POV-Ray : Newsgroups : povray.binaries.images : Eavesdropping WIP - radiosity issues Server Time
29 Nov 2026 13:30:28 EST (-0500)
  Eavesdropping WIP - radiosity issues (Message 21 to 32 of 32)
<<< Previous 20 Messages Goto Initial 32 Messages
Subject: Re: Eavesdropping WIP 07 - Testing error_bound settings
Date: 16 Sep 2006 06:16:21
Message: <450bcef5@news.povray.org>
This is a test with the two settings for error_bound, all other settings
being equal. The images here are uncompressed jpg.
the image to the left, is the original one, with:
error_bound 0.5 //first pass
error_bound {0.1 adaptive 1.5, 20} //second pass
The image to the right has the settings:
error_bound {0.5 adaptive 1.5, 20} //second pass
samples for this image were:
Radiosity samples calculated:             1124 (0.03 %)
Radiosity samples reused:              3571781
  Samples (final trace)                   1124
  Samples (recursion 1)                    188
  Samples (recursion 2)                    936
and render time about 20 minutes.
The image to the right is the better of the two IMO.
Download 'Eavesdropper_wip7test.jpg' (357 KB)
Preview of image 'Eavesdropper_wip7test.jpg'
Date: 16 Sep 2006 08:44:47
Message: <450bf1bf$1@news.povray.org>
I like your image, but I find one thing odd...
the eavesdropper is looking almost directly
into the sun.
Date: 16 Sep 2006 08:50:49
Message: <450bf329$1@news.povray.org>
"Tim Attwood" <tim### [at] comcastnet> schreef in bericht
news:450bf1bf$1@news.povray.org...
> into the sun.
Yes, well he could not choose his spot obviously :-) Must certainly be
unconfortable, to say the least...
Subject: Re: Eavesdropping WIP 07 - better radiosity
Date: 16 Sep 2006 12:35:05
Message: <eeh8se$l4e$1@chho.imagico.de>
Thomas de Groot wrote:
> Thanks Christoph. I much appreciate your comments as I feel that I still
> have a lot to learn about this matter. Forgive me if I seem obtuse, but I
> find this a difficult matter to understand, despite the excellent tutorials,
> by the way, of you and others.
> Let's see if I get this correctly.
> Concerning error_bound, what I should do is (for instance):
> OK? The quality of the results might then dictate using 0.5 or lower (or
> higher, to see where acceptable boundaries are).
Yes, you should notice however that the interaction between those
settings can be quite complicated and especially error_bound (which is
relevant both when taking and when reusing samples) can have quite
unexpected effects.  So it is possible that what you used has some
positive effect in some situations.  It would be a pretty advanced
experiment however. :-)
> My initial assumption was that by making error_bound adaptive (at least in
> the final pass) megapov would determine automatically what the necessary
> values were, thus gaining time and quality.
Error_bound is a user quality setting - there is no way for POV-Ray to
determine it automatically.  What the adaptation does is modifying the
error_bound to avoid taking additional samples.  But as said the
interactions with other settings are complicated so the influences on
the render results can be as well.
http://www.imagico.de/ (Last updated 20 Aug. 2006)
Date: 16 Sep 2006 12:50:28
Message: <450c2b54@news.povray.org>
"Thomas de Groot" <t.d### [at] internlnet> wrote in message
news:450bb0c8$1@news.povray.org...
> "St." <dot### [at] dotcom> schreef in bericht news:450ae56f$1@news.povray.org...
>>     But, you've got to do something about that texture (on the lower
>> pillars), because it looked SO good in your other image!
 (The rad artefact image).
Perhaps some kind
>> of procedural crackle might do it? (Not sure).
> Steve, I am not sure I get your meaning.
   I'm just saying that what happened with the rad artefacts is exactly what
you want for those pillar textures, that's all. Now replicate them somehow.
     ~Steve~
> Thomas
Date: 16 Sep 2006 13:05:46
Message: <450c2eea@news.povray.org>
Also, (and I'm not being picky here), compared to the people, that rope is
a heavy rope - and it should be laying flat against the ground (where the
sunlight hits it).
   ~Steve~
Date: 17 Sep 2006 03:16:24
Message: <450cf648$1@news.povray.org>
"St." <dot### [at] dotcom> schreef in bericht news:450c2eea@news.povray.org...
> is a heavy rope - and it should be laying flat against the ground (where
> the sunlight hits it).
Arrgh!!! You noticed!!! :-(
Yes, you a re perfectly right. That comes from the difficulty to get the
rope coming from the ceiling, to bend correctly and lie flat. Either I
should add more control points to the spline, or make two separate ropes. It
is something I have still to do.
Date: 17 Sep 2006 03:18:58
Message: <450cf6e2@news.povray.org>
"St." <dot### [at] dotcom> schreef in bericht news:450c2b54@news.povray.org...
> what you want for those pillar textures, that's all. Now replicate them
> somehow.
Yes, I see... Well, I am not that happy about the idea of an 'artifact'-type
texture. I prefer something smoother ans mor subtle.
But the idea is still an interesting one. I have to think about alternatives
for other scenes :-)
Subject: Re: Eavesdropping WIP - radiosity issues
Date: 18 Sep 2006 05:55:04
Message: <450e6cf8@news.povray.org>
Hi Thomas:
   Not what you asked for, but I've a composition comment: I think the
"eavesdropping" effect would be even better if you can make the figure
pose more like if it were trying to hide behind the column, perhaps
leaning on the column with the left hand?
   Great work...
Jaime
Date: 18 Sep 2006 10:08:09
Message: <450ea849$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> schreef in bericht
news:450e6cf8@news.povray.org...
> Hi Thomas:
>   Great work...
Thank you Jaime!! Much appreciated!!
Yes, you are right and I am working on a version where the figure is indeed
leaning on the column like you suggest. I think it was Janet who said
something in the same line a couple of wips ago. These wips were mainly to
solve the radiosity and other problems (the rope for example, which is now
solved).
I am now going to work seriously on the figure again.
Date: 20 Sep 2006 06:50:01
Message: <web.45111c65c506d8bc3caff7290@news.povray.org>
The composition is elegant, and the textures are very nice (always one of
your strengths), but I think the figures are still a little stiff *
stylised. Did you know Poser 5 is now available free? It was a big
improvement in naturalism over Poser 4. Poser 6 is even better, but the
bugs and technical problems make it very frustrating to use.
Date: 22 Sep 2006 03:35:00
Message: <45139224$1@news.povray.org>
"Joanne Simpson" <cor### [at] onewhiteravencom> schreef in bericht
news:web.45111c65c506d8bc3caff7290@news.povray.org...
Thank you indeed, Joanne! Much appreciated.
Yes, I am aware about the figures. To tell the truth, I did the poses
rapidly in Daz|Studio without too much thinking and more intuitively. There
certainly is much more room for improvement. If I am not too lazy and/or
taken up by other projects (like the IRTC).
I was aware of Poser 5 being free (until sept 4th; now it is sold very
cheap), but I hesitate (still) because I do not like to fill in a whole form
with personal info for ContentParadise's Passport.
I still can develop a lot more with Daz, but I'll have to reserve time for
that :-)
