POV-Ray : Newsgroups : povray.binaries.images : water bug (41kb) Server Time
29 Nov 2026 14:52:40 EST (-0500)
  water bug (41kb) (Message 1 to 15 of 15)
Subject: water bug (41kb)
Date: 2 Oct 2006 19:43:41
Message: <4521a42d@news.povray.org>
Hi everyone, just wanted to share this image I came up with. The
creature was modeled with LightWave and rendered in two passes with POV.
The first pass was rendered in 31 minutes, 54 seconds using POV-Sub (the
subdivision surface patch). This allowed me to keep the initial mesh
object very small, thus saving hard-disk space (parsing might have even
been faster, too).
The second pass was rendered 11 minutes, 7 seconds with the official
version of POV. This added the glare effect you see coming off the
creature's head.
My initial attempt at rendering this in LightWave was a little
disappointing, because there is no good-looking SSS shader for the
version I use.
Comments always welcome....
~Sam
P.S. The file for the glare effect is available upon request.
Download 'waterbug.jpg' (41 KB)
Preview of image 'waterbug.jpg'
Subject: Re: water bug (41kb)
Date: 2 Oct 2006 19:54:24
Message: <4521a6b0$1@news.povray.org>
Looks awesome! Some floating particles would make it look really
convincing...
> been faster, too).
Hm, that should be tested sometime. I use Silo for modelling, that's a
very cheap but awesome subdivision surface modeller. If subdividing
directly in POV is better than loading a big mesh, I wouldn't mind. :-)
> creature's head.
Probably just a simple pigment with a high specular, or what? Still
quite a long render for just the glare. Am I missing something? Media?
You got mine! ;-)
Do you do it like I do? Render a specular pass, blur it using average,
and layer it on top of another image? Looks good anyways. Any tricks
involved that my description lacks? Always eager to learn! :-)
aka "Tim Nikias"
Date: 3 Oct 2006 01:26:54
Message: <4521f49e@news.povray.org>
How did you get the glare effect?
-Nekar Xenos
"The truth is out there"
Date: 3 Oct 2006 03:23:43
Message: <45220fff@news.povray.org>
How did you do the glare?
-Nekar Xenos
Date: 3 Oct 2006 04:18:12
Message: <45221cc4$1@news.povray.org>
"Nekar" <ger### [at] rpmmagcoza> a écrit dans le message de news:
45220fff@news.povray.org...
Alzheimer yet? ;-)
Marc
Date: 3 Oct 2006 07:25:21
Message: <452248a1@news.povray.org>
I sent the message and nothing showed up, so I sent it again. I can only see
one message from OE now.... :op
Nekar
Date: 3 Oct 2006 12:08:42
Message: <45228b0a$1@news.povray.org>
It looks very fine.
I would now, for the final touch, add some microscopic elements (plancton)
to the water in the background. Some sharper, some blurred. Different kinds.
And maybe the idea of a distant nearly not recognizable underwater surface.
Greetings,
Sven
Date: 3 Oct 2006 16:38:00
Message: <4522ca28@news.povray.org>
That's one simple, but very nice render.
Date: 3 Oct 2006 20:29:03
Message: <4523004f@news.povray.org>
> convincing...
Thanks! I plan on adding some particles, but it's going to make the
render time higher than it would normally.... the translucent effect
isn't very lenient as far as other scene objects go. When I add more
(non-translucent) objects to the scene, the effect becomes diminished
unless I wrap everything in merge brackets. Very annoying.
There is a version for POV 3.6. You should check it out.
> quite a long render for just the glare. <>
<edit>
Close, I use the rendered scene as input for the effect. It is averaged.
Attached is the sample pattern for the effect. Q stands for quality. Q =
1 is the maximum, and uses about 236-237 samples, so there is some
improvement to be made, yet. I will soon be posting the glare effect
file to p.b.scene-files.
> You got mine! ;-)
And it is appreciated :)
~Sam
Download 'lb_chart.png' (8 KB)
Preview of image 'lb_chart.png'
Date: 3 Oct 2006 20:36:06
Message: <452301f6$1@news.povray.org>
I made a scene-file which takes a pre-rendered image and adds the effect
to it. I posted the file to p.b.scene-files
~Sam
Date: 3 Oct 2006 20:37:14
Message: <4523023a$1@news.povray.org>
Sven Littkowski wrote:
> It looks very fine.
> Greetings,
> Sven
I will add particles, but will render it sometime.... later. I'll most
likely post it directly to my website.
~Sam
Date: 3 Oct 2006 20:37:35
Message: <4523024f@news.povray.org>
Thanks!
~Sam
Date: 7 Oct 2006 09:28:58
Message: <4527ab9a@news.povray.org>
----- Original Message -----
Newsgroups: povray.binaries.images
Sent: Wednesday, October 04, 2006 2:30 AM
Wouldn't it be more realistic combining a heavily focal blurred scene with
the original in almost the same way you did this?
/* Nekar Xenos */#local N=<-20,40,100>;#local K=<20,-40,100>;#local
R=seed(0);
blob{#while((K-N).x>0)#local X=N;#local N=N+<rand(R),rand(R),1>/3;#local N=(
vlength(N-K)<vlength(X-K)?N:2*X-N);sphere{<N.y,-N.x,N.z>,1,1 scale
.02}sphere{N
,1,1 scale.02}sphere{<-N.x-40,N.y,N.z>1,1
scale.01}sphere{<N.x+40,-N.y,N.z>1,1
scale.01 }#end pigment{rgbt 1}interior{media{emission <2,4,5>*5}}hollow}
Date: 7 Oct 2006 14:09:48
Message: <4527ed6c$1@news.povray.org>
For the glare effect? Or to add particles?
~Sam
Date: 10 Oct 2006 02:27:08
Message: <452b3d3c@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
news:4527ed6c$1@news.povray.org...
>> with
For the glare effect. Are you blrurring the scene and mixing the blurred and
unblurred images together to get that efect? If so, how about using focal
blurr instead, because in real life the amount of glare depends on how far
you are from the object. Take for instance a light globe: from close-up the
filament is visible, but from further away only the glare of the light can
be seen.
-Nekar Xenos
