Just a WIP I've been working on for about a week or so.
Lately, I've often begun images, but don't manage to finish them. Most
of the time, what I want to say with them doesn't really fit into a
single image, or it evolves as time progresses and I later don't see
what I saw when I started the image. Kinda shows how chaotic my life is
to me at the moment...
Anyways, back to the image. The signposts where scripted, all I do is
collect words I want on them, and assign them to a small and simple
script. It positions the texts on small signs, attaches them to a post
and places it on the hill. Thus, over time, the sign-maze gets thicker,
as I think of more words.
The little person was modelled with the Silo 2.0 Beta. I'm no good at
organic/human modelling so far, always want to exercise it more, but
never get around to it, so I'm sticking with more stylized figures. I'm
pondering about modifying my furry fellows or such. Creating a small
"Tim Nikias" World, so-to-speak, in which I don't have to use human
forms to make the messages for universal, but that is probably for later
images, unless I give my fellows some arms or such.
The hill is a pattern-based heightfield, the grass was dug up from my
old "Miss You (while you're gone)" image. I'm thinking about modifying
it a little and make it available to the public: It creates a set of
grass-blades (like 50 or so, set via parameter), and reuses these to
create small bushels, where each bushel is random again. Thus, memory is
kept low (the blades are meshes and thus, reusing them doesn't require
much memory), even though it all looks pretty random.
Yet to to is some more work on the ground (plain brown isn't realistic,
is it?), some stones (maybe arrange for a path or two) and a background
and proper sky. Lighting is also just preliminary so far.
Tim
aka "Tim Nikias"
Download 'lostguy_05.jpg' (85 KB)
Preview of image 'lostguy_05.jpg'
Tim Nikias nous apporta ses lumieres en ce 2007/06/17 10:29:
> Regards,
> Tim
As the figure is secondary to the arows hill, keeping him as is looks OK to me.
Hi's posture is expressive enough.
Just some tweaking of the sky and polishing of the hill and signs.
Maybe adding some colouring to the posts.
You know you've been raytracing too long when you see something in the real
world and you think, "Hey! How did they get that effect?"
I agree with Alain. In addition, the grass looks like the kind of thing
you get in a desert or at a beach. Maybe dunes would be more appropriate
there. :-)
Also, consider footprints circling the hill. A joke that's classic for
good reason. :-)
His kernel fu is strong.
He studied at the Shao Linux Temple.
> there. :-)
Hm, what would be required to make it less duny and more normal grass?
> good reason. :-)
Hm... I'm not so sure if I wanna go that direction, after all, though
it's kinda funny, it's also kinda sad that this guy doesn't know where
to go, and I don't want to put too much weight on either side.
Tim
aka "Tim Nikias"
>> is to me at the moment...
>> thicker, as I think of more words.
>> I'm pondering about modifying my furry fellows or such. Creating a
>> small "Tim Nikias" World, so-to-speak, in which I don't have to use
>> human forms to make the messages for universal, but that is probably
>> for later images, unless I give my fellows some arms or such.
>> is kept low (the blades are meshes and thus, reusing them doesn't
>> require much memory), even though it all looks pretty random.
>> realistic, is it?), some stones (maybe arrange for a path or two) and
>> a background and proper sky. Lighting is also just preliminary so far.
>> Regards,
>> Tim
> to me. Hi's posture is expressive enough.
Good that I got that right on my first attempt. :-)
Yeah, all that is on my to-do list. For now, I just tweaked the hill for
the main form, scripted the stuff for the signs and tweaked the scripts
for the grass, modelled the guy, it's really just an early stage of the
image.
Tim
aka "Tim Nikias"
More smooth and fewer clumps, I think. Roots don't go well horizontally
in sand, which is why the grass tends to grow in clumps on sand.
Yeah, it's hard to say whether it would improve things. It would
definitely change the tone and story of the image.
> > there. :-)
The base of the grassblades is too wide. The way you have set them up, it
looks realistic for very short grass. But we can use Lost Guy to measure
grass heigth and realise it's quite tall. The grass near the path could
also be flatter, as it's likely someone trod on it. Your grass is also of
random height, but flat on average. Real grass tends to be in clumps, some
taller and greener, others shorter and yellower, but clumps near a tall and
green clump are more likely to be tall and green too. Finally, grass is
nearly white near the ground.
Gilles Tran's grass-making macro is very good although not perfect, you may
want to compare notes with it.
Grassblade nous apporta ses lumieres en ce 2007/06/17 16:09:
>>> there. :-)
A good use of the bozo or bumps pattern. Use it to modulate the height and
colour of the grass.
My wife likes to talk on the phone during sex; she called me from Chicago
last night.
Rodney Dangerfield
>>> there. :-)
Maybe I should have another look at it, but AFAIK it places tones of
grass-blades, while my approach is to place bushels. Maybe I'll work
further on the placing and scaling (via patterns or function) to
generate that more uniform look you mention when those bushels are
closer to each other. As it is now, I just build a bushel, texture each
blade differently and use some random scaling. But, as I said, the image
is WIP and at its beginning, still lots of room for improvement.
Thanks for all the suggestions, btw!
Tim
aka "Tim Nikias"
Deceptively simple and yet an image with a profound impact. Thanks for
sharing this with us, Tim. Read the first stanza of Dante's Inferno and you
will meet the same dilemma:
Nel mezzo del cammin di nostra vita
mi ritrovai per una selva oscura
ché la diritta via era smarrita.
( free translation: Halfway on the road of our life, I found myself in a
dark wood because the true way had been lost)
Interesting to see how some of your words are printed larger than others...
They are very revealing I guess, if not of your own thoughts, then at least
of the things in life that are important and/or unavoidable, and those
that - after all - may play a secundary role. Subtle and true.
I am looking forward to next versions.
Hey, no problem. Haven't been up to povraying for a long time, and
thought I should reignite my love for it.
Hm, being compared to Dante's Inferno... ;-)
The sizes, so far, are just because the signs are all the same size and
words get scaled and positioned to fit on them, but I've been thinking
about adding a variable to adjust for some scaling. Overall though, I
think that every one of those things is placed at the top of priorities
at one time or another (and even if its just for seconds). Though it's
all random-based, I sometimes like how two more or less seperate things
end up pointing in just about the same direction: some things lie so
close to each other, its easy to make a wrong step and end up in the
wrong place.
I hope to make vast improvements, based on my to-do-list and the
suggestions, there's still room for them. ;-)
Tim
aka "Tim Nikias"
"Tim Nikias" <JUS### [at] gmx netWARE> schreef in bericht
news:46763721$1@news.povray.org...
The thing is, you have broached a universal theme! And that is very
interesting :-)
Specifically, like this: :-)
http://www.aguntherphotography.com/oregon/oregon_dunes/grass_bush2.html
