POV-Ray : Newsgroups : povray.binaries.images : RTR isosurface clouds screen shot and code (28k jpg) Server Time
29 Nov 2026 05:27:04 EST (-0500)
  RTR isosurface clouds screen shot and code (28k jpg) (Message 1 to 9 of 9)
Subject: RTR isosurface clouds screen shot and code (28k jpg)
Date: 14 Oct 2008 19:40:24
Message: <48f52de8@news.povray.org>
Nothing massively important here, just a real-time raytracing test
involving volumetric isosurface clouds. There are no light_sources; I
faked lighting by using a texture with an ambient finish. As you can see
in the image, it's possible to get reasonably fast frame rates (when
using more than one core).
For real-time raytracing, POV does not support animating anything but
the camera, which makes things like this impossible unless you "cheat"
by having one object per frame, like frames on a film strip.
I noticed that beta 25 runs faster than 27. I don't know why this is. I
hope the POV Team keeps real-time raytracing as an option!
For those who are interested and have a quick computer, here is the code:
//recommended resolution:
//160x120
//add this to the command line:
//+a0.1 +am2 +r1 +j0.0 +bm2 +kla +rtr
#include"transforms.inc"
#default{finish{ambient 0}}
// distance from one object to the next
#declare step=30;
// number of frames
#declare frames=10000;
#declare V=0;
#while(V<frames)
   right x*4/3
   up y
   location<V*step,-10,-10>
   look_at <V*step, 0, 0>
   angle 40
  #declare V=V+1;
#declare lpos = <1,.5,0>;
#declare lcol = <1,.875,.5>*2;
#declare air = <.1 .2 .5>;
sky_sphere{
  pigment{
   spherical scale 2 translate y
   Point_At_Trans(lpos)
   poly_wave 2
   pigment_map{
    [0 rgb air-.1]
    [1 rgb lcol*2]
fog{rgb air fog_type 2 distance 5 fog_alt 1 fog_offset -2}
#declare pf=
function{
  pattern{
   granite scale 13
   translate -20
#declare hSpeed=.05;
#declare vSpeed=.025;
#declare V=0;
#while(V<frames)
  isosurface{
   function{
    -pf(x-V*hSpeed,y-V*vSpeed,z)+.5
   accuracy .02 max_gradient 1
   contained_by{box{<-12,-1,-12>,<12,1,12>}}
   pigment{
    function{pf(x-V*hSpeed,y-V*vSpeed,z)} translate lpos*.5
    color_map{[.25 rgb(air+.5)/4][1 rgb lcol]}
   finish{ambient 7.5 diffuse 0}
   translate x*V*step
  #declare V=V+1;
Beware of using this technique! You can run out of memory very easily,
especially when using infinite objects such as planes.
Sam
Download 'rtric.jpeg.jpg' (25 KB)
Preview of image 'rtric.jpeg.jpg'
Subject: Re: RTR isosurface clouds screen shot and code (28k jpg)
Date: 15 Oct 2008 11:05:00
Message: <web.48f6058214b3d85e83862e210@news.povray.org>
stbenge <THI### [at] hotmailcom> wrote:
> Hi,
> Nothing massively important here [...]
Indeed, from your posts we always expect something surprising!
Date: 15 Oct 2008 12:22:03
Message: <48f618ab$1@news.povray.org>
>> Hi,
Sorry to disappoint you with this one ;)
Date: 16 Oct 2008 01:20:00
Message: <web.48f6cec214b3d85e892adb1d0@news.povray.org>
> #declare V=0;
> #while(V<frames)
>   camera {
>    right x*4/3
>    up y
>    angle 40
>   #declare V=V+1;
> #end
Parse Warning: More than one camera in scene. Ignoring previous camera(s).
Rendering using command line '+a0.1 +am2 +r1 +j0.0 +bm2 +kla +rtr'.
Integer parameter expected for switch 'B', found 'm2'.
Cannot process command-line at ' +kla +rtr' due to a parse error.
I can't seem to render using your code and command line.
I have povray 3.6 and magapov 1.2.1 neither seem to work
Leef_me
Date: 16 Oct 2008 04:42:26
Message: <48f6fe72$1@news.povray.org>
Hallo, Sam!
Your code is interesting for static images too, decreasing a bit the
number of the frames we have strange and interesting lighted clouds.
Paolo
 >stbenge  on date 15/10/2008 01:40 wrote:
> Hi,
> //160x120
> #declare step=30;
> // number of frames
> #declare V=0;
> #while(V<frames)
>  camera {
>   right x*4/3
>   up y
>   angle 40
>  #declare V=V+1;
> #end
> sky_sphere{
>  pigment{
>   poly_wave 2
>   pigment_map{
>    [0 rgb air-.1]
>    [1 rgb lcol*2]
> #declare pf=
> function{
>  pattern{
>   granite scale 13
>   translate -20
> #declare V=0;
> #while(V<frames)
>  isosurface{
>   function{
>   pigment{
>   translate x*V*step
>  #declare V=V+1;
> #end
> Sam
Date: 16 Oct 2008 09:51:57
Message: <48f746fd$1@news.povray.org>
> I have povray 3.6
  That's the problem. The RTR feature is part of POV-Ray 3.7.
Date: 16 Oct 2008 17:59:30
Message: <48f7b942$1@news.povray.org>
Paolo Gibellini wrote:
> Hallo, Sam!
> Paolo
Hi Paolo,
Here, swap the pigment out for this one:
pigment{
  translate -lpos*.5
  color_map{
   [0 rgb lcol]
   [.75 rgb(air+.5)/4]
It's just the opposite of the other one, but it looks much better.
Sam
Date: 17 Oct 2008 04:24:11
Message: <48f84bab$1@news.povray.org>
Nice indeed...
A sort of sub-atomic clouds!
Paolo
>> Hallo, Sam!
>> Paolo
> Hi Paolo,
> pigment{
>  translate -lpos*.5
>  color_map{
>   [0 rgb lcol]
>   [.75 rgb(air+.5)/4]
> Sam
Date: 18 Oct 2008 11:48:32
Message: <48fa0550$1@news.povray.org>
Leef_me nous illumina en ce 2008-10-16 01:18 -->
>> #declare V=0;
>> #while(V<frames)
>>   camera {
>>    right x*4/3
>>    up y
>>    angle 40
>>   #declare V=V+1;
>> #end
> Leef_me
+bm2 for bounding method 2 or binary tree bounding. Not available in version
3.6. A new 3.7 feature.
+rtr and +kla, for "real time render" is also a new 3.7 feature.
To define recursion, we must first define recursion.
