POV-Ray : Newsgroups : povray.binaries.images : office supplies - ink bottle Server Time
29 Nov 2026 07:19:07 EST (-0500)
  office supplies - ink bottle (Message 1 to 25 of 25)
Subject: office supplies - ink bottle
Date: 9 Feb 2008 05:25:57
Message: <47ad7fb5@news.povray.org>
This is a sdl generated mesh object.  The idea was to transition from a
flat-sided body to a round cross-sectioned neck. ( Variations on that
transition are the design of many ink bottles.)
The macro must be fed x-y coordinates to describe the vertical profile
of the bottle in the form of an array. This array is submitted to Cris
Colefax's spline macro to produce a spline for the profile. The
horizontal cross-sections are produced from a macro based on a few
parameters like number of sides, size of bevel and tension. This macro
also outputs an array of points.  The diameter of each cross-section is
derived from the profile spline.  The cross-section array is used to
produce and store a cross-section spline.  A final macro walks these
cross-section splines and generates the mesh triangles.
At present the macro will not stand alone, the code must be tweeked for
each bottle to accomplish the transition from a sided scrossection to a
rounded cross-section.
Download 'inkbottle.0009.jpg' (66 KB)
Preview of image 'inkbottle.0009.jpg'
Subject: Re: office supplies - ink bottle
Date: 9 Feb 2008 20:18:37
Message: <47ae50ed$1@news.povray.org>
How about ink inside? :)
Is it at all possible (even if extremely hard) to make it so users set
the *volume* of ink, and it automatically figures out its "height", even
when the bottle is rotated? I would surely have no idea how to even
start coding the needed calculations...
Date: 10 Feb 2008 01:04:17
Message: <47ae93e1@news.povray.org>
Neither would I.
Ink bottles also can have labels which is another issue I am struggling
with.  Though it should be possible to generate some uv coordinates for
simple cases.
But there are graver issues with the usability of the macro which makes
me question its overall usefulness. Afterall this bottle could be
modelled and exported from a mesh modeller in 15 minutes, tops. For
instance, the positioning and rate of the transition from a 'sided'
cross section to round cross section of the neck is presently
interdependent with things like the density of the mesh.
Here is another bottle, and some ink in the earlier one
Download 'inkbottle.0016.jpg' (36 KB)
Preview of image 'inkbottle.0016.jpg'
Date: 10 Feb 2008 02:33:15
Message: <47aea8bb$1@news.povray.org>
Yo,
Just a quick guess, but as far as maintaining same level as if gravity, even
with rotation:
Have a solid section of "ink" and a solid bottle equal in size to the
interior of the bottle, and just use csg intersection textured to be "ink"..
For volume adjustment, obviously one would simply raise or lower the solid
"ink", which would then have intersection performed on it.
While possessing no fluid dynamics, I think the effect would be sufficient.
Dunno about meshes, but with "solid" pov primitives, it should work...
Now using media or blobs or something to accurately simulate fluid dynamics,
like if you shook the thing up....well someone else can figure that one
out...lol!!
Ian
news:47ae93e1@news.povray.org...
> Neither would I.
> simple cases.
Date: 10 Feb 2008 04:16:45
Message: <47aec0fd$1@news.povray.org>
> simple cases.
Hi Jim,
I've been working on a label generator over the last few days. The objects I
sent in for the 'office supplies' subject both needed labels, so I took the
code I wrote for them to make a generic labelling system. As of this morning
it generates either flat or cylindrical labels using layers of pigment to
incorporate combinations of POV-Ray objects and image maps.
By coincidence, yesterday I was thinking about how to do labels for rounded
boxes/superellipsoids though I haven't coded that up yet. I was thinking of
using the width, the depth and the roundness of the corners to control the
shape of a label. The label width would control how far around the sides of
the container the label stretched. Any ideas for anything that might make it
more useful to you?
Chris B.
Date: 10 Feb 2008 07:47:41
Message: <47aef26d@news.povray.org>
[GDS|Entropy] wrote:
> Yo,
Yo
Yes, in fact the bottles *are* meshes and that is roughly how I did it
in the picture. I used a plane for the intersection but a box would
probably have been more efficient. Mesh will do CSG if an inside_vector
is defined.  But the larger question was about the possibility of
keeping the level of the ink physically accurate for a constant volume.
  The ink bottle portrayed is a bottle for 'tusche' which is a heavy
gloppy sort of ink, like India ink, and it does tend to dry and cake
onto the inside of the bottle.  Because I am controlling the generation
of the mesh in a loop anyway it should be possible to apply a procedural
texture to just the interior part of the bottle and get something close.
Date: 10 Feb 2008 08:06:11
Message: <47aef6c3$1@news.povray.org>
Chris B wrote:
> Hi Jim,
> more useful to you?
It might very well be!  Assuming you are using bi-cubic patches, that
was one approach I was also considering.  The 'cross sections' of the
bottles are  modelled with splines using the colefax spline files.  It
certainly would be easy to generate 16 points along the bottle's surface
from those spline definitions.  But the labels on the ink bottles are
often continuous around the outside which might be trickier to do if
such total accuracy were needed, that is why I was also considering
generating uv vectors along with the mesh triangles, at least for a
certain portion of the bottle.  But either way my attitude was that I
would provide the means such that the artist could change the label, in
the simplest case, by just providing an image_map. Your system still
might integrate well in that case too.
Date: 10 Feb 2008 15:01:38
Message: <47af5822$1@news.povray.org>
The normals seem a touch overdone, but otherwise this is practically
perfect. :-)
William Tracy
Running "beautifully fast" on modern hardware is somewhere between "I've
never been to jail" and "I shower daily" on the list of human
accomplishment.
     -- phi### [at] philwelchnet, posting on Slashdot
Date: 11 Feb 2008 05:54:23
Message: <47b0295f$1@news.povray.org>
news:47aef6c3$1@news.povray.org...
>>  ... snip ...
>> rounded boxes/superellipsoids though I haven't coded that up yet. I was
>> thinking of using the width, the depth and the roundness of the corners
>> to control the shape of a label. The label width would control how far
>> around the sides of the container the label stretched. Any ideas for
>> anything that might make it more useful to you?
> It might very well be!  Assuming you are using bi-cubic patches, that was
At the moment I've used CSG, but the SDL is split into two parts and
modularised to make it easy to extend:
1. There's a label design file, in which you can render the label design
laid out flat. The design is built up of as many layers as you need. Each
layer can contain image maps, POV-Ray pigments, object pigments, text blocks
etc.
2. There's a series of macros, each of which creates a label object of a
particular shape, based on standardised variables to control the size, then
wraps the texture around onto its surface. The Width variable defines how
far around the object the label extends and therefore defines whether it's
continuous or whether there's a gap round the back.
For a new shape or new texture mapping technique (e.g. bi-cubic patches or
uv mapping), a new macro can be added. By using standardised variables to
describe the main attributes it makes it easy for a label designed for one
object shape to be wrapped around a different shape.
I did a rounded box label shape macro yesterday. Once I've wrapped a texture
onto it I'll post an image. Do you have a label design for the square
ink-bottle that I could maybe use as an example - a scan, a sketch or a
description that I could interpret?
Chris B.
Date: 11 Feb 2008 19:12:48
Message: <47b0e480@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:47b0295f$1@news.povray.org...
> texture
Here's what I've got so far. Virtually everything is configurable, including
all of the text and the shapes and colours used. The radius of the corners
and the lengths of the sides can all be set and the label will adjust itself
to fit. The width of the label can be the same as the circumference of the
bottle or less, in which case it'll wrap round the bottle for as far as
necessary.
The first image shows the label as it renders in design mode.
The second shows a label doing a complete circuit of a rounded box and
meeting at the back.
The third shows one that wraps round as far as the back corners.
Chris B.
Download 'InkBottleLabel2.jpg' (15 KB) Download 'InkBottleLabel.jpg' (14 KB) Download 'InkBottleLabelDesign.jpg' (18 KB)
Preview of image 'InkBottleLabel2.jpg'
Preview of image 'InkBottleLabel.jpg'
Preview of image 'InkBottleLabelDesign.jpg'
Date: 11 Feb 2008 20:58:56
Message: <47b0fd60@news.povray.org>
This was the source for it:
Download 'tusche.jpg' (34 KB)
Preview of image 'tusche.jpg'
Date: 12 Feb 2008 06:52:30
Message: <47b1887e@news.povray.org>
news:47b0fd60@news.povray.org...
Any good?
Chris B.
Download 'TuschePerspective.jpg' (19 KB) Download 'TuscheOrthographic.jpg' (28 KB)
Preview of image 'TuschePerspective.jpg'
Preview of image 'TuscheOrthographic.jpg'
Date: 12 Feb 2008 11:42:06
Message: <47b1cc5e$1@news.povray.org>
Chris B wrote:
> "Jim Charter" <jrc### [at] msncom> wrote in message
> Any good?
> Regards,
> Chris B.
excellent   I will play creating some uv's
Date: 13 Feb 2008 00:37:13
Message: <47b28209@news.povray.org>
Here's a first try
Download 'inkbottle.0024.jpg' (56 KB)
Preview of image 'inkbottle.0024.jpg'
Date: 13 Feb 2008 04:11:23
Message: <47b2b43b@news.povray.org>
news:47b28209@news.povray.org...
>  Here's a first try
I've just emailed you a slightly higher resolution image with brighter
colours.
I spent last night working on a macro for a label to go round angled
multi-facetted polyhedron with bevelled and rounded corners, such as your
octagonal bottle. I've got the macro to do the shape. I'll be working on the
image definition for that as time allows. Do you have a picture of its
label?
Does that new grey one have any sort of label?
Chris B.
Date: 13 Feb 2008 19:54:50
Message: <47b3915a$1@news.povray.org>
>> Here's a first try
> colours.
Cool
Perhaps the bottles themselve might lend to using csg, the mesh macros I
am using are quite clunky and a little difficult to really make bullet
proof.
> label?
Well not that particular one but the shape is of a common type some of
which do have labels
check these sites
http://www.pendemonium.com/bottles.htm
the dark bottle is on this page:
http://www.antiquebottles.com/ink/inkwell.html
there is this one too though I haven't rally explored this site:
http://www.1001inkbottles.com/
Date: 14 Feb 2008 06:12:43
Message: <47b4222b$1@news.povray.org>
news:47b3915a$1@news.povray.org...
> proof.
I think the mesh generated ones look really great. I used CSG for a plastic
bottle and it looked very regular; OK for plastic, but, IMO, too regular for
glass. It may be possible to add distortions to the surface normals, but
meshes are inherently less regular and retain the potential to allow you to
add randomness into the surface shape itself. I would recommend sticking
with meshes for this, particularly given the excellent results you've shown
here.
The CSG SDL I've written for the labels macro is also getting a bit clunky,
despite a number of rewrites, and all that does is to generate a thin strip
around a regular object. I suspect that to do a generic piece of SDL to
handle the transition from the angled sides to the cylindrical bottle neck
would be pretty tricky using just CSG.
If you're having difficulty making the macros bullet proof, you may like to
consider an idea I've used to make the label generator more user friendly.
I've created a series of include files, with each holding the parameter
settings for a particular label. Inexperienced users can therefore generate
one of the standard labels without getting their hands dirty.
Less timid users can copy a file that is close to what they want and just
tweak the bits they need without necessarily understanding many of the
settings. More adventurous users can dig into the macro calls, but will
obviously have to learn more about how they work to use them.
I think the bottles you've done would make great additions to the object
collection, even if the only changes that a user can make are to scale them.
Any additional configuration settings would be icing on the cake.
Chris B.
Date: 15 Feb 2008 01:33:43
Message: <47b53247@news.povray.org>
Yes I was kind of moving that way that's why you see the different
examples.  Also
I wanted to try using the macros to try and understand the usability
issues.
Here is a test of the new label you sent.  Actually I boosted the
saturation a bit externally and also gave it diffuse 1 in the finish.
Also in this test I generated two additional separate layers of
triangles to serve as the actually label.  This was so that the inside
of the label could be given a separate texture.  In this test a soft
grey color.
Download 'inkbottle.0029.jpg' (85 KB)
Preview of image 'inkbottle.0029.jpg'
Date: 15 Feb 2008 07:57:31
Message: <47b58c3b@news.povray.org>
news:47b53247@news.povray.org...
> grey color.
Applying a separate texture to the back is something I still need to do with
my macros. At the moment the main pattern still shows through on the back. I
figure it should be straight forward to generate two concentric labels of a
very slightly different thickness with a different design for the inside.
Here's where I've gotten to with the bevelled polyhedron shaped label.
Control settings are used to specify the top and bottom diameters, the
number of sides and the bevel width/corner roundness. This avoids the need
for uv-mapping and means that you can change the dimensions of the label
without dramatically distorting features on the design.
Each surface can have it's own design elements, but anything that extends
beyond the surface will also wrap around onto the surfaces on either side
(like the words "blue writing" on this image).
I'd be interested in getting my macros to generate labels directly onto your
bottles. I suspect the colour intensity issues would be easier to fix that
way. I could send you a copy of my macros if you'd like. They should be
simple to use, there's an include file containing 8 settings to adjust the
shape and size of the label based on the dimensions of the target object.
Once that's set up you just include it and run the Labeller macro from your
scene file and scale/translate/rotate to taste.
Chris B.
Download 'pricepentagon.jpg' (15 KB) Download 'price.jpg' (9 KB)
Preview of image 'pricepentagon.jpg'
Preview of image 'price.jpg'
Date: 23 Feb 2008 07:36:23
Message: <47c01347@news.povray.org>
"Chris B" <nom### [at] nomailcom> schreef in bericht
news:47b58c3b@news.povray.org...
> with my macros. At the moment the main pattern still shows through on the
> back. I figure it should be straight forward to generate two concentric
> labels of a very slightly different thickness with a different design for
> the inside.
Can this not be done with interior_texture?
Date: 23 Feb 2008 07:37:53
Message: <47c013a1@news.povray.org>
Just forgot to add that Jim and you are doing a great job!
Date: 23 Feb 2008 08:18:04
Message: <47c01d0c@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> wrote in message
news:47c01347@news.povray.org...
>> the inside.
> Thomas
Actually the labels all are solid objects with a controllable albeit tiny
thickness, so the 'inside' surface of the label is actually part of the
exterior surface of the label object.
Chris.
Date: 23 Feb 2008 08:20:58
Message: <47c01dba@news.povray.org>
news:47c013a1@news.povray.org...
> Thomas
Thanks Thomas.
I'm a good way through the tedious job of tidying up and documenting the
macros, so your words of encouragement are most welcome right now.
Best Regards,
Chris B.
Date: 23 Feb 2008 13:23:57
Message: <47c064bd$1@news.povray.org>
>>the inside.
> Thomas
yes it can!
Date: 6 Mar 2008 05:56:25
Message: <47cfcdd9@news.povray.org>
The finished Labeller macro is now up on http://lib.povray.org (search for
'labeller').
It incorporates a setting to blank out the texture from the inner surface of
the label.
Chris B.
