The concept was simple: a stone block sitting in a pool of rippling
water, with some assorted glassare on top.
Well, I made the pool and the stone block. But, as you can see, the
results were pittiful to say the least. (The last two even use an
extremely slow volumetric cloud algorithm - not that you can tell!)
I despare sometimes. I can't made even the simplest thing look *good*!
>_< This just looks pathetic...
Can *anybody* tell me how to make this look cool like everybody else's
renders do??
Download 'glassware01.jpg' (91 KB)
Download 'glassware02.jpg' (82 KB)
Download 'glassware03.jpg' (63 KB)
Download 'glassware05.jpg' (51 KB)
Download 'glassware06.jpg' (93 KB)
Preview of image 'glassware01.jpg'
Preview of image 'glassware02.jpg'
Preview of image 'glassware03.jpg'
Preview of image 'glassware05.jpg'
Preview of image 'glassware06.jpg'
"Orchid XP v3" <voi### [at] dev null> a écrit dans le message de news:
452791f9@news.povray.org...
> renders do??
did you visit Christoph's water tutorial ?
http://www.imagico.de/pov/water/index.html
Marc
>> renders do??
No - but thanks for the link...
Well I have a few suggestions:
1/ a perfect cube always looks very fake, use a slightly irregular shape
like a superellipsoid or isosurface
2/ it's easy to say this after the fact, but the human eye is extremely
forgiving of reflections in bumpy surfaces, so you really shouldn't worry
about making a complex sky, just something flat that has the right colours.
But it sounds like you learnt this the hard way.
3/ think about the size of the ripples regarding the scale of your scene,
these ones are huge but smooth (particularly in the last image). Smooth
usually means very small ripples, which would make the stone block about 1cm
big! I'd suggest use much much smaller ripples, so the surface is nearly
flat. if you want a dramatically wavey surface for this scale you need
something less smooth, the wrinkles pattern is sometimes pretty good for
this, or granite (inverted to make spikey waves).
4/ water material - a physically correct water is simply: pigment{rgbt
1}finish{reflection{0,1 fresnel}}interior{ior 1.33 fade_colour ...
fade_power 2 fade_distance ...}, there's a lot of tweaks you can do but that
should get you something good. Basically it's transparent, refractive, the
reflections obey fresnel so there's no need to tweak them, and if you want
to colour it you should use fade_colour not pigment because the colour
should be throughout the material not just at the surface.
5/ stone material - always reference a real material, in your present scene
I can't tell if it's meant to be a polished stone like marble, or a more
natural rough finish. A realistic rough finish is easier: just give it a
noisy normal, like normal { granite -.2 }, and no specular or phong. A
realistic smooth finish is difficult because smooth things look fake in CG,
I'd suggest choosing a stone with a very distinctive pattern, like marble or
something. And on that topic note that pov's granite pattern looks more like
marble than the marble pattern...
6/ use global_settings { assumed_gamma 1 }, it screws up all the colours in
the scene so you'll need to adjust them, but it make reflections and
lighting look more realistic.
Hope that's helpful and not patronising :)
I'd be happy to knock together an example scene of how I'd do it if you
think it would help?
Tek
http://evilsuperbrain.com
"Orchid XP v3" <voi### [at] dev null> wrote in message
news:452791f9@news.povray.org...
> renders do??
"Tek" <tek### [at] evilsuperbrain com> wrote in message
news:4527ad2a@news.povray.org...
> that should get you something good. Basically it's transparent,
> refractive, the reflections obey fresnel so there's no need to tweak them,
> and if you want to colour it you should use fade_colour not pigment
> because the colour should be throughout the material not just at the
> surface.
Doh! and of course use conserve_energy in reflections, that's vital!
Tek
Cube is a placeholder, yes. I was attempting to get the stone texture
and the water to look right first. (I intend to replace it with a
rounded cube later.)
I only used the complex volumetric sky because I already had one from
another scene that had the right colours, and I couldn't come up with a
static pigment with anything approaching the right colours.
For my trouble, I ended up with an entire scene that's bright blue. (Why
does the real world not do this BTW? The real sky is blue...)
OK. I'm currently investigating Christoph's waver macro. Seems to
produce big fractal-like waves. (I'd actually like the ripples to
radiate from the stone block and follow its shape eventually...)
The water *itself* is a fairly simple thing, as you say. It's
transparent, refractive and reflective. So basically it doesn't look
like anything by itself... gotta have something nice to reflect.
My main problem seems to be getting a decent sky. :-S
The look I'm eventually going for is water-polished rock. Maybe
limestone or something. So I probably just need to make it look slightly
lumpy... and get better colours...
I wouldn't have thought assumed_gamma 1 would have *any* effect...
surely that just means that each colour component is raised to the power
of 1 before being output?
news:4527b397$1@news.povray.org...
Spheres usually make better placeholders when tweaking materials IMO, the
hard edges of the cube mean you don't see how it interacts with the light at
all angles, making it very hard to tune effects like specular.
Well if you want ripples radiating from the block why are you looking at a
macro for fractal like waves?
Radiating from a block is a bit awkward, I suggest basing it on a function,
like:
normal { function { sin(8*pi*sqrt(pow(max(x-1,0),2)+pow(max(z-1,0),2))) } }
that should give nice "distance from a square" based ripples, though if you
plan on changing the shape of your stone it might not look so good.
Nope I disagree, if you have a realistic water material from this angle it
would be almost completely transparent, the reflection would only show up on
the top edge of the ripples (see attached picture). What's important is the
fall-off of the reflection, which should be either reflection{.01,1 falloff
5} to fake it or reflection{0,1 fresnel} if you have a realistic ior.
Yeah that confused the hell out of me when I first encountered it. The
simple answer is that pov knows what your display gamma is, or rather it has
a default of 2.2. If you don't say "assumed_gamma" it doesn't gamma correct
from the linear colour space of the pov scene to the non-linear gamma of the
monitor. assumed_gamma essentially tells pov what the gamma space of your
scene is, which is a very bizarre thing to do since pov does linear
calculations on light so by definition it has a gamma of 1, it's very
counter intuitive but it works!
Anyway I couldn't resist the urge to have a go at a similar scene myself, so
here's a picture and the source is in p.b.s-f. Most importantly note that
the reflection on the water is very subtle, without the ripples you'd hardly
see the water surface at all.
Tek
Download 'rock mat test.jpg' (62 KB)
Preview of image 'rock mat test.jpg'
I guess so...
Because it works by placing multiple concentric rings of ripples
semi-randomly. Now if I place the centers of those ripples to coincide
with the edges of the block, the ripples will follow its outline. (This,
apparently, is how the Real World(tm) works...)
Mmm, OK. In that case, my water is going to be completely black...
Is IOR=1.3 "realistic"?
Here's a random question: does LCD require gamma correction?
0__0
OMG... you created something 17,826% better than what I had in about 20
seconds!
Orchid XP v3 nous apporta ses lumieres en ce 07/10/2006 11:16:
>> the hard edges of the cube mean you don't see how it interacts with
>> the light at all angles, making it very hard to tune effects like
>> specular.
> I guess so...
>> at a macro for fractal like waves?
>> angle it would be almost completely transparent, the reflection would
>> only show up on the top edge of the ripples (see attached picture).
>> What's important is the fall-off of the reflection, which should be
>> either reflection{.01,1 falloff 5} to fake it or reflection{0,1
It is, it's close to the real ior of water. Pure water ior is 4/3. Salt or sea
water's ior is close to 1.4.
>> myself, so here's a picture and the source is in p.b.s-f. Most
>> importantly note that the reflection on the water is very subtle,
>> without the ripples you'd hardly see the water surface at all.
> 0__0
> seconds!
Fade_power should be 1 to be physicaly correct. A value of 2 is perfect for a
light source, double the distance and get 1/4 the lighting, not for fading
trough some substance. Light absorbtion trough a substance is linearly
proportional to the thicknessm, double the thickness and the effect double, it
don't quadruple.
Any way, for water, fade_distance is relatively large.
No matter how good she looks, some other guy is sick and tired of putting up
with her shit.
Men's Room, Linda's Bar and Grill, Chapel Hill , NC
"Alain" <ele### [at] netscape net> a écrit dans le message de news:
4527c96f$1@news.povray.org...
for a
double, it
> don't quadruple.
I don't agree about fade power in water :
daylight rays have to get twice (down and back up) through water before
reaching your eye so double the depth quadruple the thickness
Marc
> for a
> double, it
>> don't quadruple.
That's still linear.
If it was quadratic, 3x the depth would be 9x the darkening. By your
reasoning, it would be 6x.
Note also that POV-Ray will see that the light passes through the water
twice and darken it twice anyway, so you only need fade_power=1...
"Marc" <jac### [at] wanadoo fr> wrote in message
news:4527d21c@news.povray.org...
I think pov will simulate that implicitly anyway, because the shadow cast by
the water onto stuff underneath tints the daylight falling on the underwater
objects, then when we look at them through the water we get more tinting.
But if we're looking at a flat coloured ambient object the amount of tinting
just depends on it's distance from us.
Also I believe the power can be between 1 & 2 for realistic effects, since
the particles of fog can occlude each other... or something. I remember
figuring all this out once but the pov docs say between 1 & 2 so I'll defer
to their judgement :)
Anyway if you want it to look totally right I suggest scattering media...
Tek
> > > the power of 1 before being output?
Yes, PC LCDs are designed specifically to match the response of CRTs.
> > about 20 seconds!
> perfect for a light source, double the distance and get 1/4 the
> lighting, not for fading trough some substance. Light absorbtion
> trough a substance is linearly proportional to the thicknessm, double
> the thickness and the effect double, it don't quadruple.
Physically correct is exponential isn't it? ie a certain % of the light
gets attenuated each unit distance. If a certain distance only lets 10% of
the light through, then you'd expect 1% after double the distance, 0.01%
after 4x etc.
You are correct, but this power is applied within an exponential curve. I
think it's like exp(-x) vs exp(-pow(x,2)), IIRC. we were debating the power
part without mentioning the exp part... or at least that's what I think was
being discussed!
Tek
"scott" <ask### [at] me com> wrote in message news:4528e243@news.povray.org...
>> > about 20 seconds!
> of the light through, then you'd expect 1% after double the distance,
> 0.01% after 4x etc.
> curve.
I don't think it is, read section 3.6.1.6 of the documentation.
"scott" <ask### [at] me com> wrote in message news:452909e1@news.povray.org...
>> curve.
Ah okay, well a 1/x curve...
Anyway, I dunno what's physically correct, but it looks good enough :-)
Only because no-one has mentioned it yet:
Water will tend to look more realistic with some land underneath it.
Also, try using an image_map on a sky_sphere for your clouds.
Actually, water really *is* blue. Sky reflection contributes little to the
color of the sea. As someone else mentioned, water reflects the sky color
significantly only at shallow angles, due to the Fresnel effect. It's only
a coincidence that the sky and water are similar colors.
The sky looks blue due to Reyleigh scattering; whatever light is *not*
scattered into the is still present in the direct sunlight. By contrast,
water absorbs (removes) light preferentially from the red end of the
spectrum, leaving blue and green to illuminate the scene. That's why
underwater scenes (without camera lights) look blue, whereas objects on
land do not. Also, shallow water looks greener than deep water because
water absorbs green faster than blue.
The reason a glass or a bathtub full of water looks completely clear is that
water absorbs very little light. If your bathtub were as big as a pond, the
water would be bluish.
In Real Life, bodies of water contain particulates, which often dominate the
color of the water. The slow-moving water at the lower ends of rivers looks
brown because of the silt mixed in. The water of cold ocean currents
contains a lot of plankton, giving it somewhat of a dark greenish cast.
Some rivers contain tannin, which literally dyes the water a reddish-brown
color.
BTW, from what little i know of these things, fade_power 1 seems to make
sense for absorption. (Point light sources, of course, are subject to the
inverse square law, i.e., fade_power 2. The formula POV uses isn't quite
inverse square, but i have a feeling that the Team did it that way to
compensate for the limited dynamic range of the output.)
It doesn't make a great deal of difference in rendering terms, but the
physically correct version is usually
fade_power 1000
which triggers the use of exp(-x/D). You tend to see more of the fade_colour
with it than with fade_power 1 or 2.
The exponential comes from Beer's law, which holds for simple homogeneous
materials that don't absorb incredibly strongly (like water).
Tom
OMG... water is blue due to *beer's law*? LMAO!
Gah! >_<
Why don't they just make everything linear like it should be?
OMG! It actually works... I put some stuff *under* the water and made
the water completely transparent to completely reflective with fresnel
reflection, and suddenly it looks cool! o__O
That's amazing! Heh.
The sky is just plain blue, and it still looks good...
news:452be6a1$1@news.povray.org...
Well the human eye isn't linear, so if you make a linear display device you
end up with horrible colour banding even in 24-bit colour.
And I could make that answer a lot longer if I wanted to... don't tempt
me... ;-)
Tek
