POV-Ray : Newsgroups : povray.binaries.images : Eva sails away Server Time
29 Nov 2026 05:27:04 EST (-0500)
  Eva sails away (Message 1 to 21 of 21)
Subject: Eva sails away
Date: 25 Oct 2008 17:17:48
Message: <49038cfc@news.povray.org>
I have been working on this image since summer, and now, after 73 hours
of rendering, it's finally ready enough to be posted here.
I guess I have to render still another version, as there are some
problems with this one: for example, I have no idea what causes the
white lines on the sails. It is due to fog-media, but I don't now why.
POV3.7b29 makes them white, with 3.6 they are more brown but still visible.
Another problem is the water: I had cool waves but focal blur did
something bad to them.. I'll have to fix that too.
But, before I render this in full size, I would like to hear any
comments and critics you guys have. With lots media, trees, grass,
radiosity and focal blur, this one takes lots of time to render
(95:54:47 Rendering line 91 of 720, 67276 rad. samples on zbxt.net) so I
would like to make it as good as I can before I wait some months for it
to render :P
Download 'stage_00585.png' (328 KB)
Preview of image 'stage_00585.png'
Subject: Re: Eva sails away
Date: 25 Oct 2008 18:20:28
Message: <4t67g4du04qp585htt538bckh3dj33hske@4ax.com>
On Sun, 26 Oct 2008 00:18:31 +0300, Arttu Voutilainen
Your image is very attractive. The focal blur gives it a pointillist look. I
look forward to seeing the final and fixed version.
Regards
Date: 25 Oct 2008 19:12:26
Message: <4903a7da$1@news.povray.org>
Nice composition, nice trees, nice sky. :-)
The sails on the ship are bugging me--they're much too flat. If there's
any wind at all, they're going to be slightly curved (and if there's
not, they're going to be dangling and wrinkled).
The focal blur is quite grainy--you'll need to take your blur_samples
much higher in the final version, but you probably know this already.
William Tracy
The life of a Japanese cosplayer at Comike possesses strange
similarities to that of the free range chicken.
     -- Shirt Guy Dom
Date: 25 Oct 2008 22:30:01
Message: <web.4903d53e81c7ccbbd1b3ad10@news.povray.org>
> I have no idea what causes the white lines on the sails. It is due to
What are the sails made from? I've seen similar artifacts in my own work when
using sphere_sweeps and other parametrics (which I've found is often due to
rounding/precision errors). Scaling the entire scene several times larger often
fixes that sort of thing for me.
Okay, the critique: the near shoreline looks a bit too geometric (faceted) to me
agaisnt the water, and I think the grass is too uniformly green.
Overall a nice scene though, very tranquil.
-Rob
Date: 26 Oct 2008 00:00:02
Message: <web.4903eaad81c7ccb3b3918360@news.povray.org>
Gee, man!  The render time was already 72 hours for quite low resolution, let
alone with higher blur_samples.  Without proper hardware, 3D rendering can be
quite a pain...
Date: 26 Oct 2008 01:30:00
Message: <web.4903ffbb81c7ccb78dcad930@news.povray.org>
The colors and lighting remind me of Maxfield Parrish; nicely done.
I wish I could offer a suggestion about the 'lines,' but without seeing your
scene code, it would be a shot in the dark.  Do you have any overlapping
media-filled objects in the scene? Or is it just a single fog or atmospheric
media?
Ken W.
Date: 26 Oct 2008 03:46:32
Message: <49042058$1@news.povray.org>
Very nice composition indeed. In addition to some of the comments already
offered, I have doubts about the sun and the glare on the horizon. They seem
not to be in phase. I would suggest to take out the visible sun sphere.
(I don't suppose it represents the Moon??  :-)  )
Date: 26 Oct 2008 14:15:35
Message: <4904b3c7$1@news.povray.org>
Arttu Voutilainen nous illumina en ce 2008-10-25 17:18 -->
> to render :P
Try a test rander without focal blur nor radiosity.
In that render, use a partly transparent texture for your media container. You
may discover that those lines are where the media container intersect the sails.
If that's the case, try altering the container's shape or position so that it
never intersect the sails. If you use a plane, just place it higher so that it's
placed over the masts.
For your focal blur, try a smaller aperture.
You may also do away with it and use a blured transparency just for the lower
part. In that kind of scene, focal blur should be minimal, if present at all,
and only visibly affect the extreme foreground.
Either write something worth reading or do something worth writing.
Benjamin Franklin
Date: 26 Oct 2008 15:46:37
Message: <4904c91d$1@news.povray.org>
Aren't I a bastard? ;-)
I look at the shoreline in the extreme foreground, and I see random blue
and green pixels sprinkled around, which bugs me. With higher samples,
you'll get more of a smooth gradient.
Another option would be to tweak the aperture, reducing the amount of
blur, and reducing the number of samples needed to eliminate the grain.
Then again, some people are fine with the grain. You decide whether the
render time is worthwhile. :-)
BTW, now that you mention it, what hardware is this running on?
William Tracy
(10:16:43 PM) Ryuho: but they are physically turned off
(10:16:58 PM) Ryuho: so you can't connect to them right now
(10:16:58 PM) DanaG: I wonder if you could ssh-tunnel wake-on-lan packets.
     -- seen on #cplug
Date: 26 Oct 2008 19:30:00
Message: <web.4904fc5b81c7ccba5d4a01d0@news.povray.org>
Hi Arttu,
Very nice image.  I love sunset scenes, and I like the mood and subject of your
image.  You've done really well with media.
That said, I offer a few things that I would do:
With such atrocious render times, I would actually drop the media--there's
nothing in this image that could not be achieved with a good skysphere and fog.
 In fact, a good skysphere could probably even offer a more realistic and
dramatic result.
I would also drop the focal blur.  I agree with the others--focal blur in this
image would be minimal, and it would be easier to simply add a little blur to
the foreground later in GIMP or Photoshop.  I think you'll find that focal blur
is the cause of the majority of your render time.
I think your greens are too green and too homogeneous.  My recommendation would
be to drop it down to something like rgb <.1,.2,.0>, but use a cells pigment
with turbulence 1, lambda 10 to get some nice, realistic variation.  I would
apply this to both the tree leaves and the grass.  I know you mentioned grass
being in the render, but I can's see it (perhaps because the focal blur is
obscuring it).  If it is there, I would make it much taller and more irregular.
 For the foreground, I think you need to add some quite tall grass and
vegetation.  Gilles Tran has several varieties of grass-like plants that you
could add.
I don't know what method you used to create the terrain, but I think adding some
more irregularity and character would add a lot.  When I create terrain, I
usually use an isosurface or a pattern-generated heightfield using a function
based on something like this:
function {
  pattern {
    wrinkles
    poly_wave 3
Or, you could start with the terrain you have, but use trace to drop in
isosurface rocks and boulders along the banks of the river to get a bank that
doesn't simply slope straight into the water.
Those are my suggestions; I hope you find them helpful--I look forward to seeing
what you come up with.
Kirk
Date: 26 Oct 2008 21:20:00
Message: <web.4905166181c7ccb85de7b680@news.povray.org>
It looks like a painting combining the styles of Georges Seurat and the old
masters.
A couple of criticisms: the Sun should be the brightest object in the scene, and
the clouds near the Sun's line of sight should have brighter fringes.
Date: 27 Oct 2008 13:15:59
Message: <4905f74f@news.povray.org>
Thanks!
-- Arttu Voutilainen
Date: 27 Oct 2008 13:22:34
Message: <4905f8da$1@news.povray.org>
They are meshes (done in blender), but the problem was medias container
intersecting with the sails. It's fixed now.
Yep, I'll try to do something about those.
Thanks!
> -Rob
Date: 27 Oct 2008 13:33:23
Message: <4905fb63@news.povray.org>
Thanks!
> media?
There are actually three medias (one for atmosphere, one for clouds and
one for fog). It wasn't those though, just the fog-container
> Ken W.
Date: 27 Oct 2008 13:43:13
Message: <4905fdb1$1@news.povray.org>
Thanks! Yep, it's meant to be the sun, not moon. I guess I'll take it
off as now that you said it, I think it does look more like moon than sun :P
> Thomas
Date: 27 Oct 2008 13:47:13
Message: <4905fea1$1@news.povray.org>
> container. You may discover that those lines are where the media
> that it never intersect the sails. If you use a plane, just place it
> higher so that it's placed over the masts.
That's it! Thanks!
> lower part. In that kind of scene, focal blur should be minimal, if
> present at all, and only visibly affect the extreme foreground.
Yep, it actually turned out to be more blurred than I had expected. How
would I use blurred transparency?
Date: 27 Oct 2008 13:58:37
Message: <4906014d$1@news.povray.org>
William Tracy wrote:
>> resolution, let
Yep, I guess I'll do both: lower the aperture and increase samples. Or
if Alain can explain that blurred transparency to me well enough that I
can code it, I might try it first :P
The 72 hours was on my own computer, AMD 64 3500+. The bigger version
(now 140:57:56 Rendering line 130 of 720, 89598 rad. samples) is running
on Eero Ahonen's bit more faster AMD 4450e.
Date: 27 Oct 2008 15:41:40
Message: <49061974@news.povray.org>
Kirk Andrews wrote:
> Hi Arttu,
Thanks!
> dramatic result.
I guess it would indeed work. It's just that this whole scene evolved
from my atmosphere-experiments (which were mostly inspired by your
atmospheres and clouds, actually ;)) and it's nice to know that I can
chance the whole lightning by just moving my sun around. It's another
question if that's worth the rendering times, but :P
Yep, at least I have rendered this in full size once before w/o blur,
and it took only 'bout 14 days ;P But yeah, I'll see what I'll do about
the blur.
> could add.
There really is real grass (Gilles' MakeGrass) in foreground, but the
focal blur ate it away :(. I'm experimenting with that cells pattern
right now, and it looks promising. Plants sounds like a good idea; I'll
try those too.
> function {
>   pattern {
>     wrinkles
>     poly_wave 3
It's a heighfield which is generated from an image that is made with The
Gimp. I'll try to do something with it. Also the idea about rocks sounds
good.
And thanks for the function, I have always wondered how you make your
landscapes. I don't think I'll use it in this image though, but I'll
remember it next time when I'm doing landscapes :)
Thanks a lot, I really appreciate them. I'll see what I can do.
> Kirk
Date: 27 Oct 2008 16:17:43
Message: <490621e7$1@news.povray.org>
> masters.
Thanks.
Yep, you are right. That will be fixed.
Date: 28 Oct 2008 19:16:28
Message: <49079d4c$1@news.povray.org>
Arttu Voutilainen nous illumina en ce 2008-10-27 13:58 -->
>>> resolution, let
Have you ever done any blured reflection?
Now, do the same, but with a transparent object placed close to the camera.
The thing is, you need to keep the number of averaged normals low, as each ray
will hit the surfaces twice. Averaging 16 normale résult in each ray been
multiplied by 16x16, or 256.
I bet exercise equipment would be a lot more expensive if we had evolved from
starfish.
Date: 9 Nov 2008 15:09:51
Message: <4917438f@news.povray.org>
>>>> resolution, let
> each ray will hit the surfaces twice. Averaging 16 normale résult in
> each ray been multiplied by 16x16, or 256.
Nope, I have never really done it, but I think I tried once. I do know
how it's supposed to be done, and I'll try it when I have time to get
back to this image. School has kept me a bit busy lately..
Thanks for the tip.
