POV-Ray : Newsgroups : povray.binaries.images : More Blockwall Examples Server Time
12 Oct 2026 09:32:35 EDT (-0400)
  More Blockwall Examples (Message 1 to 15 of 15)
Subject: More Blockwall Examples
Date: 28 Dec 2008 11:28:48
Message: <4957a940@news.povray.org>
I'm currently working on a couple of bug fixes, some small enhancements and
a few more examples for my Blockwall macro.
Here's one of the new examples. I've tried to give it a bit of atmosphere by
doing a simple night scene.
Download 'blockwall_21.jpg' (89 KB)
Preview of image 'blockwall_21.jpg'
Subject: Re: More Blockwall Examples
Date: 28 Dec 2008 12:14:30
Message: <qucfl4dlinqgkmeq4gsl60bffbupr5h87v@4ax.com>
That looks great, Chris.
Regards
Date: 29 Dec 2008 03:11:38
Message: <4958863a@news.povray.org>
"Chris B" <nom### [at] nomailcom> schreef in bericht
news:4957a940@news.povray.org...
> and
> by
I am very happy with your macro and am going to use it right away! This
example looks good indeed. It shows the very different uses the macro can be
put to.
Date: 29 Dec 2008 05:27:05
Message: <4958a5f9@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:4958863a@news.povray.org...
>> and
>> by
> be put to.
> Thomas
Thanks Stephen and Thomas,
The blockwork pattern ideas behind these macros came to me when I was
thinking about your pavement conundrum Thomas.
Here's another example. Note that these perfectly circular walls are a
feature of V1.1 which I'm planning to put out in a few days time.
Download 'blockwall_22.jpg' (187 KB)
Preview of image 'blockwall_22.jpg'
Date: 29 Dec 2008 10:05:42
Message: <4958e746@news.povray.org>
news:4958a5f9@news.povray.org...
Ah yes. Reminds me that I have to use that one too. :-)
By the way, now that we talk about that macro, it would be nice to use the
curved pavement also as a trace on an underlying, non-flat surface. That way
you can provide for the necessary gutters for instance. That should not be
too difficul to implement?
Yes that is an important feature indeed.
Date: 29 Dec 2008 12:05:13
Message: <49590349@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
> and
> by
Here's another example I've generated using the macros.
Download 'blockwall_24.jpg' (143 KB)
Preview of image 'blockwall_24.jpg'
Date: 29 Dec 2008 18:00:04
Message: <49595674@news.povray.org>
Wow, that's a lot of blocks!
Render time?
Date: 29 Dec 2008 18:34:41
Message: <49595e91$1@news.povray.org>
"Nicolas Alvarez" <nic### [at] gmailcom> wrote in message
news:49595674@news.povray.org...
> Render time?
5 min 30 seconds on a 2 Quad 2.4GHz at 800x600 0.3 AA
(Mostly parsing time)
Date: 29 Dec 2008 19:14:15
Message: <495967d7@news.povray.org>
news:49590349@news.povray.org...
   Nice! I made a bridge similar to yours but with meshes. How long did this
take to render?
       ~Steve~
Date: 29 Dec 2008 19:17:45
Message: <495968a9@news.povray.org>
Oops, missed your reply to Nicolas.
  5 minutes, that's fast.
   ~Steve~
Date: 29 Dec 2008 22:05:00
Message: <web.49598fa071c490f180057960@news.povray.org>
Cool.
Date: 30 Dec 2008 07:26:20
Message: <495a136c@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:495968a9@news.povray.org...
How long did your mesh version take to render?
Of course mine doesn't use any complex lighting and I am on quite a quick
machine.
Most of the test renders are very quick because I can simply specify a
larger block size. Doubling the block size quarters the number of blocks and
still looks reasonable. I've now altered the model to enable the approach
roads to be curved. In this image I've also added a light under the middle
arch to help show off the blockwork.
Download 'blockwall_24.jpg' (137 KB)
Date: 1 Jan 2009 06:48:45
Message: <495cad9d@news.povray.org>
news:4958e746@news.povray.org...
I've posted V1.1 of the Blockwall macros with documentation and an
explanation of how to make bridges, wells, castle battlements etc here:
http://lib.povray.org/collection/blockwall/chrisb%201.1/blockwall.html
V1.1 includes the Blockwall_Arc macro to do completely circular or partially
circular walls. The first parameter is the number of degrees of arc that the
wall should transcribe. If you specify 360 degrees it interleaves the ends
so you can't see the seam.
Date: 1 Jan 2009 06:56:00
Message: <495caf50@news.povray.org>
news:495a136c@news.povray.org...
> larger block size.
Here's an example I put in the documentation using a distant camera at
640x480 with quite a large block size that took just 4 seconds to parse and
render.
Download 'blockwall_24a.jpg' (122 KB)
Preview of image 'blockwall_24a.jpg'
Date: 4 Jan 2009 13:04:41
Message: <4960fa39$1@news.povray.org>
These are brilliant.
