pigment colour and the standard finish/normal in question (i.e., Gold_Polished,
Gold_Diffuse, Gold_Beaten) etc.
Does anyone know of any decent photographic reference table(s) that compare
different metal colours? Even just jewellery metals would be a starting point.
(I've tried searching for this before and always come up short). I know some of
the common ones are defined in colors.inc, but to be honest most of them don't
look like the metals they're named for, so starting afresh would be my best
option.
I'm happy to knock up a standard set like this as long as I can find some good
image references.
Comments?
Date: 31 Mar 2009 08:25:00
Message: <49d20b9c$1@news.povray.org>
Very evocative!
Paolo
Date: 31 Mar 2009 09:33:51
Message: <49d21bbf@news.povray.org>
specific needs.
> option.
> image references.
> Comments?
Well, what I have is some data measured with a spectrophotometer. Colors
(converted into scRGB color space - which is just sRGB primaries but
with a linear gamma mapping), diffuse reflection as measured together
with some IOR for fresnel reflection.
I made some macros for them, looks like this:
...snip
// some micro normals
#declare P_Micro1 = pigment {
   granite turbulence 0
   color_map {
     [0.0 rgb 0.3]
     [1.0 rgb 0.7]
   scale 0.003
#declare P_Micro2 = pigment {
   onion turbulence 0.5
   color_map{
     [0.0  color rgb 1.00]
     [0.45 color rgb 0.99]
     [0.55 color rgb 0.96]
     [1.0  color rgb 0.95]
   scale 0.01
#declare P_Macro1 = pigment {
   crackle turbulence 1
   color_map {
     [0.00 rgb 0.3]
     [0.01 rgb 0.3]
     [0.02 rgb 0.7]
     [1.00 rgb 0.7]
   scale 0.3
// "micro"-normals for blurred reflection - to get some highlights
#macro P_Polish(Polish)
   pigment_pattern {
     average
     pigment_map {
       [1 P_Micro1 translate x*20]
       [1 P_Micro1 translate y*20]
       [1 P_Micro1 translate z*20]
       [1 P_Micro2 translate -x*20]
       [1 P_Micro2 translate -y*20]
       [1 P_Micro2 translate -z*20]
   1 - Polish
// "macro"-normals for scratches and dents
#macro P_Dents(Dents)
   pigment_pattern {
     average
     pigment_map {
       [1 P_Macro1 translate y*10]
       [1 P_Macro1 translate z*10]
   Dents
// averaged normals
#macro N_Pattern(Polish, Dents)
   normal {
     average
     normal_map {
       [1 P_Polish(Polish)]
       [1 P_Dents(Dents)]
// MATERIAL MACROS
#macro MaterialGold(Polish, Dents)
   material {
       pigment {rgb <0.9927, 0.6952, 0.3302>}
       finish {
         ambient 0  diffuse 1-0.7280
         specular 0  brilliance 3
         reflection {0.0 1.0 fresnel on metallic}
         conserve_energy
     interior {ior 2.83}
#macro MaterialSilver(Polish, Dents)
   material {
       pigment {rgb <0.9284, 0.9016, 0.8678>}
       finish {
         ambient 0  diffuse 1-0.9001
         conserve_energy
     interior {ior 3.64}
#macro MaterialCopper(Polish, Dents)
   material {
       pigment {rgb <0.7802, 0.2985, 0.1078>}
       finish {
         ambient 0  diffuse 1-0.3832
         specular 0  brilliance 2.4
         conserve_energy
     interior {ior 3.26}
...snip
Note that I did not use any specular or phong highlights, it all depends
    on (blurred) reflections so they work well with "radiosity-only"
scenes or MC-Pov. But I guess to add some specular values is simple and
the values for brilliance are just wild guesses anyway (maybe they
should be equal to the ior, I must admit that I have no idea how POV
computes this brilliance value).
Example images, one is MCPov with 200 passes and one is POV Beta 31 with
conventional lighting and 128 light sources (no radiosity).
Settings are always 0.5 for "Polished" and 0.2 for "Dents".
And I have (over)used the kitchen probe once more again ;)
Download 'material_test_mcpov.jpg' (62 KB) Download 'material_test_lightdome.jpg' (50 KB)
Preview of image 'material_test_mcpov.jpg'
Preview of image 'material_test_lightdome.jpg'
Date: 31 Mar 2009 09:42:57
Message: <49d21de1@news.povray.org>
>> To all users:
>> ian
> KW
ambient 0 in the finish statement, otherwise it would emit light.
For "radiosity-lit-only" scenes (or MCPov for that matter) it would even
mean "specular 0" and "phong 0".
-Ive
Date: 31 Mar 2009 10:05:04
Message: <49d22310$1@news.povray.org>
I like them.
Some of these are very ...organic.
Paolo
> be of interest.
> Thomas
Date: 31 Mar 2009 10:20:21
Message: <49d226a5$1@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> schreef in bericht
news:49d1ec3c$1@news.povray.org...
> not so good :(
In the meantime, the present version works fine :-)
I am sure you will find a way eventually.
Date: 31 Mar 2009 11:00:00
Message: <web.49d22ed84ee6dd4e6dd25f0b0@news.povray.org>
Beautiful. This is just what I was thinking of. Are you willing to share these,
or just the colour data? :) How many metals have you created like this?
Yeah, sounds good. Doesn't really matter, as long as they look good most of the
time, users can tweak easily enough.
Never!
To be honest, I wasn't even thinking of anything this ambitious - just a basic
polished finish, maybe some dents, really just to get the basic colours
consistent and believable. Great work!
Bill
Date: 31 Mar 2009 13:25:01
Message: <web.49d2518e4ee6dd4ef708085d0@news.povray.org>
Basically just making sure that it can be used in radiosity scenes without
acting as a light emitter there (due to ambient set to >0).
Date: 31 Mar 2009 13:30:00
Message: <web.49d2520e4ee6dd4ef708085d0@news.povray.org>
"Tim Attwood" <tim### [at] anti-spamcomcastnet> wrote:
>       ambient 0.50
Yuck! :P
Date: 31 Mar 2009 14:15:36
Message: <49d25dc8$1@news.povray.org>
Sure. But I have only four more metal materials and here they are:
...snip
#macro MaterialBronze(Polish, Dents)
   material {
       pigment {rgb <0.5568, 0.3484, 0.1528>}
       finish {
         ambient 0  diffuse 1-0.3768
         conserve_energy
     interior {ior 3.1}
#macro MaterialBrass(Polish, Dents)
   material {
       pigment {rgb <0.5709, 0.3356, 0.1491>}
       finish {
         ambient 0  diffuse 1-0.3702
         conserve_energy
     interior {ior 8.0}
#macro MaterialSteel(Polish, Dents)
   material {
       pigment {rgb <0.4412, 0.4137, 0.3727>}
       finish {
         ambient 0  diffuse 1-0.4163
         specular 0  brilliance 2.8
         conserve_energy
     interior {ior 8.6}
#macro MaterialChrome(Polish, Dents)
   material {
       pigment {rgb <0.9310, 0.9265, 0.9221>}
       finish {
         ambient 0  diffuse 1-0.9642
         conserve_energy
     interior {ior 15}
...snip
Feel free to use them in any way you like. (Note, the diffuse setting is
quite important in combination with the color itself).
I do not claim there is something "physically" accurate with them -
especially with the way I did handle the fresnel reflection. In the
"real world" metals have fresnel reflection but in the "real world" the
IOR is a complex number and for metals the imaginary part of the IOR is
the important one. To do some tests with POV is since quite a while on
my "to do"-list... oh well, if only the "real life" would not need most
of my time :)
BTW, the colors from "metals.inc" in the POV contribution are not so
bad, I think. The problem is, all of them (and this is also true for
colors.inc, woods.inc and so on) are created in the early days of
POV-Ray when everybody used assumed gamma 2.2 (or even assumed gamma was
not yet introduced, POV simply did work with gamma 2.2). But we had a
kind of paradigm change regarding the gamma handling and the new beta
enforces a linear gamma. So to use them they all have to be inverse
gamma corrected. And wrong gamma correction makes colors not only darker
or brighter, it changes also the hue.
-Ive
Date: 1 Apr 2009 04:55:00
Message: <web.49d32b3f4ee6dd4ef708085d0@news.povray.org>
That's not necessary, as without classic light sources these values don't have
any effect anyway (well, maybe a *tiny* bit more computing time).
They should definitely be non-zero for materials to work in non-radiosity-lit
scenes, as they will have to simulate highlights from the classic lights, which
we can't see otherwise.
Ideally, there should be *some* connection between these values and the
reflectivity of the material (and likewise between the roughness or
corresponding phong parameter, and the blurriness of reflectivity in case
micronormals are used), though I'm not sure how exactly these should be
related.
Date: 1 Apr 2009 10:41:37
Message: <49d37d21@news.povray.org>
  That's what #default { finish { ambient 0 } } is for.
  What happens if you *want* the texture to have an ambient value >0?
Date: 1 Apr 2009 11:09:41
Message: <49d383b5$1@news.povray.org>
This does not work if the texture already has a finish with ambient > 0.
But I'm pretty sure you know that.
Well, in a radiosity scene - thats what I was talking about - this means
you are going to define a metal (remember, this thread is about metal
textures) with a temperature of lets say 4500° Kelvin. But I guess you
know that too ;)
-Ive
Date: 1 Apr 2009 11:16:11
Message: <49d3853b$1@news.povray.org>
Well, I did see it the other way round. If you define a texture that
looks great with nice specular/phong highlights you might be
disappointed how it looks if used in a radiosity only lit scene, because
all highlights are gone.
-Ive
Date: 1 Apr 2009 11:18:08
Message: <49d385b0$1@news.povray.org>
clipka nous illumina en ce 2009-04-01 04:52 -->
> related.
Any bluring will have an effect on the tightness of the highlights. The tighter
the highlight, the more visible the effect.
Low reflectivity goes with weak highlights. Ether use a multiple of the
reflection value or something like the square root of the reflection value. The
highlights tend to look as if it increase faster than the perceived reflection
for low reflection.
You know you've been raytracing too long when you have ever gotten in a flame
war over various rendering softwares.
Stephan Ahonen
Date: 1 Apr 2009 11:21:35
Message: <49d3867f$1@news.povray.org>
Warp nous illumina en ce 2009-04-01 10:41 -->
You just add finish{ambient YourValue} and it will override that defined elsewhere.
If you provide a texture that is INTENDED as having some ambient, just add a
comment to that effect to your texture. Make it clear that that texture will
then illuminate it's surrounding in any radiosity scene.
John' First Law of Software Developer Productivity:
"A program written by someone who does not work for you will be done when it is
done."
Date: 1 Apr 2009 11:40:01
Message: <web.49d38a4a4ee6dd4ef708085d0@news.povray.org>
Not with material to place in a lib. Those should have all parameters set, just
to be sure. After all, you never know what the user sets his defaults to.
Then you're screwed with radiosity...
Date: 1 Apr 2009 11:45:00
Message: <web.49d38b094ee6dd4ef708085d0@news.povray.org>
(As a matter of fact, I think the material definitions should get some overhaul,
too, so that specular highlights and specular reflection are automatically "in
sync", so you don't have to worry about such issues)
Date: 1 Apr 2009 15:47:20
Message: <49d3c4c8$1@news.povray.org>
include files could use a #define such as RADIOSITY_TEXTURES
to provide two versions of a texture depending on whether the
#define is set before #including. For textures which just use
a different ambient value that would be no extra effort to
write using a simple macro for ambient.
#macro AMBIENT(ambient_value)
#ifdef RADIOSITY_TEXTURES
   ambient 0
#else
   ambient ambient_value
#declare T_SOME_TEXTURE = texture
   pigment {...}
   normal  {...}
   finish  {... AMBIENT(0.15)}
Date: 1 Apr 2009 16:10:00
Message: <web.49d3c8d94ee6dd4ef50167bc0@news.povray.org>
Got it. (Although the specular and phong stuff is new--I need to do some
experiments to see.)
Here's an 'old pitted iron texture' that I dug out of one of my scenes (I
actually started with one of the stones.inc pigments, and modified it)...
#declare old_pitted_iron_texture =
        pigment{
                granite  // AGATE works well for this too.
                color_map {
                        [0.000 rgb .8*<.4, .4, .380>]
                        [0.153 rgb .4]
                        [0.398 rgb .5*<0.7, 0.4, 0.25>]
                        [0.398 rgb .2*<0.7, 0.7, 0.7>]
                        [1.000 rgb <0.545, 0.380, 0.345>]
        finish{
              ambient .2 // 0 for radiosity
              diffuse 1
              phong .6
              phong_size 24
        normal {granite .7 scale 9}
KW
Download 'old_pitted_iron.jpg' (52 KB)
Preview of image 'old_pitted_iron.jpg'
Date: 1 Apr 2009 17:10:36
Message: <49d3d84c$1@news.povray.org>
  Then wouldn't the correct suggestion be "don't put an 'ambient' term
in the finish of the texture" rather than "use 'ambient 0'"?
  The former doesn't fix the ambient, so you can later change it to
whatever you want with #default. The latter fixes it and you can't
change it without modifying the texture code.
Date: 1 Apr 2009 17:11:24
Message: <49d3d87c@news.povray.org>
> elsewhere.
  Wouldn't it simply be easier if the texture didn't define any ambient
at all? Then you can use #default to set it to whatever you want.
Date: 1 Apr 2009 17:13:02
Message: <49d3d8de@news.povray.org>
> to be sure.
  Just to be sure of what?
  Why shouldn't the ambient term of a texture be definable with a
#default block, even if the texture is in a library?
  That didn't answer my question.
Date: 1 Apr 2009 17:43:32
Message: <49d3e004$1@news.povray.org>
because the designer of the texture might wish to specify
the intended ambient value for use with classical lighting.
Date: 1 Apr 2009 18:45:01
Message: <web.49d3edd34ee6dd4ef50167bc0@news.povray.org>
That's true.
Actually there's already a very easy way to turn off ALL ambient light settings
in a scene: global_settings{ambient_light 0}
It's really a multiplier (which is why it's set up as <1,1,1> by default); a
very useful little on/off ambient-light switch for running radiosity scenes.
KW
Date: 1 Apr 2009 18:55:01
Message: <web.49d3f0454ee6dd4ebda078810@news.povray.org>
> That's true.
> KW
I find that even worse - in a radiosity scene, you often want some objects to
give out light via an ambient term. Specifically with lightprobes, you need the
lightprobe image to be ambient X and diffuse 0. Radiosity based lightprobe
scenes often have no actual lights - all the lighting originates from the
lightprobe. Setting the global ambient multiplier to 0 turns off the lightprobe
in those cases, and your scene ends up black...
