POV-Ray : Newsgroups : povray.binaries.images : Moonlight Server Time
30 Jul 2026 17:17:01 EDT (-0400)
  Moonlight (Message 11 to 12 of 12)
Subject: Re: Moonlight
Date: 4 Jan 2009 18:55:00
Message: <web.49614c0697e5606385de7b680@news.povray.org>
Alain <ele### [at] netscapenet> wrote:
> Cousin Ricky nous illumina en ce 2009-01-02 18:36 -->
> > 2. It may not be "just" moonlight.  A full moon so close to the horizon isn't
> > far behind sunset (or ahead of sunrise), so there may still be a bit of
> > twilight.
> Not in a tropical setting. In those areas, the twilight last only minutes, at
> most. The moon should be almost touching the horizon to have some twilight.
backdrop plenty of times, with enough hills to make sure that the Moon is well
away from the horizon.
Also observe that in Mike's moonscape, the Moon appears to be only 2, maybe 3
degrees above the horizon.
Date: 5 Jan 2009 04:39:46
Message: <sru836-h39.ln1@badulaque.unex.es>
Among other things, Alain saw fit to write:
> at most. The moon should be almost touching the horizon to have some
> twilight.
But it lasts minutes because the sun moves in an almost vertical direction,
so it gets farther from the horizon sooner... or so I understand.
What I mean is, whether you have twilight or not, would be determined by the
position of the sun (and full moon) with respect to the horizon, not by the
time it took to reach that position. So once you have a position in a
picture, it doesn't matter if it's in the tropics or in the poles (except
for the possible effects of temperature, moisture, dust...).
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
