POV-Ray : Newsgroups : povray.binaries.images : Battlestar Warspite Server Time
13 Oct 2026 12:41:19 EDT (-0400)
  Battlestar Warspite (Message 1 to 20 of 20)
Subject: Battlestar Warspite
Date: 22 Feb 2007 17:39:09
Message: <45de1b8d@news.povray.org>
My take on BSG... pure CSG and inbuilt textures.
Rarius
Download 'battlestar.jpg' (114 KB)
Preview of image 'battlestar.jpg'
Subject: Re: Battlestar Warspite
Date: 22 Feb 2007 17:55:31
Message: <qq7st29o8hghvp20klvthb6kun08mr4lao@4ax.com>
>Rarius
Nice but a bit dark on my monitor. I looks like a lot of work. How long did it
take you to build it?
Regards
Date: 23 Feb 2007 01:40:00
Message: <web.45de8bc1a626085a632e613b0@news.povray.org>
I haven't seen that show in ages, but impressive and well done I think.
Dark is probably more realistic, but I'd also like to see it in brighter
light to see more of the model.
Charles
> Rarius
Date: 23 Feb 2007 02:31:58
Message: <45de986e$1@news.povray.org>
> Rarius
You *have* to do an animation with that thing going into battle :)
...Chambers
Date: 23 Feb 2007 03:20:02
Message: <web.45dea2baa626085af1cb1e660@news.povray.org>
> Charles
> > Rarius
Change the gamma to 2.2 the detail’s there
Date: 23 Feb 2007 04:39:31
Message: <45deb653@news.povray.org>
I like it, dark as it is perhaps, but that is part of its ominous presence.
Excellent work.
Date: 23 Feb 2007 06:04:22
Message: <45deca36@news.povray.org>
> did it
It took about a week to put together...Each hull segment is made using a
macro so I can make an inner, middle, and outer hull and combine them
together.
This render at 1280x1024 took 51m to render... Before I figured out how to
use light_groups, it took over 5 hours!
rarius
Date: 23 Feb 2007 06:05:31
Message: <45deca7b@news.povray.org>
If you can lend me a render farm I'll gladly do one... Even at 640x480 it
will take 15 mins per frame!
Rarius
Date: 23 Feb 2007 11:36:03
Message: <45df17f3$1@news.povray.org>
Want to test out my code for just that, and run it on Amazon's ECC? :-)
    "I'm getting addicted to feet. Which is
     bad, because they're like $5 a pound."
Date: 23 Feb 2007 12:27:29
Message: <45df2401$1@news.povray.org>
As others have said, nicely done!
However, I once read on a FAQ on modeling space crafts, that the best way to
show it off is on a completely *white* background. Because while it's easy
to make something look impressive on a black or starry background, perhaps
with sparse lighting, you *know* that it's a good model if you can show it
on a white background and it *still* looks fabulous. Then you can always put
in the black background and moody lighting later. Just a thought.
Rune
http://runevision.com
Date: 23 Feb 2007 15:09:02
Message: <45df49de@news.povray.org>
> Rarius
Sure, I happen to have a render farm sitting right here... It's called
IMP :)
www.imp.org
...Chambers
Date: 24 Feb 2007 03:00:08
Message: <45dff088$1@news.povray.org>
"Rune" <new### [at] runevisioncom> schreef in bericht
news:45df2401$1@news.povray.org...
> to show it off is on a completely *white* background. Because while it's
> easy to make something look impressive on a black or starry background,
> perhaps with sparse lighting, you *know* that it's a good model if you can
> show it on a white background and it *still* looks fabulous. Then you can
> always put in the black background and moody lighting later. Just a
> thought.
That is an interesting notion, and certainly true. Never thought about it
that way.
Thanks Rune!
Date: 24 Feb 2007 16:40:43
Message: <45e0b0db$1@news.povray.org>
Just when you think you at least *know* about all the main
objects and concepts ... I completely overlooked light_groups.
Thanks for mentioning, they sound quite useful ;)
Date: 24 Feb 2007 17:00:48
Message: <45e0b590@news.povray.org>
Ben Chambers wrote:
> www.imp.org
That's a nice idea. But either I got lost navigating the site,
or the only project completed since 2003 is a 15 second logo
for the site itself?
Date: 24 Feb 2007 17:20:01
Message: <web.45e0b9cda626085a47d3ae5e0@news.povray.org>
My thoughts excactly! :)
And very nice detailed ship!
Date: 24 Feb 2007 18:49:47
Message: <45e0cf1b$1@news.povray.org>
>> > to
> My thoughts exactly! :)
Thanks for all the comments. Its nice to be appreciated!
light_groups only work properly if you put the light_sources directly in the
light_group. They don't work properly if you put your lights inside a CSG
like a union as I usually do...
Taking an example scene with two union, one of which has some internal
lights...
union
    light_source{...}
    light_source{...}
union
In the following example this will work and render much faster...
light_group
    union
    light_source{...}
    light_source{...}
union
But in the following example this will work (i.e. the lights will only apply
to the first union) but render in the same time as the first example...
light_group
    union
        light_source{...}
        light_source{...}
union
Rarius
Date: 24 Feb 2007 18:55:31
Message: <45e0d073$1@news.povray.org>
"Rune" <new### [at] runevisioncom> wrote in message
> thought.
    Nice tip Rune! Thanks! Will give it a try.
       ~Steve~
> Rune
Date: 24 Feb 2007 19:42:26
Message: <45e0db72@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:45e0d073$1@news.povray.org...
>> can
>> thought.
>       ~Steve~
Ask and you shall receive... I have re-rendered it with a white background
and more lighting...
Rarius
Download 'battlestar.jpg' (96 KB)
Date: 24 Feb 2007 22:05:03
Message: <45e0fcdf$1@news.povray.org>
Christian Froeschlin wrote:
> Ben Chambers wrote:
>> www.imp.org
Nah, the Web site needs work.
Go to the IMP Farm Statistics, and you can see *some* of the past
completed jobs.
And the forums are still active - posting there would be very welcome.
...Chambers
Date: 25 Feb 2007 04:02:06
Message: <45e1508e$1@news.povray.org>
"Rarius" <rar### [at] rariuscouk> schreef in bericht
news:45e0db72@news.povray.org...
Aah! The ship in all its glory!
That looks pretty well detailed to me. I like the hull texture in
particular.
Excellent work for an all CSG product!
