POV-Ray : Newsgroups : povray.binaries.images : 6 volumes Server Time
12 Oct 2026 08:21:03 EDT (-0400)
  6 volumes (Message 1 to 13 of 13)
Subject: 6 volumes
Date: 15 Jan 2009 12:57:32
Message: <496f790c@news.povray.org>
More than the classical cone/sphere/cylinder used to count 1,2,3.
Counting from 1 to 6, here a set of increasing volumes.
Constraint are:
 * Volume must be inside a box of size 2R
 * Each side of the box must be touched, at least by a point, even on border
 * Volume of solid must be an exact multiple of piR³/3
In theory, a 7piR³/3 volume can fit the box (as 7*pi/3 < 8), but is
there such simple solid ? And what does it looks like ?
Solids are:
 1. Milk carton (berlingot) quartic
 2. Cone
 3. conocuneus (coin conique) quartic
 4. Sphere
 5. spherical top on cylinder
 6. Cylinder
Download 'volume.jpg' (289 KB)
Preview of image 'volume.jpg'
Subject: Re: 6 volumes
Date: 15 Jan 2009 16:50:01
Message: <web.496faeb71026618d3b1a12740@news.povray.org>
> Constraint are:
> Solids are:
>  2. Cone
>  4. Sphere
>  6. Cylinder
Here is a crazy superellipsoid shape which fits the bill of 7*pi/3. Although I
do have a mathematical formula which gives an exact multiple it is very nasty
so I am not sure if this counts under your brief for the shape. I have mainly
constructed this as a point of interest that such a shape can be found and
built easily with pov csg. I am still hoping I can find a simpler shape which
wouldn't have required quite so much work to build.
Malcolm
Download 'mad shape.jpg' (56 KB)
Preview of image 'mad shape.jpg'
Date: 15 Jan 2009 17:00:00
Message: <web.496fb1a31026618d81c811d20@news.povray.org>
> Constraint are:
> Solids are:
>  2. Cone
>  4. Sphere
>  6. Cylinder
Would a shape with a square top and circular bottom work (similar to 3 which is
a line top and round bottom).
I don't know what the exact volume is but it would seem that it would be the
average of a cylinder and a cube: (6+8)/2=7
-tgq
Date: 15 Jan 2009 19:25:00
Message: <web.496fd2f41026618ddea10790@news.povray.org>
The problem here is that the targeted volume is (pi/3)*7, not 1*7, and the
volume of the cylinder is (pi/3)*6, not 1*6, while the cube's volume is plain
boring 1*8.
So a gradual cross-section morph from square to circle in a way that the
cross-section area increases linearly (similar to #3) would indeed give a
volume equal to the average of a cylinder's and a cube's volume, but that
wouldn't fit the bill.
Of course, a rectangular box of size 2*2*(pi*7/12), skewed by 2-(pi*7/12) to
"fill" a 2*2*2 cube, would do the job, but something tells me that it would not
be quite in line with the spirit of the puzzle ;)
Date: 16 Jan 2009 12:24:12
Message: <4970c2bc$1@news.povray.org>
Le 15.01.2009 22:48, milco2006 nous fit lire :
Can you explain a bit how, I fail to understand it's construction.
Is there some ratio from green to blue/red ?
> Although I
I have nothing against a superellipsoid, as long as you provide its
parameters (and hopefully they are some kind of 'nice', even a cubic
root of a fraction might match), and by the same way demonstrate that
the volume is exactly and mathematicaly 7pi/3.
(and not an approximate value close enough)
Which seems a bit complex to perform, given that the sole formula of
volume that I found on mathworld for the superellipsoid is based on the
Gamma function, which is far from simplying to 7pi/3 at some stage.
(Just prove me wrong... I have no doubt that one superellipsoid, or even
a whole family of them, can have the right volume... but the real answer
 need to identify which ones!)
Date: 16 Jan 2009 12:29:32
Message: <4970c3fc$1@news.povray.org>
Le 16.01.2009 01:21, clipka nous fit lire :
Yes, correct mindset Clipka,
Moreover, how do you make a measurement of exactly pi*7/12... That's not
 too much elegant.
Note that in the spirit of the puzzle, a prism would do... if only you
can provide a base of 7pi/3R²... (cylinder is a prism, after all)
Date: 16 Jan 2009 12:32:49
Message: <4970c4c1$1@news.povray.org>
Le 16.01.2009 18:29, Le_Forgeron nous fit lire :
>  too much elegant.
Correcting myself, the base should be 7piR²/6.. as the height is 2R
That does not make it easier.
Date: 16 Jan 2009 14:05:00
Message: <web.4970da511026618d81c811d20@news.povray.org>
> Constraint are:
> Solids are:
>  2. Cone
>  4. Sphere
>  6. Cylinder
#3 could also be replaced with a paraboloid.
V=1/2pi a^2 h    - a=R, h=2R
V=1/2pi R^2 2R
V=piR³
V=3piR³/3
-tgq
Date: 16 Jan 2009 15:05:00
Message: <web.4970e74b1026618d94bbb57b0@news.povray.org>
If a certain minimum of beauty is *not* a prerequisite, then I have something:
Make a prism of this...
The "ears" are constructed with the same radius as the "body" of the shape; the
triangular cutout at the bottom left must have a height of R*(7*sqrt(3/4)-6)
(which *can* be done with compass & straightline).
The fact that the total area of this shape is 7*R^2*pi/6 should be evident... ;)
Download '7.png' (17 KB)
Preview of image '7.png'
Date: 17 Jan 2009 04:34:19
Message: <4971a61b$1@news.povray.org>
Le 16.01.2009 21:00, clipka nous fit lire :
Ok... you are better than me... a miminum of beauty should be a
requisite. Definitively.
Any 'nice' base for such prism ?
Or a thought on another shape ?
Date: 17 Jan 2009 08:35:00
Message: <web.4971ddef1026618d1c9be6790@news.povray.org>
Hm... I thought about coming up with something via polar co-ordinates - but
everything remotely simple seems to want a term including the inverse of pi,
the square root of it, or other such nasty stuff... nothing that seems to get
away without a pi term.
Date: 18 Jan 2009 17:55:01
Message: <web.4973b2be1026618d3b1a12740@news.povray.org>
Firstly let me apologise as the term superellipsoid is slightly incorrect as it
is really more of a rounded box in the strictest sense. The reason I left it
split into blue and red and green is that this splits the shape down into 8
parts of spheres (green), 12 parts of cylinders (red), 6 small boxes (blue) and
one big box (which is inside). This identifies the different parts of which the
shape is composed.
As I mentioned the different parts are varying shapes. To calculate the volume
one merely requires to add up the volumes of the whole or part shapes. To get
an exact formulation I used 'l' to be the length between the centres of the
corner spheres and 'r' to be their radius. We also know that l+2*r=2*R which
allows us to construct a cubic equation solely in l. This can be solved to find
required values and thus the shape can be constructed. The solution is not just
a little nasty, but rather very nasty but does exist and is expressible using
cube roots and fractions of polynomials in pi.
The nastiness of the solution somewhat detracts from the problem at hand
somewhat. So although I have presented a shape that has the correct volume it
is not a very satisfying solution.
The value can be calculated exactly due to the ability to split the shape into
standard geometrical sections. And as the solution to the cubic can be given in
a series of constants and mathematical operators it can technically be
calculated without approximation.
I am still keen to find a more natural shape that fulfils your conditions
however I hope this explanation is helpful.
Malcolm
Date: 19 Jan 2009 12:56:42
Message: <4974beda$1@news.povray.org>
Le 16.01.2009 20:04, Trevor G Quayle nous fit lire :
>> Solids are:
>>  2. Cone
>>  4. Sphere
>>  6. Cylinder
> V=1/2pi R^2 2R
> V=piR³
> V=3piR³/3
> -tgq
Yes. Well seen.
Nevertheless, I have a slight preference for ruled surface when
possible. (1,2,3 & 6 are ruled surfaces, 4 is obvious, and the one I'm
most dissatisfied with is 5). That's personal, so no problem if your
favorite suite uses a paraboloid, it's just that recognizing x2 vs x4
only by the eye is not obvious for me, whereas a ruled surface is less
ambiguous.
