Here is an image with Tek's rough sea, and my Moray built VOC ship (in need
of an upgrade!). Only the flags were not rendered due to a uv_mapping issue
in version 3.7.
total render time (v.3.7) about 2 hours, with a HP Media Center PC; Pentium
D 2x3GHz
Not the most perfect scene, but just to show off :-)
Download 'Tek_RoughSea.jpg' (161 KB)
Preview of image 'Tek_RoughSea.jpg'
> in version 3.7.
> D 2x3GHz
> Thomas
Nice Thomas, but…
Is there some problem with the transparency of the sea at the prow of the
ship?
The waves look like the wind is blowing from the left of the photograph :-)
but the ships sails are filled from the back and it is leaning to the
starboard and into the waves.
stephen
> in version 3.7.
> D 2x3GHz
Wow! This image could very likely become poster worthy! Keep it up!
I'd like to use Tek's sea combined with Jaime's Project Tierra (a la 'Clean
Slate'), then render it MegaPOV XRS, just to show off :-) But you're way
ahead of me :-)
Rock on,
George
http://www.gammaburst.net
> Thomas
> in version 3.7.
> D 2x3GHz
> Thomas
NICE!
I like the ship, I like the sea.. sky needs to change....
And... I wanted to mention earlier but I forgot to... the transparency seems
to high for this kind of water.
Thanks guys!!
Yes, like you all mention, there are all kind of problems showing here. This
was just a quick render so see how the ship would perform/look.
Stephen:
Yes, what you see probably, is the prow coming out of a wave. But there seem
also to be some spray in front. It looks kind of weird indeed.
And yes, the waves seem to come from the left. So the ship is tacking upwind
:-) I'm kidding. In this situation the sails should at least be turned the
other way round. And the ship leans the wrong side. Liek I said, I didn't
know how the environment would look...
George:
Thanks. No, this is nothing really special :-) Just experimenting to see how
things would look. I wait for your XRS!!!
EagleSun:
Thanks too. Transparency: see also Stephen's. I don't think transparency is
an issue, but I have other colors in mind... The ship is rather basic (I
think now, not when I built it!). The sky is Tek's. Could be something else
of course.
> Thanks guys!!
> Stephen:
Now you know which way the sea is running you can place your ship
accordingly. Don’t worry about the other comments I’ve had a rough day at
work :-)
Our IT department lost my network drive then managed to lock me out of the
network for 4 hours. You just can’t get the staff nowadays.
An angry sea like that deserves an angrier sky. Having said that... I like
it! :)
Dan
GoofyGraffix.com
Thomas de Groot spake:
> need of an upgrade!). Only the flags were not rendered due to a uv_mapping
> issue in version 3.7.
> Pentium D 2x3GHz
> Thomas
Ooooo.....
Stefan Viljoen
Polar Design Solutions
"Stephen" <mcavoys_AT_aolDOT.com> schreef in bericht
news:web.45632933a1eb5d8bf1cb1e660@news.povray.org...
> accordingly. Don't worry about the other comments I've had a rough day at
> work :-)
> network for 4 hours. You just can't get the staff nowadays.
Aah, the good old days of quill pens and ink, scratching slowly but
determinedly on seasoned parchments!! :-)
> > work :-)
> Thomas
Humph!
Now you’re showing your age :-) I only go back as far as dip pens
news:web.45643206a1eb5d8bf1cb1e660@news.povray.org...
> Humph!
> Now you're showing your age :-) I only go back as far as dip pens
<cackle! cackle!> Just only 1..60 years old, young man!
Experimenting further.
To align apparent wind direction and ship behaviour, I mirrored the
isosurface's function around x. Of course, I could have turned the ship, but
that is the easy way out and I prefer to experiment.
What I did was change: f_ridged_mf( (x+y*.2)/4, Q+y*.4, z/4, etc. into:
f_ridged_mf( ((x+y*.2)/4)/-1, Q+y*.4, z/4, etc
and: (f_spotted(x/5+y/5, 0, z/5)-.5)*1 into: (f_spotted((x/5+y/5)/-1, 0,
z/5)-.5)*1
To stay on the save side, I added the parenteses before multiplying by -1.
This should be faster than mirroring the isosurface itself. But maybe this
introduces unwanted things. What do you think?
Download 'Tek_RoughSea.jpg' (180 KB)
> z/5)-.5)*1
> Thomas
The sea looks very different, most of the white horses have gone and the
foreground is smooth. Quite reflective in fact. But then you’ll have
noticed that yourself.
What does the scene look like if the camera is placed on the other side of
your ship, should it not look like the way it was before?
news:web.45644c0da1eb5d8bf1cb1e660@news.povray.org...
>> Thomas
> foreground is smooth. Quite reflective in fact. But then you'll have
Yes, you are right! I just discovered a moment ago that I forgot to mirror
the function in the texture too!! :-(
That accounts for the loss of white horses. A new image is being brewed on
the POV burner. I shall post it later this afternoon. From what I can
already see, the white horses are back!! :-)
One reason why I did not want to move the ship (or the camera, for the time
being) is that I like the light incidence on it. However, it is mainly
because I want to play a bit with the functions and see what happens in the
present context.
I don't know, presently about the foreground. There seems to be a large
swale here. Later I shall lift the camera to see how it looks from above and
if this is recurring elsewhere.
Oh! We learn by our mistakes and I’ve learned a lot :-)
One other thing in the original post of the modified scene you said that you
multiplied by -1 when you actually divided by -1. I know the results are
the same (I hope) is there any particular reason?
Actually there were two other things. On my works monitor the image looks a
little washed out, what gamma settings are you using?
> present context.
> Thomas
news:web.456458a1a1eb5d8bf1cb1e660@news.povray.org...
> Oh! We learn by our mistakes and I've learned a lot :-)
> you
Ah! According to the documentation (c paragraph 2.3.3.3.9) transformations
on functions are different. So multiplying x by 2 is given as (x/2, y, z).
See the docs for more details. This is a very important paragraph because it
allows you to manipulate the functions as you want. It helped me enormously
in building my Geomorph macro a couple of years ago (see:
http://povray.tirnalong.com/ow.asp?GeoMorph ).
> a
I have the same when first viewing the image in WindowsExplorer for
instance. Saving it again in PSP without doing anything generally takes care
of the problem. It come from the new gamma handling in version 3.7. It has
been replaced by display_gamma in the ini, and set at 2.2. If I read the
docs right, presently 'assumed_gamma = 1' is automatically translated to
'display_gamma = 2.2' but I am not sure about this. Still a thing to
investigate.
> > you
That makes sense to me <g> I don't do hard things.
> > a
> investigate.
Interesting, Thanks
> in version 3.7.
> D 2x3GHz
> Thomas
Nice pic, but the captain will be court martialed and keel hauled for
running full sail in that kind of weather merely to appease your artistic
vision!
On Wed, 22 Nov 2006 13:27:04 +0100, "Thomas de Groot" <t.d### [at] inter nlDOTnet>
>> Humph!
>Thomas
Young man! Why thank you. You "silver surfer". you :-)
I'm not far behind you only 4 years.
Regards
On Wed, 22 Nov 2006 16:02:36 +0100, "Thomas de Groot" <t.d### [at] inter nlDOTnet>
>investigate.
FYI
At home using my laptop I need to do a gamma correction of 0.38 with PSP. It
then looks dramatic & great.
Regards
"gonzo" <rgo### [at] lanset com> schreef in bericht
news:web.4564a442a1eb5d8ba0c272b50@news.povray.org...
> vision!
Well, you know how it went in those days: the captain was subject to the
official VOC trader onboard (in this case, me) who told him what to do! They
often hated each other, but in most cases things went well.
"Stephen" <mcavoysATaolDOTcom@> schreef in bericht
news:a0e9m29nki4bu5ei6rbij87smtouu27frh@4ax.com...
Ah ha!!! Still the prerogative of age!! :-)
news:pqe9m2d6nep75994s9fhm5lujkolg35k5b@4ax.com...
> FYI
> It
Interesting.
I shall have to investigate this somehow. At this stage I can tell the
following (just using the current v.3.6 global settings and rendering in
v.3.7):
- 'As is', the image looks fine in the render window;
- in the viewer of Windows Explorer, the image looks washed out;
- in PSP, the image looks fine, identical to the render window;
- saving the image in PSP (without changing anything) and opening it in the
WinEx viewer, the image looks fine;
Now, of course, this is all on one machine. I have not (yet) tested it by
opening the image on another PC.
Subject: Re: Tek's sea revisited - third visit
Date: 24 Nov 2006 08:03:55
Message: <4566edbb@news.povray.org>
I keep being fascinated by Tek's rough sea.
This is a third visit to that region. Just playing around. The only thing I
changed here is cancelling the -30*y rotation of the isosurface in Tek's
original code.
Imo, the issue now is one of scale with the ship. I think that the ship
should be somewhat larger. On the other hand, the image is quite dramatic
with the ship plunging in the trough between two waves. In the forefront,
there is also what appears to be a trough.
Download 'Tek_RoughSea_03.jpg' (53 KB)
Preview of image 'Tek_RoughSea_03.jpg'
> original code.
> Thomas
Yes!
Running afor the wind with all sails set.
