POV-Ray : Newsgroups : povray.binaries.images : Interlocking heightfields Server Time
29 Nov 2026 06:33:27 EST (-0500)
  Interlocking heightfields (Message 1 to 12 of 12)
Subject: Interlocking heightfields
Date: 19 May 2008 04:17:38
Message: <483137a2@news.povray.org>
In povray.general, Stephen asked for a method to make a seamless patchwork
of height_fields (topic: Interlocking heightfields; May 11th). John
VanSickle was so kind to provide a couple of interesting macros. While
learning to use them, I made this simple test image consisting of 16
heightfields. I thought I could post it here, as info.
For more details, see:
http://news.povray.org/povray.general/thread/%3Cnkge24ll63d2pdoe3qr8kvg29bgf79sf63%404ax.com%3E/?mtop=273531
and scroll down to John's message.
Download 'JVS_HFpatchwork.jpg' (49 KB)
Preview of image 'JVS_HFpatchwork.jpg'
Subject: Re: Interlocking heightfields
Date: 19 May 2008 07:20:29
Message: <djo234l8ud8mvphls790infpm3skca7fp7@4ax.com>
On Mon, 19 May 2008 10:17:37 +0200, "Thomas de Groot"
That looks really good, well done.
Too bad my new scene is all at sea. So I'm using your
TdG_RipplingWater material instead <g>
Regards
Date: 19 May 2008 07:38:27
Message: <483166b3$1@news.povray.org>
When I used these macros, I gave the height fields a high enough
resolution so that there was no need for any tricks with the normals.
There was no smoothing, and the texture applied to the height fields had
no normal component.  To make the height fields rougher, I put more
roughness in the pigment used to generate the height fields, so that the
height fields really were rougher, instead of merely appearing to be.
John
Date: 19 May 2008 08:29:30
Message: <483172aa@news.povray.org>
"John VanSickle" <evi### [at] hotmailcom> schreef in bericht
news:483166b3$1@news.povray.org...
Yes, there are all kind of possibilities indeed to make the height_fields
look interesting. Thanks John, for your further suggestions, which I shall
certainly try out too.
Date: 19 May 2008 10:20:46
Message: <48318cbe$1@news.povray.org>
...in particular, I overlooked that little parameter Test... :-)
Date: 20 May 2008 03:27:54
Message: <48327d7a@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> schreef in bericht
news:48318cbe$1@news.povray.org...
> Thomas
...which altogether, leads finally to this.
Download 'JVS_HFpatchwork.jpg' (89 KB)
Date: 21 May 2008 09:18:30
Message: <48342126$1@news.povray.org>
Awesome!
Paolo
>> Thomas
> Thomas
Date: 22 May 2008 03:47:01
Message: <483524f5$1@news.povray.org>
"Paolo Gibellini" <p.g### [at] gmailcom> schreef in bericht
news:48342126$1@news.povray.org...
> Awesome!
> Paolo
This is just basic stuff as far as I am concerned. All the credit for the
real work should go to John!!  :-)
Date: 22 May 2008 08:17:19
Message: <4835644f$1@news.povray.org>
>> Awesome!
>> Paolo
The macro may need tweaking.  The rippling in the left-hand side of the
image appears to be an artifact.
John
Date: 22 May 2008 10:25:02
Message: <4835823e$1@news.povray.org>
news:4835644f$1@news.povray.org...
I have been wondering about that. It appears indeed in the close up height
field blocks.
Date: 26 May 2008 07:24:25
Message: <483a9de9@news.povray.org>
> field blocks.
The macro (IIRC) calculates the number of pixels spanned in any
direction by the heightfield, and sets the height field's resolution to
that value.  It may be that when the line of view is parallel or
near-parallel to the diagonal of the height field, that this is not
quite enough.  Increasing the resolution of the HF (probably by no more
than 40%) should fix this.
The ripple may also be the result of aliasing, in which case the same
remedy--increasing the HF resolution--is called for, but there would
also need to be aa + jittering in the render for the rippling to be
eliminated, if this is the cause.
John
Date: 26 May 2008 11:26:46
Message: <483ad6b6$1@news.povray.org>
news:483a9de9@news.povray.org...
> The macro (IIRC) calculates the number of pixels spanned in any direction
> by the heightfield, and sets the height field's resolution to that value.
> It may be that when the line of view is parallel or near-parallel to the
> diagonal of the height field, that this is not quite enough.  Increasing
> the resolution of the HF (probably by no more than 40%) should fix this.
That is correct. I have introduced a multiplicator to the Details parameter
in the macro, which does a nice job, especially for larger images.
> remedy--increasing the HF resolution--is called for, but there would also
> need to be aa + jittering in the render for the rippling to be eliminated,
Tentatively, I introduced the smooth option in the macro, just to see what
it does. The rippling is further generated I think by the pigment I used,
where a downscaled wrinkle is present. The effect is somewhat lessened if  I
scale it a bit up. However in larger renders, one clearly sees the mesh of
rectangles so increasing the resolution works best.
All in all, using the macro is just to find the settings which will work
best together, which is fun to do.
