POV-Ray : Newsgroups : povray.binaries.images : Sven's SL Heli Chopper 02 Server Time
29 Nov 2026 07:33:20 EST (-0500)
  Sven's SL Heli Chopper 02 (Message 1 to 15 of 15)
Subject: Sven's SL Heli Chopper 02
Date: 30 Jan 2008 19:10:13
Message: <47a111e5@news.povray.org>
Description from the scene file:
> About: My persistence of the vision of a small ultra-light helicoper,
> featuring a small engine and made of fiber glass (the case) and plexi
> glass (for the canopy). Note the two conter-rotating rotors beside
> each other.  This helicopter could carry, as concepted with this
> file, one adult normally and probably another one in some cases, or
> some light freight beside the pilot.
Full credits go to Sven Littkowski, all I did was the 50-hour render :)
Download 'sl heli chopper 02.png' (125 KB)
Preview of image 'sl heli chopper 02.png'
Subject: Re: Sven's SL Heli Chopper 02
Date: 30 Jan 2008 19:20:30
Message: <47a1144e$1@news.povray.org>
A lot of credits go, as well, to Nicolas Alvarez who gave 50 hours to render
the scene.
Thanks, Nicolas!
Sven
"Nicolas Alvarez" <nic### [at] gmailisthebestcom> schrieb im
Newsbeitrag news:47a111e5@news.povray.org...
Date: 30 Jan 2008 19:48:21
Message: <47a11ad5$1@news.povray.org>
> the scene.
While my other core was working on... something. Maybe biology, maybe
chemistry, maybe testing primes. Right now, one CPU is researching
nano-magnetic molecules and the other is doing geometry.
I'm pretty sure a lot of people on this newsgroup knows what horror it
is to see an idle CPU. I keep mine busy.
Date: 30 Jan 2008 20:10:01
Message: <web.47a11ebcb71eddd4b8ab52540@news.povray.org>
keep it up and it won't hold for long... ;)
Date: 30 Jan 2008 20:15:00
Message: <web.47a11fecb71eddd4b8ab52540@news.povray.org>
whew!  50 hours for, what?, 10 choppers?!  I beat you 2:  I rendered 9 simple
glasses in 44 hours!  my next project is to render a RSOCP in 100 hours! :P
Date: 30 Jan 2008 20:18:18
Message: <47a121da@news.povray.org>
This heavy usage indeed lowers CPU life, but not enough to be an issue,
because it would become obsolete way before that anyway. Quote:
> 2) Anything wears out faster when in action than when iddle (and
> especially when switching between active and iddle). The question isn't
> really relevant, you should rather ask if anything wears out faster than
> when its replacement would otherwise have been expected. (Whether a
> harddrive lasts 20 years or 10 years doesn't matter if you replace it in
> 5...)
Date: 30 Jan 2008 20:35:01
Message: <web.47a124c4b71eddd4b8ab52540@news.povray.org>
> > 5...)
hmm, yes.  But geeks don't think that way:  we want to optimize and be
lightweight!  If I can save my CPU from a burning death, I will do go out of my
way to do it.  Other than halting povray, that is... :)
Date: 30 Jan 2008 21:00:58
Message: <47a12bda$1@news.povray.org>
No, only 3 hours. Plus 47 hours for creating a photon map from
badly-bounded shapes :)
Date: 30 Jan 2008 21:05:44
Message: <47a12cf8$1@news.povray.org>
Maybe the geeks you know. The geeks *I* know would buy more computers
just to run those distributed computing projects.
Date: 30 Jan 2008 22:25:01
Message: <web.47a13e79b71eddd4b8ab52540@news.povray.org>
oh!  there are photons?!  *scrutinizes image*
yes, there seems there are photons after all:  they seem to show up in the
ground just below the shiny reflective chopper fronts.  But problem is:  from
the point-of-view chosen, it's hardly visible.  Luckly, the photon map is
saved, and getting a close-up shot of the effect should be much easier.  It
seems the only reason for the insane photon map build time is the high number
of reflective geometries there.
Date: 31 Jan 2008 00:35:26
Message: <47a15e1e$1@news.povray.org>
Hey - that's interesting! Your colors look better than the colors in my
image! I wonder, why.
What version of POV-Ray do you use, Nicolas?
Sven
Date: 31 Jan 2008 01:51:43
Message: <47a16fff$1@news.povray.org>
Significantly more of an issue is the extra amount of electricity you
chew through doing this.
William Tracy
You know you've been raytracing too long when you get lots of "undefined
or invalid # directive"-errors when programming in C++.
    -- Warp
(...I have discovered that Warp is quite correct about this.)
Date: 31 Jan 2008 11:33:01
Message: <47a1f83d@news.povray.org>
Remember the statistics I posted before: the number of photons finally
stored was quite low, 0.1% of the photons shot.
Date: 31 Jan 2008 11:37:41
Message: <47a1f955$1@news.povray.org>
3.6.1a
Note I disabled radiosity, that could be related... :)
Date: 31 Jan 2008 23:15:33
Message: <47a29ce5$4@news.povray.org>
Yes, that might be it. I use the same version. Hmm, it looks better without
radiosity.
I made a list of TO-DOs:
- Render again but without radiosity
- remove the interior to get a better canopy glass
- correct the rotor blade joints on the right rotors
The positive side effect with the first two points in that list is, that
they will speed up the render time.
I would like to invite you all, to get my scene file and do your own
textures on my little helichopper baby. Also, the entire chopper is a
macro - you can animate it (doors, rotors, rotor angle)! Would you like? If
I get a positive feedback, I will release my source code to the publicity
(after the neccessary corrections are done). So: WHO WOULD LIEK TO GET THE
HELICHOPPER SOURCECODE?
Sven
Newsbeitrag news:47a1f955$1@news.povray.org...
> 3.6.1a
