POV-Ray : Newsgroups : povray.binaries.images : Making clothes in Poser - Take 5 Server Time
13 Oct 2026 09:36:57 EDT (-0400)
  Making clothes in Poser - Take 5 (Message 1 to 38 of 38)
Subject: Making clothes in Poser - Take 5
Date: 24 May 2007 05:18:02
Message: <4655584a@news.povray.org>
Here is a piece of more complicated clothing: a pantaloon.
uv mapping is not easy. Note the stripes getting wider downwards. Not easy
to avoid that.
The t-shirt is a conforming prop from Poser. I note that conforming clothes
are much more difficult to move than dynamic clothes!! The underlying skin
tends to get through much more rapidly  :-(
Download 'Poser_figuretest_08b.jpg' (69 KB)
Preview of image 'Poser_figuretest_08b.jpg'
Subject: Re: Making clothes in Poser - Take 5
Date: 24 May 2007 06:40:35
Message: <46556ba3$1@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> a écrit dans le message de
news: 4655584a@news.povray.org...
> to avoid that.
> clothes are much more difficult to move than dynamic clothes!! The
> underlying skin tends to get through much more rapidly  :-(
> Thomas
Nice shaping :-)
For the uv_mapping problem couldn't you scale smaller the coordinates at the
wide part?
Marc
Date: 24 May 2007 07:15:01
Message: <web.465572442b96b31b3e3af320@news.povray.org>
> to avoid that.
> Thomas
So we are going to have a “Clothes Room” expert here, excellent!
Are you using conforming clothes as cloth? If so did you have problems
removing the end caps?
IIRC I could discard the skin parts of conforming clothes for
most of the ones that I tested. Also/or make them invisible and switch off
“Collide against”.
Date: 24 May 2007 07:22:24
Message: <46557570$1@news.povray.org>
"Marc" <jac### [at] wanadoofr> schreef in bericht
news:46556ba3$1@news.povray.org...
> Nice shaping :-)
Thanks Marc!
This figure is going eventually to
http://news.povray.org/povray.binaries.images/thread/%3C45097171%40news.povray.org%3E/?ttop=242333&mtop=232563&moff=20
which I shall revisit and update with new/better figures. It is going to be
a series called "Iskander the Sailor" (the name of this particular chap
here).
> the wide part?
Hmm... I am not sure I can do that in Silo 2.
As is, the problem is not too visible, but if I add a bump map for the
weave, it becomes really horrible.
Date: 24 May 2007 07:25:02
Message: <web.4655753e2b96b31b3e3af320@news.povray.org>
"Marc" <jac### [at] wanadoofr> wrote:
> Nice shaping :-)
> wide part?
If the stripes are getting wider due to the material stretching you might
get unpredictable results.
Also in RL pantaloons have inserts and darts to give them the ballooned
shape. That would make stripes an unsuitable design unless you don’t mind a
break in the pattern. Although it is perfect for testing, Rupert the bear
trousers might be better, IMHO.
http://en.wikipedia.org/wiki/Rupert_Bear
Date: 24 May 2007 07:36:07
Message: <465578a7$1@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> schreef in bericht
news:web.465572442b96b31b3e3af320@news.povray.org...
> So we are going to have a "Clothes Room" expert here, excellent!
> "Collide against".
He He!! Expert? Who knows? Anyway, I want to explore these avenues because
of the complex stories I have in mind. And it is worthwhile to know
'everything' about the programs you are using, isn't it?  :-)
I have to make the step between conforming and dynamic clothes yet. So I
guess I first have to export one, edit it in Silo (or Wings), and import it
again as dynamic clothing. Looks like an interesting experiment.
Yes indeed. I forgot that possibility to switch of the skin under the
conforming clothes. That would solve the problem indeed.
Date: 24 May 2007 07:49:46
Message: <46557bda$1@news.povray.org>
news:web.4655753e2b96b31b3e3af320@news.povray.org...
That is what happens in fact, as the mesh is stretched, thus stretching the
map.
> shape. That would make stripes an unsuitable design unless you don't mind
> a
There are breaks anyway along the seams (which you don't really see in this
particular image). In accordance with RL, I provided vertical seams along
the front and back, and along the inner and outer sides, thus making four
panels, that were then rotated and oriented as well as possible according to
the stripe pattern. Inserts and darts would be difficult to simulate/model I
believe.
Oh God! Dear old Rupert! Long time no see!!
His trousers would also show stretching, but maybe less visible? I shall
experiment.
Date: 24 May 2007 08:10:01
Message: <web.46557ef32b96b31b3e3af320@news.povray.org>
You had better become one, because I’ve made myself sick of Poser clothes
for a while. My current project doesn’t need any because the world’s
population is naked :-)
Maybe Janet might do the girlie thing, I bet she is a dab hand with the
pinking shears :-)
Careful, I did that at first and Poser made end caps that had to be removed.
For skirts the bottom end cap was located half way up the body. Giving the
OBJ an inside hem which I found very time consuming to delete. Without
retesting I think that it is better to convert the conforming clothes to
cloth in the Clothes Room. There are some restraints, I think that you
might need to convert body parts separately. I think that I’m loosing my
short term memory it was only a month or two ago :-)
Or remove it in a modeler.
Date: 24 May 2007 08:20:02
Message: <web.465582862b96b31b3e3af320@news.povray.org>
> map.
I thought that it looked like stretching. You will need to tweak the cloth
parameters. What does a square centimeter of cotton weigh?
> > a
> believe.
Hmm, impressive! It is little things like that, that add to the look.
Thinking about it. It might not be too difficult using subdivision for
inserts and deleting lines and joining points for darts. But I’ll leave it
for someone else to do :-)
> experiment.
Sad when you model things from your childhood.
Date: 24 May 2007 08:43:19
Message: <46558867$1@news.povray.org>
news:web.465582862b96b31b3e3af320@news.povray.org...
>> the
>> map.
What I mean is something different. The stretching does not happen in the
Cloth Room during the simulation, it is already there in the basic mesh
where the width of the faces at the bulges is wider than at the waist or at
the ankles. Now, this is a thought indeed. Maybe, if I could model the
pantaloon in such a way that more faces were produced at the bulges than at
waist or ankles.... Hmm... I'm not sure...
>> this
>> to
>> simulate/model I
>> believe.
> inserts and deleting lines and joining points for darts. But I'll leave it
It is knowledge of tayloring that is beginning to be needed in the first
place!
>> experiment.
<grin> As yet, I don't feel at all alzheimerish  :-)
Date: 24 May 2007 08:53:58
Message: <46558ae6@news.povray.org>
news:web.46557ef32b96b31b3e3af320@news.povray.org...
>> because
> You had better become one, because I've made myself sick of Poser clothes
> for a while. My current project doesn't need any because the world's
Now, that is the easy way out!  :-)
> pinking shears :-)
I am really curious to see that!
>> it
> removed.
> might need to convert body parts separately. I think that I'm loosing my
Hm.. Have to be careful. See what I can do.
Oh, yes, of course. Good idea.
Date: 24 May 2007 09:30:01
Message: <web.465592532b96b31c4e49fa40@news.povray.org>
The story demands it. I’ve no option unless I want to compromise my
principles, and it is all done in the best possible taste. :-)
> > pinking shears :-)
I’ve said enough.
> >> it
> > removed.
I made things more difficult for myself than I needed to.
I’m full of them today :-)
Date: 24 May 2007 09:40:02
Message: <web.465594df2b96b31c4e49fa40@news.povray.org>
> >> the
> >> map.
> the ankles.
I see, my misunderstanding.
[snip]
> place!
From my memory of the 70’s flares; Stitch (insert and join) a triangular
section to the inside seam of rectangular sections and draw in the hem.
> >> experiment.
<g>
Date: 24 May 2007 23:50:02
Message: <web.46565b6a2b96b31f07d58b80@news.povray.org>
I used to have pinking shears, a long time ago. :)
If the pants are seamed as real pants are, you can try to create the UV map
as 4 pieces and also minimize any deformation of the mesh when its
flattened out to the UV map. Thinking of it as pants pieces you will sew
together is a good way of approaching it. I know I am a Blender fan, but,
really, Blender has some great UV mapping options.
As for skin poking through, I know Poser magnets can be used to pull the
clothing out a bit. But, I never quite got the hang of those magnets.
Eliminating the body part is fast and easy, if its that simple. But
sometimes its not.
Poser 7 has a morphing tool you could use to get rid of "poke through", and
also modify the figure, check out:
http://www.renderosity.com/news.php?viewStory=13544
You can also do this sort of thing in a 3D modeller. Ha, ha like Blender! :)
Cheers, Janet
Date: 25 May 2007 03:21:00
Message: <46568e5c@news.povray.org>
news:web.465594df2b96b31c4e49fa40@news.povray.org...
>> place!
> From my memory of the 70's flares; Stitch (insert and join) a triangular
Yes, but will a modeller with uv mapping give the same result?
There is a work around that I have just started testing and which might be
the answer. I am adding vertical seams through those parts that widen
towards the bulges, from the top and from the bottom. This way, the cloth
panels are flattened out much more with less distortion as a result. Look at
the two highlighted panels to the left on the attached image, to see what I
have started to do in the ankle area.
Download 'SiloScreenShot.jpg' (313 KB)
Preview of image 'SiloScreenShot.jpg'
Date: 25 May 2007 03:40:37
Message: <465692f5$1@news.povray.org>
"Janet" <par### [at] attnet> schreef in bericht
news:web.46565b6a2b96b31f07d58b80@news.povray.org...
> map
Well, what do you think of Silo (see the screenshot in my answer to Stephen,
above)?  :-)
However, I think that the RL approach and the modelling approach are
necessarily different. What no modeller like Wings or Silo can do (correct
me if Blender is different from this) is to deform a mesh, keeping the same
net surface area. You always scale the mesh one way or another by bending,
translating, or rotating vertexes, edges or whole surfaces. In RL this only
happens with really stretch-prone materials like spandex.
> sometimes its not.
Ah yes, magnets. Still have to learn to use those. Thanks for reminding me
Janet!
> and
Another tool I have yet to learn to use!!
You really like to rub in the salt, don't you?  :-)
Date: 25 May 2007 07:15:02
Message: <web.4656c4a22b96b31c4e49fa40@news.povray.org>
I don’t know :-(
That looks so competent, I must get round to making my own UV maps, I’ve got
an old copy of UV Mapper somewhere.
Date: 25 May 2007 07:20:02
Message: <web.4656c5562b96b31c4e49fa40@news.povray.org>
So did my mother, now I’ve got very fancy ears :-)
> sometimes its not.
There is a lot in Poser if you can get it to work.
Date: 25 May 2007 07:39:37
Message: <4656caf9@news.povray.org>
news:web.4656c5562b96b31c4e49fa40@news.povray.org...
That is very true. Poser has sometimes strange idiosyncrasies... :-)
Date: 25 May 2007 19:50:02
Message: <web.465775302b96b312786ac610@news.povray.org>
LOL!!
Good point. :) I agree.
Date: 25 May 2007 20:05:02
Message: <web.465778a42b96b312786ac610@news.povray.org>
> above)?  :-)
Silo looks nice. It seems to have helped to cut the bottoms a bit. Anyway,
your pantaloons are not that easy to UV map. :) Another trick is to warp
the stripes in Photoshop (or whatever else can do this) by pinching them in
at the wide part of the pant legs.
I think what matters the most with UV mapping is how close the UV map "mesh"
is to the 3D object's mesh. The more deformation (stretch) on the UV map vs.
the object mesh, the more warping you will get. Blender has the ability to
minimize the stretch on the UV map. I don't know if Silo does, but it would
be worth looking into. Especially if you want to use stripes! lol :)
> Janet!
> > and
My feeling is that the morphing tool is better than the magnets. It just has
to be, right, or why would they add that feature?
Yes, I'll admit it. Should I be kinder?
Date: 26 May 2007 03:04:19
Message: <4657dbf3$1@news.povray.org>
news:web.465778a42b96b312786ac610@news.povray.org...
> in
Yes indeed. Similar to what you see with those planet maps used for mapping
on a sphere.
> "mesh"
> vs.
> would
I have to admit that stripes are not the most easy to map, but then it
immediately show also where attention should go and what the boundaries of
certain procedures are.
In fact, one should  make the map with the mesh ready. The best caset would
be to 'paint' on the uv proxies. I suppose that is why Poser provides the
base maps of the figures
> has
I agree.
<grin> I'll survive! Will push me to Blender eventually, so keep on trying!
Date: 26 May 2007 07:05:01
Message: <web.465813882b96b319dafebf60@news.povray.org>
You're definitely giving me inspiration to (finally) get POSER, and start
playing around.
Oh no--even MORE time at the computer!!  ;-)
Keep up the good work; I'm following it closely.
Ken
Date: 26 May 2007 07:55:22
Message: <4658202a$1@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> schreef in bericht
news:web.465813882b96b319dafebf60@news.povray.org...
> playing around.
It really is worth the money, especially if you have a fast computer.
I am going to ask e-frontier for a free coupon, bringing in customers :-)
Is that a problem??  :-)
Thank you, Ken. Happy to share what I can, and what I learn.
Date: 26 May 2007 07:57:45
Message: <838g53pv40p740omk80e2cetbbpsma2vdh@4ax.com>
>> Janet!
>> > and
Don't you set up the morphing tool by using the magnets first, to get your
target?
Please keep this thread going as I'm learning a lot just reading it.
Regards
Date: 26 May 2007 07:59:24
Message: <388g539s3hp2pnm561jjksk6j6qck9j5nc@4ax.com>
>LOL!!
From an old comedy song. Not my own.
Regards
Date: 26 May 2007 08:37:15
Message: <465829fb$1@news.povray.org>
"Stephen" <mcavoysATaolDOTcom@> schreef in bericht
news:838g53pv40p740omk80e2cetbbpsma2vdh@4ax.com...
> target?
I don't know, as I have still to try this. But I shall report back!
I now just tried out the Apollo Maximus figure that fls13 suggested in
povray.tools.poser (the plump Ken thread). Full of potential.
I certainly shall!! There is an exciting learning process going on just now.
I am going to be in serious trouble for the Black Robe entry, however :-)
Date: 26 May 2007 09:55:25
Message: <3qeg53ddsfmf37k88b1aspn4gohqd0snog@4ax.com>
On Sat, 26 May 2007 14:37:16 +0200, "Thomas de Groot" <t.d### [at] internlDOTnet>
>> target?
Sorry Thomas but I was asking Janet:-)
I've not downloaded it but probably will. I've just started looking at models
other than Nene and the basic ones. I'm surprised at the diversity of controls
and morphs. I'm using seven models for a cast of thousands and each one needs
something different done for the same effect.
It keeps you young :-)
That's why I don't bother unless I'm working on something that fits the subject.
I'm always branching up new rivers of ignorance.
Regards
Date: 26 May 2007 10:30:01
Message: <web.4658432c2b96b312b3089000@news.povray.org>
> >> target?
Oh, that would be bad!!
(laugh) I don't know for sure, its a new Poser 7 feature. I have Poser 6,
Thomas has Poser 7 (I think).
Date: 26 May 2007 12:51:50
Message: <eapg53l64eq7rrlbm721i2be3l49jllfcv@4ax.com>
>> >> target?
I sit at your feet, why?
I thought that you set up a magnet then created a morph with the magnet settings
applied. Is that a "Duh" moment for me?
So have I ( Poser 6) although I'm thinking of reinstalling Poser 4 to get a BVH
programme I've got, working.
Regards
Date: 26 May 2007 14:05:01
Message: <web.4658769c2b96b312b3089000@news.povray.org>
> >> >> target?
Well, now you got me curious. :) I found this, it explains the new morphing
feature in Poser 7:
http://www.e-frontier.com/article/articleview/2092/1/324/
Kinda makes me want to get Poser 7.
Date: 26 May 2007 15:36:22
Message: <3v2h539q8shdmn1pt84aqet701bn4ou04j@4ax.com>
>feature in Poser 7:
Oh! We are talking about different things. And I can't get the video to play :-(
I'll probably wait until Poser 8 then Poser 7 will be discounted :-)
Regards
Date: 26 May 2007 16:40:01
Message: <web.46589a3b2b96b3115e32ec30@news.povray.org>
I kind of figured we were. :) Too bad it won't play for you. It works like a
brush to push or pull parts of a mesh. And it has several controls for the
brush. And no *#@% magnets!  And an automated symetry thingy that looks
very cool for morphing symetrical thingies... like humans.
Date: 26 May 2007 17:19:31
Message: <vv8h53pa978ror5joppp2pb64o8u56rej9@4ax.com>
Thanks for the description. I can't get magnets to work very well for me either.
Regards
Date: 27 May 2007 03:09:42
Message: <46592eb6$1@news.povray.org>
news:web.4658432c2b96b312b3089000@news.povray.org...
>> >> your
>> >> target?
Yes, I have Poser7. I started experimenting with the morphing tool. I works
quite intuitively, but one has to be very careful with the settings. Also,
at boundaries between figure and object, it tends to jump from one to the
other without notice and you have to backtrack a bit (mostly ctrl-z is
enough) to correct the mess. However, I only started, so this may be newbie
stuff as it were.
Date: 27 May 2007 03:25:06
Message: <46593252@news.povray.org>
news:web.4658769c2b96b312b3089000@news.povray.org...
> morphing
> feature in Poser 7:
Hmm. I guess I prefer Jasmin's tutorial on the Renderosity site. Video's
often make me yawn :-)
However, this explains well the workings, although it avoids the problem I
mentioned higher up in the thread about the boundaries between figure and
object.
Date: 30 Jul 2007 12:05:01
Message: <web.46ae0c042b96b31b39109d30@news.povray.org>
> > morphing
> > feature in Poser 7:
> object.
> Thomas
Hi Thomas,
this is Michael,
I just read your words: "I guess I prefer Jasmin's tutorial on the
Renderosity site" .....
I looked instantly at Renderosity, but there is no tutorial from JASMIN ...
Can you please write me the link down.
thanks Michael
Date: 31 Jul 2007 04:03:45
Message: <46aeece1@news.povray.org>
"tigerkidden3d" <tig### [at] webde> schreef in bericht
news:web.46ae0c042b96b31b39109d30@news.povray.org...
> Hi Thomas,
> this is Michael,
It's crazy :-(   I am unable to find it!!!
The link was by JasminC, somewhere in April this year, but I don't remember
if it was in the tutorial or the Poser forum section. But whatever I do, I
find nothing at all. A pity, because it was a neat little tutorial....
