After a cumulative render of about 49 hours, here is finally 'Age of
Curiosity', the second part of my series Cathy's World.
The long render is not so much due to the media, but to the use of Rune's
Patina macro which covers most of the scene. The tunnel has been inspired by
a sequence from the film Stalker, by Andrei Tarkovski.
Download 'AgeOfCuriosity_final.jpg' (69 KB)
Preview of image 'AgeOfCuriosity_final.jpg'
"Thomas de Groot" <t.d### [at] inter nlDOTnet> wrote in message
news:462209fe@news.povray.org...
> by a sequence from the film Stalker, by Andrei Tarkovski.
I like this Thomas! The scene has an eeriness about it - I mean, is she
looking at YOU? Or, is she trying to spot something she 'may' have seen
whilst you are crouching down trying to keep as still as possible? <spooky!>
~Steve~
> Thomas
You did a very good job then, because I was instantly reminded of that
scene when i saw the picture. I think the one complaint I have is that
it doesn't feel very wet somehow -- sort of like a drainage pipe
somewhere where it hasn't rained for a month. I can't put my finger on
what it is that makes me think this. I still like the image though and
you capture a mood well with it.
"St." <dot### [at] dot com> schreef in bericht news:462288bd$1@news.povray.org...
> <spooky!>
Thank you Steve!
Well, I don't know what/or who Cathy is looking at. Maybe the drops of water
falling from the stalactite? But most probably at something behind the
camera, where the light comes from... I have no idea, and I would like to
turn around, but I cannot.
"Kevin Wampler" <wampler+pov### [at] u washington edu> schreef in bericht
news:46228c3b$1@news.povray.org...
> it doesn't feel very wet somehow -- sort of like a drainage pipe somewhere
> where it hasn't rained for a month. I can't put my finger on what it is
> that makes me think this. I still like the image though and you capture a
> mood well with it.
Thank you indeed Kevin! Glad you recognized the scene, although this image
is not intended of course as a Tarkovski reminder. I just borrowed the key
element for my own purposes. There are still some other locations in Stalker
which I would like to "borrow".
Yes, the wet feel is difficult. I tried to get that by making part of the
wall and objects texture reflective in Rune's Patina macro, but it is rather
difficult to control correctly. Water should be running also down the walls,
dropping from the cable or the ceiling (only from the stalactites now). So
this particular scene here is from a fairly dry season, which explains why
Cathy is able to explore :-)
Too dark.
On Sun, 15 Apr 2007 13:18:20 +0200, "Thomas de Groot" <t.d### [at] inter nlDOTnet>
Too light, until I adjusted the gamma.
Evocative as usual.
Regards
Too dark (Warp)
Too light (Stephen)
Now, isn't that interesting?
The scene uses the default gamma procedure for v.3.7. The only thing I did
was resave the png image before exporting to jpg.
The scene anyhow is rather dark because it is intended to be that. However,
I can see the details well enough on my screen.
"Thomas de Groot" <t.d### [at] inter nlDOTnet> schreef in bericht
news:46235b01$1@news.povray.org...
> Too dark (Warp)
> Too light (Stephen)
> However, I can see the details well enough on my screen.
< I pressed send before I was finished...>
We have had this discussion before concerning the gamma in 3.7 I believe. As
far as I can tell, if I do nothing to my scene, it renders exactly identical
on 3.6 or 3.7, with the exception that WinIE shows the image far too light,
which is solved by just saving the image in PaintShopPro, without doing
anything. But otherwise, I see no difference.
Just the same, thanks Warp and Stephen to mention this :-)
"Stephen" <mcavoysATaolDOTcom@> schreef in bericht
news:s9c62351dm0fm556e4fkd7l8tgfns5skms@4ax.com...
> Evocative as usual.
Thank you indeed Stephen! I do my best :-)
Great seeing Poser figures in Povray! Keep em coming.
She's too curious. :) I see what you mean by "in the shadows" now. I like
the way the lights are streaming in. I am glad too, whenever I see people
using Poser and POV-Ray together. Poser is not as easy as it looks (I
find), to create an image that looks good from an artistic standpoint. So,
great job Thomas!
"Janet" <par### [at] att net> schreef in bericht
news:web.4624432e1a29668e136e395e0@news.povray.org...
> great job Thomas!
Thank you indeed, Janet!
My question in povray.tools.poser concerned another image in fact where
radiosity should play an important role. Here, I didn't use radiosity at
all, as the render was already so terribly slow, so that I preferred using
v.3.7 on my dual core machine (and still 49 hours!).
Poser is very complex and I found (for now) that the best way to tackle
facial expressions and body language is to start from very simple basics as
found in the provided poses, and change those gradually until a harmonious
balance is found. It is very easy to overdue the effect, so one has to be
very careful. Especially the facial expressions need changes sometimes that
are hardly visible, but which convey a huge impact. And looking often into
the mirror helps a lot! :-) I think one has to be a bit of a (mental)
performer...
I like Poser very much and my "before and after" entry will show several
Poser figures. But I feel also that one has to restrain oneselves from using
Poser everywhere. It has to add a significant value to the scene, otherwise
it may look artificial. Oh well...
One of my next projects will involve tayloring clothes...
"fls13" <fls### [at] netzero net> schreef in bericht
news:web.462424a61a29668e5d33d38c0@news.povray.org...
Wait for my "before and after" entry.
....and mine (well, Daz|Studio anyway).
Great image, Thomas. I like the detail in this, and your posed figures
always have personality. The brightness is an interesting issue actually,
it's too dark on my CRT but looks fine on my laptop. I have the same
problem with my images. I don't think this is something that can be easily
solved; I think one has to just make sure details are not lost in darkness
(or brightness) and leave it up to the audience to brighten/darken their
display or gamma-correct the image.
Keep it up!
Bill
> ...Here, I didn't use radiosity at
Oh no!! I couldn't wait that long. Well, maybe...
> performer...
Yes, subtle expressions can be hard to get right.
I think it depends on what you want the image to be. If its a portrait then,
that's a lot of Poser. And, yeah, it can easily look unrealistic. But,
that's part of the challenge. I will look for the "Before and After" pic.
Do you mean making your own clothes, or modifying existing ones?
news:web.4625a8ec1a29668e7da18c860@news.povray.org...
>> using
>> otherwise
> then,
Part of the challenge indeed. That has a great attraction. Find the right
balance between the initial vision and the created scene...
Yeah, it's coming along nicely, I guess. I won't be ready with radiosity
renders, though, so it will be the best for the moment :-)
Well, both, probably. In the near future I shall need a whole new set of
clothes not to be found elsewhere, so that will be a good opportunity to
explore those areas. There is that tutorial that Stephen found
(povray.tools.poser) and I still have to get familiar with Clothing Designer
which looks promising. So, we'll see.
"Bill Pragnell" <bil### [at] hotmail com> schreef in bericht
news:web.46249d731a29668e731f01d10@news.povray.org...
Ok. Daz|Studio works quite well too :-)
Thank you indeed, Bill! Much appreciated.
I am currently and exclusively working on LCD flat screen, so I cannot
compare, but there is (was also) a certain difference. I suppose that with
the gradual extinction of CRT the problem will "solve" itself.... :-)
> Keep it up!
I will!!
> Too dark (Warp)
> Too light (Stephen)
That's too funny! :-) Looks quite good on my (older) Mac and (older)
Viewsonic CRT monitor. Monitor gamma of 1.8, AFAIK.
Nice work. Not sure just what the *material* is supposed to be that's
sagging down through the holes, though. Looks kind of like old peeling
paint. I would suggest a curved look to that material--like metal that has
been blasted through by a bomb. Or perhaps a rougher edge to the material;
looks a bit too "rounded off."
Ken W.
"Kenneth" <kdw### [at] earthlink net> schreef in bericht
news:web.46270e0a1a29668e7ed3e70e0@news.povray.org...
Thank you, Kenneth!
Don't know either what the *material* is :-) looks organic to me. I
experimented with rougher edges (those are meshes) but the results were not
convincing at all, so I stayed with this, after several aborted
re-modellings of them. They were, by far, the most difficult things to model
in this scene, and even now I am not entirely satisfied...
> Thomas
Good luck Thomas, You are brave to attempt it. I have done "clothing" that
doesn't have to bend, like a hat, earrings, stuff like that. Those are
pretty easy to do, relatively speaking.
news:web.4627c2d51a29668e3c1e96f10@news.povray.org...
Thanks Janet, I shall need it :-)
Yes, the hard stuff (in terms of material) is easiest to model. However,
people have done it, so we should be able too, shouldn't we?
I have first to finish a couple of things and then I start in earnest. And I
shall report back here about my impressions.
> Thomas
Yes, Thomas, we should be able to. :) We can do anything! Another trick you
can try is morph targets. This is where you take existing clothing and
modify it somehow in Wings, Blender, whatever. It works great, but the only
issue is, you can't add or subtract vertices, so its limited that way. You
can do this with figures too, not just clothing.
news:web.4629260f1a29668ea517c74b0@news.povray.org...
>> Thomas
> you
> only
Ah! Excellent reminder! That should be something on my list too.
On Fri, 20 Apr 2007 09:26:08 +0200, "Thomas de Groot" <t.d### [at] inter nlDOTnet>
Materials are handy for assigning vertexes to groups, such as constrained or
soft decorated.
Regards
news:lgmj239gi30grr385ae4nor36fic8b75uj@4ax.com...
> or
> soft decorated.
I think I understand what you mean Stephen, but could you develop this a bit
more, please?
On Sun, 22 Apr 2007 09:12:37 +0200, "Thomas de Groot" <t.d### [at] inter nlDOTnet>
wrote:
>could you develop this a bit more, please?
LOL
In ready made dynamic clothing props you are likely to find that certain parts
have predefined materials. If for instance you want to make a bow as a "Soft
Decorative Group" you will probably find that it has its own material. It is
easier to select the vertices this way than do it manually. I find that it is
easier to subtract the points that you don't want than to add then as it is only
too easy to pick vertices behind the target. I have been using this method to
pick a Constrained Group round the neck of my dress. (Not MY dress but my
model's dress :-) the collar just happens to be two vertices deep.
One point to note is, if you save your work with the "Hide other objects"
checked then the poser figure becomes invisible at the body parts level. Very
annoying!
Regards
news:8f7m23th1pldnlb0546j45g0f5u7d8tllf@4ax.com...
> parts
> "Soft
> is
> is
> is only
> to
> Very
> annoying!
Ah! Here is the expert speaking!! :-) Thank you Stephen, I think this is
going to be very helpful. As said, I have not yet really explored this
domain of Poser, so it is all new to me, but this kind of advice is
certainly helping to make progress. Thanks indeed.
On Mon, 23 Apr 2007 09:05:13 +0200, "Thomas de Groot" <t.d### [at] inter nlDOTnet>
Hardly an expert but I've had quite a few problems, some I've managed to solve
and a lot I've not. It might help if I'd read the tutorials properly and start
off simply. Unfortunately for me I want to run before I've learnt to walk :-)
The forums I've found don't give much help for what I want to do (I've been
spoilt by this newsgroup) and my time is limited :-)
If I can be of help please ask.
Regards
news:f8oo23d7l48lafps8ov4ofvidsebqtrdo0@4ax.com...
> solve
> start
[See, Thomas? You are not the only one!!]
> been
I shall certainly ask when hitting a wall :-)
On Mon, 23 Apr 2007 14:47:27 +0200, "Thomas de Groot" <t.d### [at] inter nlDOTnet>
>> and a lot I've not. It might help if I'd read the tutorials properly and start off
simply.
Did you ever doubt it? :-)
>> been
My pleasure
Regards
After more than 12 years, I just noticed for the first time that there is a dog
in the scene.
Op 29/09/2019 om 17:13 schreef Cousin Ricky:
> in the scene.
LOL
I had to check that, especially as I changed the title of the scene an
age ago into 'Stalker Tunnel'. In fact, it is not a dog but a cat ;-)
After all this time, I wonder if the original title was not better...
