POV-Ray : Newsgroups : povray.binaries.images : Stone Wall Server Time
17 Oct 2026 14:31:26 EDT (-0400)
  Stone Wall (Message 1 to 14 of 14)
Subject: Stone Wall
Date: 22 Dec 2008 06:19:21
Message: <494f77b9@news.povray.org>
I'm just putting the finishing touches to a macro to generate block walls
and stone walls.
Here's a little taste of what it does:
Download 'blockwall_09.jpg' (55 KB) Download 'blockwall_08.jpg' (20 KB)
Preview of image 'blockwall_09.jpg'
Preview of image 'blockwall_08.jpg'
Subject: Re: Stone Wall
Date: 22 Dec 2008 09:52:54
Message: <494fa9c6@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:494f77b9@news.povray.org...
> and stone walls.
Ooooooo...   Very nice!
I had a brick wall macro, but I was never entirely happy with the results.
Mostly, what I didn't like was the fact that POV-Ray doesn't allow you to
overlay textures.  e.g. giving each brick a texture, then overlaying a
semi-transparent texture on the entire wall.  Perhaps there are ways around
that limitation, but I couldn't think of anything that worked well.
I especially like the "slate" wall.  This is very impressive.
Date: 22 Dec 2008 11:30:50
Message: <494fc0ba$1@news.povray.org>
"Jeremy "UncleHoot" Praay" <jer### [at] questsoftwarecmo> wrote in message
news:494fa9c6@news.povray.org...
Thanks.
You can overlay textures so long as the upper layers do have some
transparency. I have seen a technique that produced reasonable results using
the brick pattern (though I've never used it). There's a tutorial at
http://www.shipbrook.com/jeff/raytrace/bricks.html covering something
similar. I don't know if that technique is worth exploring.
Date: 22 Dec 2008 11:45:01
Message: <web.494fc3c55ad54a0cfd38c63e0@news.povray.org>
> and stone walls.
Very pretty. Spline-based?
A.D.B.
Date: 22 Dec 2008 12:26:14
Message: <494fcdb6@news.povray.org>
"Anthony D. Baye" <Sha### [at] spamnomorehotmailcom> wrote in message
news:web.494fc3c55ad54a0cfd38c63e0@news.povray.org...
>> and stone walls.
> A.D.B.
The top one is.
The bottom one uses an array of corner points.
It's actually a set of macros that use interchangeable block styles.
I tried to think of all the different ways to define a wall and did a macro
for each.
Here's one where you specify the extents of a box and it puts a perimeter
wall inside it. The holes are just CSG.
Download 'blockwall_06.jpg' (23 KB)
Preview of image 'blockwall_06.jpg'
Date: 22 Dec 2008 22:45:00
Message: <web.49505df25ad54a0cfd38c63e0@news.povray.org>
> >> and stone walls.
> > A.D.B.
> The top one is.
> for each.
WANT!
A.D.B.
Date: 23 Dec 2008 04:06:54
Message: <4950aa2e$1@news.povray.org>
"Chris B" <nom### [at] nomailcom> schreef in bericht
> and stone walls.
Oh! Ah! This is very nice!
I was cleaning up my collection of macros and came across a similar one by
Dave Blandston, some years ago. That was not as good as yours definitely.
Makes me think of your stonecol macro though.
Date: 24 Dec 2008 09:33:22
Message: <49524832@news.povray.org>
> and stone walls.
Here's an attempt to show the block-based walling in a better light:
Download 'blockwall_08.jpg' (82 KB)
Date: 24 Dec 2008 09:38:43
Message: <49524973@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:4950aa2e$1@news.povray.org...
>> and stone walls.
> Thomas
Ah yes! Stonecol is very old and used height fields, whereas this new macro
actually defines the individual blocks. It does though perhaps betray the
obsession that I've had with getting credible looking masonry over the years
Date: 24 Dec 2008 11:44:58
Message: <4952670a@news.povray.org>
> and stone walls.
It's done.
It's available on the Object Collection at http://lib.povray.org called
StoneWall.
Happy XMass
Date: 25 Dec 2008 06:42:55
Message: <495371bf$1@news.povray.org>
>> walls and stone walls.
> It's done.
> called StoneWall.
> Happy XMass
It is "BlockWall", isn't it?
Thanks for the good work!
Greetings,
Marc-Hendrik
Date: 25 Dec 2008 15:58:23
Message: <4953f3ef$1@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:495371bf$1@news.povray.org...
>> It's done.
>> called StoneWall.
>> Happy XMass
> Greetings,
> Marc-Hendrik
Ah Yes! Sorry. You're totally right.
Date: 26 Dec 2008 18:20:34
Message: <495566c2@news.povray.org>
All your images (especially the top one in the first message) have way too
many JPEG artifacts :(
Date: 26 Dec 2008 19:05:46
Message: <4955715a@news.povray.org>
"Nicolas Alvarez" <nic### [at] gmailcom> wrote in message
news:495566c2@news.povray.org...
I did use a very high jpg compression because these are the images that went
into the online documentation at
http://lib.povray.org/collection/blockwall/chrisb%201.0/blockwall.html,
where there are quite a lot of different examples, so I was conscious of the
total dsplay time. Anyway, here's an 800x600 AA0.3 with a 90% jpg quality
setting.
Also, when you download the object you can readily regenerate all of the
images artifact free at whatever resolution you want using animation options
+kfi0 +kff20 and by setting Example=frame_number at the top of the scene
file. It takes about 15 minutes to generate the 19 images at 800x600 AA0.3
using 3.7 on a 4 way machine (images 11 and 16 are blank).
Download 'blockwalla.jpg' (208 KB)
Preview of image 'blockwalla.jpg'
