POV-Ray : Newsgroups : povray.binaries.images : Sierpinski Pyramid Server Time
1 Jan 2026 21:01:29 EST (-0500)
  Sierpinski Pyramid (Message 1 to 4 of 4)
Subject: Sierpinski Pyramid
Date: 22 Jun 2006 07:40:34
Message: <449a81b2@news.povray.org>
I was bored, and the recursive torii post got me thinking of recursion,
so I made a simple macro that draws the Sierpinski Pyramid.  Before I
made this, I didn't know POV-Ray allowed macros to call themselves.
This particular image is built from 78,125 pyramids, each made using 6
triangles, for a total of 468,750 triangles, all wrapped up in a single
mesh with some radiosity, sky_sphere, and a plane tacked on.
(NOTE: I did some searching around...some places show the Sierpinski
Pyramid as having 3 sides on the base, others with 4.  4 was easier to
implement, so I used that.)
-DJ
Download 'sierpinksi.png' (239 KB)
Preview of image 'sierpinksi.png'
Subject: Re: Sierpinski Pyramid
Date: 22 Jun 2006 11:35:00
Message: <web.449ab7c455dc3319a620e4ec0@news.povray.org>
When you use a four-sided base, it makes the base (and all the mini-bases)
solid - this makes the structure look heavier/thicker - so there's some
artistic considerations to be made.
Recursive works for this - but random-walk is, IMHO, more fun ;)
Anyway, tasty stuff.
-s
5TF!
Date: 22 Jun 2006 13:36:49
Message: <449ad531@news.povray.org>
If you manage to make things like this when you're bored, I wonder what
creations you do if you are fully in rendering..?
Best greetings,
Sven
Date: 26 Jun 2006 08:40:01
Message: <web.449fd43b55dc33191bd1c060@news.povray.org>
Recursion is fun! Here's a similar pyramid in the Menger-Sierpinski family I
did late last year.
// Persistence Of Vision raytracer version 3.5 sample file.
// -F -A0.4 +AM2 +R1
// -D +A0.1 +AM2 +R4
// -d +A0.05 +AM2 +R3
// Auth: PM 2Ring
global_settings {
  assumed_gamma 1
  //max_trace_level 10
  #if(0)
  radiosity {
    pretrace_end 0.08
    always_sample off
  ambient_light 0
#include "textures.inc"
#declare RoomRad = 30;
#declare Do_Room = 1;
#declare Eye=<0, 5.0,-11>/sqrt(410)*RoomRad *.55;
  location  Eye
  right x*image_width/image_height up y
  direction z
  angle 40
  look_at   1.65*y
//light_source {Eye + <1,1,1> * .05 rgb .4}
light_source {<-7, 15, -12>/sqrt(113)*RoomRad * .7 rgb 1}
//---Textures------------------------------------------------------------------
#declare FMetal =
finish {
  ambient 0.02
  diffuse 0.35  *2
  //phong 0.65 phong_size 120
  specular .5 roughness 1e-4
  //brilliance 3
  //metallic
  //reflection {0.75 metallic}
  reflection {0.2}
#declare FShiny =
finish {
  ambient 0.05 diffuse 0.75
  specular .25 roughness 1e-4
  //brilliance .5
  reflection 0.175
#declare Checker =
texture{
  pigment { checker rgb 1 transmit 1, rgb 0.05 transmit .25 rotate 45*y
scale 4 }
  finish {FShiny}
//---Objects------------------------------------------------------------------
#declare RR = sqrt(.5);
#macro RBox(A,W,C,D)
  sphere{A, W*RR pigment{colour C}finish{FMetal}}
  //box{A, A+W pigment{colour C}finish{FMetal}}
  //box{A, A+W material{M_NB_Glass texture{pigment{colour C filter 1}}}}
  #if(D>0)
    #local WW=W/2;
    #local DD=D-1;
    RBox(A+x*W,WW, (C+x)/2,DD)
    RBox(A+y*W,WW, (C+y)/2,DD)
    RBox(A+z*W,WW, (C+z)/2,DD)
#declare RCrystal =
union {
  RBox(0, 2, rgb 1, 5)
  rotate <0, -225, 0>
  translate z*sqrt(2)
//The room
#declare Room =
union{
  sphere{
    0, RoomRad
      //rgb .55
      gradient y
      color_map {
        [0 rgb <0, 0, .1>]
        [1 rgb <.1,.2,1>*2]
      scale RoomRad/2
    finish{ambient .1 diffuse .5}
    //normal{granite .1 scale .02}
  #if(1)
  box{
    <-1, -1/RoomRad, -1>, <1, 0, 1> scale RoomRad
    //texture{White_Marble scale 2}texture{Checker}
    pigment{crackle solid} normal{crackle 1} finish{FShiny}
  hollow
  no_shadow
  translate -2*y
//---The
scene------------------------------------------------------------------
object{RCrystal}
#if(Do_Room)
  object{Room}
#else
  background {rgb .5}
Download 'rblockb2.jpg' (135 KB)
Preview of image 'rblockb2.jpg'
