POV-Ray : Newsgroups : povray.binaries.images : website buttons new versions Server Time
29 Nov 2026 15:25:27 EST (-0500)
  website buttons new versions (Message 1 to 3 of 3)
Subject: website buttons new versions
Date: 21 Aug 2006 05:50:39
Message: <44e981ef@news.povray.org>
Due to the bad weather in Belgium I found some time to work further on the
website buttons macro I started some time ago.
The macro can render now a set of buttons for a website using pov animation
(and a few days of patience on 512*384)
By the way: is there any way to change the name of the bmp output file in
the during rendering? output is now produced by the animation in
webbuttons00.bmp,webbuttons01.bmp etc. It would be more convenient for later
use of render output if I could name them something like button_<text inside
button>_blue_normalstate.bmp.
There is 2 versions pressed state with lights shining & normal  both
rendered with +-14 lights behind the text. Problem is that they take a long
time to render. Is there any way to speed up rendering with this amount of
lights.
I tried one version with radiosity with an emitting text behind the black
text, but I'm not really happy with the result. The way the light shines on
the side of the button seems unnatural to me. I like the backlight inside
the button though.
I don't know enough of radiosity I to find out how to improve it. Any
suggestions would be appreciated.
Radiosity settings are :
global_settings {
      max_trace_level 100
      assumed_gamma 1.25
      #if (Radiosity)
        radiosity {
              pretrace_start 0.04           // start pretrace at this size
              pretrace_end   0.002          // end pretrace at this size
              count  250                      // higher -> higher quality
(1..1600) [35]
              nearest_count  10               // higher -> higher quality
(1..10) [5]
              error_bound 2               // higher -> smoother, less
accurate [1.8]
              recursion_limit 3             // how much interreflections are
calculated (1..5+) [3]
              low_error_factor .5           // reduce error_bound during
last pretrace step
              gray_threshold 0.0            // increase for weakening colors
(0..1) [0]
              minimum_reuse 0.015           // reuse of old radiosity
samples [0.015]
              brightness 0.4                 // brightness of radiosity
effects (0..1) [1]
              adc_bailout 0.01/2
              //normal on                   // take surface normals into
account [off]
              //media on                    // take media into account [off]
              //save_file "file_name"       // save radiosity data
              //load_file "file_name"       // load saved radiosity data
              //always_sample off           // turn sampling in final trace
off [on]
              //max_sample 1.0              // maximum brightness of samples
      #else
Download 'webbuttons_radiosity3.jpg' (64 KB) Download 'webbuttons_normal1.jpg' (40 KB) Download 'webbuttons_normal2.jpg' (42 KB)
Preview of image 'webbuttons_radiosity3.jpg'
Preview of image 'webbuttons_normal1.jpg'
Preview of image 'webbuttons_normal2.jpg'
Subject: Re: website buttons new versions
Date: 21 Aug 2006 22:18:36
Message: <44ea697c@news.povray.org>
Johan Feyaerts nous apporta ses lumieres en ce 21/08/2006 05:50:
> Hi,
> lights.
> the button though.
> global_settings {
>       max_trace_level 100
>       assumed_gamma 1.25
>       #if (Radiosity)
>         radiosity {
You can try 0.00125 or 000625, but try other settings first.
> (1..1600) [35]
Need to increase still more. Go for 600 to 1000.
> (1..10) [5]
This one can go up to 20, worth a try
> accurate [1.8]
Try 1 or 2 as you way not need 3 interreflections
> last pretrace step
Lowering this may help
> (0..1) [0]
> samples [0.015]
You can try increasing this one by a SMALL value. Use steps no more than 0.001.
If increasing don't give better results, try smaller values, same step size.
> effects (0..1) [1]
>               adc_bailout 0.01/2
You may need to reduce some more.
> account [off]
> off [on]
>       #else
Unitarianism: Come let us reason together about this shit.
Date: 22 Aug 2006 15:45:00
Message: <web.44eb5cfa4c7c91a54daddc090@news.povray.org>
I've found the two most important factors in radiosity are 'count' &
'error_bound'.
Try this as your radiosity block:
radiosity{
  // pretrace_start 0.02
  // pretrace_end 0.005
  count 100
  error_bound 0.1
  // nearest_count 10
This should be reasonably neat and give you an indication of where things
are heading, but the low error_bound will make things blotchy.  To smooth
it out, you will need to increase 'count' to 300-500, increase
'nearest_count' to 10 and lower the 'pretrace_start' & 'pretrace_end'
values.
